Good evening folks,
I recently build a new system, I have used Manjaro on my old one for years with only a few minor problems now and then, so I really didn’t expect the new one could be that unstable with lot of problems.
Hybernation isn’t working at all, after the first hibernation period the system is basically nuts. It reacts to input by waking up, but sometimes it immediately goes back so sleep. Sometimes I can log in, than it logs me out again, sometimes several times. I basically have to restart, to be able to use it again.
I could live without hibernation. But nearly everytime I use the system some applications just don’t start at all. Sometimes from the beginning, sometimes they work for 20 Min or 1 hour, than crash. Sometimes I can just restart them, sometimes they won’t restart. Be it Browser, Steam or even the protocol viewer that comes with the OS. After a restart they mostly do work again, but usually they crash again later on.
Every component is brand new, so hardware issues seems rather unlikely. The system is freshly installed. I could only install it with open graphic drivers, every attempt to use the proprietary ones results in a freeze while the live-system trys to boot. Installing the propietary drivers later on works, but the whole UI often freezes while using the proprietary drivers. Since the sound continues working in that cases, I assume it’s a problem with the graphic drivers.
I’m basically a little bit lost, because there are so many problems. The only thing I found so far are a few btrfs errors in the log:
22:43:19 kernel: BTRFS error (device nvme0n1p2): bdev /dev/nvme0n1p2 errs: wr 0, rd 0, flush 0, corrupt 525, gen 0
22:43:19 kernel: BTRFS warning (device nvme0n1p2): csum failed root 256 ino 289124 off 32444416 csum 0x1031a2ee expected csum 0xe2542cd0 mirror 1
22:43:19 kernel: BTRFS error (device nvme0n1p2): bdev /dev/nvme0n1p2 errs: wr 0, rd 0, flush 0, corrupt 524, gen 0
22:43:19 kernel: BTRFS error (device nvme0n1p2): bdev /dev/nvme0n1p2 errs: wr 0, rd 0, flush 0, corrupt 523, gen 0
22:43:19 kernel: BTRFS error (device nvme0n1p2): bdev /dev/nvme0n1p2 errs: wr 0, rd 0, flush 0, corrupt 522, gen 0
22:43:19 kernel: BTRFS error (device nvme0n1p2): bdev /dev/nvme0n1p2 errs: wr 0, rd 0, flush 0, corrupt 521, gen 0
22:43:19 kernel: BTRFS error (device nvme0n1p2): bdev /dev/nvme0n1p2 errs: wr 0, rd 0, flush 0, corrupt 520, gen 0
22:43:19 kernel: BTRFS error (device nvme0n1p2): bdev /dev/nvme0n1p2 errs: wr 0, rd 0, flush 0, corrupt 519, gen 0
22:43:19 kernel: BTRFS error (device nvme0n1p2): bdev /dev/nvme0n1p2 errs: wr 0, rd 0, flush 0, corrupt 518, gen 0
22:43:19 kernel: BTRFS error (device nvme0n1p2): bdev /dev/nvme0n1p2 errs: wr 0, rd 0, flush 0, corrupt 517, gen 0
22:43:19 kernel: BTRFS error (device nvme0n1p2): bdev /dev/nvme0n1p2 errs: wr 0, rd 0, flush 0, corrupt 516, gen 0
22:43:19 kernel: btrfs_dev_stat_inc_and_print: 172 callbacks suppressed
22:43:19 kernel: btrfs_print_data_csum_error: 172 callbacks suppressed
22:42:19 kernel: BTRFS error (device nvme0n1p2): bdev /dev/nvme0n1p2 errs: wr 0, rd 0, flush 0, corrupt 343, gen 0
22:42:19 kernel: BTRFS warning (device nvme0n1p2): csum failed root 256 ino 289124 off 28442624 csum 0x3a839dfc expected csum 0x4f4099c6 mirror 1
22:42:19 kernel: BTRFS error (device nvme0n1p2): bdev /dev/nvme0n1p2 errs: wr 0, rd 0, flush 0, corrupt 342, gen 0
22:42:19 kernel: BTRFS warning (device nvme0n1p2): csum failed root 256 ino 289124 off 28377088 csum 0x8df0e1aa expected csum 0x246c9961 mirror 1
