Hello, I installed xfce Manjaro in an old computer of mine. I wiped the disk and made a fresh install, but my audio devices (the one of the Motherboard and a sound card attached) don’t work. They don’t even appear in the audio devices, just the dummy audio, any help?
inxi -Fazy --admin --verbosity=7 --filter --no-host --width
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/vmlinuz-5.9-x86_64
root=UUID=2ea535b1-3d3c-43a4-9486-b9c46ebb3328 ro quiet apparmor=1
security=apparmor resume=UUID=b5ab30ce-6c09-49ca-a58f-5c146928d1ba
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop Mobo: Foxconn model: G31MX Series serial: <filter>
BIOS: Phoenix v: 6.00 PG date: 07/30/2008
RAM: total: 1.94 GiB used: 665.7 MiB (33.5%)
Info: Single Core model: Intel Core2 Duo E7300 bits: 64 type: MCP
arch: Penryn family: 6 model-id: 17 (23) stepping: 6 microcode: 60F
L2 cache: 3 MiB bogomips: 5321
Speed: 1596 MHz min/max: 1600/2667 MHz Core speed (MHz): 1: 1596
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc cpuid
cx16 cx8 de ds_cpl dtes64 dtherm dts est fpu fxsr lahf_lm lm mca mce mmx
monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge pni pse pse36 pti
rep_good sep sse sse2 sse4_1 ssse3 syscall tm tm2 tsc vme xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2
mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Device-1: NVIDIA GT218 [GeForce 405] vendor: Pegatron driver: nouveau
v: kernel bus ID: 01:00.0 chip ID: 10de:10c5 class ID: 0300
Display: x11 server: X.Org 1.20.10 driver: loaded: nouveau
unloaded: modesetting alternate: fbdev,nv,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 1440x900 s-dpi: 96 s-size: 381x238mm (15.0x9.4")
s-diag: 449mm (17.7")
Monitor-1: VGA-1 res: 1440x900 hz: 60 dpi: 90 size: 408x255mm (16.1x10.0")
diag: 481mm (18.9")
OpenGL: renderer: NVA8 v: 3.3 Mesa 20.3.4 direct render: Yes
Device-1: NVIDIA High Definition Audio vendor: Pegatron
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0be3
class ID: 0403
Sound Server: ALSA v: k5.9.16-1-MANJARO
vendor: Foxconn driver: r8169 v: kernel port: be00 bus ID: 03:00.0
chip ID: 10ec:8168 class ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros AR5212/5213/2414 Wireless Network Adapter
vendor: D-Link System AirPlus DWL-G520 driver: ath5k v: kernel port: be00
bus ID: 04:02.0 chip ID: 168c:0013 class ID: 0200
IF: wlp4s2 state: down mac: <filter>
Message: No Bluetooth data was found.
Local Storage: total: 465.76 GiB used: 9.16 GiB (2.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LT012-1DG142
size: 465.76 GiB block size: physical: 4096 B logical: 512 B
speed: <unknown> rotation: 5400 rpm serial: <filter> rev: SDM1 scheme: GPT
Floppy-1: /dev/fd0
ID-1: / raw size: 62 GiB size: 60.78 GiB (98.03%) used: 8.7 GiB (14.3%)
fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 2ea535b1-3d3c-43a4-9486-b9c46ebb3328
ID-2: /boot raw size: 4 GiB size: 3.87 GiB (96.87%) used: 74.6 MiB (1.9%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: f4cb285a-d56b-4b5e-9783-2550716c99aa
ID-3: /home raw size: 391.75 GiB size: 384.59 GiB (98.17%)
used: 401.9 MiB (0.1%) fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: f93c480e-a3dc-4979-ac9e-bccc87f6579f
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: b5ab30ce-6c09-49ca-a58f-5c146928d1ba
ID-1: /dev/sda1 maj-min: 8:1 size: 8 MiB fs: swap label: N/A
uuid: 37dac481-eae7-4c27-af3b-0767c81f5bbe
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 8 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Device-1: 1-2:2 info: Fitipower Integrated Multi Card Reader
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s chip ID: 18e3:9102 class ID: 0806 serial: <filter>
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip ID: 1d6b:0001 class ID: 0900
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
System Temperatures: cpu: 40.0 C mobo: N/A gpu: nouveau temp: 63.0 C
Processes: 155 Uptime: 4m wakeups: 0 Init: systemd v: 247 Compilers:
gcc: N/A Packages: pacman: 1171 lib: 403 flatpak: 0 Shell: Bash v: 5.1.0
running in: xfce4-terminal inxi: 3.3.01
