Thanks a lot Fabby
Here is the output when resuming from sleep and problem occurs:
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.5.0
!!Script ran on: Thu Mar 11 09:58:21 UTC 2021
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: TOSHIBA
Product Name: PORTEGE Z20t-B
Product Version: PT15BA-00J00Y
Firmware Version: Version 1.90
System SKU: PT15BA
Board Vendor: TOSHIBA
Board Name: PORTEGE Z20t-B
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI0003:00/status 15
/sys/bus/acpi/devices/IFX0102:00/status 15
/sys/bus/acpi/devices/INT33D3:00/status 11
/sys/bus/acpi/devices/INT33D4:00/status 11
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0A05:00/status 15
/sys/bus/acpi/devices/PNP0C02:03/status 15
/sys/bus/acpi/devices/PNP0C0A:00/status 31
/sys/bus/acpi/devices/PNP0C0A:01/status 31
/sys/bus/acpi/devices/PNP0C0C:00/status 11
/sys/bus/acpi/devices/PNP0C0F:00/status 9
/sys/bus/acpi/devices/PNP0C0F:01/status 9
/sys/bus/acpi/devices/PNP0C0F:02/status 9
/sys/bus/acpi/devices/PNP0C0F:03/status 9
/sys/bus/acpi/devices/PNP0C0F:04/status 9
/sys/bus/acpi/devices/PNP0C0F:05/status 9
/sys/bus/acpi/devices/PNP0C0F:06/status 9
/sys/bus/acpi/devices/PNP0C0F:07/status 9
/sys/bus/acpi/devices/TOS6205:00/status 15
/sys/bus/acpi/devices/TOS6208:00/status 11
/sys/bus/acpi/devices/TTP1200:00/status 15
/sys/bus/acpi/devices/device:06/status 15
!!Kernel Information
Kernel release: 5.10.19-1-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k5.10.19-1-MANJARO
Library version: 1.2.4
Utilities version: 1.2.4
!!Loaded ALSA modules
snd_hda_intel (card 0)
snd_hda_intel (card 1)
!!Sound Servers on this system
PipeWire:
Installed - Yes (/usr/bin/pipewire)
Running - Yes
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
0 [HDMI ]: HDA-Intel - HDA Intel HDMI
HDA Intel HDMI at 0xf1230000 irq 50
1 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0xf1234000 irq 48
!!PCI Soundcards installed in the system
00:03.0 Audio device [0403]: Intel Corporation Broadwell-U Audio Controller [8086:160c] (rev 09)
Subsystem: Toshiba Corporation Device [1179:0001]
00:1b.0 Audio device [0403]: Intel Corporation Wildcat Point-LP High Definition Audio Controller [8086:9ca0] (rev 03)
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
dmic_detect : Y
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 0
power_save_controller : N
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1
dmic_detect : Y
enable_msi : -1
pm_blacklist : Y
power_save : 0
single_cmd : -1
snoop : -1
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/pci/drivers/snd_hda_intel
Tree:
!!Card: /sys/class/sound/card1
Tree:
!!HDA-Intel Codec information
--startcollapse--
Codec: Intel Broadwell HDMI
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x80862808
Subsystem Id: 0x80860101
Revision Id: 0x100000
No Modem Function Group found
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x6611: 8-Channels Digital
Converter: stream=0, channel=0
Digital: Enabled KAE
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
bits [0x1e]: 16 20 24 32
formats [0x5]: PCM AC3
Power states: D0 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Node 0x04 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Node 0x05 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x00 0x00]
Pincap 0x0b000094: OUT Detect HBR HDMI DP
Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
Conn = Digital, Color = Unknown
DefAssociation = 0x1, Sequence = 0x0
Pin-ctls: 0x00:
Unsolicited: tag=00, enabled=0
Devices: 0
Connection: 0
Node 0x06 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x07 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x08 [Vendor Defined Widget] wcaps 0xf00000: Mono
Codec: Conexant CX20753/4
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x14f15111
Subsystem Id: 0x11790694
Revision Id: 0x100100
Default PCM:
rates [0x160]: 44100 48000 96000
bits [0xe]: 16 20 24
formats [0x1]: PCM
Power states: D0 D1 D2 D3 D3cold S3D3cold CLKSTOP EPSS
GPIO: io=3, o=0, i=0, unsolicited=1, wake=0
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x10 [Audio Output] wcaps 0xc1d: Stereo Amp-Out R/L
Control: name="Headphone Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Control: name="Headphone Playback Switch", index=0, device=0
