Continuing the discussion from the topic Linux freezes tightly, REISUB does not work. Written kernel.sysrq=1. Swap is not used:
After installing 5.17 kernel, the system worked stably, but after the last update, the system freezes again.
inxi --full --verbosity=7 --filter --no-host
Kernel: 5.18.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: X555YI v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: X555YI v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X555YI.702 date: 01/30/2019
ID-1: BAT0 charge: 25.8 Wh (100.0%) condition: 25.8/38.0 Wh (67.8%)
volts: 7.5 min: 7.5 model: ASUSTeK X555-50 type: Li-ion serial: N/A
status: not charging cycles: 384
RAM: total: 6.7 GiB used: 1.77 GiB (26.4%)
RAM Report:
Info: quad core model: AMD A8-7410 APU with AMD Radeon R5 Graphics bits: 64
type: MCP smt: <unsupported> arch: Puma rev: 1 cache: L1: 256 KiB L2: 2 MiB
Speed (MHz): avg: 1106 high: 1167 min/max: 1000/2200 boost: enabled
cores: 1: 1051 2: 1066 3: 1142 4: 1167 bogomips: 17574
Flags: 3dnowprefetch abm acc_power aes aperfmperf apic arat avx bmi1
bpext clflush cmov cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de
decodeassists extapic extd_apicid f16c flushbyasid fpu fxsr fxsr_opt ht
hw_pstate ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor
movbe msr mtrr nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae
pat pausefilter pclmulqdq pdpe1gb perfctr_llc perfctr_nb pfthreshold pge
pni popcnt pse pse36 ptsc rdtscp rep_good sep skinit ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 svm svm_lock syscall topoext tsc tsc_scale vme vmmcall
wdt xsave xsaveopt
Device-1: AMD Mullins [Radeon R4/R5 Graphics] vendor: ASUSTeK
driver: amdgpu v: kernel arch: GCN 2 ports: active: eDP-1 empty: DP-1
bus-ID: 00:01.0 chip-ID: 1002:9851 class-ID: 0300
Device-2: AMD Jet PRO [Radeon R5 M230 / R7 M260DX Radeon 520 Mobile]
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN 1 pcie: speed: 2.5 GT/s
lanes: 4 bus-ID: 01:00.0 chip-ID: 1002:6665 class-ID: 0380
Device-3: Chicony USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-1.4:4 chip-ID: 04f2:b52b class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x15c9 res: 1366x768
hz: 60 dpi: 101 size: 344x193mm (13.54x7.6") diag: 394mm (15.5") modes:
max: 1366x768 min: 640x480
OpenGL: renderer: AMD KABINI (LLVM 13.0.1 DRM 3.46 5.18.5-1-MANJARO)
v: 4.6 Mesa 22.1.1 direct render: Yes
Device-1: AMD Kabini HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:01.1 chip-ID: 1002:9840 class-ID: 0403
Device-2: AMD FCH Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Sound Server-1: ALSA v: k5.18.5-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.0 running: yes
Sound Server-4: PipeWire v: 0.3.52 running: no
Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Lite-On
driver: rtl8723be v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 02:00.0 chip-ID: 10ec:b723 class-ID: 0280
IF: wlp2s0 state: down mac: <filter>
vendor: ASUSTeK driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1
port: c000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-1.3:3 chip-ID: 0bda:b721 class-ID: e001 serial: <filter>
Local Storage: total: 931.51 GiB used: 18.77 GiB (2.0%)
ID-1: /dev/sda vendor: Toshiba model: MQ01ABD100 size: 931.51 GiB
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 5J scheme: GPT
ID-1: / size: 661.13 GiB used: 18.77 GiB (2.8%) fs: ext4 dev: /dev/sda3
label: N/A uuid: df029a60-dcfd-4c97-be87-681cf65a4b37
ID-2: /boot/efi size: 511 MiB used: 4.6 MiB (0.9%) fs: vfat
dev: /dev/sda1 label: N/A uuid: 1328-15F3
ID-1: swap-1 type: partition size: 4.88 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda4 label: N/A uuid: 3ca44c05-81c5-4a4e-9886-092085b2332b
ID-1: /dev/sda2 size: 253.37 GiB fs: ext4 label: N/A
uuid: 7853b4fd-8ab7-4265-a5f1-f075176a9f01
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 0438:7900 class-ID: 0900
Device-1: 1-1.3:3 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 2.1 speed: 12 Mb/s power: 500mA
Device-2: 1-1.4:4 info: Chicony USB2.0 VGA UVC WebCam type: Video
