I want my pc to boot into the tty, not using other tty2-tty6 but have it boot terminal so i can then choose to start a desktop environment. When i first installed manjaro and learned you could have multiple window managers and got awesome as well kde plasma. The login screen lets you choose sessions and it changes without problem.
I then found out you can make X not start by default by doing: sudo systemctl set-default multi-user.target. Then if wanting to go into a desktop enviornment just do: startx.
Heres my problem: when i startx, it goes automatically into plasma. And when i log out it goes into tty. I can no longer change sessions or choose awesome should i want. At least that i know of.
Does anybody know how i can keep it so i boot to tty without losing my ability to go into awesome or plasma? Any help would be appreciated, thank you!