22:42:19 kernel: BTRFS error (device nvme0n1p2): bdev /dev/nvme0n1p2 errs: wr 0, rd 0, flush 0, corrupt 341, gen 0
22:42:19 kernel: BTRFS warning (device nvme0n1p2): csum failed root 256 ino 289124 off 28311552 csum 0x058268ba expected csum 0xf048d3dc mirror 1
22:42:19 kernel: BTRFS error (device nvme0n1p2): bdev /dev/nvme0n1p2 errs: wr 0, rd 0, flush 0, corrupt 340, gen 0
22:42:19 kernel: BTRFS warning (device nvme0n1p2): csum failed root 256 ino 289124 off 28246016 csum 0xeb994f8f expected csum 0xf45bd499 mirror 1
22:42:19 kernel: BTRFS error (device nvme0n1p2): bdev /dev/nvme0n1p2 errs: wr 0, rd 0, flush 0, corrupt 339, gen 0
22:42:19 kernel: BTRFS warning (device nvme0n1p2): csum failed root 256 ino 289124 off 28131328 csum 0x4cfac7b1 expected csum 0xa8341472 mirror 1
22:42:19 kernel: BTRFS error (device nvme0n1p2): bdev /dev/nvme0n1p2 errs: wr 0, rd 0, flush 0, corrupt 338, gen 0
22:42:19 kernel: BTRFS warning (device nvme0n1p2): csum failed root 256 ino 289124 off 28000256 csum 0x753737ff expected csum 0xb6a94553 mirror 1
22:42:19 kernel: BTRFS error (device nvme0n1p2): bdev /dev/nvme0n1p2 errs: wr 0, rd 0, flush 0, corrupt 337, gen 0
22:42:19 kernel: BTRFS warning (device nvme0n1p2): csum failed root 256 ino 289124 off 27934720 csum 0xc7d9480f expected csum 0x834ab2ed mirror 1
22:42:19 kernel: BTRFS error (device nvme0n1p2): bdev /dev/nvme0n1p2 errs: wr 0, rd 0, flush 0, corrupt 336, gen 0
22:42:19 kernel: BTRFS warning (device nvme0n1p2): csum failed root 256 ino 289124 off 27869184 csum 0xb3531cc7 expected csum 0x40f21c77 mirror 1
22:42:19 kernel: BTRFS error (device nvme0n1p2): bdev /dev/nvme0n1p2 errs: wr 0, rd 0, flush 0, corrupt 335, gen 0
22:42:19 kernel: BTRFS warning (device nvme0n1p2): csum failed root 256 ino 289124 off 27803648 csum 0x32460767 expected csum 0xcc0c9d78 mirror 1
22:42:19 kernel: BTRFS error (device nvme0n1p2): bdev /dev/nvme0n1p2 errs: wr 0, rd 0, flush 0, corrupt 334, gen 0
22:42:19 kernel: BTRFS warning (device nvme0n1p2): csum failed root 256 ino 289124 off 27738112 csum 0x313b108b expected csum 0xb386547e mirror 1
22:34:22 kernel: BTRFS info (device nvme0n1p2 state M): use zstd compression, level 1
22:34:22 kernel: BTRFS info (device nvme0n1p2): enabling free space tree
22:34:22 kernel: BTRFS info (device nvme0n1p2): turning on async discard
22:34:22 kernel: BTRFS info (device nvme0n1p2): enabling ssd optimizations
22:34:22 kernel: BTRFS info (device nvme0n1p2): checking UUID tree
22:34:22 kernel: BTRFS info (device nvme0n1p2): start tree-log replay
22:34:22 kernel: BTRFS info (device nvme0n1p2): bdev /dev/nvme0n1p2 errs: wr 0, rd 0, flush 0, corrupt 333, gen 0
22:34:22 kernel: BTRFS info (device nvme0n1p2): using crc32c (crc32c-lib) checksum algorithm
22:34:22 kernel: BTRFS info (device nvme0n1p2): first mount of filesystem 68dd2443-d32a-431c-80ee-193884bc1a3f
22:34:22 kernel: BTRFS: device fsid 68dd2443-d32a-431c-80ee-193884bc1a3f devid 1 transid 545 /dev/nvme0n1p2 (259:2) scanned by mount (313)
22:34:22 kernel: Btrfs loaded, zoned=yes, fsverity=yes
I already tried using the LTS-Kernel 6.12.63-1 instead of 6.18.3-2, the problems remained.
At first I used the 25.1 Manjaro Release and switched to the 26 Release, the problems remained.
I’m thinking about reinstalling the system again with ext4 to see, if that improves the stability. But with btrfs as the recommended filesystem I wonder why using it would cause that much trouble.