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Advanced Micro Devices Root Hub ports: 2 rev: 2.0
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 3-1:2 info: [Maxxter] Optical Gaming Mouse [Xtrem]
type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 100mA chip-ID: 18f8:0f97 class-ID: 0301
Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 56.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3000
GPU: device: amdgpu temp: 48.0 C device: amdgpu temp: 51.0 C
Processes: 198 Uptime: 12m wakeups: 1 Init: systemd v: 251
default: graphical Compilers: gcc: 12.1.0 clang: 13.0.1 Packages:
pacman: 1091 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.18
dmesg
[ 0.000000] Linux version 5.18.5-1-MANJARO (builduser@fv-az489-954) (gcc (GCC) 12.1.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT_DYNAMIC Thu Jun 16 12:28:47 UTC 2022
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64 root=UUID=df029a60-dcfd-4c97-be87-681cf65a4b37 rw quiet udev.log_priority=3
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[ 0.000000] signal: max sigframe size: 1776
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000008b7a4fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000008b7a5000-0x000000008b8c7fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000008b8c8000-0x000000008bdc6fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000008bdc7000-0x000000008d1a0fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000008d1a1000-0x000000008de2dfff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000008de2e000-0x000000008de94fff] type 20
[ 0.000000] BIOS-e820: [mem 0x000000008de95000-0x000000008e026fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000008e027000-0x000000008e03dfff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000008e03e000-0x000000008e066fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000008e067000-0x000000008e4bbfff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000008e4bc000-0x000000008e998fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000008e999000-0x000000008eff9fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000008effa000-0x000000008effffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000feb00000-0x00000000feb00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec01fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed40000-0x00000000fed44fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000022effffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.40 by American Megatrends
[ 0.000000] efi: ESRT=0x8de2a318 ACPI=0x8be4b000 ACPI 2.0=0x8be4b000 SMBIOS=0xf05b0
[ 0.000000] SMBIOS 2.8 present.
[ 0.000000] DMI: ASUSTeK COMPUTER INC. X555YI/X555YI, BIOS X555YI.702 01/30/2019
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 2195.785 MHz processor
[ 0.001078] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.001085] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.001097] last_pfn = 0x22f000 max_arch_pfn = 0x400000000
[ 0.001550] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.001824] total RAM covered: 2288M
[ 0.002290] Found optimal setting for mtrr clean up
[ 0.002291] gran_size: 64K chunk_size: 32M num_reg: 3 lose cover RAM: 0G
[ 0.002444] e820: update [mem 0x8f000000-0xffffffff] usable ==> reserved
[ 0.002465] last_pfn = 0x8f000 max_arch_pfn = 0x400000000
[ 0.008881] found SMP MP-table at [mem 0x000fd8f0-0x000fd8ff]
[ 0.008908] esrt: Reserving ESRT space from 0x000000008de2a318 to 0x000000008de2a350.
[ 0.008924] Using GB pages for direct mapping
[ 0.011702] Secure boot disabled
[ 0.011704] RAMDISK: [mem 0x36ee7000-0x3776afff]
[ 0.011714] ACPI: Early table checksum verification disabled
[ 0.011720] ACPI: RSDP 0x000000008BE4B000 000024 (v02 _ASUS_)
[ 0.011727] ACPI: XSDT 0x000000008BE4B098 0000AC (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.011739] ACPI: FACP 0x000000008BE58318 00010C (v05 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.011749] ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20211217/tbfadt-615)
[ 0.011757] ACPI: DSDT 0x000000008BE4B1D0 00D147 (v02 _ASUS_ Notebook 01072009 INTL 20120913)