Device: name="CX20753/4 Analog", type="Audio", device=0
Amp-Out caps: ofs=0x4a, nsteps=0x4a, stepsize=0x03, mute=1
Amp-Out vals: [0x80 0x80]
Converter: stream=5, channel=0
PCM:
rates [0x60]: 44100 48000
bits [0xa]: 16 24
formats [0x1]: PCM
Power states: D0 D1 D2 D3 EPSS
Node 0x11 [Audio Output] wcaps 0xc1d: Stereo Amp-Out R/L
Control: name="Speaker Playback Volume", index=0, device=0
Control: name="Speaker Playback Switch", index=0, device=0
Amp-Out vals: [0x35 0x35]
PCM:
bits [0xa]: 16 24
formats [0x1]: PCM
Node 0x12 [Beep Generator Widget] wcaps 0x70000c: Mono Amp-Out
Control: name="Beep Playback Volume", index=0, device=0
ControlAmp: chs=1, dir=Out, idx=0, ofs=0
Control: name="Beep Playback Switch", index=0, device=0
Amp-Out caps: ofs=0x07, nsteps=0x07, stepsize=0x0f, mute=0
Amp-Out vals: [0x04]
Node 0x13 [Audio Input] wcaps 0x100d1b: Stereo Amp-In R/L
Control: name="Capture Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=2, ofs=0
Control: name="Capture Switch", index=0, device=0
Amp-In caps: ofs=0x4a, nsteps=0x50, stepsize=0x03, mute=1
Amp-In vals: [0x80 0x80] [0x50 0x50] [0x50 0x50] [0x80 0x80]
Converter: stream=1, channel=0
SDI-Select: 0
PCM:
bits [0xa]: 16 24
formats [0x1]: PCM
Connection: 4
0x18 0x1a* 0x19 0x1e
Node 0x14 [Audio Input] wcaps 0x100d1b: Stereo Amp-In R/L
Amp-In vals: [0x4a 0x4a] [0x4a 0x4a] [0x4a 0x4a] [0x4a 0x4a]
SDI-Select: 0
PCM:
bits [0xa]: 16 24
formats [0x1]: PCM
Connection: 4
0x19* 0x1a 0x15 0x1e
Node 0x15 [Audio Mixer] wcaps 0x20050b: Stereo Amp-In
Amp-In caps: ofs=0x4a, nsteps=0x4a, stepsize=0x03, mute=1
Amp-In vals: [0x00 0x00] [0x00 0x00]
Connection: 2
0x10 0x11
Node 0x16 [Pin Complex] wcaps 0x400581: Stereo
Pincap 0x0000001c: OUT HP Detect
Pin Default 0x04211040: [Jack] HP Out at Ext Right
Conn = 1/8, Color = Black
DefAssociation = 0x4, Sequence = 0x0
Pin-ctls: 0xc0: OUT HP
Unsolicited: tag=01, enabled=1
Connection: 2
0x10* 0x11
Node 0x17 [Pin Complex] wcaps 0x400501: Stereo
Pincap 0x00000010: OUT
Pin Default 0x40f000f0: [N/A] Other at Ext N/A
Conn = Unknown, Color = Unknown
DefAssociation = 0xf, Sequence = 0x0
Pin-ctls: 0x40: OUT
Connection: 2
0x10* 0x11
Node 0x18 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x2f, mute=0
Pincap 0x00001124: IN Detect
Vref caps: HIZ 80
Pin-ctls: 0x00: VREF_HIZ
Node 0x19 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Control: name="Mic Boost Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Vref caps: HIZ 80
Pin Default 0x04a11030: [Jack] Mic at Ext Right
DefAssociation = 0x3, Sequence = 0x0
Pin-ctls: 0x24: IN VREF_80
Unsolicited: tag=02, enabled=1
Node 0x1a [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Control: name="Internal Mic Boost Volume", index=0, device=0
Amp-In vals: [0x02 0x02]
Pincap 0x00000020: IN
Pin Default 0x95a60120: [Fixed] Mic at Int Top
DefAssociation = 0x2, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x1b [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1d [Pin Complex] wcaps 0x400581: Stereo
Pin Default 0x90170110: [Fixed] Speaker at Int N/A
Conn = Analog, Color = Unknown
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 2
0x10 0x11*
Node 0x1e [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Pincap 0x00000024: IN Detect
Pin-ctls: 0x00:
--endcollapse--
!!ALSA Device nodes
crw-rw----+ 1 root audio 116, 12 Mar 11 20:50 /dev/snd/controlC0
crw-rw----+ 1 root audio 116, 5 Mar 11 20:50 /dev/snd/controlC1
crw-rw----+ 1 root audio 116, 11 Mar 11 20:50 /dev/snd/hwC0D0
crw-rw----+ 1 root audio 116, 4 Mar 11 20:50 /dev/snd/hwC1D0
crw-rw----+ 1 root audio 116, 10 Mar 11 20:50 /dev/snd/pcmC0D10p
crw-rw----+ 1 root audio 116, 6 Mar 11 20:50 /dev/snd/pcmC0D3p
crw-rw----+ 1 root audio 116, 7 Mar 11 20:50 /dev/snd/pcmC0D7p
crw-rw----+ 1 root audio 116, 8 Mar 11 20:50 /dev/snd/pcmC0D8p
crw-rw----+ 1 root audio 116, 9 Mar 11 20:50 /dev/snd/pcmC0D9p
crw-rw----+ 1 root audio 116, 3 Mar 11 20:50 /dev/snd/pcmC1D0c
crw-rw----+ 1 root audio 116, 2 Mar 11 20:50 /dev/snd/pcmC1D0p
crw-rw----+ 1 root audio 116, 1 Mar 11 20:50 /dev/snd/seq
crw-rw----+ 1 root audio 116, 33 Mar 11 20:50 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 80 Mar 11 20:50 .
