No access to Hard Drive partitions after Update
Well, I managed to have the latest updates installed after following @cimarronline advice in my thread Update: Could Not Satisfy Dependencies - networkmanager-openrc but later when I rebooted, I now have no access to my Hard Drive partitions. On the Desktop appears icons for Filesystem root, efi, Trash, File System and Home. In Thunar, only the following appears - my UserName, Desktop, Trash, Network, Filesystem root, efi and File System.
I also followed the advice given in the Xfce restart and shutdown buttons grayed out since elogind update thread to fix that problem I also noticed but I still do not have access to my partitions.
WTF is going on?
What is the output of rc-status -a (in the terminal)?
@cimarronline
Hi Paul,
I’ll get back to you with that tomorrow. I’ve switched back to the Calculate partition for now and off to bed soon. Hasta mañana.
I have the same using runit gvfs maybe the cause
@cimarronline
Runlevel: nonetwork
 local                                  [  started  ]
Runlevel: boot
 hwclock                                [  started  ]
 modules                                [  started  ]
 fsck                                   [  started  ]
 root                                   [  started  ]
 mtab                                   [  started  ]
 swap                                   [  started  ]
 localmount                             [  started  ]
 urandom                                [  started  ]
 procfs                                 [  started  ]
 sysctl                                 [  started  ]
 bootmisc                               [  started  ]
 termencoding                           [  started  ]
 keymaps                                [  stopped  ]
 binfmt                                 [  started  ]
 loopback                               [  started  ]
 net.lo                                 [  started  ]
 hostname                               [  started  ]
Runlevel: shutdown
 killprocs                              [  stopped  ]
 savecache                              [  stopped  ]
 mount-ro                               [  stopped  ]
Runlevel: default
 dbus                                   [  started  ]
 elogind                                [  started  ]
 syslog-ng                              [  started  ]
 cronie                                 [  started  ]
 NetworkManager                         [  started  ]
 netmount                               [  started  ]
 xdm                                    [  started  ]
 cupsd                                  [  started  ]
 acpid                                  [  started  ]
 alsasound                              [  started  ]
 bluetooth                              [  started  ]
 local                                  [  started  ]
Runlevel: sysinit
 sysfs                                  [  started  ]
 devfs                                  [  started  ]
 udev                                   [  started  ]
 dmesg                                  [  started  ]
 kmod-static-nodes                      [  started  ]
 udev-trigger                           [  started  ]
Dynamic Runlevel: hotplugged
Dynamic Runlevel: needed/wanted
 modules-load                           [  started  ]
 avahi-daemon                           [  started  ]
 xdm-setup                              [  started  ]
Dynamic Runlevel: manual
And below here is the output from Calculate 15 in case it’s of any use for comparison purposes.
Runlevel: nonetwork
 local                                  [  started  ]
Runlevel: boot
 hwclock                                [  started  ]
 swap                                   [  started  ]
 modules                                [  started  ]
 fsck                                   [  started  ]
 tmpfiles.setup                         [  started  ]
 root                                   [  started  ]
 sysctl                                 [  started  ]
 dbus                                   [  started  ]
 urandom                                [  started  ]
 procfs                                 [  started  ]
 binfmt                                 [  started  ]
 swapfiles                              [  started  ]
 net.lo                                 [  started  ]
 consolefont                            [  started  ]
 consolekit                             [  started  ]
 keymaps                                [  started  ]
 xdm                                    [  started  ]
Runlevel: shutdown
Runlevel: default
 sshd                                   [  started  ]
 calculate-core                         [  stopped  ]
 vixie-cron                             [  started  ]
 preload                                [  started  ]
 cupsd                                  [  started  ]
 fuse                                   [  started  ]
 local                                  [  started  ]
 laptopd                                [  started  ]
Runlevel: sysinit
 dmesg                                  [  started  ]
 sysfs                                  [  started  ]
 devfs                                  [  started  ]
 tmpfiles.dev                           [  started  ]
 udev                                   [  started  ]
Runlevel: single
How did consolekit end up in your boot runlevel?
Remove it. Elogind and consolekit do not work together, two session trackers is no good idea.
Edit: Ah, its two outputs, overlooked the calculate line.
Whats the content of /etc/pam.d/lightdm-greeter?
That consolekit is in his Calculate linux rc-status, not Manjaro.
The keymaps service is stopped, but that probably wouldn’t affect drive mounting, I’d guess.
I think its a pam thingy, and some pam.d file still has systemd.so in it, so DM thing.
