majik
3 November 2024 11:50
1
until recently the Night Light utility in the tray used to be adjustable by 1% steps when the Shift key was used, however this no longer works; holding Shift prevents any change and the step size without Shift is 5%
Fn+Shift+F1/F2 still adjusts in 1% steps
KDE Plasma Version: 6.1.5
KDE Frameworks Version: 6.6.0
Qt Version: 6.7.2
Kernel Version: 6.10.13-3-MANJARO (64-bit)
Graphics Platform: X11
BG405
4 November 2024 01:06
2
Could you tell us which “night light utility” please? I assume you don’t mean the usual screen brightness adjustments via scrolling whilst hovering over the icon?
… This is still in 1% steps for me; tried your method using SHIFT in conjunction with the Fn and, on my machine, F5 and F6 keys.
I’m using the linux66 LTS
series at present.
Does switching to a Plasma Wayland session make any difference?
I just tried adjusting the brightness on my Plasma Wayland session by holding the shift key while scrolling the mouse wheel over the brightness icon in the system tray, and it did it in 1% increments. I also learnt that it works the same way with the volume icon - 5% without the shift key, 1% with the shift key.
Although it should be noted that I am on Testing branch, which means I am on Plasma 6.2.2, while Stable branch is on Plasma 6.1.5.
BG405
4 November 2024 01:14
4
Good point there @scotty65 . I forgot to mention I’m also using Wayland.
I’ve set my volume to always use 1% steps; at least this one is easily changed in System Settings
majik
4 November 2024 03:12
5
yes, i meant the sys tray util that’s packaged with plasma - it no longer adjusts brightness in 1% steps with shift key
haven’t tried wayland, and yes, shift works in 1% steps for me with the volume icon
BG405
4 November 2024 03:30
6
I’d certainly give Wayland a go, nothing to lose as it’s easily switchable via the SDDM login screen (bottom left, usually).
Another thing worth trying is the linux66
kernel, and/or linux611
to see if it might be driver (integration?) related (which I sort of doubt in this case but no harm in giving them a go).
A bit more detail on your system may also be helpful:
inxi -zv8
majik
4 November 2024 03:58
7
issue was the same on wayland and the 6.6 kernel - i’ll give the 6.11 kernel a shot tomorrow
inxi is spitting out a lot of info that i’d have to go though before posting
If privacy is an issue, rest assured, the following inxi
command filters out all personally identifiable information;
inxi --admin --verbosity=8 --filter --no-host --width
Cheers.
majik
4 November 2024 04:27
9
thanks for the inxi syntax - i’ll go with -v 5 for now if that’s ok
inxi
$ inxi --admin --verbosity=5 --filter --no-host --width
Kernel: 6.10.13-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
root=UUID=bb1d3d93-e1ee-4b58-94bc-d9b9b6f183a1 rw
resume=UUID=365557ba-d129-4798-90eb-91ecda0db65d udev.log_priority=3
nowatchdog
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK MAX (MS-7C02) v: 1.0
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: 3.B0 date: 05/12/2021
System RAM: total: 16 GiB available: 13.57 GiB used: 2.32 GiB (17.1%)
Device-1: Channel-A DIMM 0 type: no module installed
(unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.Skill
part-no: F4-3200C16-8GVGB serial: N/A
Device-3: Channel-B DIMM 0 type: no module installed
Info: model: AMD Ryzen 5 3400G with Radeon Vega Graphics bits: 64
type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3 note: check
built: 2019 process: GF 12nm family: 0x17 (23) model-id: 0x18 (24)
stepping: 1 microcode: 0x8108109
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB
desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2300 min/max: 1400/3700 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 2300 2: 2300 3: 2300
4: 2300 5: 2300 6: 2300 7: 2300 8: 2300 bogomips: 59229
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Device-1: Advanced Micro Devices [AMD/ATI] Picasso/Raven 2 [Radeon Vega
Series / Radeon Mobile Series] driver: amdgpu v: kernel arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
lanes: 16 ports: active: HDMI-A-1 empty: DVI-D-1,HDMI-A-2,HDMI-A-3
bus-ID: 27:00.0 chip-ID: 1002:15d8 class-ID: 0300 temp: 42.0 C
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: HDMI-A-1 model: BenQ EX2510 serial: <filter> built: 2020
res: 1920x1080 dpi: 90 gamma: 1.2 size: 544x303mm (21.42x11.93")
diag: 623mm (24.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.4-arch1.0.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 11 Graphics
