Hi,
I just got my new pinephone but the damn thing didn’t initialize with a setup sequence – it just came up asking for a passcode! How do I reset it? I tried removing the battery, which didn’t work. I’m stuck.
tonyvr
Oh, I didn’t install a SIM or SDCard yet. I just removed tag from battery and turned it on.
Found the answer on Reddit: 123456
Oh, it also says that you can reset the passcode with linux ‘passwd’ command, but make sure it is all numeric digits or you are screwed!
