I have Manjaro installed on a HDD.
Everything works perfectly.
Bought a new NVME M2 SSD , put it on my motherboard but also kept the old HDD connected.
Installed Manjaro on the new SSD.
The SSD doesn’t appear to be bootable in the motherboard options.
When entering Manjaro from the HDD I can see the SSD drive.
What I would want to have is basically boot Manjaro from the new SSD one and ignore the HDD one and just use it as storage even if Manjaro is also present on the HDD.
Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
Copy the output from inxi (including the command) and paste it into your post.
To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
You can also use Maxi
to collect information about the boot process. This works,
when you are in your running system (with CTRL+ALT+F2).
And also in a live environment
P.S.
Photos are not welcome here because they are not searchable and thus will not help anyone once the thread is resolved. It is also advisable to use the search function before asking the same question again
From the pictures, you installed Manjaro on the NVMe in Legacy (BIOS) mode, while your BIOS is set to boot your computer in EFI mode. You need to set it to boot in Legacy mode.
Now I have entered the UEFI mode on the usb stick and made sure that it said EFI up left where you showed the first arrow and reinstalled Manjaro on the SSD.
The filesystem and everything looks identical now between the HDD and the SSD yet the SSD is still not available in the bios at booting options.
I have done like you said and it still didn’t show
But what did work is updating the BIOS to a prev version.
I updated the BIOS last year to the latest version but apparently that didn’t help with my current problem.
Now I updated to an older version and it works.
