No 5.1 Sound with StarTech 7.1 USB Audio Adapter ICUSBAUDIO7D
Hello,
I’m having problem getting Analog 5.1 Sound on my new external Soundcard.
While im doing 5.1 speaker tests in Pavucontrol, all 6 channels working correctly,
the same when im start playing a game… the 5.1 is solid there.
The problem starts when im using Youtube or SMPlayer where only Front Speaker’s showing output, while center/sub and rear left and rear right are silence… i only get something out from Center in SMPlayer when i switch from Stereo to Mono.
I also looked at Alsamixer but there wasn’t much to adjust, no channel was muted, so im not sure what to do next.
$ pactl list cards
Card #43
        Driver: alsa
        Owner Module: n/a
        Properties:
                device.enum.api = "udev"
                device.api = "alsa"
                media.class = "Audio/Device"
                api.alsa.path = "hw:0"
                api.alsa.card = "0"
                api.alsa.card.name = "HDA ATI HDMI"
                api.alsa.card.longname = "HDA ATI HDMI at 0xf6ca0000 irq 152"
                device.plugged.usec = "10505834"
                device.bus_path = "pci-0000:03:00.1"
                sysfs.path = "/devices/pci0000:00/0000:00:01.1/0000:01:00.0/0000:02:00.0/0000:03:00.1/sound/card0"
                device.bus = "pci"
                device.subsystem = "sound"
                device.vendor.id = "0x1002"
                device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
                device.product.id = "0xab40"
                device.product.name = "Navi 48 HDMI/DP Audio Controller"
                device.name = "alsa_card.pci-0000_03_00.1"
                device.description = "Navi 48 HDMI/DP Audio Controller"
                device.nick = "HDA ATI HDMI"
                device.icon_name = "audio-card-analog-pci"
                api.alsa.use-acp = "true"
                api.acp.auto-port = "false"
                api.dbus.ReserveDevice1.Priority = "-20"
                api.alsa.split-enable = "true"
                spa.object.id = "2"
                factory.id = "15"
                client.id = "42"
                object.id = "43"
                object.serial = "43"
                object.path = "alsa:acp:HDMI"
                alsa.card = "0"
                alsa.card_name = "HDA ATI HDMI"
                alsa.long_card_name = "HDA ATI HDMI at 0xf6ca0000 irq 152"
                alsa.mixer_name = "ATI R6xx HDMI"
                alsa.components = "HDA:1002aa01,00aa0100,00100a00"
                alsa.id = "HDMI"
                device.string = "0"
        Profiles:
                off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
                output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: no)
                output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: no)
                output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 5700, available: no)
                output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (sinks: 1, sources: 0, priority: 5700, available: yes)
                output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
                output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
                output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
                output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
                output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
                output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
                pro-audio: Pro Audio (sinks: 4, sources: 0, priority: 1, available: yes)
        Active Profile: off
        Ports:
                hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, availability group: Legacy 1, not available)
                        Properties:
                                port.type = "hdmi"
                                port.availability-group = "Legacy 1"
                                card.profile.port = "0"
                        Part of profile(s): output:hdmi-stereo, output:hdmi-surround, output:hdmi-surround71
                hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, availability group: Legacy 2, not available)
                        Properties:
                                port.type = "hdmi"
                                port.availability-group = "Legacy 2"
                                card.profile.port = "1"
                        Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-surround-extra1, output:hdmi-surround71-extra1
                hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, availability group: Legacy 3, not available)
                        Properties:
                                port.type = "hdmi"
                                port.availability-group = "Legacy 3"
                                card.profile.port = "2"
                        Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-surround-extra2, output:hdmi-surround71-extra2
                hdmi-output-3: HDMI / DisplayPort 4 (type: HDMI, priority: 5600, latency offset: 0 usec, availability group: Legacy 4, available)
                        Properties:
                                port.type = "hdmi"
                                port.availability-group = "Legacy 4"
                                card.profile.port = "3"
                                device.product.name = "HS233"
                                iec958.codecs.detected = "[\"PCM\"]"
                                audio.channels.detected = "2"
                                audio.position.detected = "[FL,FR]"
                        Part of profile(s): output:hdmi-stereo-extra3
Card #164
        Driver: alsa
        Owner Module: n/a
        Properties:
                device.api = "alsa"
                api.alsa.path = "hw:1"
                api.alsa.card = "1"
                api.alsa.card.name = "ICUSBAUDIO7D"
                api.alsa.card.longname = "ICUSBAUDIO7D at usb-0000:15:00.0-12, full speed"
                device.plugged.usec = "5669443862"
                device.bus_path = "pci-0000:15:00.0-usb-0:12:1.0"
                sysfs.path = "/devices/pci0000:00/0000:00:02.1/0000:05:00.0/0000:06:0c.0/0000:15:00.0/usb3/3-12/3-12:1.0/sound/card1"
                device.bus-id = "usb-0d8c_USB_Sound_Device-00"
                device.bus = "usb"
                device.vendor.id = "0x0d8c"
                device.vendor.name = "C-Media Electronics, Inc."
