Hope I picked the right forum category to post in. I’m actually having couple of weird problems with this system but will start with that the system is hanging when running updates (pacman -Syu). Some background, this is a newly installed Manjaro system using ISO downloaded a week ago (just the default xfce version).
First time running pacman -Syu and it will start going through the download process of several hundred package updates. It randomly freezes with the most recent packages at the bottom hanging at random percents. I open a new tab terminal and can ping my router and 8.8.8.8.
Other weird issues so far with using this system 76 meekat someone gave me. I’ve tried the updates several times and keep reproducing this issue with it handing. I’ll do a shutdown -r now come back into the system unlock the pacman db and try again. I even tried reinstalling from the USB ISO and totally start over. Twice the clock has been way off (certificate is not yet valid message) so I fixed by running ‘timedatectl set-ntp true’
I’m not sure what commands or outputs would be helpful to get started on this. I wonder if its a hardware issue. Also when the system hangs im usually no logner able to ssh into it. This is being setup as a small home server but for the pacman updates issue I have a local monitor and keyboard connected.
One other weird issue if that’s not enough a few times the system seemed like it went to sleep, display/monitor turned off. I went back later and disabled that settings but it still happened if I leave it running for hours. When I tap the keyboard to wake the system up its like it rebooted itself. I tried to check logs for kernel or crash using some commands I found online but didn’t find anything.
Apologies for throwing many weird random issues together. I’m just not sure where to start as this is a fresh install I’m trying on some used hardware. Maybe I need to replace the small internal cmos battery? But would that be causing all these weird problems?
Kernel: 6.6.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=8e3400b0-57a4-46ad-8bf8-17bd3755d1b5 rw quiet splash
udev.log_priority=3
Console: pty pts/4 DM: LightDM v: 1.32.0 Distro: Manjaro base: Arch Linux
Type: Desktop System: System76 product: Meerkat v: meer4 serial: <filter>
Chassis: type: 3 v: meer4 serial: N/A
Mobo: Intel model: NUC8BEB v: J72693-303 serial: <filter>
part-nu: BOXNUC8i3BEK uuid: 8fc77b9f-b1d6-828d-6361-94c691a5dc70 UEFI: Intel
v: BECFL357.86A.0048.2018.0919.2013 date: 09/19/2018
System RAM: total: 4 GiB available: 3.7 GiB used: 1.18 GiB (31.8%)
igpu: 64 MiB
Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None
Device-1: SODIMM1 type: DDR4 detail: synchronous size: 4 GiB
speed: 2400 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits): data: 64
total: 64 manufacturer: Crucial part-no: CT4G4SFS824A.C8FF serial: <filter>
Device-2: SODIMM2 type: no module installed
Slot: 0 type: PCIe lanes: 16 status: in use info: J6B2 length: long
volts: 3.3 bus-ID: 00:01.0
Slot: 1 type: PCIe lanes: 1 status: in use info: J6B1 length: short
volts: 3.3 bus-ID: 00:1c.3
Slot: 2 type: PCIe lanes: 1 status: in use info: J6D1 length: short
volts: 3.3 bus-ID: 00:1c.4
Slot: 3 type: PCIe lanes: 1 status: in use info: J7B1 length: short
volts: 3.3 bus-ID: 00:1c.5
Slot: 4 type: PCIe lanes: 1 status: in use info: J8B4 length: short
volts: 3.3 bus-ID: 00:1c.6
Info: model: Intel Core i3-8109U socket: BGA1528 (U3E1) note: check bits: 64
type: MT MCP arch: Coffee Lake gen: core 8 level: v3 note: check built: 2017
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 0xA (10)
microcode: 0xF4
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 3264 high: 3600 min/max: 400/3600 base/boost: 2300/3500
scaling: driver: intel_pstate governor: powersave volts: 0.8 V
ext-clock: 100 MHz cores: 1: 3600 2: 3475 3: 2383 4: 3600 bogomips: 24008