drwxr-xr-x 3 root root 320 Mar 11 20:50 ..
lrwxrwxrwx 1 root root 12 Mar 11 20:50 pci-0000:00:03.0 -> ../controlC0
lrwxrwxrwx 1 root root 12 Mar 11 20:50 pci-0000:00:1b.0 -> ../controlC1
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: HDMI [HDA Intel HDMI], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: HDMI [HDA Intel HDMI], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: HDMI [HDA Intel HDMI], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: HDMI [HDA Intel HDMI], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: HDMI [HDA Intel HDMI], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 1: PCH [HDA Intel PCH], device 0: CX20753/4 Analog [CX20753/4 Analog]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card HDMI
Card hw:0 'HDMI'/'HDA Intel HDMI at 0xf1230000 irq 50'
Mixer name : 'Intel Broadwell HDMI'
Components : 'HDA:80862808,80860101,00100000'
Controls : 35
Simple ctrls : 5
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
Simple mixer control 'IEC958',4
Mono: Playback [on]
!!-------Mixer controls for card PCH
Card hw:1 'PCH'/'HDA Intel PCH at 0xf1234000 irq 48'
Mixer name : 'Conexant CX20753/4'
Components : 'HDA:14f15111,11790694,00100100'
Controls : 20
Simple ctrls : 9
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Limits: Playback 0 - 74
Mono: Playback 53 [72%] [-21.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 0 [0%] [-74.00dB] [off]
Front Right: Playback 0 [0%] [-74.00dB] [off]
Simple mixer control 'Speaker',0
Mono:
Front Left: Playback 74 [100%] [0.00dB] [on]
Front Right: Playback 74 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Beep',0
Mono: Playback 4 [57%] [-12.00dB] [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 80
Front Left: Capture 80 [100%] [6.00dB] [on]
Front Right: Capture 80 [100%] [6.00dB] [on]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Enabled'
Simple mixer control 'Internal Mic Boost',0
Limits: 0 - 3
Front Left: 2 [67%] [24.00dB]
Front Right: 2 [67%] [24.00dB]
!!Alsactl output
--startcollapse--
state.HDMI {
control.1 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.2 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.4 {
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.5 {
iface MIXER
name 'IEC958 Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface PCM
device 3
name ELD
value ''
comment {
access 'read volatile'
type BYTES
count 0
control.7 {
iface CARD
name 'HDMI/DP,pcm=7 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.8 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.9 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.10 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.11 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.12 {
iface PCM
device 7
name ELD
value ''
comment {
type BYTES
count 0
control.13 {
iface CARD
name 'HDMI/DP,pcm=8 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.14 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.15 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.16 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.17 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.18 {
iface PCM
device 8
name ELD
value ''
comment {
type BYTES
count 0
control.19 {
iface CARD
name 'HDMI/DP,pcm=9 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.20 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.21 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.22 {
iface MIXER
index 3
comment {
access 'read write'
type IEC958
count 1
control.23 {
iface MIXER
index 3
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.24 {
iface PCM
device 9
name ELD
value ''
comment {
type BYTES
count 0
control.25 {
iface CARD
name 'HDMI/DP,pcm=10 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.26 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.27 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.28 {
iface MIXER
index 4
comment {
access 'read write'
type IEC958
count 1
control.29 {
iface MIXER
index 4
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.30 {
iface PCM
device 10
name ELD
value ''
comment {
type BYTES
count 0
control.31 {
iface PCM
device 3
name 'Playback Channel Map'
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.32 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.33 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.34 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.35 {
iface PCM
device 10
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
state.PCH {
control.1 {
iface MIXER
name 'Headphone Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 74'
dbmin -7400
dbmax 0
dbvalue.0 -7400
dbvalue.1 -7400