                device.product.id = "0x0102"
                device.product.name = "CM106 Like Sound Device"
                device.serial = "0d8c_USB_Sound_Device"
                device.name = "alsa_card.usb-0d8c_USB_Sound_Device-00"
                device.description = "CM106 Like Sound Device"
                device.nick = "ICUSBAUDIO7D"
                device.icon_name = "audio-card-analog-usb"
                api.dbus.ReserveDevice1 = "Audio1"
                spa.object.id = "4"
                factory.id = "15"
                client.id = "42"
                object.id = "63"
                object.serial = "164"
                object.path = "alsa:acp:ICUSBAUDIO7D"
                alsa.card = "1"
                alsa.card_name = "ICUSBAUDIO7D"
                alsa.long_card_name = "ICUSBAUDIO7D at usb-0000:15:00.0-12, full speed"
                alsa.driver_name = "snd_usb_audio"
                alsa.mixer_name = "USB Mixer"
                alsa.components = "USB0d8c:0102"
                alsa.id = "ICUSBAUDIO7D"
                device.string = "1"
        Profiles:
                output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: yes)
                output:analog-stereo+input:iec958-stereo: Analog Stereo Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 6555, available: yes)
                output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: yes)
                output:iec958-stereo+input:analog-stereo: Digital Stereo (IEC958) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5565, available: yes)
                output:iec958-stereo+input:iec958-stereo: Digital Stereo Duplex (IEC958) (sinks: 1, sources: 1, priority: 5555, available: yes)
                output:iec958-stereo: Digital Stereo (IEC958) Output (sinks: 1, sources: 0, priority: 5500, available: yes)
                output:analog-surround-21+input:analog-stereo: Analog Surround 2.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: yes)
                output:analog-surround-41+input:analog-stereo: Analog Surround 4.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: yes)
                output:analog-surround-51+input:analog-stereo: Analog Surround 5.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: yes)
                output:analog-surround-21+input:iec958-stereo: Analog Surround 2.1 Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 1355, available: yes)
                output:analog-surround-41+input:iec958-stereo: Analog Surround 4.1 Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 1355, available: yes)
                output:analog-surround-51+input:iec958-stereo: Analog Surround 5.1 Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 1355, available: yes)
                output:analog-surround-21: Analog Surround 2.1 Output (sinks: 1, sources: 0, priority: 1300, available: yes)
                output:analog-surround-41: Analog Surround 4.1 Output (sinks: 1, sources: 0, priority: 1300, available: yes)
                output:analog-surround-51: Analog Surround 5.1 Output (sinks: 1, sources: 0, priority: 1300, available: yes)
                output:analog-surround-40+input:analog-stereo: Analog Surround 4.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: yes)
                output:analog-surround-50+input:analog-stereo: Analog Surround 5.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: yes)
                output:analog-surround-71+input:analog-stereo: Analog Surround 7.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: yes)
                output:analog-surround-40+input:iec958-stereo: Analog Surround 4.0 Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 1255, available: yes)
                output:analog-surround-50+input:iec958-stereo: Analog Surround 5.0 Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 1255, available: yes)
                output:analog-surround-71+input:iec958-stereo: Analog Surround 7.1 Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 1255, available: yes)
                output:analog-surround-40: Analog Surround 4.0 Output (sinks: 1, sources: 0, priority: 1200, available: yes)
                output:analog-surround-50: Analog Surround 5.0 Output (sinks: 1, sources: 0, priority: 1200, available: yes)
                output:analog-surround-71: Analog Surround 7.1 Output (sinks: 1, sources: 0, priority: 1200, available: yes)
                output:iec958-ac3-surround-51+input:analog-stereo: Digital Surround 5.1 (IEC958/AC3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 365, available: yes)