@artoo
#%PAM-1.0
# Load environment from /etc/environment and ~/.pam_environment
auth      required pam_env.so
# Always let the greeter start without authentication
auth      required pam_permit.so
# No action required for account management
account   required pam_permit.so
# Can't change password
password  required pam_deny.so
# Setup session
session   required pam_unix.so
session   optional pam_ck_connector.so nox11
replace this line with
session optional pam_elogind.so
@artoo It’s still SNAFU! :disappointed:
Check
/etc/pam.d/system-login
For anything more, I need logs.
/var/log/daemon.log
/var/log/auth.log
/var/log/errors.log
@artoo
#%PAM-1.0
auth       required   pam_tally.so         onerr=succeed file=/var/log/faillog
auth       required   pam_shells.so
auth       requisite  pam_nologin.so
auth       include    system-auth
account    required   pam_access.so
account    required   pam_nologin.so
account    include    system-auth
password   include    system-auth
session    optional   pam_loginuid.so
session    include    system-auth
session    optional   pam_motd.so          motd=/etc/motd
session    optional   pam_mail.so          dir=/var/spool/mail standard quiet
-session   optional   pam_elogind.so
session    required   pam_env.so
Looks fine, what about log files?
Perhaps polkit issue.
@artoo
Apr 29 11:49:44 MyLenovoB590 dbus[1404]: [system] Successfully activated service 'org.freedesktop.ModemManager1'
Apr 29 11:49:44 MyLenovoB590 /etc/init.d/netmount[1571]: WARNING: netmount will start when NetworkManager has started
Apr 29 11:49:44 MyLenovoB590 /etc/init.d/keymaps[1573]: ERROR: keymaps failed to start
Apr 29 11:49:44 MyLenovoB590 dhclient[1544]: DHCPDISCOVER on enp3s0 to 255.255.255.255 port 67 interval 5
Apr 29 11:49:44 MyLenovoB590 dhclient[1544]: DHCPREQUEST on enp3s0 to 255.255.255.255 port 67
Apr 29 11:49:44 MyLenovoB590 dhclient[1544]: DHCPOFFER from 192.168.0.1
Apr 29 11:49:44 MyLenovoB590 acpid[1545]: starting up with netlink and the input layer
Apr 29 11:49:44 MyLenovoB590 acpid[1545]: 1 rule loaded
Apr 29 11:49:44 MyLenovoB590 acpid[1545]: waiting for events: event logging is off
Apr 29 11:49:45 MyLenovoB590 dhclient[1544]: DHCPNAK from 192.168.1.1
Apr 29 11:49:45 MyLenovoB590 bluetoothd[1711]: Bluetooth daemon 5.44
Apr 29 11:49:45 MyLenovoB590 avahi-daemon[1764]: Found user 'avahi' (UID 84) and group 'avahi' (GID 84).
Apr 29 11:49:45 MyLenovoB590 avahi-daemon[1764]: Successfully dropped root privileges.
Apr 29 11:49:45 MyLenovoB590 avahi-daemon[1764]: avahi-daemon 0.6.32 starting up.
Apr 29 11:49:45 MyLenovoB590 bluetoothd[1711]: Starting SDP server
Apr 29 11:49:45 MyLenovoB590 avahi-daemon[1764]: Successfully called chroot().
Apr 29 11:49:45 MyLenovoB590 avahi-daemon[1764]: Successfully dropped remaining capabilities.
Apr 29 11:49:45 MyLenovoB590 avahi-daemon[1765]: chroot.c: open() failed: No such file or directory
Apr 29 11:49:45 MyLenovoB590 avahi-daemon[1764]: Failed to open /etc/resolv.conf: Invalid argument
Apr 29 11:49:45 MyLenovoB590 avahi-daemon[1764]: No service file found in /etc/avahi/services.
Apr 29 11:49:45 MyLenovoB590 avahi-daemon[1764]: Joining mDNS multicast group on interface enp3s0.IPv6 with address fe80::ab2a:19e9:dd86:9be2.
Apr 29 11:49:45 MyLenovoB590 avahi-daemon[1764]: New relevant interface enp3s0.IPv6 for mDNS.
Apr 29 11:49:45 MyLenovoB590 avahi-daemon[1764]: Network interface enumeration completed.
Apr 29 11:49:45 MyLenovoB590 avahi-daemon[1764]: Registering new address record for fe80::ab2a:19e9:dd86:9be2 on enp3s0.*.
Apr 29 11:49:45 MyLenovoB590 bluetoothd[1711]: Bluetooth management interface 1.14 initialized
Apr 29 11:49:46 MyLenovoB590 acpid[1545]: client connected from 1662[0:0]
Apr 29 11:49:46 MyLenovoB590 acpid[1545]: 1 client rule loaded
Apr 29 11:49:46 MyLenovoB590 avahi-daemon[1764]: Server startup complete. Host name is MyLenovoB590.local. Local service cookie is 4118563972.
