I have just bought and installed a new AMD Radeon RX 6600 XT GPU but when I booted up my machine the GUI did not start. Here is what I found out:
I have tried to run
mhwd -a pci free 0300
Output said that driver ‘video-linux’ was already installed, from Xorg - ArchWiki I can see that my GPU needs amdgpu driver and using pacman I can confirm that xf86-video-amdgpu
is installed. However when running:
inxi -G
Output:
Graphics: Device-1: Advanced micro devices [AMD/ATI] Navi 23 [Radeon RX 6600/6600 XT/6600M] driver: N/A
Display: server: X.org 1.20.13 driver: loaded: ati,radeon unloaded: modesetting tty: 240x67
Message: advanced graphics data unavailable in console. Try -G --display
The driver is N/A and amdgpu is not listed. Most of the forum posts I have seen all had the driver listed in this output and their problem appeared when loading it.
When running xinit
the xorg log falls with error ‘no screens found’, it tries to load the radeon driver but it just lists a bunch of cards none of which match my model. I would think that this is expected because the newer cards would be supported by the amdgpu driver.
I am quite new to the linux world so I apologise if I missed anything obvious but I could not figure it out after a few hours. Any help would be appreciated.
Welcome to the forum
Please post the output of inxi -Fazy --filter
Thanks for the quick response, here is the output:
Kernel: 5.10.68-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=b976e490-b4fd-4138-964e-a5110146f470 rw quiet apparmor=1
security=apparmor resume=UUID=123ec7c2-8196-4de8-b138-8c33a0b79eae
udev.log_priority=3
Console: tty 2 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: ASUS product: All Series v: N/A serial: <filter>
Mobo: ASUSTeK model: MAXIMUS VI HERO v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 0903 date: 10/09/2013
Info: Quad Core model: Intel Core i5-4670K bits: 64 type: MCP arch: Haswell
family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache: L2: 6 MiB
bogomips: 27258
Speed: 2827 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 2827 2: 2670
3: 2689 4: 2401
Type: l1tf
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Micro-Star MSI
driver: N/A bus-ID: 03:00.0 chip-ID: 1002:73ff class-ID: 0300
unloaded: modesetting alternate: fbdev,vesa tty: 240x67
Message: Advanced graphics data unavailable in console. Try -G --display
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Device-2: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
driver: snd_hda_intel v: kernel bus-ID: 03:00.1 chip-ID: 1002:ab28
class-ID: 0403
Sound Server-1: ALSA v: k5.10.68-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.37 running: no
Device-1: Intel Ethernet I217-V vendor: ASUSTeK driver: e1000e v: kernel
port: f040 bus-ID: 00:19.0 chip-ID: 8086:153b class-ID: 0200
Local Storage: total: 1.94 TiB used: 45.71 GiB (2.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD20EARX-00PASB0
type: N/A serial: <filter> rev: AB51 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SDSSDHP128G
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 6RL scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Generic model: USB Flash Disk
size: 7.18 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 1100 scheme: MBR
ID-1: / raw-size: 41.24 GiB size: 40.3 GiB (97.71%) used: 16.17 GiB (40.1%)
fs: ext4 dev: /dev/sdb5 maj-min: 8:21
used: 25.2 MiB (26.3%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 963.02 GiB size: 946.83 GiB (98.32%)
used: 3.12 GiB (0.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb6 maj-min: 8:22
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 145 Uptime: 5m wakeups: 0 Memory: 15.57 GiB
used: 415.2 MiB (2.6%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 12.0.1 Packages: 1265 pacman: 1263 lib: 335 flatpak: 0
snap: 2 Shell: Bash (login) v: 5.1.8 running-in: tty 2 inxi: 3.3.06
@aafsmarak Do you have any suggestions about what I should do?
I will try when I get home as I am currently at work. I have already tried it previously and if I recall correctly the driver still was not being loaded when I was running xinit
nor listed in inxi
despite not seeing any errors.
Evernow
September 28, 2021, 2:58pm
7
Try a newer kernel like 5.14.
system
Closed
October 1, 2021, 4:59am
8