                output:iec958-ac3-surround-51+input:iec958-stereo: Digital Surround 5.1 (IEC958/AC3) Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 355, available: yes)
                output:iec958-ac3-surround-51: Digital Surround 5.1 (IEC958/AC3) Output (sinks: 1, sources: 0, priority: 300, available: yes)
                input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: yes)
                input:iec958-stereo: Digital Stereo (IEC958) Input (sinks: 0, sources: 1, priority: 55, available: yes)
                pro-audio: Pro Audio (sinks: 1, sources: 1, priority: 1, available: yes)
        Active Profile: output:analog-surround-51+input:analog-stereo
        Ports:
                analog-input-mic: Microphone (type: Mic, priority: 8700, latency offset: 0 usec, availability unknown)
                        Properties:
                                port.type = "mic"
                        Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21+input:analog-stereo, output:analog-surround-40+input:analog-stereo, output:analog-surround-41+input:analog-stereo, output:analog-surround-50+input:analog-stereo, output:analog-surround-51+input:analog-stereo, output:analog-surround-71+input:analog-stereo, output:iec958-stereo+input:analog-stereo, output:iec958-ac3-surround-51+input:analog-stereo
                analog-input-linein: Line In (type: Line, priority: 8100, latency offset: 0 usec, availability unknown)
                        Properties:
                                port.type = "line"
                iec958-stereo-input: Digital Input (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec, availability unknown)
                        Properties:
                                port.type = "spdif"
                        Part of profile(s): input:iec958-stereo, output:analog-stereo+input:iec958-stereo, output:analog-surround-21+input:iec958-stereo, output:analog-surround-40+input:iec958-stereo, output:analog-surround-41+input:iec958-stereo, output:analog-surround-50+input:iec958-stereo, output:analog-surround-51+input:iec958-stereo, output:analog-surround-71+input:iec958-stereo, output:iec958-stereo+input:iec958-stereo, output:iec958-ac3-surround-51+input:iec958-stereo
                analog-output-speaker: Speakers (type: Speaker, priority: 10000, latency offset: 0 usec, availability unknown)
                        Properties:
                                port.type = "speaker"
                        Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-stereo+input:iec958-stereo, output:analog-surround-21, output:analog-surround-21+input:analog-stereo, output:analog-surround-21+input:iec958-stereo, output:analog-surround-40, output:analog-surround-40+input:analog-stereo, output:analog-surround-40+input:iec958-stereo, output:analog-surround-41, output:analog-surround-41+input:analog-stereo, output:analog-surround-41+input:iec958-stereo, output:analog-surround-50, output:analog-surround-50+input:analog-stereo, output:analog-surround-50+input:iec958-stereo, output:analog-surround-51, output:analog-surround-51+input:analog-stereo, output:analog-surround-51+input:iec958-stereo, output:analog-surround-71, output:analog-surround-71+input:analog-stereo, output:analog-surround-71+input:iec958-stereo
                iec958-stereo-output: Digital Output (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec, availability unknown)
                        Properties:
                                port.type = "spdif"
                                card.profile.port = "4"
                        Part of profile(s): output:iec958-stereo, output:iec958-stereo+input:analog-stereo, output:iec958-stereo+input:iec958-stereo
$ inxi -zv8
  Kernel: 7.2.3-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-7.2-x86_64
    root=UUID=7d0165de-089c-45ee-adb3-9a8ca8d12132 rw amd_pstate=passive
    amdgpu.ppfeaturemask=0xffffffff sysrq_always_enabled=1
    resume=UUID=342d34b4-152b-4a04-9479-c0b3cbc6c96f udev.log_priority=3
  Desktop: KDE Plasma v: 6.7.4 tk: Qt v: N/A info: frameworks v: 6.29.0
  Type: Desktop Mobo: Gigabyte model: X870E AORUS ELITE WIFI7 v: x.x
    serial: <superuser required> uuid: <superuser required> Firmware: UEFI
    vendor: American Megatrends LLC. v: FA7 date: 12/12/2025
  System RAM: total: 32 GiB available: 30.95 GiB used: 3.13 GiB (10.1%)
  Device-1: Channel-A DIMM 0 type: no module installed
  Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 6000 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: TeamGroup