[ 0.011764] ACPI: FACS 0x000000008D19EB80 000040
[ 0.011770] ACPI: APIC 0x000000008BE58428 00007E (v03 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.011776] ACPI: FPDT 0x000000008BE584A8 000044 (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.011782] ACPI: FIDT 0x000000008BE584F0 00009C (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.011789] ACPI: MCFG 0x000000008BE58590 00003C (v01 _ASUS_ Notebook 01072009 MSFT 00010013)
[ 0.011795] ACPI: HPET 0x000000008BE585D0 000038 (v01 _ASUS_ Notebook 01072009 AMI 00000005)
[ 0.011801] ACPI: WDRT 0x000000008BE58608 000047 (v01 _ASUS_ Notebook 01072009 AMI 00000005)
[ 0.011807] ACPI: ECDT 0x000000008BE58650 0000C1 (v01 _ASUS_ Notebook 01072009 AMI. 00000005)
[ 0.011813] ACPI: UEFI 0x000000008BE58718 000042 (v01 00000000 00000000)
[ 0.011820] ACPI: BGRT 0x000000008BE58760 000038 (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.011826] ACPI: SSDT 0x000000008BE58798 000CB4 (v01 AMD AGESA 00000001 AMD 00000001)
[ 0.011832] ACPI: SSDT 0x000000008BE59450 0048CE (v02 AMD AGESA 00000002 MSFT 04000000)
[ 0.011839] ACPI: SSDT 0x000000008BE5DD20 0015A5 (v01 AMD CPMCMN 00000001 INTL 20120913)
[ 0.011845] ACPI: SSDT 0x000000008BE5F2C8 000F39 (v01 AMD CPMZPODD 00000001 INTL 20120913)
[ 0.011851] ACPI: SSDT 0x000000008BE60208 00155C (v01 AMD CPMDFIGP 00000001 INTL 20120913)
[ 0.011857] ACPI: SSDT 0x000000008BE61768 00082B (v01 AMD CPMDFDGP 00000001 INTL 20120913)
[ 0.011864] ACPI: MSDM 0x000000008B87CF18 000055 (v03 _ASUS_ Notebook 00000000 ASUS 00000001)
[ 0.011869] ACPI: Reserving FACP table memory at [mem 0x8be58318-0x8be58423]
[ 0.011872] ACPI: Reserving DSDT table memory at [mem 0x8be4b1d0-0x8be58316]
[ 0.011874] ACPI: Reserving FACS table memory at [mem 0x8d19eb80-0x8d19ebbf]
[ 0.011877] ACPI: Reserving APIC table memory at [mem 0x8be58428-0x8be584a5]
[ 0.011879] ACPI: Reserving FPDT table memory at [mem 0x8be584a8-0x8be584eb]
[ 0.011881] ACPI: Reserving FIDT table memory at [mem 0x8be584f0-0x8be5858b]
[ 0.011883] ACPI: Reserving MCFG table memory at [mem 0x8be58590-0x8be585cb]
[ 0.011885] ACPI: Reserving HPET table memory at [mem 0x8be585d0-0x8be58607]
[ 0.011887] ACPI: Reserving WDRT table memory at [mem 0x8be58608-0x8be5864e]
[ 0.011889] ACPI: Reserving ECDT table memory at [mem 0x8be58650-0x8be58710]
[ 0.011891] ACPI: Reserving UEFI table memory at [mem 0x8be58718-0x8be58759]
[ 0.011893] ACPI: Reserving BGRT table memory at [mem 0x8be58760-0x8be58797]
[ 0.011896] ACPI: Reserving SSDT table memory at [mem 0x8be58798-0x8be5944b]
[ 0.011898] ACPI: Reserving SSDT table memory at [mem 0x8be59450-0x8be5dd1d]
[ 0.011900] ACPI: Reserving SSDT table memory at [mem 0x8be5dd20-0x8be5f2c4]
[ 0.011902] ACPI: Reserving SSDT table memory at [mem 0x8be5f2c8-0x8be60200]
[ 0.011904] ACPI: Reserving SSDT table memory at [mem 0x8be60208-0x8be61763]
[ 0.011906] ACPI: Reserving SSDT table memory at [mem 0x8be61768-0x8be61f92]
[ 0.011908] ACPI: Reserving MSDM table memory at [mem 0x8b87cf18-0x8b87cf6c]
[ 0.011978] No NUMA configuration found
[ 0.011980] Faking a node at [mem 0x0000000000000000-0x000000022effffff]
[ 0.011987] NODE_DATA(0) allocated [mem 0x22effc000-0x22effffff]
[ 0.012039] Zone ranges:
[ 0.012041] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.012045] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.012048] Normal [mem 0x0000000100000000-0x000000022effffff]
[ 0.012052] Device empty
[ 0.012054] Movable zone start for each node
[ 0.012055] Early memory node ranges
[ 0.012056] node 0: [mem 0x0000000000001000-0x000000000009ffff]
[ 0.012059] node 0: [mem 0x0000000000100000-0x000000008b7a4fff]
[ 0.012062] node 0: [mem 0x000000008b8c8000-0x000000008bdc6fff]
[ 0.012064] node 0: [mem 0x000000008de95000-0x000000008e026fff]
[ 0.012066] node 0: [mem 0x000000008e03e000-0x000000008e066fff]
[ 0.012068] node 0: [mem 0x000000008e4bc000-0x000000008e998fff]
[ 0.012070] node 0: [mem 0x000000008effa000-0x000000008effffff]
[ 0.012072] node 0: [mem 0x0000000100000000-0x000000022effffff]
[ 0.012075] Initmem setup node 0 [mem 0x0000000000001000-0x000000022effffff]
