I am new to Linux btw. I bjorked my installation up so I reformatted and reinstalled Manjaro KDE but now no audio at all.
Been there done that, I even have the T shirt. We were all new to Linux once.
Please supply additional information.
In the Terminal
inxi -zv8
Would be a good start. Use </> button at the top of the Edit Box, and place your result inside the multiple back ticks.
Kernel: 6.12.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=1a088ca0-14d2-461e-a050-3521a67eae58 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.14.0
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING v: Rev 1.xx
BIOS: American Megatrends v: 4301 date: 03/04/2021
System RAM: total: 16 GiB available: 15.54 GiB used: 2.33 GiB (15.0%)
Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: 2133 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMK16GX4M2B3200C16 serial: N/A
Device-2: DIMM_A2 type: no module installed
Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
Device-4: DIMM_B2 type: no module installed
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 0 microcode: 0xA20102D
desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 1752 min/max: 550/4851 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1752 2: 1752 3: 1752
4: 1752 5: 1752 6: 1752 7: 1752 8: 1752 9: 1752 10: 1752 11: 1752 12: 1752
13: 1752 14: 1752 15: 1752 16: 1752 bogomips: 121411
stibp succor svm_lock syscall tce topoext tsc tsc_scale umip user_shstk
v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
affected
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: Gigabyte driver: nouveau
v: kernel non-free: 550-570.xx+ status: current (as of 2025-04;
EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: DP-1 empty: DP-2,HDMI-A-1,HDMI-A-2
bus-ID: 08:00.0 chip-ID: 10de:2484 class-ID: 0300
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: nouveau gpu: nouveau display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
s-diag: 777mm (30.58")
Monitor-1: DP-1 model: Gigabyte G27QC serial: <filter> built: 2020 res:
mode: 2560x1440 hz: 165 scale: 100% (1) dpi: 109 gamma: 1.2 chroma: red:
x: 0.655 y: 0.333 green: x: 0.286 y: 0.635 blue: x: 0.149 y: 0.059 white:
x: 0.314 y: 0.329 size: 597x336mm (23.5x13.23") diag: 685mm (27")
ratio: 16:9 modes: 2560x1440, 1920x1080, 1280x1440, 1680x1050, 1280x1024,
1440x900, 1280x960, 1280x720, 1440x576, 1024x768, 1440x480, 800x600,
720x576, 720x480, 640x480, 720x400
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau x11:
drv: nouveau inactive: wayland
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 25.0.5-arch1.1 glx-v: 1.4
direct-render: yes renderer: NV174 device-ID: 10de:2484 memory: 7.8 GiB
unified: no
API: Vulkan v: 1.4.313 layers: N/A device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3070 (NVK GA104) driver: mesa nvk v: 25.0.5-arch1.1
device-ID: 10de:2484 surfaces: N/A
x11: xdpyinfo, xprop, xrandr
Device-1: NVIDIA GA104 High Definition Audio vendor: Gigabyte
link-max: gen: 4 speed: 16 GT/s bus-ID: 08:00.1 chip-ID: 10de:228b
class-ID: 0403
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.12.28-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
Device-2: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 07:00.0
chip-ID: 8086:2725 class-ID: 0280
IF: wlp7s0 state: up mac: <filter>
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2
chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 960.16 GiB used: 11.82 GiB (1.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
tech: SSD serial: <filter> fw-rev: 1B6Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SDSSDH3500G
tech: SSD serial: <filter> fw-rev: 70RL scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: SanDisk model: Ultra size: 28.64 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: 1.00
scheme: MBR
ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 11.82 GiB (2.5%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 1a088ca0-14d2-461e-a050-3521a67eae58
ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-3: /var/cache raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-4: /var/log raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-1: /dev/sda1 maj-min: 8:1 size: 50 MiB fs: ntfs label: System Reserved
uuid: 003A9B203A9B11B0
ID-2: /dev/sda2 maj-min: 8:2 size: 465.21 GiB fs: ntfs label: N/A
uuid: 2298A10C98A0DF91
ID-3: /dev/sda3 maj-min: 8:3 size: 507 MiB fs: ntfs label: N/A
uuid: 841EA1A61EA1922A
ID-4: /dev/sdc1 maj-min: 8:33 size: 28.61 GiB fs: exfat label: Ventoy
uuid: 99CD-08C7
ID-5: /dev/sdc2 maj-min: 8:34 size: 32 MiB fs: vfat label: VTOYEFI
uuid: 626B-4255
Device-1: 1-4:2 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 0a12:0001
class-ID: e001
Device-2: 1-5:3 info: Microdia USB Keyboard type: keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 0c45:7603 class-ID: 0301
Device-3: 1-6:4 info: Logitech G403 Prodigy Gaming Mouse type: mouse,HID
lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c083 class-ID: 0300
serial: <filter>
Device-1: 2-3:2 info: SanDisk Ultra type: mass storage driver: usb-storage
interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
mode: 3.2 gen-1x1 power: 896mA chip-ID: 0781:5581 class-ID: 0806
serial: <filter>
System Temperatures: cpu: 38.0 C mobo: 35.0 C
Fan Speeds (rpm): cpu: 913 case-1: 904 case-2: 923 case-3: 0
Power: 12v: 9.92 5v: N/A 3.3v: N/A vbat: 3.23
Packages: pm: pacman pkgs: 1228 libs: 350 tools: pamac pm: flatpak pkgs: 0
1: https://mirror.funami.tech/manjaro/stable/$repo/$arch
2: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
3: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
4: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
5: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
6: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
7: http://manjaro.mirror.ac.za/stable/$repo/$arch
8: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
9: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
10: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
11: https://mirrors2.manjaro.org/stable/$repo/$arch
12: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
13: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
14: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
15: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
16: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
17: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
18: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
19: https://mirror.zetup.net/manjaro/stable/$repo/$arch
20: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
21: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
22: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
23: https://repos.silknet.com/manjaro/stable/$repo/$arch
24: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
25: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
26: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
27: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
28: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
29: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
30: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
31: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
32: http://manjaro.grena.ge/stable/$repo/$arch
33: http://mirror.fcix.net/manjaro/stable/$repo/$arch
34: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
35: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
36: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