    part-no: UD5-6000 serial: <filter>
  Device-3: Channel-B DIMM 0 type: no module installed
  Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 9800X3D bits: 64 type: MT MCP arch: Zen 5 gen: 5
    level: v4 note: check built: 2024+ process: TSMC n4 (4nm) family: 0x1A (26)
    model-id: 0x44 (68) stepping: 0 microcode: 0xB404035
    smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
  Speed (MHz): avg: 5272 min/max: 603/5272 boost: enabled scaling:
    driver: amd-pstate governor: performance cores: 1: 5272 2: 5272 3: 5272
    4: 5272 5: 5272 6: 5272 7: 5272 8: 5272 9: 5272 10: 5272 11: 5272 12: 5272
    13: 5272 14: 5272 15: 5272 16: 5272 bogomips: 150108
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl avx_vnni bmi1 bmi2 bpext
    bus_lock_detect cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov
    cmp_legacy constant_tsc cpb cppc cpuid cpuid_fault cqm cqm_llc
    cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
    decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu
    fsgsbase fsrm fxsr fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs
    invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
    movbe movdir64b movdiri msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx
    ospke osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
    perfctr_core perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni
    stibp succor svm svm_lock syscall tce topoext tsc tsc_adjust tsc_scale
    umip user_shstk v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme
    vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec
    xsaveerptr xsaveopt xsaves xtopology
  Type: spec_rstack_overflow mitigation: IBPB on VMEXIT only
    conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Type: vmscape mitigation: IBPB on VMEXIT
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [Radeon RX 9070/9070
    XT/9070 GRE] vendor: Tul / PowerColor driver: amdgpu v: kernel
    arch: RDNA-4 code: Navi-4x process: TSMC n4 (4nm) built: 2025+ pcie:
    gen: 5 speed: 32 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1,
    DP-2, DP-3, Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:7550 class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 0
  Monitor-1: HDMI-A-1 model: HannSpree/HannStar HS233 serial: <filter>
    built: 2010 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 96 gamma: 1.2
    chroma: red: x: 0.647 y: 0.333 green: x: 0.302 y: 0.600 blue: x: 0.149
    y: 0.055 white: x: 0.314 y: 0.329 size: 510x287mm (20.08x11.3")
    diag: 585mm (23") ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024,
    1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600,
    720x576, 720x480, 640x480, 720x400
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi wayland:
    drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 vendor: amd mesa v: 26.2.2-arch1.1 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon RX 9070 (radeonsi gfx1201 ACO DRM
    3.64 7.2.3-2-MANJARO) device-ID: 1002:7550 memory: 15.62 GiB unified: no
    display-ID: :1.0
  API: Vulkan v: 1.4.357 layers: 6 device: 0 type: discrete-gpu name: AMD
    Radeon RX 9070 (RADV GFX1201) driver: mesa radv v: 26.2.2-arch1.1
    device-ID: 1002:7550 surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: corectrl wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio
    driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 16
    bus-ID: 03:00.1 chip-ID: 1002:ab40 class-ID: 0403
  Device-2: C-Media CM106 Like Sound Device
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-12:4 chip-ID: 0d8c:0102 class-ID: 0300
  API: ALSA v: k7.2.3-2-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.8 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8922AE 802.11be PCIe Wireless Network Adapter
    driver: rtw89_8922ae v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    port: e000 bus-ID: 0f:00.0 chip-ID: 10ec:8922 class-ID: 0280
  IF: wlp15s0 state: down mac: <filter>
  Device-2: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 10:00.0
  IF: enp16s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:2 chip-ID: 0bda:8922
  Local Storage: total: 3.18 TiB used: 502.01 GiB (15.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SFYRDY2000G
    lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK51.2 temp: 45.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung model: SSD 960 EVO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 2B7QCXE7 temp: 21.9 C
    scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: PSSD T7
