I recently upgraded my WiFi on my old laptop that runs manjaro xfce.
It worked perfectly for a few. However it has issues where the wifi chip will randomly turn off. I watch livestreams on that laptop primarily. Wanted bluetooth to connect an xbox one controller.
I was thinking it was all the other 2.4g networks interfering. Maybe the bluetooth. Turning the bluetooth off helps for a few on 2.4g. However it’s been doing it a lot tonight. I enabled the 5g radio on my router and it’s even worse.
The second there is any major load. The chip shuts down in a way. I have to reboot the computer for it to work again. Doing a ping on my router and launching a browser. It’ll say no buffer space available. When it was pinging fine until I launched a browser.
Is it just the chip I bought? I thought intel was the best nic you could get. It worked perfectly when I initially installed it. Any suggestions?
EDIT
I failed to mention what model it was. I had an image but it wouldn’t let me post it.
I upgraded to an Intel 7260HMW from a Realtek RTL8188CE. The laptop is a Toshiba L655-S5155.
Please read this: How to provide good information
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
What did you do exactly?
What’s the output to:
nmcli device wifi list
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel, … you have without typing it every time
I re-seated the card yesterday. As well as added some electrical tape to the back of it since there was a label insulating the back side of the old chip.
I swapped the WiFi chip on my Toshiba Satellite L655-S5155. From a Realtek RTL8188CE to an Intel 7260HMW. I’ll be upgrading the processor soon too to an i5 560m.
Infra 8 130 Mbit/s 100 ▂▄▆█ WPA2
Infra 48 405 Mbit/s 45 ▂▄__ WPA2
Infra 1 130 Mbit/s 40 ▂▄__ WPA2
Infra 153 405 Mbit/s 40 ▂▄__ WPA2
Infra 36 405 Mbit/s 39 ▂▄__ --
Infra 36 405 Mbit/s 39 ▂▄__ WPA2
Infra 36 540 Mbit/s 34 ▂▄__ WPA2
Infra 2 195 Mbit/s 32 ▂▄__ WPA2
Infra 48 405 Mbit/s 32 ▂▄__ WPA2
Infra 2 130 Mbit/s 29 ▂___ WPA2
Infra 40 405 Mbit/s 24 ▂___ WPA2
Infra 48 540 Mbit/s 24 ▂___ WPA2
Infra 161 405 Mbit/s 22 ▂___ WPA2
Infra 157 540 Mbit/s 20 ▂___ WPA2
Infra 48 405 Mbit/s 19 ▂___ WPA2
Infra 149 270 Mbit/s 19 ▂___ WPA2
Infra 36 540 Mbit/s 17 ▂___ WPA2
Infra 165 0 Mbit/s 17 ▂___ WEP
The first one listed is my network. However on my tablet I used WiFi Analyzer and it shows a lot more WiFi networks than listed from that command. I removed some info from the output. If it’s absolutely needed I can post the un-edited output.
So far I changed my 2.4ghz to 802.11b/g/n only from mixed. I’m on channel 8 since it has the least devices on it. However I’m thinking I should leave it to auto. It’s been on 8 for a while, I was troubleshooting another device a while ago. I also added a “iwlwifi-7260-14.ucode” file to my firmware directory I got from Intel’s site here. However I don’t think it’s being used. I added it to the /lib/firmware/ directory.
It’s been more stable but I think its because its the weekend and the weather is nice. People are out and about. Not at home as much using their devices. I still had the same issue last night a little after midnight. All day it was fine though and even now I have it playing a stream just fine.
In the future, when providing code/output, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text so that the output looks like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.
Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat.
Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur.
Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
instead of like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.`
(as that makes both our lives much easier)
No need to do anything right now as I’m an editor here on this site and have fixed it for you already. However, in the future I might not see your post so review my edits by pushing the orange pencil above the post I just fixed.
You were lucky to still have a BIOS machine because on UEFI systems, changing brands is a royal pain in the lower abdomen.
Try 5.4 and 5.10 LTS (Long Term Support) first and see what that does.
You’re on your own channel not in use by anyone else so that’s not it.
I’ve changed to the 5.4 LTS kernel. So far so good. The WiFi did mess up earlier but that was on 5.11.
If it stays playing a stream throughout the night I’ll try the 5.9.16-1 kernel tomorrow. It was installed when I initially installed Manjaro a few weeks ago. Switched from an old Linux Lite install. Pacman is much better than apt.
Could it be that I have my router set to specifically channel 8? I’m thinking other routers in the area are set to auto and jump around often.
Looking at WiFi analyzer there are no good channels in the 2.4g or 5g range that my router can do. There can be anywhere from 6-14 other routers on channel 8.
I don’t see how. I added up all the different access points WiFi analyzer found. 124 networks in the 2.4ghz band. 60 in the 5ghz band.
I wasn’t having these disconnection issues on the old WiFi module/chip. Could it be the hardware itself? I got it used from ebay. However the seller is reputable.
One thing I’ve noticed is when I run a speedtest. I get up to 80Mbps out of my total 130. I thought 2.4 was limited to 40Mbps when there are so many networks. Could that be why the WiFi is being disabled on my laptop?
Thanks.
EDIT:
Another thing I’ve noticed is forum posts where people are saying they disabled power saving features. However that’s on windows. I tried locating the iwlwifi.conf file in modprobe.d however there is nothing inside of modprobe.d. Maybe I needed sudo to view the files. Idk.
Well I’ve found this. It works but its not optimal.
I remember reading somewhere while troubleshooting a WiFi card in a desktop that Realtek is considered a joke in the I.T world. I go to buy Intel thinking it’s better and have these issues. Go figure, assuming and all.
EDIT: It definitely was that specific 7260 module. I returned it and bought a Wireless-N model and haven’t had an issue. No 5ghz but I don’t need it. Just wanted bluetooth and faster speeds over 2.4.
Kernel isn’t going to change a thing. The problem is the hardware. Unfortunately. The HMW model of the module has problems with interference. It’s a common issue among the 7260HMW modules from what I gather.
I’ll try 5.10 as you suggest. However it isn’t listed as LTS.
I’m not on my own channel. There are no good channels in my area. I got those numbers from WiFi Analyzer on my tablet. Idk how accurate that is but it seems accurate.
Seems to me I bought the wrong WiFi module. $15 down the drain. Should’ve done my research. The script I found works to reset it but I can’t get cron to run it as suggested. It’s not optimal but at least I don’t have to restart the laptop now.
I’ll let you know if there’s any difference on 5.10. However I think my last post is the solution sadly.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
