Ich habe unter KDE in Wifi & Networking mein Ethernet Interface gelöscht, wie kann ich das wieder herstellen? Neu booten hilft nicht. Inxi zeigt die Killer-Karte noch an, aber in den Settings sehe ich sie nicht.
TIA
Kernel: 6.19.8-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1 clocksource: tsc
avail: acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-6.19-x86_64
root=UUID=5a7dee63-71ac-4df2-8606-7afa7e744b60 rw quiet splash
resume=UUID=1bfe5c9e-da2a-4609-a13a-1da74a7a1abb udev.log_priority=3
Console: pty pts/2 DM: SDDM Distro: Manjaro base: Arch Linux
Type: Laptop System: Acer product: Predator PHN16S-71 v: V1.21 serial: <filter> Chassis:
type: 10 serial: N/A
Mobo: ARL model: FTYPE_ARX v: V1.21 serial: <filter> part-nu: 0000000000000000
uuid: c602e8f1-1d5f-ed46-a648-74d4ddca989b Firmware: UEFI vendor: INSYDE v: 1.21
date: 11/07/2025
ID-1: BAT1 charge: 32.7 Wh (42.8%) condition: 76.3/76.3 Wh (100%) volts: 14.6 min: 15.48
model: SIMPLO AP24A7Q type: Li-ion serial: <filter> charging: status: discharging cycles: 15
System RAM: total: 16 GiB available: 15.05 GiB used: 9.12 GiB (60.6%)
Array-1: capacity: 64 GiB slots: 2 modules: 2 EC: None max-module-size: 32 GiB note: est.
Device-1: Controller0-ChannelA-DIMM1 type: DDR5 detail: synchronous size: 8 GiB
speed: 6400 MT/s volts: curr: 1.1 width (bits): data: 64 total: 64 manufacturer: SK Hynix
part-no: HMCG66AHBVA315N serial: <filter>
Device-2: Controller0-ChannelB-DIMM1 type: DDR5 detail: synchronous size: 8 GiB
Message: No PCI Slot data found.
Info: model: Intel Core Ultra 7 255HX socket: BGA2114 (U3E1) note: check bits: 64 type: MCP
arch: Arrow Lake level: v3 note: check built: 2024+ process: Intel 20a (2nm) family: 6
model-id: 0xC6 (198) stepping: 2 microcode: 0x11B
Topology: cpus: 1x dies: 1 clusters: 11 cores: 20 smt: <unsupported> cache: L1: 2 MiB
desc: d-12x32 KiB, 8x48 KiB; i-20x64 KiB L2: 36 MiB desc: 8x3 MiB, 3x4 MiB L3: 30 MiB
desc: 1x30 MiB
Speed (MHz): avg: 2200 min/max: 800/5300:5100:4500 base/boost: 4059/8500 scaling:
driver: intel_pstate governor: powersave volts: 0.9 V ext-clock: 100 MHz cores: 1: 2200 2: 2200
3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200 13: 2200
14: 2200 15: 2200 16: 2200 17: 2200 18: 2200 19: 2200 20: 2200 bogomips: 115200
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities arch_lbr
arch_perfmon art avx avx2 avx_vnni bmi1 bmi2 bts bus_lock_detect clflush clflushopt clwb cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid lahf_lm lam lm mca
mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat
pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed
rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect ss ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg wbnoinvd x2apic
Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional; PBRSB-eIBRS: Not
affected; BHI: BHI_DIS_S
Device-1: Intel Arrow Lake-S [Intel Graphics] vendor: Acer Incorporated ALI driver: i915
v: kernel alternate: xe arch: Xe2-LPG process: TSMC n3 (3nm) built: 2025+ ports: active: eDP-1
empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:7d67 class-ID: 0300
Device-2: NVIDIA GB206M [GeForce RTX 5060 Max-Q / Mobile] vendor: Acer Incorporated ALI
driver: nvidia v: 590.48.01 alternate: nouveau,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-11) arch: Lovelace code: AD1xx process: TSMC n4 (5nm) built: 2022+
pcie: gen: 5 speed: 32 GT/s lanes: 8 link-max: lanes: 16 ports: active: none
empty: DP-3,HDMI-A-1,eDP-2 bus-ID: 02:00.0 chip-ID: 10de:2d59 class-ID: 0300
Device-3: Chicony ACER FHD User Facing driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 3-6:3 chip-ID: 04f2:b831 class-ID: fe01 serial: <filter>
Display: unspecified server: X.org v: 1.21.1.21 with: Xwayland v: 24.1.9
compositor: kwin_wayland driver: X: loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa
dri: iris gpu: i915 tty: 144x38
Monitor-1: eDP-1 model: Samsung 0x41ab built: 2023 size-res: N/A in console gamma: 1.2 chroma:
red: x: 0.682 y: 0.322 green: x: 0.235 y: 0.725 blue: x: 0.137 y: 0.047 white: x: 0.314 y: 0.329
diag: 405mm (15.9") modes: 2560x1600
EDID-Warnings: 1: parse_edid: unknown tag 112
API: EGL v: 1.5 hw: drv: intel iris drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: iris device: 3 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia
inactive: wayland,x11,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 26.0.2-arch1.1 note: console (EGL sourced)