Apr 29 11:49:46 MyLenovoB590 dhclient[1544]: DHCPACK from 192.168.0.1
Apr 29 11:49:46 MyLenovoB590 avahi-daemon[1764]: Joining mDNS multicast group on interface enp3s0.IPv4 with address 192.168.0.31.
Apr 29 11:49:46 MyLenovoB590 avahi-daemon[1764]: New relevant interface enp3s0.IPv4 for mDNS.
Apr 29 11:49:46 MyLenovoB590 avahi-daemon[1764]: Registering new address record for 192.168.0.31 on enp3s0.IPv4.
Apr 29 11:49:46 MyLenovoB590 dhclient[1544]: bound to 192.168.0.31 -- renewal in 253284 seconds.
Apr 29 11:49:46 MyLenovoB590 nm-dispatcher[1462]: req:1 'up' [enp3s0]: new request (2 scripts)
Apr 29 11:49:46 MyLenovoB590 nm-dispatcher[1462]: req:1 'up' [enp3s0]: start running ordered scripts...
Apr 29 11:49:47 MyLenovoB590 ModemManager[1475]: <info>  Couldn't check support for device at '/sys/devices/pci0000:00/0000:00:1c.1/0000:02:00.0': not supported by any plugin
Apr 29 11:49:47 MyLenovoB590 ModemManager[1475]: <info>  Couldn't check support for device at '/sys/devices/pci0000:00/0000:00:1c.3/0000:03:00.0': not supported by any plugin
Apr 29 11:49:47 MyLenovoB590 /etc/init.d/NetworkManager[1853]: status: inactive
Apr 29 11:49:47 MyLenovoB590 dbus[1404]: [system] Activating service name='org.manjaro.pamac' (using servicehelper)
Apr 29 11:49:47 MyLenovoB590 nm-dispatcher[1462]: req:2 'connectivity-change': new request (2 scripts)
Apr 29 11:49:47 MyLenovoB590 dbus[1404]: [system] Successfully activated service 'org.manjaro.pamac'
Apr 29 11:49:47 MyLenovoB590 dhclient[1839]: XMT: Info-Request on enp3s0, interval 1020ms.
Apr 29 11:49:47 MyLenovoB590 dhclient[1839]: RCV: Reply message on enp3s0 from fe80::feb4:e6ff:fe45:560.
Apr 29 11:49:48 MyLenovoB590 nm-dispatcher[1462]: req:3 'dhcp6-change' [enp3s0]: new request (2 scripts)
Apr 29 11:49:48 MyLenovoB590 avahi-daemon[1764]: Leaving mDNS multicast group on interface enp3s0.IPv6 with address fe80::ab2a:19e9:dd86:9be2.
Apr 29 11:49:48 MyLenovoB590 avahi-daemon[1764]: Joining mDNS multicast group on interface enp3s0.IPv6 with address fd4b:c23f:5941:1:9ce:ed65:11d4:fa9b.
Apr 29 11:49:48 MyLenovoB590 avahi-daemon[1764]: Registering new address record for fd4b:c23f:5941:1:9ce:ed65:11d4:fa9b on enp3s0.*.
Apr 29 11:49:48 MyLenovoB590 avahi-daemon[1764]: Withdrawing address record for fe80::ab2a:19e9:dd86:9be2 on enp3s0.
Apr 29 11:49:52 MyLenovoB590 nm-dispatcher[1462]: req:2 'connectivity-change': start running ordered scripts...
Apr 29 11:49:52 MyLenovoB590 nm-dispatcher[1462]: req:3 'dhcp6-change' [enp3s0]: start running ordered scripts...
Apr 29 11:54:29 MyLenovoB590 dbus[1404]: [system] Activating service name='org.manjaro.pamac' (using servicehelper)
Apr 29 11:54:29 MyLenovoB590 dbus[1404]: [system] Successfully activated service 'org.manjaro.pamac'
Apr 29 11:54:32 MyLenovoB590 dbus[1404]: [system] Activating service name='org.freedesktop.UPower' (using servicehelper)
Apr 29 11:54:32 MyLenovoB590 dbus[1404]: [system] Successfully activated service 'org.freedesktop.UPower'
Apr 29 11:54:32 MyLenovoB590 dbus[1404]: [system] Activating service name='org.freedesktop.UDisks2' (using servicehelper)
Apr 29 11:54:32 MyLenovoB590 dbus[1404]: [system] Activated service 'org.freedesktop.UDisks2' failed: Cannot launch daemon, file not found or permissions invalid
Apr 29 11:55:59 MyLenovoB590 init[1]: Switching to runlevel: 6
Apr 29 11:55:59 MyLenovoB590 acpid[1545]: client 1662[0:0] has disconnected
Apr 29 11:55:59 MyLenovoB590 acpid[1545]: client connected from 2234[0:0]
Apr 29 11:55:59 MyLenovoB590 acpid[1545]: 1 client rule loaded
Apr 29 11:56:00 MyLenovoB590 bluetoothd[1711]: Terminating
Apr 29 11:56:00 MyLenovoB590 bluetoothd[1711]: Stopping SDP server
Apr 29 11:56:00 MyLenovoB590 bluetoothd[1711]: Exit
Apr 29 11:56:01 MyLenovoB590 avahi-daemon[1764]: Got SIGTERM, quitting.