[ 0.012085] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.012141] On node 0, zone DMA: 96 pages in unavailable ranges
[ 0.022599] On node 0, zone DMA32: 291 pages in unavailable ranges
[ 0.022839] On node 0, zone DMA32: 8398 pages in unavailable ranges
[ 0.022850] On node 0, zone DMA32: 23 pages in unavailable ranges
[ 0.022905] On node 0, zone DMA32: 1109 pages in unavailable ranges
[ 0.022952] On node 0, zone DMA32: 1633 pages in unavailable ranges
[ 0.046141] On node 0, zone Normal: 4096 pages in unavailable ranges
[ 0.046263] On node 0, zone Normal: 4096 pages in unavailable ranges
[ 0.046424] ACPI: PM-Timer IO Port: 0x808
[ 0.046437] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.046450] IOAPIC[0]: apic_id 5, version 33, address 0xfec00000, GSI 0-23
[ 0.046457] IOAPIC[1]: apic_id 6, version 33, address 0xfec01000, GSI 24-55
[ 0.046461] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.046465] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.046472] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.046474] ACPI: HPET id: 0x10228201 base: 0xfed00000
[ 0.046490] e820: update [mem 0x8a5e1000-0x8a5f9fff] usable ==> reserved
[ 0.046511] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.046557] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.046561] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.046565] PM: hibernation: Registered nosave memory: [mem 0x8a5e1000-0x8a5f9fff]
[ 0.046569] PM: hibernation: Registered nosave memory: [mem 0x8b7a5000-0x8b8c7fff]
[ 0.046572] PM: hibernation: Registered nosave memory: [mem 0x8bdc7000-0x8d1a0fff]
[ 0.046574] PM: hibernation: Registered nosave memory: [mem 0x8d1a1000-0x8de2dfff]
[ 0.046576] PM: hibernation: Registered nosave memory: [mem 0x8de2e000-0x8de94fff]
[ 0.046579] PM: hibernation: Registered nosave memory: [mem 0x8e027000-0x8e03dfff]
[ 0.046583] PM: hibernation: Registered nosave memory: [mem 0x8e067000-0x8e4bbfff]
[ 0.046586] PM: hibernation: Registered nosave memory: [mem 0x8e999000-0x8eff9fff]
[ 0.046590] PM: hibernation: Registered nosave memory: [mem 0x8f000000-0xf7ffffff]
[ 0.046591] PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[ 0.046593] PM: hibernation: Registered nosave memory: [mem 0xfc000000-0xfeafffff]
[ 0.046595] PM: hibernation: Registered nosave memory: [mem 0xfeb00000-0xfeb00fff]
[ 0.046596] PM: hibernation: Registered nosave memory: [mem 0xfeb01000-0xfebfffff]
[ 0.046598] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec01fff]
[ 0.046599] PM: hibernation: Registered nosave memory: [mem 0xfec02000-0xfec0ffff]
[ 0.046601] PM: hibernation: Registered nosave memory: [mem 0xfec10000-0xfec10fff]
[ 0.046602] PM: hibernation: Registered nosave memory: [mem 0xfec11000-0xfecfffff]
[ 0.046604] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[ 0.046606] PM: hibernation: Registered nosave memory: [mem 0xfed01000-0xfed3ffff]
[ 0.046607] PM: hibernation: Registered nosave memory: [mem 0xfed40000-0xfed44fff]
[ 0.046609] PM: hibernation: Registered nosave memory: [mem 0xfed45000-0xfed7ffff]
[ 0.046610] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfed8ffff]
[ 0.046612] PM: hibernation: Registered nosave memory: [mem 0xfed90000-0xfeffffff]
[ 0.046613] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.046617] [mem 0x8f000000-0xf7ffffff] available for PCI devices
[ 0.046619] Booting paravirtualized kernel on bare hardware
[ 0.046623] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.053809] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
[ 0.054361] percpu: Embedded 63 pages/cpu s221184 r8192 d28672 u524288
[ 0.054388] pcpu-alloc: s221184 r8192 d28672 u524288 alloc=1*2097152
[ 0.054394] pcpu-alloc: [0] 0 1 2 3
[ 0.054443] Fallback order for Node 0: 0
[ 0.054450] Built 1 zonelists, mobility grouping on. Total pages: 1786740
[ 0.054453] Policy zone: Normal
[ 0.054456] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64 root=UUID=df029a60-dcfd-4c97-be87-681cf65a4b37 rw quiet udev.log_priority=3
[ 0.054572] Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64", will be passed to user space.