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-U GT3e [Iris Plus Graphics 655] driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: DP-1 empty: DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:3ea5
class-ID: 0300
Display: x11 server: X.org v: 1.21.1.12 compositor: xfwm4 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 tty: 190x42
Monitor-1: DP-1 model: Dell P2217 serial: <filter> built: 2016
res: 1680x1050 dpi: 90 gamma: 1.2 chroma: red: x: 0.635 y: 0.357 green:
x: 0.310 y: 0.643 blue: x: 0.153 y: 0.071 white: x: 0.314 y: 0.329
size: 474x296mm (18.66x11.65") diag: 559mm (22") ratio: 16:10
modes: 1680x1050, 1920x1080, 1920x1080i, 1280x1024, 1152x864, 1280x720,
1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
device: 1 drv: swrast surfaceless: drv: iris inactive: gbm,wayland,x11
API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 24.0.2-manjaro1.1
note: console (EGL sourced) renderer: Mesa Intel Iris Plus Graphics 655 (CFL
GT3), llvmpipe (LLVM 16.0.6 256 bits)
Device-1: Intel Cannon Point-LP High Definition Audio driver: snd_hda_intel
chip-ID: 8086:9dc8 class-ID: 0403
API: ALSA v: k6.6.25-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: n/a (root, process) with:
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
Device-2: Intel Ethernet I219-V driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:15be class-ID: 0200
Device-3: ASIX AX88179 Gigabit Ethernet driver: ax88179_178a type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-3:2
chip-ID: 0b95:1790 class-ID: ff00 serial: <filter>
IF: enp0s20f0u3 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Local Storage: total: 232.89 GiB used: 8.02 GiB (3.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 1B2QEXE7 temp: 26.9 C
scheme: GPT
ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%) used: 8.02 GiB (3.5%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 8e3400b0-57a4-46ad-8bf8-17bd3755d1b5
used: 296 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: B8E8-30ED
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:2 info: Shenzhen Riitek Wireless Receiver
type: mouse,keyboard driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 50mA
chip-ID: 1997:2466 class-ID: 0301
Device-2: 1-2:3 info: YICHIP Wireless Device type: keyboard,mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 3151:3020 class-ID: 0301
serial: <filter>
Device-3: 1-10:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
Device-1: 2-3:2 info: ASIX AX88179 Gigabit Ethernet type: Network
driver: ax88179_178a interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 496mA chip-ID: 0b95:1790 class-ID: ff00
serial: <filter>
System Temperatures: cpu: 33.0 C pch: 37.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 928 libs: 296 tools: pamac
1: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
2: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 199
1: cpu: 100% command: ps pid: 2100 mem: 4.12 MiB (0.1%)
2: cpu: 0.9% command: Xorg pid: 461 mem: 102.4 MiB (2.7%)
3: cpu: 0.4% command: xfce4-terminal pid: 999 mem: 52.4 MiB (1.3%)
4: cpu: 0.2% command: sudo pid: 2089 mem: 7.62 MiB (0.2%)
5: cpu: 0.1% command: [kworker/3:2-events] pid: 81 mem: 0.00 MiB (0.0%)
Memory top: 5 of 199
1: mem: 167.0 MiB (4.4%) command: xfdesktop pid: 695 cpu: 0.0%
2: mem: 102.4 MiB (2.7%) command: Xorg pid: 461 cpu: 0.9%
3: mem: 84.3 MiB (2.2%) command: xfwm4 pid: 638 cpu: 0.1%
4: mem: 62.2 MiB (1.6%) command: blueman-applet started-by: python pid: 735
cpu: 0.0%
5: mem: 57.4 MiB (1.5%) command: nm-applet pid: 743 cpu: 0.0%
Processes: 199 Power: uptime: 3h 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 1.47 GiB services: upowerd,xfce4-power-manager
Init: systemd v: 255 default: graphical tool: systemctl
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Sudo (sudo) v: 1.9.15p5
default: Bash v: 5.2.26 running-in: pty pts/4 (SSH) inxi: 3.3.33