Apr 29 11:56:01 MyLenovoB590 avahi-daemon[1764]: Leaving mDNS multicast group on interface enp3s0.IPv6 with address fd4b:c23f:5941:1:9ce:ed65:11d4:fa9b.
Apr 29 11:56:01 MyLenovoB590 avahi-daemon[1764]: Leaving mDNS multicast group on interface enp3s0.IPv4 with address 192.168.0.31.
Apr 29 11:56:01 MyLenovoB590 avahi-daemon[1764]: avahi-daemon 0.6.32 exiting.
Apr 29 11:56:01 MyLenovoB590 acpid[1545]: exiting
Apr 29 09:08:12 MyLenovoB590 lightdm[1903]: PAM unable to dlopen(/usr/lib/security/pam_ck_connector.so): /usr/lib/security/pam_ck_connector.so: cannot open shared object file: No such file or directory
Apr 29 09:08:12 MyLenovoB590 lightdm[1903]: PAM adding faulty module: /usr/lib/security/pam_ck_connector.so
Apr 29 09:08:12 MyLenovoB590 lightdm[1903]: pam_unix(lightdm-greeter:session): session opened for user lightdm by (uid=0)
Apr 29 09:11:45 MyLenovoB590 lightdm[1903]: pam_unix(lightdm-greeter:session): session closed for user lightdm
Apr 29 09:11:45 MyLenovoB590 lightdm[1937]: pam_unix(lightdm:session): session opened for user mtbvfr by (uid=0)
Apr 29 09:11:45 MyLenovoB590 kernel: elogind[1417]: New session c1 of user mtbvfr.
Apr 29 09:11:47 MyLenovoB590 polkitd[1457]: Registered Authentication Agent for unix-session:c1 (system bus name :1.20 [/usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1], object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.utf8)
Apr 29 09:14:44 MyLenovoB590 kernel: elogind[1417]: System is rebooting.
Apr 29 09:14:44 MyLenovoB590 lightdm[1937]: pam_unix(lightdm:session): session closed for user mtbvfr
Apr 29 09:14:44 MyLenovoB590 kernel: elogind[1417]: Removed session c1.
Apr 29 09:14:44 MyLenovoB590 polkitd[1457]: Unregistered Authentication Agent for unix-session:c1 (system bus name :1.20, object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.utf8) (disconnected from bus)
Apr 29 09:14:45 MyLenovoB590 lightdm[2273]: PAM unable to dlopen(/usr/lib/security/pam_ck_connector.so): /usr/lib/security/pam_ck_connector.so: cannot open shared object file: No such file or directory
Apr 29 09:14:45 MyLenovoB590 lightdm[2273]: PAM adding faulty module: /usr/lib/security/pam_ck_connector.so
Apr 29 09:14:45 MyLenovoB590 lightdm[2273]: pam_unix(lightdm-greeter:session): session opened for user lightdm by (uid=0)
Apr 29 09:14:46 MyLenovoB590 lightdm[2273]: pam_unix(lightdm-greeter:session): session closed for user lightdm
Apr 29 11:49:48 MyLenovoB590 lightdm[1914]: PAM unable to dlopen(/usr/lib/security/elogind.so): /usr/lib/security/elogind.so: cannot open shared object file: No such file or directory
Apr 29 11:49:48 MyLenovoB590 lightdm[1914]: PAM adding faulty module: /usr/lib/security/elogind.so
Apr 29 11:49:48 MyLenovoB590 lightdm[1914]: pam_unix(lightdm-greeter:session): session opened for user lightdm by (uid=0)
Apr 29 11:54:26 MyLenovoB590 lightdm[1914]: pam_unix(lightdm-greeter:session): session closed for user lightdm
Apr 29 11:54:26 MyLenovoB590 lightdm[1943]: pam_unix(lightdm:session): session opened for user mtbvfr by (uid=0)
Apr 29 11:54:26 MyLenovoB590 kernel: elogind[1431]: New session c1 of user mtbvfr.