I happily provide more info, right now I’m just a bit clueless where to start ![]()
System specs:
Kernel: 6.18.3-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
root=UUID=68dd2443-d32a-431c-80ee-193884bc1a3f rw rootflags=subvol=@
quiet splash resume=UUID=8a31998a-cc31-4d57-b1f4-457959766495
udev.log_priority=3
Desktop: GNOME v: 49.2 tk: GTK v: 3.24.51 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 49.2 Distro: Manjaro
base: Arch Linux
Type: Desktop Mobo: Gigabyte model: B850 AORUS ELITE WIFI7 v: x.x
serial: <superuser required> uuid: <superuser required> Firmware: UEFI
vendor: American Megatrends LLC. v: F6 date: 07/16/2025
System RAM: total: 32 GiB available: 30.46 GiB used: 3.13 GiB (10.3%)
Device-1: Channel-A DIMM 0 type: no module installed
Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 16 GiB speed: 6400 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: TeamGroup
part-no: UD5-6400 serial: <filter>
Device-3: Channel-B DIMM 0 type: no module installed
Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 7 9800X3D bits: 64 type: MCP arch: Zen 5 gen: 5
level: v4 note: check built: 2024+ process: TSMC n4 (4nm) family: 0x1A (26)
model-id: 0x44 (68) stepping: 0 microcode: 0xB404035
Topology: cpus: 1x dies: 1 clusters: 1 cores: 8 smt: <unsupported> cache:
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 8 MiB desc: 8x1024 KiB
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 603 min/max: 603/5272 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 603 2: 603 3: 603
4: 603 5: 603 6: 603 7: 603 8: 603 bogomips: 75054
apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl avx_vnni bmi1 bmi2 bpext
bus_lock_detect cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov
cmp_legacy constant_tsc cpb cppc cpuid cpuid_fault cqm cqm_llc
cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu
fsgsbase fsrm fxsr fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe movdir64b movdiri msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx
ospke osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni
stibp succor svm svm_lock syscall tce topoext tsc tsc_adjust tsc_scale
umip user_shstk v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme
vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves xtopology
Type: spec_rstack_overflow mitigation: IBPB on VMEXIT only
conditional; STIBP: disabled; PBRSB-eIBRS: Not affected; BHI: Not
affected
Type: vmscape mitigation: IBPB on VMEXIT
Device-1: NVIDIA GB203 [GeForce RTX 5080] vendor: ASUSTeK driver: nouveau
v: kernel alternate: nova_core non-free: 550-580.xx+
status: current (as of 2025-11) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 5 speed: 32 GT/s lanes: 16
ports: active: DP-6,HDMI-A-2 empty: DP-4,DP-5 bus-ID: 01:00.0
chip-ID: 10de:2c02 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Granite Ridge [Radeon Graphics]
vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: none empty: DP-1, DP-2, DP-3, HDMI-A-1,
Writeback-1 bus-ID: 10:00.0 chip-ID: 1002:13c0 class-ID: 0300 temp: 35.0 C
compositor: gnome-shell driver: gpu: nouveau display-ID: 0
Monitor-1: DP-6 model: LG (GoldStar) ULTRAGEAR serial: <filter>
built: 2023 res: 2560x1440 dpi: 109 gamma: 1.2 chroma: red: x: 0.686
y: 0.310 green: x: 0.263 y: 0.671 blue: x: 0.149 y: 0.055 white: x: 0.314
y: 0.329 size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
modes: 2560x1440, 1920x1080, 1280x720, 1024x768, 800x600, 720x480,
640x480
Monitor-2: HDMI-A-2 model: LG (GoldStar) ULTRAGEAR serial: <filter>
modes: 2560x1440, 3840x2160, 1920x1080, 1280x720, 1024x768, 800x600,
720x576, 720x480, 640x480
EDID-Warnings: 1: parse_edid: unhandled CEA mode 93 2: parse_edid:
unhandled CEA mode 94 3: parse_edid: unhandled CEA mode 95 4: parse_edid:
unhandled CEA mode 96 5: parse_edid: unhandled CEA mode 97
API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 0 drv: zink
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: zink surfaceless:
drv: zink wayland: drv: zink x11: drv: zink
API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 25.3.2-arch1.1 glx-v: 1.4
direct-render: yes renderer: zink Vulkan 1.4(NVIDIA GeForce RTX 5080 (NVK
GB203) (MESA_NVK)) device-ID: 10de:2c02 memory: 15.55 GiB unified: no
display-ID: :0.0
Info: Tools: api: eglinfo,glxinfo x11: xprop,xrandr
Device-1: NVIDIA GB203 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 5 speed: 32 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:22e9
class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
bus-ID: 10:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Gigabyte
bus-ID: 10:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Shokz Loop120 by driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 7-1.2.2.1:8
chip-ID: 3511:2ef2 class-ID: 0102 serial: <filter>
API: ALSA v: k6.18.3-2-MANJARO status: kernel-api tools: N/A
Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
status: active 2: wireplumber status: active
Device-1: Realtek RTL8922AE 802.11be PCIe Wireless Network Adapter
driver: rtw89_8922ae v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
