NetworkManager: Wake on LAN not activated after restart but after suspension
When I restart my machine my connection is set to Wake-on: d despite having it set to Magic in the connection’s setting. It doesn’t change after a restart and I only found out with ethtool. https://imgur.com/Tfj8HaI.png
I have to suspend the machine and wake it up manually so it sets Wake-on to g by itself.
Why does this happen and how could I stop it from happening?
inxi --admin --verbosity=7 --filter --width:
  Kernel: 5.4.159-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=9c990afe-ac5c-4165-9e48-ff48b437b88a rw quiet
  cryptdevice=UUID=3560dd58-9f35-426b-b4ae-89455bbb4694:luks-3560dd58-9f35-426b-b4ae-89455bbb4694
  root=/dev/mapper/luks-3560dd58-9f35-426b-b4ae-89455bbb4694
  resume=/dev/mapper/luks-99ccecba-9ba6-4587-ab59-9d6fb50fde69
  udev.log_priority=3 sysrq_always_enabled=1
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
  Type: Desktop System: FUJITSU product: ESPRIMO Q556/2 v: N/A
  serial: <superuser required> Chassis: type: 3 serial: <superuser required>
  Mobo: FUJITSU model: D3403-U1 v: S26361-D3403-U1
  serial: <superuser required> UEFI-[Legacy]: FUJITSU // American Megatrends
  v: 5.0.0.12 R1.18.0 for D3403-U1x date: 06/13/2018
  RAM: total: 7.62 GiB used: 2.89 GiB (37.9%)
  Info: Dual Core model: Intel Core i3-6100T bits: 64 type: MT MCP
  arch: Skylake-S family: 6 model-id: 5E (94) stepping: 3 microcode: EA cache:
  L1: 128 KiB L2: 512 KiB L3: 3 MiB bogomips: 25610
  Speed: 900 MHz min/max: 800/3200 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
  4: 900
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
  avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
  mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
  rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
  xsaves xtopology xtpr
  Type: l1tf
  Device-1: Intel HD Graphics 530 vendor: Fujitsu Solutions driver: i915
  v: kernel bus-ID: 00:02.0 chip-ID: 8086:1912 class-ID: 0300
  Display: x11 server: X.Org 1.21.1.1 compositor: picom v: git-dac85 driver:
  loaded: intel display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 3071x1080 s-dpi: 96 s-size: 813x286mm (32.0x11.3")
  s-diag: 862mm (33.9")
  OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 21.2.5
  direct render: Yes
  Device-1: Intel 100 Series/C230 Series Family HD Audio
  vendor: Fujitsu Solutions driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
  chip-ID: 8086:a170 class-ID: 0403
  Sound Server-1: ALSA v: k5.4.159-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.40 running: no
  vendor: Fujitsu Solutions driver: r8169 v: kernel port: e000 bus-ID: 01:00.0
  IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: luks-3560dd58-9f35-426b-b4ae-89455bbb4694 maj-min: 254:0
  type: LUKS dm: dm-0 size: 229.66 GiB
  Components:
  p-1: nvme0n1p1 maj-min: 259:1 size: 229.67 GiB
  Device-2: luks-99ccecba-9ba6-4587-ab59-9d6fb50fde69 maj-min: 254:1
  type: LUKS dm: dm-1 size: 8.8 GiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 8.8 GiB
  Local Storage: total: 238.47 GiB used: 174.13 GiB (73.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLW256HEHP-00000
  size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 type: SSD serial: <filter> rev: CXB7401Q scheme: MBR
  ID-1: / raw-size: 229.66 GiB size: 225 GiB (97.97%) used: 174.13 GiB (77.4%)
  fs: ext4 dev: /dev/dm-0 maj-min: 254:0
  mapped: luks-3560dd58-9f35-426b-b4ae-89455bbb4694 label: N/A
  uuid: 9c990afe-ac5c-4165-9e48-ff48b437b88a
  dev: /dev/dm-1 maj-min: 254:1
  mapped: luks-99ccecba-9ba6-4587-ab59-9d6fb50fde69 label: swap
  uuid: 1ba29d4d-5d8e-4f74-ab65-53bd61541a64
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
  Device-1: 1-2:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
  power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Device-2: 1-7:5 info: Creative Sound BlasterX Vanguard K08
  type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 3 rev: 2.0
  speed: 12 Mb/s power: 500mA chip-ID: 041e:3128 class-ID: 0300
  serial: <filter>
  Device-3: 1-8:6 info: Logitech USB Receiver type: Keyboard,Mouse,HID
  power: 98mA chip-ID: 046d:c539 class-ID: 0300
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 31.0 C pch: 39.0 C mobo: N/A
  Processes: 242 Uptime: 2h 4m wakeups: 7 Init: systemd v: 249 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: pacman: 1348 lib: 332 Shell: Zsh v: 5.8
  running-in: xfce4-terminal inxi: 3.3.09