Apr 29 11:54:28 MyLenovoB590 polkitd[1471]: Registered Authentication Agent for unix-session:c1 (system bus name :1.21 [/usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1], object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.utf8)
Apr 29 11:55:59 MyLenovoB590 kernel: elogind[1431]: System is rebooting.
Apr 29 11:55:59 MyLenovoB590 lightdm[1943]: pam_unix(lightdm:session): session closed for user mtbvfr
Apr 29 11:55:59 MyLenovoB590 kernel: elogind[1431]: Removed session c1.
Apr 29 11:55:59 MyLenovoB590 polkitd[1471]: Unregistered Authentication Agent for unix-session:c1 (system bus name :1.21, object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.utf8) (disconnected from bus)
Apr 29 11:56:00 MyLenovoB590 lightdm[2240]: PAM unable to dlopen(/usr/lib/security/elogind.so): /usr/lib/security/elogind.so: cannot open shared object file: No such file or directory
Apr 29 11:56:00 MyLenovoB590 lightdm[2240]: PAM adding faulty module: /usr/lib/security/elogind.so
Apr 29 11:56:00 MyLenovoB590 lightdm[2240]: pam_unix(lightdm-greeter:session): session opened for user lightdm by (uid=0)
Apr 29 11:56:00 MyLenovoB590 lightdm[2240]: pam_unix(lightdm-greeter:session): session closed for user lightdm
Apr 29 09:08:08 MyLenovoB590 /etc/init.d/keymaps[1555]: ERROR: keymaps failed to start
Apr 29 09:08:09 MyLenovoB590 avahi-daemon[1745]: chroot.c: open() failed: No such file or directory
Apr 29 11:49:47 MyLenovoB590 gpod[683]: No device found with uuid 366bb24612f3a91304c7bff51bd8c5a2d300dd55, is it plugged in?
Apr 29 11:55:26 MyLenovoB590 kernel: brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
Apr 29 11:55:26 MyLenovoB590 kernel: brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
In your lightdm-greeter pam file, I made a mistake.
It should be
@artoo
It’s still SNAFU.
daemon
Apr 29 12:27:03 MyLenovoB590 /etc/init.d/netmount[1567]: WARNING: netmount will start when NetworkManager has started
Apr 29 12:27:03 MyLenovoB590 /etc/init.d/keymaps[1569]: ERROR: keymaps failed to start
Apr 29 12:27:03 MyLenovoB590 dbus[1403]: [system] Successfully activated service 'org.freedesktop.ModemManager1’
Apr 29 12:27:03 MyLenovoB590 acpid[1541]: starting up with netlink and the input layer
Apr 29 12:27:03 MyLenovoB590 acpid[1541]: 1 rule loaded
Apr 29 12:27:03 MyLenovoB590 acpid[1541]: waiting for events: event logging is off
Apr 29 12:27:03 MyLenovoB590 dhclient[1629]: DHCPREQUEST on enp3s0 to 255.255.255.255 port 67
Apr 29 12:27:03 MyLenovoB590 dhclient[1629]: DHCPNAK from 192.168.1.1
Apr 29 12:27:03 MyLenovoB590 dhclient[1629]: DHCPDISCOVER on enp3s0 to 255.255.255.255 port 67 interval 3
Apr 29 12:27:03 MyLenovoB590 dhclient[1629]: DHCPOFFER from 192.168.0.1
Apr 29 12:27:04 MyLenovoB590 bluetoothd[1717]: Bluetooth daemon 5.44
Apr 29 12:27:04 MyLenovoB590 avahi-daemon[1770]: Found user ‘avahi’ (UID 84) and group ‘avahi’ (GID 84).
Apr 29 12:27:04 MyLenovoB590 avahi-daemon[1770]: Successfully dropped root privileges.
Apr 29 12:27:04 MyLenovoB590 avahi-daemon[1770]: avahi-daemon 0.6.32 starting up.
Apr 29 12:27:04 MyLenovoB590 bluetoothd[1717]: Starting SDP server
Apr 29 12:27:04 MyLenovoB590 avahi-daemon[1770]: Successfully called chroot().
Apr 29 12:27:04 MyLenovoB590 avahi-daemon[1770]: Successfully dropped remaining capabilities.
Apr 29 12:27:04 MyLenovoB590 avahi-daemon[1771]: chroot.c: open() failed: No such file or directory
Apr 29 12:27:04 MyLenovoB590 avahi-daemon[1770]: Failed to open /etc/resolv.conf: Invalid argument
Apr 29 12:27:04 MyLenovoB590 avahi-daemon[1770]: No service file found in /etc/avahi/services.
