I quit Windows and installed manjaro kde… now running it… i have d drive which is ntfs formatted i use for my steam libary etc… can i use it here in manjaro too? i mean ntfs format doesnt effect performance ? My dota 2 libary in my d drive…
I didnt installed anything like driver… i have ryzen 3 1200 and rx 560 with 8 gb ram ddr 4 and ssd
and last one… how to run windows games i mean i see lutris is the best option? any guide to set it up ?
there is a Steam for Manjaro it works under linux ,
but it means for the same account you will have to load games for linux ( reset all profiles games and save )
if you want to play with disk ntfs game , see proton
Thanks for the answer… MY GAMES STORED IN NTFS steam libary… i didnt ask how to run Windows app in manjaro… i ask, if i use those stored games via steam it will cost performance issues becasue that libary folders stored at ntfs formatted disk ?
