Can I somehow add Analog Stereo Input configuration profile to pavucontrol
for this USB sound card?
Hi. I got a condenser mic which was supposed to record a crystal clear voice but has a lot of static when connected directly to my motherboard’s sound card so I’m trying to connect it through a USB sound card it came with as it is supposed to power and amplify XLR microphones but that card doesn’t have an Analogue Stereo Input or …Duplex in pavucontrol
's Configuration tab, there’s only:
- Analog Stereo Output …and
- Off
❯ lsusb
Bus 001 Device 007: ID 08bb:2902 Texas Instruments PCM2902 Audio Codec
It has a 2 physical female jack sockets labelled as microphone and headphones, journalctl
says it’s an input device and arecord -l
shows it’s a capture hardware device, moreover amixer -c2
said the microphone is [on]
but [0%] [0.00dB]
so I’ve increased mic’s volume to 75% with alsamixer
but it still doesn’t show in pavucontrol
as input device, there’s no input profile in Configuration tab and arecord -D"hw:2,0" -fs16_le foo.wav
records silence.
journalctl
Nov 16 22:04:16 blackshit kernel: usb 1-9: new full-speed USB device number 7 using xhci_hcd
Nov 16 22:04:16 blackshit kernel: usb 1-9: New USB device found, idVendor=08bb, idProduct=2902, bcdDevice= 1.00
Nov 16 22:04:16 blackshit kernel: usb 1-9: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Nov 16 22:04:16 blackshit kernel: usb 1-9: Product: USB PnP Sound Device
Nov 16 22:04:16 blackshit kernel: usb 1-9: Manufacturer: C-Media Electronics Inc.
Nov 16 22:04:16 blackshit kernel: input: C-Media Electronics Inc. USB PnP Sound Device as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.3/0003:08BB:2902.0018/input/input31
Nov 16 22:04:16 blackshit kernel: hid-generic 0003:08BB:2902.0018: input,hidraw8: USB HID v1.00 Device [C-Media Electronics Inc. USB PnP Sound Device] on usb-0000:00:14.0-9/input3
arecord -l
❯ arecord -l
**** List of CAPTURE Hardware Devices ****
card 2: Device [USB PnP Sound Device], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Subdevice #0: subdevice #0
amixer -c2
❯ amixer -c2
Simple mixer control 'Speaker',0
Capabilities: pvolume pswitch pswitch-joined
Limits: Playback 0 - 151
Mono:
Front Left: Playback 0 [0%] [-28.37dB] [off]
Front Right: Playback 0 [0%] [-28.37dB] [off]
Simple mixer control 'Mic',0
Capabilities: pvolume pvolume-joined cvolume cvolume-joined pswitch pswitch-joined cswitch cswitch-joined
Playback channels: Mono
Capture channels: Mono
Limits: Playback 0 - 127 Capture 0 - 16
Mono: Playback 0 [0%] [0.00dB] [off] Capture 12 [75%] [17.85dB] [on]
Simple mixer control 'Auto Gain Control',0
Capabilities: pswitch pswitch-joined
Mono: Playback [on]
I got another USB sound card from a different shop and it turned out to be… exactly the same device/chipset/everything in a fancier cover. Both behave exactly the same and in both cases output works but not the input so I don’t think it’s broken hardware issue.
While searching for possible solutions I’ve encountered this drop-in PulseAudio replacement called PipeWire. Should I try to install manjaro-pipewire
or is it more probable to solve this issue with manjaro-pulse
inxi
Kernel: 5.10.70-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=f54aa98f-0686-45c4-8bc3-6d95ca77e027 rw acpi_osi=Linux
intel_pstate=skylake_hwp enable_rc6=1 enable_fbc=1 enable_psr=1
disable_power_well=0 semaphores=1 quiet
Desktop: i3 4.19.1 info: i3bar vt: 7 dm: LightDM 1.30.0
Type: Desktop Mobo: MSI model: Z170A SLI PLUS (MS-7998) v: 1.0
serial: <filter> UEFI-[Legacy]: American Megatrends v: 1.10 date: 12/16/2015
RAM: total: 15.59 GiB used: 3.81 GiB (24.4%)
Info: Quad Core model: Intel Core i5-6600K bits: 64 type: MCP
arch: Skylake-S family: 6 model-id: 5E (94) stepping: 3 microcode: EA cache:
L2: 6 MiB bogomips: 28009
Speed: 800 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: ASUSTeK driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1b81 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: picom v: git-fd6ff driver:
Screen-1: 0 s-res: 3840x2160 s-dpi: 110 s-size: 887x494mm (34.9x19.4")
s-diag: 1015mm (40")
Monitor-1: DP-2 res: 3840x2160 hz: 60 dpi: 111 size: 878x485mm (34.6x19.1")
diag: 1003mm (39.5")
OpenGL: renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
chip-ID: 8086:a170 class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f0
class-ID: 0403
Device-3: Texas Instruments PCM2902 Audio Codec type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-9:2 chip-ID: 08bb:2902
class-ID: 0300
Sound Server-1: ALSA v: k5.10.70-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: no
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros AR93xx Wireless Network Adapter driver: ath9k
v: kernel bus-ID: 03:00.0 chip-ID: 168c:0030 class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
Local Storage: total: 1.93 TiB used: 1.14 TiB (59.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 EVO 120GB
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: BB6Q scheme: MBR
SMART Message: Unknown smartctl error. Unable to generate data.