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.2 spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: SSD
    serial: <filter> scheme: GPT
  ID-1: / raw-size: 390.62 GiB size: 383.43 GiB (98.16%)
    used: 14.39 GiB (3.8%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: root
    uuid: 7d0165de-089c-45ee-adb3-9a8ca8d12132
    used: 328 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: efi
    uuid: 3BE0-5B02
  ID-3: /home raw-size: 503.28 GiB size: 494.31 GiB (98.22%)
    used: 13.81 GiB (2.8%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: home
    uuid: 938cd14e-1366-4038-9b43-1348b0e4aae4
  ID-4: /media/nvme-games raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
    used: 473.81 GiB (25.9%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
    label: nvme-games uuid: ef738838-b40e-4cbe-a55d-a3f8bcfdb11a
  ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%)
    priority: -1 dev: /dev/sda2 maj-min: 8:2 label: swap
    uuid: 342d34b4-152b-4a04-9479-c0b3cbc6c96f
  ID-1: /dev/nvme1n1p1 maj-min: 259:3 size: 100 MiB fs: vfat label: N/A
    uuid: 9095-62C6
  ID-2: /dev/nvme1n1p2 maj-min: 259:4 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme1n1p3 maj-min: 259:5 size: 396.75 GiB fs: ntfs label: N/A
    uuid: 388AB2318AB1EB8E
  ID-4: /dev/nvme1n1p4 maj-min: 259:6 size: 546 MiB fs: ntfs label: N/A
    uuid: 800CA58D0CA57EB2
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-6:2 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:8922 class-ID: e001 serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-7:2 info: Integrated Express GIGABYTE Device type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5711 class-ID: 0300
  Device-2: 3-10:3 info: A4Tech XL-730K / XL-747H XL-750BK XL-755BK Mice
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 09da:9090 class-ID: 0301
  Device-3: 3-12:4 info: C-Media CM106 Like Sound Device type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
  Hub-4: 4-0:1 info: super-speed hub ports: 6 rev: 3.1
  Device-1: 4-1:2 info: Samsung PSSD T7 type: mass storage driver: uas
    interfaces: 1 rev: 3.2 speed: 10 Gb/s (1.16 GiB/s) lanes: 1
    mode: 3.2 gen-2x1 power: 896mA chip-ID: 04e8:4001 class-ID: 0806
    serial: <filter>
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-8: 8-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-9: 9-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 9-2:2 info: CHERRY G83 (RS 6000) Keyboard type: keyboard
    chip-ID: 046a:0011 class-ID: 0301
  Hub-10: 10-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-11: 11-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  System Temperatures: cpu: 42.5 C mobo: 46.0 C gpu: amdgpu temp: 29.0 C
    mem: 27.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 651
  Packages: pm: pacman pkgs: 1373 libs: 377 tools: pamac pm: flatpak pkgs: 0
    1: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    2: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    3: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 330
  1: cpu: 1.9% command: firefox pid: 19840 mem: 395.0 MiB (1.2%)
  2: cpu: 1.7% command: firefox pid: 19612 mem: 725.6 MiB (2.2%)
  3: cpu: 1.0% command: Linux started-by: dolphin pid: 20348
    mem: 145.9 MiB (0.4%)
  4: cpu: 0.8% command: kwin_wayland pid: 905 mem: 264.4 MiB (0.8%)
  5: cpu: 0.7% command: firefox pid: 19852 mem: 356.3 MiB (1.1%)
  Memory top: 5 of 330
  1: mem: 725.6 MiB (2.2%) command: firefox pid: 19612 cpu: 1.7%
  2: mem: 506.9 MiB (1.5%) command: plasmashell pid: 1021 cpu: 0.1%
  3: mem: 395.0 MiB (1.2%) command: firefox pid: 19840 cpu: 1.9%
  4: mem: 358.2 MiB (1.1%) command: systemsettings pid: 20185 cpu: 0.0%
  5: mem: 356.3 MiB (1.1%) command: firefox pid: 19852 cpu: 0.7%
  Processes: 330 Power: uptime: 2h 47m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.31 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 261 default: graphical
    tool: systemctl
  Compilers: gcc: 16.2.1 Shell: Bash v: 5.3.15 running-in: konsole
    inxi: 3.3.41
I think this should probably be expected, depending upon the source audio – YouTube is likely stereo (at best); SMPlayer – again, it depends upon whether the file contained the audio streams.
Otherwise, to fake 5.1 – to have the audio seem to be 5.1 by virtue of using all speakers, I recall having to split channels and perform other magic tricks. In Windows there was invariably software to assist – on Manjaro, I’m limited to headphones, and can’t begin to test any workarounds.