control.2 {
iface MIXER
name 'Headphone Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.3 {
iface MIXER
name 'Speaker Playback Volume'
value.0 74
value.1 74
comment {
access 'read write'
type INTEGER
count 2
range '0 - 74'
dbmin -7400
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.4 {
iface MIXER
name 'Speaker Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.5 {
iface MIXER
name 'Auto-Mute Mode'
value Enabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.6 {
iface MIXER
name 'Capture Volume'
value.0 80
value.1 80
comment {
access 'read write'
type INTEGER
count 2
range '0 - 80'
dbmin -7400
dbmax 600
dbvalue.0 600
dbvalue.1 600
control.7 {
iface MIXER
name 'Capture Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.8 {
iface MIXER
name 'Internal Mic Boost Volume'
value.0 2
value.1 2
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3600
dbvalue.0 2400
dbvalue.1 2400
control.9 {
iface MIXER
name 'Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3600
dbvalue.0 0
dbvalue.1 0
control.10 {
iface MIXER
name 'Beep Playback Volume'
value 4
comment {
access 'read write'
type INTEGER
count 1
range '0 - 7'
dbmin -2800
dbmax 0
dbvalue.0 -1200
control.11 {
iface MIXER
name 'Beep Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.12 {
iface MIXER
name 'Master Playback Volume'
value 53
comment {
access 'read write'
type INTEGER
count 1
range '0 - 74'
dbmin -7400
dbmax 0
dbvalue.0 -2100
control.13 {
iface MIXER
name 'Master Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.14 {
iface CARD
name 'Internal Mic Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.15 {
iface CARD
name 'Mic Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.16 {
iface CARD
name 'Headphone Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.17 {
iface CARD
name 'Speaker Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.18 {
iface PCM
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.19 {
iface PCM
name 'Capture Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.20 {
iface MIXER
name 'PCM Playback Volume'
value.0 255
value.1 255
comment {
access 'read write user'
type INTEGER
count 2
range '0 - 255'
tlv '0000000100000008ffffec1400000014'
dbmin -5100
dbmax 0
dbvalue.0 0
dbvalue.1 0
--endcollapse--
!!All Loaded Modules
ac97_bus
aesni_intel
af_alg
agpgart
algif_hash
algif_skcipher
bluetooth
bnep
btbcm
btintel
btrtl
btusb
cbc
ccm
cdc_ether
cdc_mbim
cdc_ncm
cdc_wdm
cec
cfg80211
cmac
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
dm_crypt
dm_mod
drm
drm_kms_helper
e1000e
ecc
ecdh_generic
encrypted_keys
ext4
fat
fb_sys_fops
fuse
ghash_clmulni_intel
glue_helper
hid_multitouch
hid_sensor_accel_3d
hid_sensor_als
hid_sensor_gyro_3d
hid_sensor_hub
hid_sensor_iio_common
hid_sensor_incl_3d
hid_sensor_magn_3d
hid_sensor_rotation
hid_sensor_trigger
i2c_algo_bit
i915
iTCO_vendor_support
iTCO_wdt
industrialio
industrialio_triggered_buffer
intel_cstate
intel_gtt
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_uncore
ip_tables
irqbypass
iwlmvm
iwlwifi
jbd2
joydev
kfifo_buf
kvm
kvm_intel
ledtrig_audio
libarc4
libcrc32c
loop
lpc_ich
mac80211
mac_hid
mbcache
mc
mei
mei_hdcp
mei_me
mei_wdt
mii
mmc_block
mmc_core
mousedev
nf_tables
nfnetlink
pcspkr
psmouse
qcserial
rapl
rfcomm
rfkill
rng_core
rtsx_pci
rtsx_pci_sdmmc
serio_raw
sg
snd
snd_compress
snd_hda_codec
snd_hda_codec_conexant
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_pcm
snd_pcm_dmaengine
snd_soc_core
snd_timer
soc_button_array
soundcore
soundwire_bus
soundwire_cadence
soundwire_generic_allocation
soundwire_intel
sparse_keymap
squashfs
syscopyarea
sysfillrect
sysimgblt
toshiba_acpi
toshiba_bluetooth
tpm
tpm_infineon
tpm_tis
tpm_tis_core
trusted
uinput
usb_wwan
usbhid
usbnet
uvcvideo
vfat
video
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wacom
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xhci_pci
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x05 0x18560010
0x06 0x18560010
0x07 0x18560010
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC1D0/init_pin_configs:
0x16 0x04211040
0x17 0x40f000f0
0x18 0x40f000f0
0x19 0x04a11030
0x1a 0x95a60120
0x1d 0x90170110
0x1e 0x40f000f0
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D0/hints:
!!ALSA/HDA dmesg
And here is the difference before and after (left is before sleep, right is after sleep):
6 !!Script ran on: Thu Mar 11 09:58:21 UTC 2021 | !!Script ran on: Thu Mar 11 10:00:39 UTC 2021
293 Converter: stream=5, channel=0 | Converter: stream=0, channel=0
307 Converter: stream=5, channel=0 | Converter: stream=0, channel=0
329 Converter: stream=1, channel=0 | Converter: stream=0, channel=0
