Why my mirror is not approved? Do they also require correct PTR records?
It seems like a joke, but you cannot foul us! The truth has been said
Manjaro is supporting 5G!!!
@akin2silver Didn’t you also have this problem:
(and what did you do to ram it through the approval process?)
No issues with PTR records as I was using a CDN I couldn’t set them up even if I tried.
To get it through approval I just @ ed Phil m in gitlab in a comment on my issue. Mine was slightly escalated as Australia had none working and 2 broken ones listed.
Yeah I would say if it’s been 2 weeks just ping Phil in a comment. If you look at the closed issues most of them had to do the same
Thanks, i’m added a comment just now)
very low speed from triolan
:: Обновление баз данных пакетов...
core 169,8 KiB 186 KiB/s 00:01 [###########################################################] 100%
extra 1994,9 KiB 181 KiB/s 00:11 [###########################################################] 100%
^Community 3,3 MiB 72,7 KiB/s 00:44 [##############################-----------------------------] 51%
Interrupt signal received
manjaro (2a03:7380:114:42ab:68ba:c180:8b76:3fe7) -> fastmirror.pp.ua 2021-02-03T18:17:05+0200
Keys: Help Display mode Restart statistics Order of fields quit
Packets Pings
Host Loss% Snt Last Avg Best Wrst StDev
1. 2a03:7380:114:42ab::1 0.0% 61 3.6 4.7 1.5 26.5 5.9
2. 2a03:7380:114::5 1.6% 61 3.1 5.3 1.7 58.5 8.6
3. 2a03:7380:c0:13::5 0.0% 61 2.0 5.9 1.9 46.7 8.9
4. 2a03:7380:c0:f::2 0.0% 61 3.0 5.7 2.2 39.6 6.5
5. rs.v6.ix.net.ua 0.0% 61 5.3 6.0 2.5 27.6 5.8
6. internationalbandwidth-svc075496-ic364176.c.telia.net 3.3% 61 3.5 9.8 3.2 121.9 17.4
7. 2a01:d0:0:1c::43 1.6% 61 31.4 36.5 30.8 111.6 11.7
8. 2a01:d0:ffff:7a02::2 3.3% 61 34.5 42.7 32.1 87.4 10.5
9. (waiting for reply)
Hello. For now repo setup to 1GBps channel and IPv6 works with 6to4 tunnel. That means your traffic goes from Hibraltar to Ukraine using tunnel.