Well, I suppose that was a lot of text just to say I really can’t help, but I hope a workaround can be found, especially after your recent history with other audio devices. :four_leaf_clover:
I compared the same sound source in SMPlayer/VLC Player and the same Youtube Videos with my old PC, where i get the full 5.1 sound for this 2channel sources (i guess it is for the youtube videos the same).
The major difference is the creative AE-5 Soundcard but i also use a DD5.1 amplifier (6ch ext. in) in analog mode.
While at my NEW PC im using for testing with the new StarTech Soundcard, only 2 pairs of headphones to simulate 5.1 in the kitchen and switching channels with the 3,5mm jacks.
I’m wondering if my amplifier maybe doing some magic, which maybe lead to the virtual/upmixing 5.1 channel sound on all boxes or if im doing something wrong here inside Manjaro on my other PC, related to alsamixer or pavucontrol.
While i think that i switched several different pavu profiles already, with no differend outcome.
But as i played Diablo2 Remaster and the sound was working great, i just hope i can archive the old experience with that new sound card also.
To check audio from Youtube and SMPlayer:
pactl list sink-inputs
If the data shows audio is stereo only, Pipewire can be re-configured to upmix stereo to 5.1 surround
Upmixing · PipeWire Wiki
PipeWire by default does not upmix stereo audio to multichannel 5.1 or 7.1 audio because the default behaviour should be to route the audio as is and not apply filters to the audio.
You need to manually enable upmixing in PulseAudio clients, Native PipeWire clients and bluetooth devices.
PulseAudio
To enable upmixing for PulseAudio clients, make a file ~/.config/pipewire/pipewire-pulse.conf.d/40-upmix.conf with the content:
# Enables upmixing
stream.properties = {
    channelmix.upmix      = true
    channelmix.upmix-method = psd
    channelmix.lfe-cutoff = 150
    channelmix.fc-cutoff  = 12000
    channelmix.rear-delay = 12.0
And restart the pipewire-pulse server.
This USB device has different and fewer ALSA mixer controls than AE-5 card
Probe #0d97a184b8 of System76 Gazelle: amixer
Card sysdefault:3 'ICUSBAUDIO7D'/'ICUSBAUDIO7D at usb-0000:00:14.0-1.2, full speed'
  Mixer name	: 'USB Mixer'
  Components	: 'USB0d8c:0102'
  Controls      : 16
  Simple ctrls  : 6
Simple mixer control 'Speaker',0
  Capabilities: pvolume pswitch pswitch-joined
  Playback channels: Front Left - Front Right - Rear Left - Rear Right - Front Center - Woofer - Side Left - Side Right
  Limits: Playback 0 - 197
  Mono:
  Front Left: Playback 10 [5%] [-35.06dB] [on]
  Front Right: Playback 10 [5%] [-35.06dB] [on]
  Rear Left: Playback 10 [5%] [-35.06dB] [on]
  Rear Right: Playback 10 [5%] [-35.06dB] [on]
  Front Center: Playback 10 [5%] [-35.06dB] [on]
  Woofer: Playback 10 [5%] [-35.06dB] [on]
  Side Left: Playback 10 [5%] [-35.06dB] [on]
  Side Right: Playback 10 [5%] [-35.06dB] [on]
Simple mixer control 'PCM',0
  Capabilities: cvolume cswitch cswitch-joined
  Limits: Capture 0 - 6928
  Front Left: Capture 4096 [59%] [-0.01dB] [on]
  Front Right: Capture 4096 [59%] [-0.01dB] [on]
Simple mixer control 'PCM Capture Source',0
  Capabilities: enum
  Items: 'Mic' 'Line' 'IEC958 In' 'Mixer'
  Item0: 'Mic'
Simple mixer control 'Line',0
  Capabilities: pvolume cvolume pswitch pswitch-joined cswitch cswitch-joined
  Limits: Playback 0 - 8065 Capture 0 - 6928
  Front Left: Playback 6144 [76%] [-0.01dB] [off] Capture 0 [0%] [-16.00dB] [off]
  Front Right: Playback 6144 [76%] [-0.01dB] [off] Capture 0 [0%] [-16.00dB] [off]
Simple mixer control 'Mic',0
  Front Left: Playback 6144 [76%] [-0.01dB] [off] Capture 6928 [100%] [11.06dB] [on]
  Front Right: Playback 6144 [76%] [-0.01dB] [off] Capture 6928 [100%] [11.06dB] [on]
Simple mixer control 'IEC958 In',0
  Capabilities: cswitch cswitch-joined
  Capture channels: Mono
  Mono: Capture [on]
Thank you so much for that response nikgnomic, im pretty sure that will help me a lot :slight_smile:
Do you think that the AE-5 card has this up-mixing for 5.1 already implemented?
