Hye,
I have a Manjaro Gnome on a X86 PC; no problem. I have connected my NAS with NFS protocol --> everything is right.
I’ve used Manjaro Plasma ARM for PI400. I have the last update.
After adding the correct line on /etc/fstab, the following command return me
[patrick@PI400 etc]$ sudo mount -a
mount.nfs: Protocol not supported
Is the NFS protocol not yet supported on ARM version ? A manual mount return me the same error.
[patrick@PI400 etc]$ pamac search nfs-utils
mkinitcpio-nfs-utils 0.3-7 core
ipconfig and nfsmount tools for NFS root support in mkinitcpio
nfs-utils [Installés] 2.5.2-2 core
Support programs for Network File Systems
And after a reboot, the first command reply me:
[patrick@PI400 ~]$ sudo mount -a
[sudo] Mot de passe de patrick : Created symlink /run/systemd/system/remote-fs.target.wants/rpc-statd.service → /usr/lib/systemd/system/rpc-statd.service.
