No Audio and failure to shutdown on Manjaro Xfce
Reboot didn’t change anything. still no reboot without issue, still no sound. Did remove snap.
pactl info:
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 67
Tile Size: 65472
User Name: actwo
Host Name: actwo
Server Name: PulseAudio (on PipeWire 1.0.3)
Server Version: 15.0.0
Default Sample Specification: float32le 2ch 48000Hz
Default Channel Map: front-left,front-right
Default Sink: auto_null
Default Source: auto_null.monitor
Cookie: 0e64:5309
journal:
https://0x0.st/XoF0.txt
status wireplumber:
● wireplumber.service - Multimedia Service Session Manager
     Loaded: loaded (/usr/lib/systemd/user/wireplumber.service; enabled; preset: enabled)
     Active: active (running) since Tue 2024-04-23 09:39:03 CEST; 3min 41s ago
   Main PID: 833 (wireplumber)
      Tasks: 7 (limit: 38076)
     Memory: 14.5M (peak: 15.0M)
        CPU: 99ms
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/wireplumber.service
             └─833 /usr/bin/wireplumber
Apr 23 09:39:03 actwo systemd[747]: Started Multimedia Service Session Manager.
Apr 23 09:39:03 actwo wireplumber[833]: Failed to get percentage from UPower: org.freedesktop.DBus.Error.NameHasNoOwner
Apr 23 09:39:03 actwo wireplumber[833]: [0:00:16.748285160] [833] ERROR IPAModule ipa_module.cpp:172 Symbol ipaModuleInfo not found
Apr 23 09:39:03 actwo wireplumber[833]: [0:00:16.748299371] [833] ERROR IPAModule ipa_module.cpp:292 v4l2-compat.so: IPA module has no valid info
Apr 23 09:39:03 actwo wireplumber[833]: [0:00:16.748322923] [833]  INFO Camera camera_manager.cpp:284 libcamera v0.2.0
systemctl --user status pipewire*:
● pipewire-pulse.service - PipeWire PulseAudio
     Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.service; disabled; preset: enabled)
     Active: active (running) since Tue 2024-04-23 09:39:03 CEST; 4min 36s ago
TriggeredBy: ● pipewire-pulse.socket
   Main PID: 834 (pipewire-pulse)
      Tasks: 3 (limit: 38076)
     Memory: 7.7M (peak: 8.4M)
        CPU: 42ms
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire-pulse.service
             └─834 /usr/bin/pipewire-pulse
Apr 23 09:39:03 actwo systemd[747]: Started PipeWire PulseAudio.
● pipewire-pulse.socket - PipeWire PulseAudio
     Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.socket; enabled; preset: enabled)
     Active: active (running) since Tue 2024-04-23 09:39:02 CEST; 4min 37s ago
   Triggers: ● pipewire-pulse.service
     Listen: /run/user/1000/pulse/native (Stream)
     CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pipewire-pulse.socket
Apr 23 09:39:02 actwo systemd[747]: Listening on PipeWire PulseAudio.
● pipewire.socket - PipeWire Multimedia System Sockets
     Loaded: loaded (/usr/lib/systemd/user/pipewire.socket; enabled; preset: enabled)
   Triggers: ● pipewire.service
     Listen: /run/user/1000/pipewire-0 (Stream)
             /run/user/1000/pipewire-0-manager (Stream)
     CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pipewire.socket
Apr 23 09:39:02 actwo systemd[747]: Listening on PipeWire Multimedia System Sockets.
● pipewire.service - PipeWire Multimedia Service
     Loaded: loaded (/usr/lib/systemd/user/pipewire.service; disabled; preset: enabled)
TriggeredBy: ● pipewire.socket
   Main PID: 829 (pipewire)
      Tasks: 4 (limit: 38076)
     Memory: 10.3M (peak: 11.3M)
        CPU: 38ms
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
             └─829 /usr/bin/pipewire
Apr 23 09:39:03 actwo systemd[747]: Started PipeWire Multimedia Service.
Any suggestions?
If there is no sound in PulseAudio or PipeWire replacement service, issue is probably in ALSA
I suggest check ALSA configuration
sudo alsa-info.sh --upload
http://alsa-project.org/db/?f=06bc12aa20cf5666a5357c67e8e7925f9634d0d9
Update: as soon as I run “sudo update-grub” the audio works, until the next reboot.
