Newbie: Manjaro really slow
What cli commands should I use to check what is wrong ?
Pls post output of
inxi -Fazy --filter
Kernel: 5.10.70-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=5d94d1b6-4498-4570-818b-62f25b0d3623 rw acpi_osi=Linux
acpi_backlight=vendor quiet resume=UUID=2ea393bc-5a21-4e01-9eca-c3fe50b9a28d
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Laptop System: LENOVO product: 20AWS17N00 v: ThinkPad T440p
serial: Chassis: type: 10 serial:
Mobo: LENOVO model: 20AWS17N00 v: SDK0E50510 PRO serial:
UEFI-[Legacy]: LENOVO v: GLET67WW (2.21 ) date: 02/27/2014
ID-1: BAT0 charge: 40.6 Wh (96.7%) condition: 42.0/56.2 Wh (74.7%)
volts: 12.1 min: 10.8 model: SMP 45N1149 type: Li-ion serial:
status: Unknown
Info: Dual Core model: Intel Core i5-4300M bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache:
L2: 3 MiB
bogomips: 20762
Speed: 2054 MHz min/max: 800/3300 MHz Core speeds (MHz): 1: 2054 2: 1981
3: 2041 4: 2081
Type: l1tf
Device-1: Intel 4th Gen Core Processor Integrated Graphics
vendor: Lenovo ThinkPad T440p driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:0416 class-ID: 0300
Device-2: Acer SunplusIT Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-12:5 chip-ID: 5986:0268 class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4")
s-diag: 485mm (19.1")
Monitor-1: eDP-1 res: 1600x900 hz: 60 dpi: 132 size: 309x174mm (12.2x6.9")
diag: 355mm (14")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
v: 4.5 Mesa 21.2.3 compat-v: 3.0 direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
vendor: Lenovo ThinkPad T440p driver: snd_hda_intel v: kernel
bus-ID: 00:03.0 chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio
bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
Sound Server-1: ALSA v: k5.10.70-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Device-1: Intel Ethernet I217-LM vendor: Lenovo ThinkPad T440p
driver: e1000e v: kernel port: 3080 bus-ID: 00:19.0 chip-ID: 8086:153a
class-ID: 0200
IF: enp0s25 state: down mac:
Device-2: Intel Centrino Advanced-N 6235 driver: iwlwifi v: kernel
bus-ID: 03:00.0 chip-ID: 8086:088f class-ID: 0280
IF: wlp3s0 state: up mac:
Local Storage: total: 312.5 GiB used: 163.38 GiB (52.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HCC545032B9A300
size: 298.09 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: rev: CC0D scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Kingston
model: DataTraveler 3.0 size: 14.41 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: scheme: MBR
ID-1: / raw-size: 289.29 GiB size: 283.75 GiB (98.08%)
used: 160.5 GiB (56.6%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 54.0 C mobo: 0.0 C
Fan Speeds (RPM): cpu: 2709
Processes: 268 Uptime: 16h 8m wakeups: 2 Memory: 7.47 GiB
used: 3.59 GiB (48.1%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 12.0.1 Packages: 1894 pacman: 1864 lib: 480 flatpak: 0
snap: 30 Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.07
This is a really old CPU you’ve got there, it’s a 4th generation i5, about 7/8 years of age and only has two (2) cores. So it might be a little slow.
Nevertheless, to see what’s the holdup, run and post the output(s) of:
sudo top
This will provide real-time stats of your resource usage.
systemd-analyze critical-chain
and
systemd-analyze blame
Edit:
Please wrap any pasted terminal output in three (3) backtics (```) before and after the pasted text. Like this::
text
This will just ensure that it’s properly formatted and will be displayed like this:
Urna phasellus tincidunt elementum amet portaest sem adipiscing
ipsum metus rutrum nec
congue vivamus dolor sollicitudin
sit quisque felis aliquam
facilisis lacus vel orci erat.
instead of like this:
Making it much easier to read.
