why i cannot rename folder? There is faded in rename option. I have swiched from windows. My disk partitions are one is GPT and another is MBR. So how can i rename that.
Thanks in advance.
Thanks in advance.
Sounds like you don’t have write permissions to the folder.
https://wiki.archlinux.org/title/File_permissions_and_attributes
Welcome to the forum!
There’s your problem. GNU/Linux is a UNIX-family operating system, while Windows is a completely unrelated operating system that began its life as merely a graphical user interface on top of MS-DOS, which did not know the concept of permissions, because MS-DOS was a single-user platform for standalone personal computers.
The following read is very technical, but it explains all of the concepts, as well as some of the history.
What folder? There’s a reason a user does not have write permission in the system folders. You should not be modifying files there. User files / folders are in your home directory.