port: d000 bus-ID: 07:00.0 chip-ID: 10ec:8922 class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: c000 bus-ID: 08:00.0
IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:6 chip-ID: 0bda:8922
Local Storage: total: 955.74 GiB used: 132.18 GiB (13.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lexar model: SSD NM790 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 18950 temp: 42.9 C scheme: GPT
ID-2: /dev/sdc maj-min: 8:32 vendor: Transcend model: JetFlash 2G
size: 1.88 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter> fw-rev: 8.07
scheme: MBR
ID-1: / raw-size: 920.07 GiB size: 920.07 GiB (100.00%)
used: 132.18 GiB (14.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 68dd2443-d32a-431c-80ee-193884bc1a3f
used: 664 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 57D7-5569
ID-3: /home raw-size: 920.07 GiB size: 920.07 GiB (100.00%)
ID-4: /run/media/thorsten/STICK 2 GB raw-size: 1.87 GiB
size: 1.87 GiB (99.79%) used: 44 KiB (0.0%) fs: vfat dev: /dev/sdc1
maj-min: 8:33 label: STICK 2 GB uuid: 8C03-66C5
ID-5: /var/cache raw-size: 920.07 GiB size: 920.07 GiB (100.00%)
ID-6: /var/log raw-size: 920.07 GiB size: 920.07 GiB (100.00%)
ID-1: swap-1 type: partition size: 33.51 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 8a31998a-cc31-4d57-b1f4-457959766495
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Hub-2: 1-3:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
Device-1: 1-3.1:4 info: Transcend Information JetFlash type: mass storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 200mA chip-ID: 8564:1000 class-ID: 0806
serial: <filter>
Device-2: 1-5:3 info: Yubicom Yubikey 4/5 OTP+U2F+CCID
type: keyboard,HID,smart card driver: hid-generic,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 30mA
chip-ID: 1050:0407 class-ID: 0b00
Device-3: 1-6:5 info: Integrated Express GIGABYTE Device type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5711 class-ID: 0300
Device-4: 1-9:6 info: Realtek Bluetooth Radio type: bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 0bda:8922 class-ID: e001 serial: <filter>
Hub-3: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
Hub-4: 2-3:2 info: Realtek Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-8: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-9: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-10: 7-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 7-1.1:3 info: HP Officejet 6500 E710n-z
type: printer,mass storage driver: usb-storage,usblp interfaces: 5 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
chip-ID: 03f0:5412 class-ID: 0701 serial: <filter>
Hub-11: 7-1.2:4 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Device-1: 7-1.2.1:5 info: Evoluent VerticalMouse 4 type: mouse
chip-ID: 1a7c:0191 class-ID: 0301
Hub-12: 7-1.2.2:6 info: Cambridge Silicon Radio Mpow HC5 Headset in
charging mode - USB Hub ports: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 0a12:4010 class-ID: 0900
Device-1: 7-1.2.2.1:8 info: Shokz Loop120 by type: HID,audio
driver: hid-generic,snd-usb-audio,usbhid interfaces: 5 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 3511:2ef2
Hub-13: 7-1.2.3:7 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-14: 7-1.2.3.2:9 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 7-1.2.3.2.3:11 info: Philips Speech Processing USB Keyboard
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 0911:2188 class-ID: 0301 serial: <filter>
Device-2: 7-1.2.3.3:10 info: Philips Speech Processing
System Temperatures: cpu: 41.9 C mobo: 25.0 C gpu: amdgpu temp: 36.0 C
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1134 libs: 339 tools: gnome-software,pamac
pm: flatpak pkgs: 0
1: https://mirror.23m.com/manjaro/stable/$repo/$arch
2: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
3: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
4: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
5: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
6: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
7: https://manjaro.kurdy.org/stable/$repo/$arch
8: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
9: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 333
1: cpu: 7.5% command: kgx pid: 7170 mem: 228.6 MiB (0.7%)
2: cpu: 4.0% command: firefox pid: 4598 mem: 395.7 MiB (1.2%)
3: cpu: 3.4% command: firefox pid: 4103 mem: 555.9 MiB (1.7%)
4: cpu: 3.0% command: gnome-shell pid: 2236 mem: 316.3 MiB (1.0%)
5: cpu: 2.8% command: ./firefox.real pid: 6559 mem: 449.9 MiB (1.4%)
Memory top: 5 of 333
1: mem: 555.9 MiB (1.7%) command: firefox pid: 4103 cpu: 3.4%
2: mem: 449.9 MiB (1.4%) command: ./firefox.real pid: 6559 cpu: 2.8%
3: mem: 395.7 MiB (1.2%) command: firefox pid: 4598 cpu: 4.0%
4: mem: 340.3 MiB (1.0%) command: nautilus pid: 5899 cpu: 1.2%
5: mem: 325.6 MiB (1.0%) command: firefox pid: 4496 cpu: 0.2%
Processes: 333 Power: uptime: 41m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.12 GiB services: gsd-power,
power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
tool: systemctl
Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: kgx inxi: 3.3.40