renderer: NVIDIA GeForce RTX 5060 Laptop GPU/PCIe/SSE2, Mesa Intel Graphics (ARL), llvmpipe
(LLVM 22.1.1 256 bits)
API: Vulkan v: 1.4.341 layers: 2 device: 0 type: discrete-gpu name: NVIDIA GeForce RTX 5060
Laptop GPU driver: nvidia v: 590.48.01 device-ID: 10de:2d59 surfaces: N/A
Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo de: kscreen-console,kscreen-doctor
gpu: nvidia-settings,nvidia-smi wl: wayland-info x11: xdpyinfo, xprop, xrandr
Device-1: NVIDIA GB206 High Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 5
speed: 32 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 02:00.1 chip-ID: 10de:22eb class-ID: 0403
Device-2: Intel 800 Series ACE vendor: Acer Incorporated ALI driver: sof-audio-pci-intel-mtl
alternate: snd_sof_pci_intel_mtl,snd_hda_intel bus-ID: 80:1f.3 chip-ID: 8086:7f50 class-ID: 0401
API: ALSA v: k6.19.8-1-MANJARO status: kernel-api with: aoss type: oss-emulator
Server-3: PipeWire v: 1.6.2 status: n/a (root, process) with: 1: pipewire-pulse status: active
2: wireplumber status: active 3: pipewire-alsa type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Intel Arrow Lake-S PCH CNVi WiFi vendor: Rivet Networks driver: iwlwifi v: kernel
bus-ID: 80:14.3 chip-ID: 8086:7f70 class-ID: 0280
IF: wlp128s20f3 state: up mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Device-2: Realtek Killer E3000 2.5GbE vendor: Acer Incorporated ALI driver: N/A modules: r8169
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 82:00.0 chip-ID: 10ec:3000 class-ID: 0200
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 3-14:4 chip-ID: 8087:0033 class-ID: e001
Local Storage: total: 2.79 TiB used: 1.28 TiB (46.0%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: SK Hynix model: HFS001TEJ9X125N size: 953.87 GiB
block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter>
fw-rev: 51022A20 temp: 45.9 C scheme: GPT
SMART: yes health: PASSED on: 31d 23h cycles: 142 read-units: 3,477,471 [1.78 TB]
written-units: 2,191,328 [1.12 TB]
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW020T9 size: 1.86 TiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter>
fw-rev: 001C temp: 33.9 C scheme: GPT
SMART: yes health: PASSED on: 1y 73d 21h cycles: 26,497 read-units: 24,367,015 [12.4 TB]
written-units: 14,506,925 [7.42 TB]
ID-1: / raw-size: 164.06 GiB size: 160.43 GiB (97.78%) used: 31.31 GiB (19.5%) fs: ext4
block-size: 4096 B dev: /dev/nvme0n1p7 maj-min: 259:10 label: N/A
uuid: 5a7dee63-71ac-4df2-8606-7afa7e744b60
ID-2: /boot/efi raw-size: 512 MiB size: 508 MiB (99.22%) used: 62.8 MiB (12.4%) fs: vfat
block-size: 512 B dev: /dev/nvme0n1p1 maj-min: 259:4 label: ESP uuid: BCBD-63E2
ID-3: /home raw-size: 280.72 GiB size: 275.25 GiB (98.05%) used: 10.09 GiB (3.7%) fs: ext4
block-size: 4096 B dev: /dev/nvme0n1p5 maj-min: 259:8 label: N/A
uuid: 4ccd9b37-2894-40a4-9952-1a0f9f980b22
ID-4: /mnt/data raw-size: 1.86 TiB size: 1.86 TiB (100.00%) used: 1.24 TiB (66.8%) fs: ntfs
block-size: 4096 B dev: /dev/nvme1n1p2 maj-min: 259:2 label: Data2 uuid: 5CCC75F7CC75CC30
Kernel: swappiness: 60 (default) cache-pressure: 100 (default) zswap: yes compressor: zstd
max-pool: 20%
ID-1: swap-1 type: partition size: 31.25 GiB used: 0 KiB (0.0%) priority: -1
dev: /dev/nvme0n1p6 maj-min: 259:9 label: swap uuid: 1bfe5c9e-da2a-4609-a13a-1da74a7a1abb
ID-1: /dev/nvme0n1p2 maj-min: 259:5 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:6 size: 476.32 GiB fs: bitlocker label: N/A
uuid: 06f9c71d-0638-4ee1-9ea9-1a2372fbb2fb
ID-3: /dev/nvme0n1p4 maj-min: 259:7 size: 1024 MiB fs: ntfs label: Recovery
uuid: F204BE5A04BE2191
ID-4: /dev/nvme1n1p1 maj-min: 259:1 size: 16 MiB fs: N/A label: N/A uuid: N/A
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 chip-ID: 1d6b:0002 class-ID: 0900
Hub-2: 2-0:1 info: super-speed hub ports: 2 rev: 3.1 speed: 20 Gb/s (2.33 GiB/s) lanes: 2
mode: 3.2 gen-2x2 chip-ID: 1d6b:0003 class-ID: 0900
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 16 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
Device-1: 3-4:2 info: CX 2.4G Receiver type: keyboard,mouse driver: hid-generic,usbhid
interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
chip-ID: 3554:fc03 class-ID: 0301
Device-2: 3-6:3 info: Chicony ACER FHD User Facing type: video driver: uvcvideo interfaces: 5
rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b831
Device-3: 3-14:4 info: Intel AX211 Bluetooth type: bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA chip-ID: 8087:0033