Because it would suprise me, if my amplifier would do that.
I think all youtube content is limited to stereo, at least when i try speaker soundchannel test video’s… there is none of this working and many people wrote in the comments that there is some sound changes happening from youtube related to the multi channels.
Im using that settings right now and the upmixing works so far, but with a big trade off… I can hear some Sound Distortions at my rear channels, the voices are cut out there (as it should be) but i can hear from the muted voices a squeaky sound distortion in my rear when ever there is anyone talking.
  1. Is there a way to improve that?
  2. I’m wondering also that there isn’t a channel option that the upmixing knows for how many channels it has to do that.
  3. Another question for me would be, if it is possible to create a bash script to enable/disable upmixing (on the fly), when ever i play a media or if i play a game.
I do not know for certain since I have never had a 5.1 audio system, but AE-5 devices have a Surround Channel Config mixer control in ALSA that is probably upmixing stereo audio streams, similar to using the PipeWire re-configuration for other devices that do not have built-in signal-processing features
https://linux-hardware.org/?probe=5133a970ab&log=amixer
Simple mixer control 'Surround Channel Config',0
  Capabilities: enum
  Items: '2.0' '2.1' '4.0' '4.1' '5.1'
  Item0: '2.0'
As far as I know, youtube has 5.1 surround content (Dolby Digital 5.1 (AC-3) and DTS Digital Surround) but I do not know if any Linux web browser can play 5.1 surround audio to analog outputs, so it is likely to be limited to stereo only.
pavucontrol has advanced options for AC-3 and DTS encoding for digital outputs (HDMI or SPDIF), but not analog surround outputs
Previous example from PipeWire Wiki would upmix all audio streams to 5.1.
To play some stereo content without upmixing, create a virtual sink:
PipeWire Wiki – Guide Upmixing – Virtual upmix sink (simple)
This example makes a new stereo sink that uses the standard stream upmixing logic to upmix to 5.1. You can link the output to a 5.1 sink.
This can be an alternative to globally enabling the upmixing for all clients. Simply redirect the client to this sink to make it upmix or directly to the 5.1 sink to get stereo.
To create the virtual upmix sink, make a file ~/.config/pipewire/pipewire.conf.d/25-sink-upmix-5.1.conf with the content:
# An example of a stereo sink that will use the stream upmixing
# logic to create a 5.1 output.
context.modules = [
    {   name = libpipewire-module-loopback
        args = {
            node.description = "Stereo to 5.1 upmix"
            # global audio position makes sure capture and playback streams
            # are converted to this intermediate format
            audio.position = [ FL FR ]
            capture.props = {
                node.name = "sink.upmix_5_1"
                media.class = "Audio/Sink"
            playback.props = {
                node.name = "playback.upmix-5.1"
                # from the internal stereo to this will trigger upmix
                audio.position = [ FL FR FC LFE RL RR]
                # where to link this to
                target.object = "alsa_output.usb-0d8c_USB_Sound_Device-00.analog-surround-51"
                # Makes sure the output channels stay as configured rather than matching
                # target.object
                stream.dont-remix = true
                # Prevents this loopback module from being processed (and possibly keeping
                # CPU at a higher power state) when its not linked to clients
                node.passive = true
                # enable channel upmix
                # use fancy filters and delay in the rear channels
                channelmix.upmix-method = psd  # none, simple
                # filter for the LFE channel
                # filter for the FC channel
                # delay in rear channels
                # optionally widen the stereo field
                channelmix.stereo-widen = 0.0
                # optionally apply a hilbert transform (90 degree phase shift) on
                # the rear channels to improve spacialization
                channelmix.hilbert-taps = 0
Or try this python script that has a GUI to switch between 5.1 and stereo playback:
GitHub - amekusa03/PipeWire-5.1ch-Upmix-Switcher: A lightweight GUI tool to toggle and tune 2ch stereo to 5.1ch surround sound upmixing for PipeWire..