Apr 29 12:27:04 MyLenovoB590 avahi-daemon[1770]: Joining mDNS multicast group on interface enp3s0.IPv6 with address fe80::ab2a:19e9:dd86:9be2.
Apr 29 12:27:04 MyLenovoB590 avahi-daemon[1770]: New relevant interface enp3s0.IPv6 for mDNS.
Apr 29 12:27:04 MyLenovoB590 avahi-daemon[1770]: Network interface enumeration completed.
Apr 29 12:27:04 MyLenovoB590 avahi-daemon[1770]: Registering new address record for fe80::ab2a:19e9:dd86:9be2 on enp3s0..
Apr 29 12:27:04 MyLenovoB590 bluetoothd[1717]: Bluetooth management interface 1.14 initialized
Apr 29 12:27:04 MyLenovoB590 dhclient[1629]: DHCPACK from 192.168.0.1
Apr 29 12:27:04 MyLenovoB590 avahi-daemon[1770]: Joining mDNS multicast group on interface enp3s0.IPv4 with address 192.168.0.31.
Apr 29 12:27:04 MyLenovoB590 avahi-daemon[1770]: New relevant interface enp3s0.IPv4 for mDNS.
Apr 29 12:27:04 MyLenovoB590 avahi-daemon[1770]: Registering new address record for 192.168.0.31 on enp3s0.IPv4.
Apr 29 12:27:04 MyLenovoB590 dhclient[1629]: bound to 192.168.0.31 – renewal in 301183 seconds.
Apr 29 12:27:04 MyLenovoB590 nm-dispatcher[1461]: req:1 ‘up’ [enp3s0]: new request (2 scripts)
Apr 29 12:27:04 MyLenovoB590 nm-dispatcher[1461]: req:1 ‘up’ [enp3s0]: start running ordered scripts…
Apr 29 12:27:05 MyLenovoB590 /etc/init.d/NetworkManager[1843]: status: inactive
Apr 29 12:27:05 MyLenovoB590 dbus[1403]: [system] Activating service name=‘org.manjaro.pamac’ (using servicehelper)
Apr 29 12:27:05 MyLenovoB590 avahi-daemon[1770]: Server startup complete. Host name is MyLenovoB590.local. Local service cookie is 1051615232.
Apr 29 12:27:05 MyLenovoB590 nm-dispatcher[1461]: req:2 ‘connectivity-change’: new request (2 scripts)
Apr 29 12:27:05 MyLenovoB590 acpid[1541]: client connected from 1716[0:0]
Apr 29 12:27:05 MyLenovoB590 acpid[1541]: 1 client rule loaded
Apr 29 12:27:05 MyLenovoB590 ModemManager[1474]: Couldn’t check support for device at ‘/sys/devices/pci0000:00/0000:00:1c.1/0000:02:00.0’: not supported by any plugin
Apr 29 12:27:05 MyLenovoB590 ModemManager[1474]: Couldn’t check support for device at ‘/sys/devices/pci0000:00/0000:00:1c.3/0000:03:00.0’: not supported by any plugin
Apr 29 12:27:06 MyLenovoB590 dbus[1403]: [system] Successfully activated service 'org.manjaro.pamac’
Apr 29 12:27:06 MyLenovoB590 acpid[1541]: client connected from 1716[0:0]
Apr 29 12:27:06 MyLenovoB590 acpid[1541]: 1 client rule loaded
Apr 29 12:27:06 MyLenovoB590 dhclient[1911]: XMT: Info-Request on enp3s0, interval 1050ms.
Apr 29 12:27:06 MyLenovoB590 dhclient[1911]: RCV: Reply message on enp3s0 from fe80::feb4:e6ff:fe45:560.
Apr 29 12:27:06 MyLenovoB590 nm-dispatcher[1461]: req:3 ‘dhcp6-change’ [enp3s0]: new request (2 scripts)
Apr 29 12:27:07 MyLenovoB590 avahi-daemon[1770]: Leaving mDNS multicast group on interface enp3s0.IPv6 with address fe80::ab2a:19e9:dd86:9be2.
Apr 29 12:27:07 MyLenovoB590 avahi-daemon[1770]: Joining mDNS multicast group on interface enp3s0.IPv6 with address fd4b:c23f:5941:1:9ce:ed65:11d4:fa9b.
Apr 29 12:27:07 MyLenovoB590 avahi-daemon[1770]: Registering new address record for fd4b:c23f:5941:1:9ce:ed65:11d4:fa9b on enp3s0.
