NetworkManger inactive after resuming from suspend
openrc
i3
network-manager
#1
Hi,
I’m using Manjaro stable: i3 + openrc
After the latest update I
NetworkManger service is showed inactivate after resuming from suspend. I’m cannot activate it using nm-applet, I tried to restart the service but the wifi still off.
  • if I’m connected using wifi and laptop gos sleep: NetworkManger —> goes inactive after wake up. and I cannot use nm-applet (shows networking disabled) or nmtui to scan / connect wifi
  • if i’m coonected using ethernet and laptop goes sleep: nm-applet shows as “disconnected” and left click gives “Networking disabled” , but I still can connect using the browser and rc-status shows NetworkManager as active. When I disconnect I can not reconnect again using nm-applet (do not allow to reactivate network) and the rc-status shows NetworkManager as inactive. However, I can activated network using nmtuiand connect using ethernet (nm-applet still gives a wrong networking status: Networking disabled).
  • Quiting nmtui disconnect me, which is not the expected behaviour.
  • I get this message in dmesg: [ 147.634101] udevd[488]: RUN{builtin}: 'uaccess' unknown /usr/lib/udev/rules.d/73-seat-late.rules:15 when resuming from suspend… I deleted this file without result.
  • I tried to downgrade NetworkManager and nm-applet without result (nm-applet did launch)
For power management I’m using xfce power manager
Now, everytime I want to connect to wifi i have to reboot. For ethernet I can use nmtui but nor for wifi.
Any idea how to find the cause of this problem!
Wifi issues after elogind update (>227.2-1)
[unstable] elogind update 228.1-1 breaking suspend, hibernate
[Stable Update] 2017-05-27 - Kernels, Cinnamon, Firefox, Mesa, OpenSSL, Kodi
[Testing Update] 2017-05-26 - Samba, Kernels, OpenSSL
[Stable Update] 2017-06-06 - Plasma 5, Boost, Deepin, Mesa, GCC
#2
Well you’re not the only one who has the issues…
I also facing the same problem tooo…
The workaround for now is to downgrade elogind
LUKS setup on NVME SSD drive
#3
I think that should be downgrade elogind (and libelogind, to 227.2).
#4
Oops! My mistake. Thanks for noticing it!
#5
Thanks @cimarronline and @thefallenrat
I’ll try and reboot…
#6
The other option when using elogind 229.3 is running one or both (as needed) of these commands to restore networking after suspend:
sudo rc-service NetworkManager restart
sudo nmcli dev set wlp3s0 managed yes
(with wlp3s0 replaced by your wireless interface)
#7
Yes. I’m using elogind 229.3, so this solution is the best for me now.
Known bugs like that one should be noted on the update annoucement. I always read the annoucement before updating to prevent such problems. I waist much time. thns life savior.
#8
I also downgraded to 227.2 and my system ran fine until the latest testing update. I am now booted in kernel 4.9 as I haven’t been able to get an internet connection in 4.10 and & 4.11 after suspending. I NetworkManager widget did show there was no connection for a while but I had an Ethernet connection anyway. With this latest update there was no way to establish a connection until I booted into another kernel… @artoo are you there?
I just saw that there was a elogind update in unstable today and updated. I booted into kernel 4.11.3 and all was well, I suspended and came back and the NetworkManager widget shows it is disabled but I still have Internet connection…
#9
This issue has been fixed with elogind-229.6-1.
#10
Awesome! It’s about time!
#11
Hey, I know this is a stupid question, but when can this be expected to land on stable?
