I have the same problem, I just can’t install it on my machine.
Why? After almost 10 hours of digging I found why!
In the kernel 5.15 that the new Manjaro distributions use (XFCE, KDE or GNOME) the is a serious problem with EFI or UEFI support.
The setup always fail to set the grub-install on /boot/efi.
I read all the articles related with the subject, tried everything and no EFI install, so I looked for more info.
Here is the problem:
The kernel module for efivarsfs is obsolete, the new module is fs-efivars.
The problem is that that module is not in the kernel version 5.10 of Manjaro, instead the old one is as you can see here:
The new one doesn’t even show in the kernel modules list.
But if you check the content of /proc/config.gz you see this:
[manjaro@manjaro k_sources]$ zcat /proc/config.gz | grep CONFIG_EFI
CONFIG_EFI=y
CONFIG_EFI_STUB=y
CONFIG_EFI_MIXED=y
CONFIG_EFI_PARTITION=y
# CONFIG_EFI_VARS is not set
CONFIG_EFI_ESRT=y
CONFIG_EFI_VARS_PSTORE=y
CONFIG_EFI_VARS_PSTORE_DEFAULT_DISABLE=y
CONFIG_EFI_RUNTIME_MAP=y
# CONFIG_EFI_FAKE_MEMMAP is not set
CONFIG_EFI_SOFT_RESERVE=y
CONFIG_EFI_RUNTIME_WRAPPERS=y
CONFIG_EFI_GENERIC_STUB_INITRD_CMDLINE_LOADER=y
CONFIG_EFI_BOOTLOADER_CONTROL=m
CONFIG_EFI_CAPSULE_LOADER=m
# CONFIG_EFI_TEST is not set
CONFIG_EFI_RCI2_TABLE=y
# CONFIG_EFI_DISABLE_PCI_DMA is not set
CONFIG_EFI_EMBEDDED_FIRMWARE=y
CONFIG_EFI_DEV_PATH_PARSER=y
CONFIG_EFI_EARLYCON=y
CONFIG_EFI_CUSTOM_SSDT_OVERLAYS=y
CONFIG_EFIVAR_FS=y
# CONFIG_EFI_PGT_DUMP is not set
Noting the settings:
CONFIG_EFIVAR_FS=y // The new version
# CONFIG_EFI_VARS is not set // The old one commented and not set
Therefore when the setup tries to find the efivars it fails.
Someone forgot something… (just a thought, perhaps…)
Hi @joaorsilva ,
I wonder whether you could consider another that it is not the problem you posted, because the output on my system is the same as yours.
Here is the output of the terminal command on my system: lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 223,6G 0 disk
├─sda1 8:1 0 500M 0 part /boot/efi
├─sda2 8:2 0 3,9G 0 part [SWAP]
├─sda3 8:3 0 97,7G 0 part /
└─sda4 8:4 0 121,5G 0 part /home
mmcblk0 179:0 0 29,1G 0 disk
├─mmcblk0p1 179:1 0 300M 0 part
└─mmcblk0p2 179:2 0 28,8G 0 part
mmcblk0boot0 179:8 0 4M 1 disk
mmcblk0boot1 179:16 0 4M 1 disk
Here is the output of the terminal command: zcat /proc/config.gz | grep CONFIG_EFI
CONFIG_EFI=y
CONFIG_EFI_STUB=y
CONFIG_EFI_MIXED=y
CONFIG_EFI_ESRT=y
# CONFIG_EFI_DISABLE_RUNTIME is not set
CONFIG_EFIVAR_FS=y
I have no idea what causes the error. It seems quiet random, the only thing that sometimes work is to try to install it again but don’t format any partitions. Again why this should work I have no idea.
Just seen “grub-install: error: unknown filesystem.” this is why it fails?
I also saw “Successfully unmounted /tmp/calamares-root-6ru5m3t3/boot/efi.” I thought this had to be mounted for grub install?
When you get the error grub-install: error: unknown filesystem it is usually due to an oversight with custom partitioning.
It is easy to forget to select fat32 for the efi mount point as default is ext4 - I have done it more than a couple of times and I know the message - and what it means.
You will never get this error message using the installer’s default partitioning - only when you accidently uses ext4 for the efi parition.