[ 0.056808] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.057951] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.058550] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.136872] Memory: 6964872K/7261060K available (14343K kernel code, 2124K rwdata, 11068K rodata, 1856K init, 3308K bss, 295928K reserved, 0K cma-reserved)
[ 0.137780] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.137823] ftrace: allocating 45072 entries in 177 pages
[ 0.149977] ftrace: allocated 177 pages with 4 groups
[ 0.150157] Dynamic Preempt: full
[ 0.150259] rcu: Preemptible hierarchical RCU implementation.
[ 0.150261] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[ 0.150263] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.150265] Trampoline variant of Tasks RCU enabled.
[ 0.150266] Rude variant of Tasks RCU enabled.
[ 0.150267] Tracing variant of Tasks RCU enabled.
[ 0.150268] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.150270] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.159764] NR_IRQS: 20736, nr_irqs: 1000, preallocated irqs: 16
[ 0.160188] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[ 0.160212] random: crng init done
[ 0.160257] Console: colour dummy device 80x25
[ 0.160282] printk: console [tty0] enabled
[ 0.160320] ACPI: Core revision 20211217
[ 0.160588] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[ 0.160610] APIC: Switch to symmetric I/O mode setup
[ 0.161050] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.177278] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x1fa6a503882, max_idle_ns: 440795209134 ns
[ 0.177286] Calibrating delay loop (skipped), value calculated using timer frequency.. 4393.55 BogoMIPS (lpj=7319283)
[ 0.177291] pid_max: default: 32768 minimum: 301
[ 0.180670] LSM: Security Framework initializing
[ 0.180683] landlock: Up and running.
[ 0.180686] Yama: becoming mindful.
[ 0.180700] LSM support for eBPF active
[ 0.180769] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.180802] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.181221] BIOS may not properly restore RDRAND after suspend, hiding RDRAND via CPUID. Use rdrand=force to reenable.
[ 0.181244] LVT offset 1 assigned for vector 0xf9
[ 0.181251] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 4
[ 0.181253] Last level dTLB entries: 4KB 512, 2MB 256, 4MB 128, 1GB 0
[ 0.181263] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.181267] Spectre V2 : Mitigation: Retpolines
[ 0.181268] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.181271] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[ 0.190759] Freeing SMP alternatives memory: 36K
[ 0.303309] smpboot: CPU0: AMD A8-7410 APU with AMD Radeon R5 Graphics (family: 0x16, model: 0x30, stepping: 0x1)
[ 0.303704] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.303708] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.303746] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.303789] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.303824] Performance Events: AMD PMU driver.
[ 0.303831] ... version: 0
[ 0.303832] ... bit width: 48
[ 0.303834] ... generic registers: 4
[ 0.303835] ... value mask: 0000ffffffffffff
[ 0.303837] ... max period: 00007fffffffffff
[ 0.303838] ... fixed-purpose events: 0
[ 0.303840] ... event mask: 000000000000000f
[ 0.303950] rcu: Hierarchical SRCU implementation.
[ 0.303950] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.303950] smp: Bringing up secondary CPUs ...
