Difficulty: ★★☆☆☆
When installing Manjaro Cinnamon, the battery can be stuck at 10% or not changing.
check your tlp settings:
sudo tlp-stat --battery
which indicated:
Install acpi_call kernel module for ThinkPad battery recalibration
If that’s the case, install
acpi_call. As there are several versions, the below tutorial usesdkmsso it’s available for all of your kernels.pamac install acpi_call-dkms -
change your
mkinitcpio.conffile to includeMODULES=(battery):sudo nano --backup /etc/mkinitcpio.conf- Press Ctrl+W
- Type
MODULES=and hit Enter - to find the line starting with
MODULES- If that line starts with
#, please remove the hash character - If not, ensure that line contains
(battery).
reinitialize your initial RAM disk environment:
sudo mkinitcpio --allpresets
Reboot:
sudo reboot
For more information, please click the Arch Wiki link…