class-ID: e001
Hub-4: 4-0:1 info: super-speed hub ports: 10 rev: 3.1 speed: 20 Gb/s (2.33 GiB/s) lanes: 2
System Temperatures: cpu: 46.5 C mobo: N/A gpu: nvidia temp: 44 C
Fan Speeds (rpm): N/A
Packages: 1423 pm: pacman pkgs: 1386 libs: 388 tools: pamac pm: flatpak pkgs: 37
1: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
2: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
3: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
4: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
5: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
6: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://mirror.easyname.at/manjaro/stable/$repo/$arch
8: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
9: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
10: https://mirror.23m.com/manjaro/stable/$repo/$arch
11: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
12: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
13: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
14: https://mirrors.manjaro.org/repo/stable/$repo/$arch
15: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
16: https://manjaro.grena.ge/stable/$repo/$arch
17: https://manjaro.ynh.ovh/stable/$repo/$arch
18: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
19: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
20: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
21: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
22: https://mirror.init7.net/manjaro/stable/$repo/$arch
23: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
24: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
25: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
26: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
27: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
28: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
29: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
30: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
31: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
32: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
33: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
34: https://muug.ca/mirror/manjaro/stable/$repo/$arch
35: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
36: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
37: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
38: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
39: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
40: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
41: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
42: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
43: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
44: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
45: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
46: https://mirrors2.manjaro.org/stable/$repo/$arch
47: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
48: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
49: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
50: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
51: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
52: https://mirror.fcix.net/manjaro/stable/$repo/$arch
53: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
54: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
55: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
56: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
57: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 411
1: cpu: 63.7% command: firefox pid: 1867 mem: 1018.0 MiB (6.6%)
2: cpu: 27.0% command: kwin_wayland pid: 1118 mem: 487.9 MiB (3.1%)
3: cpu: 20.2% command: firefox pid: 2601 mem: 333.4 MiB (2.1%)
4: cpu: 10.5% command: firefox pid: 7449 mem: 359.2 MiB (2.3%)
5: cpu: 3.2% command: pamac-manager pid: 3892 mem: 1414.6 MiB (9.1%)
Memory top: 5 of 411
1: mem: 1414.6 MiB (9.1%) command: pamac-manager pid: 3892 cpu: 3.2%
2: mem: 1018.0 MiB (6.6%) command: firefox pid: 1867 cpu: 63.7%
3: mem: 487.9 MiB (3.1%) command: kwin_wayland pid: 1118 cpu: 27.0%
4: mem: 451.8 MiB (2.9%) command: plasmashell pid: 1309 cpu: 1.4%
5: mem: 359.2 MiB (2.3%) command: firefox pid: 7449 cpu: 10.5%
Processes: 411 Power: uptime: 25m states: freeze,mem,disk suspend: s2idle wakeups: 0
hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 5.92 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 259
Compilers: gcc: 15.2.1 Shell: Bash (su) v: 5.3.9 running-in: pty pts/2 inxi: 3.3.40