(radeonsi raven LLVM 18.1.8 DRM 3.57 6.10.13-3-MANJARO)
device-ID: 1002:15d8 memory: 1.95 GiB unified: no
API: Vulkan v: 1.3.295 layers: N/A device: 0 type: integrated-gpu name: AMD
Radeon Vega 11 Graphics (RADV RAVEN) driver: mesa radv v: 24.2.4-arch1.0.1
device-ID: 1002:15d8 surfaces: xcb,xlib
Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 27:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: Mark of the Unicorn M Series driver: cdc_acm,snd-usb-audio
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2
chip-ID: 07fd:000b class-ID: 0a00 serial: <filter>
API: ALSA v: k6.10.13-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: azirevpn-us-mia state: unknown speed: N/A duplex: N/A mac: N/A
Local Storage: total: 9.1 TiB used: 2.3 TiB (25.2%)
model: WDS100T3XHC-00SJG0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 102000WD temp: 44.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT2000MX500SSD1
tech: SSD serial: <filter> fw-rev: 033 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 EVO 4TB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: SanDisk model: SDSSDH32000G
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 70RL scheme: MBR
ID-1: / raw-size: 905.34 GiB size: 890.05 GiB (98.31%) used: 15.2 GiB (1.7%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: Root
uuid: bb1d3d93-e1ee-4b58-94bc-d9b9b6f183a1
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: BOOT
uuid: 61A2-791F
ID-3: /home raw-size: 931.02 GiB size: 915.33 GiB (98.31%)
used: 99.45 GiB (10.9%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: Home
uuid: d186724a-14d9-46e5-a29d-b16ae175fd25
Kernel: swappiness: 20 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: partition size: 25.39 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: swap
uuid: 365557ba-d129-4798-90eb-91ecda0db65d
System Temperatures: cpu: 41.6 C mobo: N/A gpu: amdgpu temp: 41.0 C
Fan Speeds (rpm): N/A
Processes: 272 Power: uptime: 22m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.41 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: pm: pacman pkgs: 1426 libs: 308 tools: pamac Compilers:
gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: konsole inxi: 3.3.36
BG405
4 November 2024 04:35
10
majik:
Type: Desktop
This is definitely worth knowing.
I wasn’t aware you could adjust brightness settings on an external monitor without using xrandr
settings (which I used on a be-headed laptop with external monitor(s), to set brightness and contrast levels for night use, but have since forgotten how, unfortunately). Naturally, this had no effect on the monitor backlight, being an LCD.
Kernel 6.10 has reached EOL.
General availability of kernel 6.12 (LTS) is expected this month.
Though these have no obvious bearing on your issue.
I use Wayland; the step size seems to be as expected. It has been a year since using X11 (except on Debian and BSD) so I can’t comment much on that.
Good luck.
majik
4 November 2024 04:50
12
the issue is the same with wayland
Perhaps kernel 6.12 (LTS) will weave some magic.
Create a new User account, and see if you have the same issue there. This will usually indicate whether the issue is limited to your current User; or rule it out.
Otherwise
One other thing that I would like you to do is check the change brightness by 1% shortcuts on your system. They can be accessed via:
System Settings => Keyboard => Shortcuts => Power Management
The shortcut for “Decrease Screen Brightness by 1%” should be “Shift+Monitor Brightness Down”
The shortcut for “Increase Screen Brightness by 1%” should be “Shift+Monitor Brightness Up”
majik
4 November 2024 14:09
15
@scotty65 - the shortcuts are correct and match what you specified
i re-read all the replies here (and thanks everyone for jumping in to help) and it isn’t clear to me whether anyone has tested the sys tray night light brightness thingy to see if it works in 1% increments on X11 (Shift key + mouse wheel)
next i guess i’ll test under a fresh user acct. because i’m suspecting the issue may be a config file in /home, but if anyone knows which file that may be, please let me know
majik
16 January 2025 15:40
16
issue resolved as a result of a manjaro update (dunno which)
BG405
17 January 2025 02:00
17
majik:
(dunno which)
This is not an indicator of an actual Solution so therefore I have unmarked it and set a topic timer independently.
Unless more is added, it will automatically close in 4 days.
BG405
Closed
21 January 2025 02:51
18
This topic was automatically closed after 4 days. New replies are no longer allowed.