Apr 29 12:27:07 MyLenovoB590 avahi-daemon[1770]: Withdrawing address record for fe80::ab2a:19e9:dd86:9be2 on enp3s0.
Apr 29 12:27:10 MyLenovoB590 nm-dispatcher[1461]: req:2 ‘connectivity-change’: start running ordered scripts…
Apr 29 12:27:10 MyLenovoB590 nm-dispatcher[1461]: req:3 ‘dhcp6-change’ [enp3s0]: start running ordered scripts…
Apr 29 12:27:59 MyLenovoB590 dbus[1403]: [system] Activating service name=‘org.manjaro.pamac’ (using servicehelper)
Apr 29 12:28:00 MyLenovoB590 dbus[1403]: [system] Successfully activated service 'org.manjaro.pamac’
Apr 29 12:28:01 MyLenovoB590 dbus[1403]: [system] Activating service name=‘org.freedesktop.UPower’ (using servicehelper)
Apr 29 12:28:01 MyLenovoB590 dbus[1403]: [system] Successfully activated service 'org.freedesktop.UPower’
Apr 29 12:28:02 MyLenovoB590 dbus[1403]: [system] Activating service name=‘org.freedesktop.UDisks2’ (using servicehelper)
Apr 29 12:28:02 MyLenovoB590 dbus[1403]: [system] Activated service ‘org.freedesktop.UDisks2’ failed: Cannot launch daemon, file not found or permissions invalid
Apr 29 12:33:00 MyLenovoB590 dbus[1403]: [system] Activating service name=‘org.freedesktop.nm_dispatcher’ (using servicehelper)
Apr 29 12:33:00 MyLenovoB590 dbus[1403]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher’
Apr 29 12:33:00 MyLenovoB590 nm-dispatcher[2335]: req:1 ‘connectivity-change’: new request (2 scripts)
Apr 29 12:33:00 MyLenovoB590 nm-dispatcher[2335]: req:1 ‘connectivity-change’: start running ordered scripts…
Apr 29 12:41:53 MyLenovoB590 dbus[1403]: [system] Activating service name=‘org.freedesktop.nm_dispatcher’ (using servicehelper)
Apr 29 12:41:53 MyLenovoB590 dbus[1403]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher’
Apr 29 12:41:53 MyLenovoB590 avahi-daemon[1770]: Withdrawing address record for fd4b:c23f:5941:1:9ce:ed65:11d4:fa9b on enp3s0.
Apr 29 12:41:53 MyLenovoB590 avahi-daemon[1770]: Leaving mDNS multicast group on interface enp3s0.IPv6 with address fd4b:c23f:5941:1:9ce:ed65:11d4:fa9b.
Apr 29 12:41:53 MyLenovoB590 avahi-daemon[1770]: Joining mDNS multicast group on interface enp3s0.IPv6 with address fe80::ab2a:19e9:dd86:9be2.
Apr 29 12:41:53 MyLenovoB590 avahi-daemon[1770]: Registering new address record for fe80::ab2a:19e9:dd86:9be2 on enp3s0.*.
Apr 29 12:41:53 MyLenovoB590 avahi-daemon[1770]: Withdrawing address record for fe80::ab2a:19e9:dd86:9be2 on enp3s0.
Apr 29 12:41:53 MyLenovoB590 avahi-daemon[1770]: Leaving mDNS multicast group on interface enp3s0.IPv6 with address fe80::ab2a:19e9:dd86:9be2.
Apr 29 12:41:53 MyLenovoB590 avahi-daemon[1770]: Interface enp3s0.IPv6 no longer relevant for mDNS.
Apr 29 12:41:53 MyLenovoB590 nm-dispatcher[2455]: req:1 ‘connectivity-change’: new request (2 scripts)
Apr 29 12:41:53 MyLenovoB590 nm-dispatcher[2455]: req:1 ‘connectivity-change’: start running ordered scripts…
Apr 29 12:41:54 MyLenovoB590 avahi-daemon[1770]: Withdrawing address record for 192.168.0.31 on enp3s0.
Apr 29 12:41:54 MyLenovoB590 avahi-daemon[1770]: Leaving mDNS multicast group on interface enp3s0.IPv4 with address 192.168.0.31.
Apr 29 12:41:54 MyLenovoB590 avahi-daemon[1770]: Interface enp3s0.IPv4 no longer relevant for mDNS.