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD20EFRX-68AX9N0
type: N/A serial: <filter> rev: 0A80 scheme: GPT
ID-1: / raw-size: 103.79 GiB size: 103.74 GiB (99.95%)
used: 29.2 GiB (28.1%) fs: xfs block-size: 512 B dev: /dev/sda1 maj-min: 8:1
label: N/A uuid: f54aa98f-0686-45c4-8bc3-6d95ca77e027
ID-2: /home raw-size: 1.82 TiB size: 1.79 TiB (98.42%)
used: 1.11 TiB (62.1%) fs: ext4 block-size: 4096 B dev: /dev/sdb1
maj-min: 8:17 label: Storage uuid: 9860f9db-3c65-4f5e-965b-de7f94e746d4
ID-1: /dev/sda2 maj-min: 8:2 size: 8 GiB fs: xfs label: N/A
uuid: 15b83ec7-a8d2-4299-b1b1-f1a3b9eff12c
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-9:2 info: Texas Instruments PCM2902 Audio Codec type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 08bb:2902 class-ID: 0300
Device-2: 1-13:4
info: Xenta 2.4GHz Wireless Reciever (Mini Keyboard & Mouse)
type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 1d57:fa20 class-ID: 0300
Device-3: 1-14:5 info: Valve Wireless Steam Controller type: Keyboard,HID
driver: hid-steam,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 28de:1142 class-ID: 0300
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.0 speed: 5 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 46.0 C mobo: 38.0 C gpu: nvidia temp: 58 C
Fan Speeds (RPM): cpu: 0 fan-2: 311 fan-3: 808 fan-4: 0 fan-5: 0 gpu: nvidia
fan: 37%
Processes: 198 Uptime: 1h 20m wakeups: 0 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1573
lib: 395 Shell: Zsh v: 5.8 running-in: tmux: inxi: 3.3.08
pacmd list-cards
❯ pacmd list-cards
3 card(s) available.
index: 4
driver: <module-alsa-card.c>
owner module: 28
properties:
alsa.card = "2"
alsa.card_name = "USB PnP Sound Device"
alsa.long_card_name = "C-Media Electronics Inc. USB PnP Sound Device at usb-0000:00:14.0-9, full speed"
alsa.driver_name = "snd_usb_audio"
device.bus_path = "pci-0000:00:14.0-usb-0:9:1.0"
sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/sound/card2"
udev.id = "usb-C-Media_Electronics_Inc._USB_PnP_Sound_Device-00"
device.bus = "usb"
device.vendor.id = "08bb"
device.vendor.name = "Texas Instruments"
device.product.id = "2902"
device.product.name = "PCM2902 Audio Codec"
device.serial = "C-Media_Electronics_Inc._USB_PnP_Sound_Device"
device.string = "2"
device.description = "PCM2902 Audio Codec"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-usb"
profiles:
output:analog-stereo-output: Analog Stereo Output (priority 5000, available: unknown)
off: Off (priority 0, available: unknown)
active profile: <output:analog-stereo-output>
sinks:
alsa_output.usb-C-Media_Electronics_Inc._USB_PnP_Sound_Device-00.analog-stereo-output/#7: PCM2902 Audio Codec Analog Stereo
sources:
alsa_output.usb-C-Media_Electronics_Inc._USB_PnP_Sound_Device-00.analog-stereo-output.monitor/#9: Monitor of PCM2902 Audio Codec Analog Stereo
ports:
analog-output: Analog Output (priority 9900, latency offset 0 usec, available: unknown)
properties:
pacmd list-sources
❯ pacmd list-sources
6 source(s) available.
index: 9
name: <alsa_output.usb-C-Media_Electronics_Inc._USB_PnP_Sound_Device-00.analog-stereo-output.monitor>
flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: IDLE
suspend cause: (none)
priority: 1040
volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
base volume: 65536 / 100% / 0.00 dB
volume steps: 65537
muted: no
current latency: 0.00 ms
max rewind: 344 KiB
sample spec: s16le 2ch 44100Hz
channel map: front-left,front-right
Stereo
used by: 0
linked by: 0
configured latency: 2000.00 ms; range is 0.50 .. 2000.00 ms
monitor_of: 7
card: 4 <alsa_card.usb-C-Media_Electronics_Inc._USB_PnP_Sound_Device-00>
module: 28
properties:
device.description = "Monitor of PCM2902 Audio Codec Analog Stereo"
device.class = "monitor"
alsa.card = "2"
device.bus = "usb"
device.string = "2"