This is after I added snd_hda_intel.dmic_detect=0 to GRUB_CMDLINE_LINUX_DEFAULT=“” in /etc/default/grub.
The system also shuts down without issues after doing this.
How do I get it to persist now? Any advice?
ALSA data shows no soundcards detected
!!Soundcards recognised by ALSA
--- no soundcards ---
!!Aplay/Arecord output
APLAY
aplay: device_list:279: no soundcards found...
ARECORD
arecord: device_list:279: no soundcards found...
Section !!Amixer output is empty - consistent with previous error “Invalid card number ‘0’”
Section !!All Loaded Modules does not include alternate drivers snd_soc_skl or snd_sof_pci_intel_cnl
If ALSA is not working, PulseAudio/PipeWire can use Bluetooth devices for audio playback
But if no Bluetooth devices are available PulseAudio/PipeWire creates Dummy Output auto_null
So, right now it does work with bluetooth, but what am I supposed to do now?
SOF is already installed, so what should I do besides removing that GRUB Entry?
Remove snd_hda_intel.dmic_detect=0 from /etc/default/grub
Update GRUB - sudo update-grub
Reboot system
If audio is not working as expected check ALSA configuration sudo alsa-info.sh --upload
After rebooting, the machine was hung up at boot, so I had to powerkill it. Next reboot went well.
Here’s the ALSA dump:
http://alsa-project.org/db/?f=bde9a68ec3e91cbf890cee81aae69812807bb522
ALSA data shows a modprobe option for snd_hda_intel driver
!!Modprobe options (Sound related)
snd_hda_intel: model=generic
If modprobe option has been added to /etc/default/grub remove it, update GRUB and reboot
If modprobe option is in a .conf file in folder /etc/modprobe.d/ remove it and reboot
After reboot check ALSA configuration sudo alsa-info.sh --upload
In /etc/modprobe.d/ there are two files, alsa-base.conf and blacklist-watchdog.conf. Should I remove one of them?
I do not remember adding anything else to /etc/default/grub.
Edit:
Sorry, I just now understood what you wrote. alsa-base.conf contains only
options snd-hda-intel model=generic
while blacklist-watchdog.conf contains only
blacklist iTCO_wdt
What should I do now?
Regarding /etc/modprobe.d/blacklist-watchdog.conf - this is likely a file you have added yourself in order to disable watchdog (for whatever reason). Beyond that, I can’t say whether it is directly connected to the current issue(s).
alsa-base.conf contains options snd-hda-intel model=generic
sudo rm /etc/modprobe.d/alsa-base.conf
Reboot
Alright, on poweroff and startup the pc hung up, I had to powerkill it again, jus tso you know.
Here’s the new link:
http://alsa-project.org/db/?f=e9f68829065b3a5486efe952f6e919d790b147d0
If my system has a large number of updates installed (1.5-2 GB) it may take a long time (15-25 minutes) to clear old packages and settings before shutting down. From past experience I learned that system will continue to take a long time to shutdown if it is powered off during shutdown
For Audio issue: No changes in ALSA data. No soundcards recognised. No sof-firmware audio modules loaded
I suggest reinstall sof-firmware
pamac reinstall sof-firmware
and shutdown system
shutdown
When system is restarted, check if audio playback devices are detected in ALSA
aplay -l
If no playback devices are shown try re-initialising ALSA devices
sudo alsactl init
For shutdown issue post more information from journal
journalctl -b -1 | tail -n100 | curl -F 'file=@-' https://0x0.st
Yesterday I already left it on shutdown for at least 3 hours, probably more. It was a lot of updates (around 10GB), but that should still have been enough, shouldn’t it have been?
I will try that again later, but I kinda doubt it will help. When the audio worked (always just for one powercycle) the machine also had no issues shutting down and starting up…
By the way, here is a picture of the screen on shutdown
@nikgnomic any Ideas on this?
aplay -l finds no soundcards, alsactl init doesn’t improve this sadly.
Here is the journal link:
https://0x0.st/XXOZ.txt
I suggest boot system from a live ISO and check ALSA configuration
If there are no soundcards detected on live ISO it is likely a hardware failure
The sound does work in windows (I am triple-booting because some stupid tools are not economical to run on Linux). I will try a live stick tho