Thanks for linking this tool.
How save is it to use tools like that, which are outside the official repository?
Could this tool be dangerous or even include malware attacks, if i install this? I’m just ask this since this tool looks pretty new and has zero feedback on github.
Well this is from a SoundblasterZ but maybe the upmixing works there the same as with my AE-5.
Anyways, do you think i could somehow simple duplicated the upmixing from my AE-5 to archive the same upmixing quality with my StarTech Soundcard?
I compared yesterday both rear channels on both soundcards and on the same media source.
And the alsa upmixing was so clean, there was absolute no distortion with the Creative AE-5. Who ever created this presets, really nailed it to be perfect.
This settings not really do it, for my StarTech Soundcard (only rear channels are affected):
Enables upmixing
If you do not trust the script, don’t use it. I came across this script when looking for more information about upmixing in PipeWire.
The script has different presets for a global upmix configuration, similar to first example in PipeWire Wiki guide (40-upmix.conf ): that could also be used with the virtual sink example (25-sink-upmix-5.1.conf)
PipeWire-5.1ch-Upmix-Switcher/main.py at main · amekusa03/PipeWire-5.1ch-Upmix-Switcher · GitHub
PRESETS = {
    "Standard (PSD Default)": {
        "method": "psd",
        "lfe_cutoff": 150,
        "rear_delay": 0.0,
        "fc_cutoff": 12000,
        "stereo_widen": 0.0,
    "Movies / Surround Focus": {
        "method": "psd",
        "lfe_cutoff": 120,
        "rear_delay": 15.0,
        "fc_cutoff": 10000,
        "stereo_widen": 0.1,
    "Music / Natural Ambience": {
        "method": "psd",
        "lfe_cutoff": 80,
        "rear_delay": 5.0,
        "fc_cutoff": 0,
        "stereo_widen": 0.2,
    "Simple (Simple Method)": {
        "method": "simple",
        "lfe_cutoff": 120,
        "rear_delay": 0.0,
        "fc_cutoff": 0,
Linux-hardware data in post #4 was for a AE-5 Plus pci-e card, similar your audio device
https://linux-hardware.org/?probe=5133a970ab&log=inxi
 Device-3: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D /
   Z-Series BlasterX AE-5 Plus] driver: snd_hda_intel v: kernel pcie:
   speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 1102:0012 class-ID: 0403
Previous generations of Creative pci-e cards (Recon3D and Z-series) use the same audio codec as the current AE series: Hardware for Linux - CA1032 Sound Core3D
Thank you again for assisting me with my sound questions :slight_smile:
TBH, i don’t know exactly how to verify to trust a random github script in general.
Because i have no idea where to look at, which code parts could be dangerous or not.
The only command which i would overview/monitor a script and i know that it could be dangerous for my PC is “rm -rf” (which delete’s all mounted drives) but that’s it, because im not a programmer.
Im wondering which part is channelmix.fc-cutoff = 12000 doing in the upmixing area.
Is there somewhere a overview to see all possible commands for UpMixing and how each filter-command exactly works?
FC stands for Front Center? And it cut everything off below (or above?) 12000Hz and redirect it to rear?
I’m wondering if that Hz cutoff is to high placed and that is why partial sound voice’s are bleeding from Center Channel into the Rear Channels?
Could that be the culprit for the distortions?
What is a virtual sink? And does this presets show up in Alsamixer or where to switch/use them?
channelmix.fc-cutoff=12000 is a low-pass filter for the Center channel on a 5.1 speaker system to block frequencies above 12 kHz, that may improve clarity of the dialogue in a movie
GitHub - PipeWire-5.1ch-Upmix-Switcher
Detailed Parameter Tuning:
  • Upmix Algorithm (psd / simple / none)
  • Subwoofer LFE Cutoff Frequency (40 Hz – 200 Hz)
  • Rear Speaker Delay (0.0 ms – 50.0 ms)
  • Center FC Cutoff Frequency (0 Hz – 20,000 Hz)
  • Stereo Ambience Widening (0.00 – 1.00)
