Hi,
I’m a newbie and it shows.
I am trying to install python through the pamac UI.
I get this message which is confusing (and seems dangerous) to me.
- manjaro-system needs to be removed but it is a locked package
- pacman needs to be removed but it is a locked package
How do I remove these without damaging Manjaro?
isn’t python pre-installed as a default package?? please confirm
It is pre-installed. You’re trying to uninstall it but it is necessary for the system to run so it doesn’t allow you to do that
Hi @SheppeyMan,
That is because your system hasn’t been kept updated.
Manjaro is a curated rolling release, meaning it has to be kept up-to-date. And thee software you’re trying to install needs the newer version, so the older one needs to be replaced.
And no, don’t try not updating a part of it, as this will lead to a partial update state, which will break the system.
Edit:
My mistake. I read it as some kind of package/addon/plugin/extra for Python, not Python itself. But the rest about updates, installing those updates, installing software and so on is still applicable.
Python is pre-installed in Manjaro, and in fact, in most if not all linux distros. Check by typing
python --version
in terminal.
Unlike Windows, it’s already a GNU/Linux distro de facto standard to have python 2 and 3 interpreter pre-installed.
At terminal, run which python
and which python3
to display the path to the python2 and python3 interpreter.
You can run python
or python3
to start the python 2 interpreter and python 3 interpreter respectively.