Apr 29 12:41:54 MyLenovoB590 nm-dispatcher[2455]: req:2 ‘down’ [enp3s0]: new request (2 scripts)
Apr 29 12:41:54 MyLenovoB590 nm-dispatcher[2455]: req:2 ‘down’ [enp3s0]: start running ordered scripts…
Apr 29 12:42:42 MyLenovoB590 init[1]: Switching to runlevel: 6
Apr 29 12:42:43 MyLenovoB590 acpid[1541]: client 1716[0:0] has disconnected
Apr 29 12:42:43 MyLenovoB590 acpid[1541]: client connected from 2608[0:0]
Apr 29 12:42:43 MyLenovoB590 acpid[1541]: 1 client rule loaded
Apr 29 12:42:43 MyLenovoB590 bluetoothd[1717]: Terminating
Apr 29 12:42:43 MyLenovoB590 bluetoothd[1717]: Stopping SDP server
Apr 29 12:42:43 MyLenovoB590 bluetoothd[1717]: Exit
Apr 29 12:42:54 MyLenovoB590 /etc/init.d/xdm[2920]: start-stop-daemon: 1 process refused to stop
Apr 29 12:42:54 MyLenovoB590 /etc/init.d/xdm[2896]: ERROR: xdm failed to stop
Apr 29 12:42:54 MyLenovoB590 avahi-daemon[1770]: Got SIGTERM, quitting.
Apr 29 12:42:54 MyLenovoB590 avahi-daemon[1770]: avahi-daemon 0.6.32 exiting.
Apr 29 12:42:54 MyLenovoB590 acpid[1541]: exiting
auth
Apr 29 12:27:07 MyLenovoB590 lightdm[1922]: pam_unix(lightdm-greeter:session): session opened for user lightdm by (uid=0)
Apr 29 12:27:07 MyLenovoB590 kernel: elogind[1430]: New session c1 of user lightdm.
Apr 29 12:27:57 MyLenovoB590 lightdm[1922]: pam_unix(lightdm-greeter:session): session closed for user lightdm
Apr 29 12:27:57 MyLenovoB590 lightdm[1967]: pam_unix(lightdm:session): session opened for user mtbvfr by (uid=0)
Apr 29 12:27:57 MyLenovoB590 kernel: elogind[1430]: Removed session c1.
Apr 29 12:27:57 MyLenovoB590 kernel: elogind[1430]: New session c2 of user mtbvfr.
Apr 29 12:27:59 MyLenovoB590 polkitd[1470]: Registered Authentication Agent for unix-session:c2 (system bus name :1.23 [/usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1], object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.utf8)
Apr 29 12:39:00 MyLenovoB590 gnome-keyring-daemon[2419]: couldn’t access control socket: /run/user/1000/keyring/control: No such file or directory
Apr 29 12:42:42 MyLenovoB590 kernel: elogind[1430]: System is rebooting.
Apr 29 12:42:42 MyLenovoB590 lightdm[1967]: pam_unix(lightdm:session): session closed for user mtbvfr
Apr 29 12:42:42 MyLenovoB590 kernel: elogind[1430]: Removed session c2.
Apr 29 12:42:42 MyLenovoB590 polkitd[1470]: Unregistered Authentication Agent for unix-session:c2 (system bus name :1.23, object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.utf8) (disconnected from bus)
Apr 29 12:42:43 MyLenovoB590 lightdm[2614]: pam_unix(lightdm-greeter:session): session opened for user lightdm by (uid=0)
Apr 29 12:42:43 MyLenovoB590 kernel: elogind[1430]: New session c3 of user lightdm.
Apr 29 12:42:44 MyLenovoB590 lightdm[2614]: pam_unix(lightdm-greeter:session): session closed for user lightdm
Apr 29 12:42:44 MyLenovoB590 kernel: elogind[1430]: Removed session c3.
errors
Apr 29 12:27:06 MyLenovoB590 gpod[706]: No device found with uuid 366bb24612f3a91304c7bff51bd8c5a2d300dd55, is it plugged in?
Apr 29 12:32:44 MyLenovoB590 kernel: brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
Apr 29 12:32:44 MyLenovoB590 kernel: brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
Apr 29 12:38:00 MyLenovoB590 kernel: brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
Apr 29 12:38:00 MyLenovoB590 kernel: brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
Apr 29 12:39:00 MyLenovoB590 kernel: brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
Apr 29 12:39:00 MyLenovoB590 kernel: brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
Apr 29 12:39:26 MyLenovoB590 kernel: brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
Apr 29 12:39:26 MyLenovoB590 kernel: brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
What about that? I mean, why is that?
There’s this too:
Apr 29 12:28:02 MyLenovoB590 dbus[1403]: [system] Activating service name='org.freedesktop.UDisks2' (using servicehelper)
@artoo
Don’t ask me. I don’t know.
