I have installed pale moon and language pack from official repositories. But it not compatible. Language Pack (Ru) version in the pamac is 28.15.0-1, but version in the browser is 29.0.0rc8…Please help, how fix it?
It says it’s the same version
Packages | Stable | Testing | Unstable | Repository |
palemoon-bin | 28.15.0-1 | 28.15.0-2 | 28.15.0-2 | community |
palemoon-i18n-ru | 28.15.0-1 | 28.15.0-1 | 28.15.0-1 | community |
Uninstall palemoon and add it again
yes. I also have the same versions in the repositories
It does not help
Where did you install palemoon from? The other thing you can do is download the language extension of that version from Github and add it.
Delete palemoon-i18n-ru 28.15.0-1 first
install palemoon from pamac. official repo (community).
I delete palemoon-i18n-ru 28.15.0-1, but cannot install Russian by your link. I got a message: Russian (RU) Language Pack could not be installed because it is not compatible with Pale Moon 28.15.0.
So you have installed 28.15 not 29
Russian 28.15.0
It’s weird that the official repo language pack doesn’t work
It link works. Russian (RU) Language Pack has been installed succesffully
its good. but after every update i need manually update Lang pack from official site or github. its not very comfortable. So what other ideas to make the lang pack work from the repo?
In the next update it should be solved and you don’t need to install the .xpi from github
Thanks! I Hope
Just update system, but the error is still here.
Did you remove the language plugin first and then update?
yes. now i RE-install language plugin, but it doesn’t help too