37: https://manjaro.kurdy.org/stable/$repo/$arch
38: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
39: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
40: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
41: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
42: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
43: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
44: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
45: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
46: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
47: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
48: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
49: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
50: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
51: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
52: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
53: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
54: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
55: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
56: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
57: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
58: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
59: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
60: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
61: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
62: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
63: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
64: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
65: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
66: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
67: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
68: https://mirror.init7.net/manjaro/stable/$repo/$arch
69: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
70: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
71: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
72: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
73: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
74: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
75: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
76: https://mirror.koddos.net/manjaro/stable/$repo/$arch
77: https://mirrors.manjaro.org/repo/stable/$repo/$arch
78: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
79: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
80: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
81: https://mirror.dc.uz/manjaro/stable/$repo/$arch
82: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
83: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
84: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
85: https://mirror.23m.com/manjaro/stable/$repo/$arch
86: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
87: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
88: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
89: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
90: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
91: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
92: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
93: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
94: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
95: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
96: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
97: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
98: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
99: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
100: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
101: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
102: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
103: https://mirror.bardia.tech/manjaro/stable/$repo/$arch
104: https://mirror.seahost.de/manjaro/stable/$repo/$arch
105: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
106: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
107: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
108: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
109: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
110: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
111: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
112: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
113: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
114: https://mirrors.netix.net/manjaro/stable/$repo/$arch
115: https://linorg.usp.br/manjaro/stable/$repo/$arch
116: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
117: https://mirror.easyname.at/manjaro/stable/$repo/$arch
118: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
119: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
120: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
121: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
122: https://muug.ca/mirror/manjaro/stable/$repo/$arch
123: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
124: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
125: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
126: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
127: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
128: https://mirrors.piconets.webwerks.in/manjaro-mirror/stable/$repo/$arch
129: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
130: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
131: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
132: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
133: https://manjaro.ynh.ovh/stable/$repo/$arch
Processes:
CPU top: 5 of 351
1: cpu: 13.4% command: firefox pid: 1228 mem: 456.3 MiB (2.8%)
2: cpu: 5.7% command: firefox pid: 1699 mem: 313.2 MiB (1.9%)
3: cpu: 3.4% command: firefox pid: 1481 mem: 435.0 MiB (2.7%)
4: cpu: 2.4% command: kwin_x11 pid: 895 mem: 165.7 MiB (1.0%)
5: cpu: 2.2% command: Xorg pid: 737 mem: 85.2 MiB (0.5%)
Memory top: 5 of 351
1: mem: 456.3 MiB (2.8%) command: firefox pid: 1228 cpu: 13.4%
2: mem: 435.0 MiB (2.7%) command: firefox pid: 1481 cpu: 3.4%
3: mem: 375.5 MiB (2.3%) command: plasmashell pid: 920 cpu: 1.6%
4: mem: 313.2 MiB (1.9%) command: firefox pid: 1699 cpu: 5.7%
5: mem: 221.7 MiB (1.3%) command: konsole pid: 2105 cpu: 2.0%
Processes: 351 Power: uptime: 5m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.19 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: N/A Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.38
I see you have some nVidia hardware there. You problem may be a driver problem, but it’s best I leave this to someone with actual experience debugging nVidia issues.
thank you for you help anyway
No worries, someone will come in sooner or later.
Welcome to the forum!
So your audio hardware is recognized, but you have two distinct audio devices. My preliminary advice therefore would be to…
Use
pavucontrol
to select which audio device should be used — hint: use the one your speakers are plugged into; and… -
Check your volume controls to see whether anything is muted.
Nah, the Nvidia High Definition Audio is fully compatible with the Intel HDA driver. This is only Nvidia’s licensed version of it.
Thank you for your time, I switched to proprietary drivers and bang audio.
Ah yes, if your speakers are connected to your Nvidia adapter and/or they are built into the monitor, then you do need the proprietary driver to get them to produce sound. The nouveau
driver does not handle sound.
First post gets a like from me just for using “bjorked”