[ 0.303950] x86: Booting SMP configuration:
[ 0.303950] .... node #0, CPUs: #1 #2 #3
[ 0.309809] smp: Brought up 1 node, 4 CPUs
[ 0.309809] smpboot: Max logical packages: 1
[ 0.309809] smpboot: Total of 4 processors activated (17573.20 BogoMIPS)
[ 0.311414] devtmpfs: initialized
[ 0.311414] x86/mm: Memory block size: 128MB
[ 0.311882] ACPI: PM: Registering ACPI NVS region [mem 0x8bdc7000-0x8d1a0fff] (20815872 bytes)
[ 0.314077] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.314098] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.314180] pinctrl core: initialized pinctrl subsystem
[ 0.314341] PM: RTC time: 04:58:19, date: 2022-06-17
[ 0.315370] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.315900] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.316187] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.316488] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.316562] audit: initializing netlink subsys (disabled)
[ 0.316614] audit: type=2000 audit(1655441899.153:1): state=initialized audit_enabled=0 res=1
[ 0.316614] thermal_sys: Registered thermal governor 'fair_share'
[ 0.316614] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.316614] thermal_sys: Registered thermal governor 'step_wise'
[ 0.316614] thermal_sys: Registered thermal governor 'user_space'
[ 0.316614] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.316614] cpuidle: using governor ladder
[ 0.316614] cpuidle: using governor menu
[ 0.316614] HugeTLB: can free 4095 vmemmap pages for hugepages-1048576kB
[ 0.316614] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.317320] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.317329] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.317351] PCI: Using configuration type 1 for base access
[ 0.320096] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.320106] HugeTLB: can free 7 vmemmap pages for hugepages-2048kB
[ 0.320106] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.320106] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.320877] ACPI: Added _OSI(Module Device)
[ 0.320880] ACPI: Added _OSI(Processor Device)
[ 0.320882] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.320883] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.320886] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.320888] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.320890] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.351858] ACPI: 7 ACPI AML tables successfully acquired and loaded
[ 0.354363] ACPI: EC: EC started
[ 0.354365] ACPI: EC: interrupt blocked
[ 0.355686] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.355689] ACPI: EC: Boot ECDT EC used to handle transactions
[ 0.357150] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.364590] ACPI: Interpreter enabled
[ 0.364634] ACPI: PM: (supports S0 S3 S4 S5)
[ 0.364637] ACPI: Using IOAPIC for interrupt routing
[ 0.364695] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.365275] ACPI: Enabled 5 GPEs in block 00 to 1F
[ 0.384566] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.384579] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.384880] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ 0.384912] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[ 0.385716] PCI host bridge to bus 0000:00
[ 0.385720] pci_bus 0000:00: root bus resource [io 0x0000-0x03af window]
[ 0.385724] pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7 window]
[ 0.385728] pci_bus 0000:00: root bus resource [io 0x03b0-0x03df window]
[ 0.385731] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.385735] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000dffff window]
[ 0.385738] pci_bus 0000:00: root bus resource [mem 0xd0000000-0xfed3ffff window]
[ 0.385742] pci_bus 0000:00: root bus resource [mem 0xfed45000-0xffffffff window]
[ 0.385746] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.385767] pci 0000:00:00.0: [1022:1566] type 00 class 0x060000
[ 0.385914] pci 0000:00:01.0: [1002:9851] type 00 class 0x030000
[ 0.385929] pci 0000:00:01.0: reg 0x10: [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.385939] pci 0000:00:01.0: reg 0x18: [mem 0xf0000000-0xf07fffff 64bit pref]
[ 0.385947] pci 0000:00:01.0: reg 0x20: [io 0xf000-0xf0ff]
[ 0.385954] pci 0000:00:01.0: reg 0x24: [mem 0xfea00000-0xfea3ffff]
[ 0.385961] pci 0000:00:01.0: reg 0x30: [mem 0xfea40000-0xfea5ffff pref]
[ 0.385969] pci 0000:00:01.0: enabling Extended Tags
[ 0.385984] pci 0000:00:01.0: BAR 0: assigned to efifb
[ 0.385990] pci 0000:00:01.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.386023] pci 0000:00:01.0: supports D1 D2
[ 0.386025] pci 0000:00:01.0: PME# supported from D1 D2 D3hot
[ 0.386151] pci 0000:00:01.1: [1002:9840] type 00 class 0x040300
[ 0.386165] pci 0000:00:01.1: reg 0x10: [mem 0xfea64000-0xfea67fff 64bit]
[ 0.386191] pci 0000:00:01.1: enabling Extended Tags
[ 0.386226] pci 0000:00:01.1: supports D1 D2
[ 0.386291] pci 0000:00:02.0: [1022:156b] type 00 class 0x060000
[ 0.386378] pci 0000:00:02.1: [1022:1439] type 01 class 0x060400
[ 0.386411] pci 0000:00:02.1: enabling Extended Tags
[ 0.386453] pci 0000:00:02.1: PME# supported from D0 D3hot D3cold
[ 0.386569] pci 0000:00:02.2: [1022:1439] type 01 class 0x060400
[ 0.386602] pci 0000:00:02.2: enabling Extended Tags
[ 0.386644] pci 0000:00:02.2: PME# supported from D0 D3hot D3cold
[ 0.386764] pci 0000:00:02.3: [1022:1439] type 01 class 0x060400
[ 0.386797] pci 0000:00:02.3: enabling Extended Tags
[ 0.386838] pci 0000:00:02.3: PME# supported from D0 D3hot D3cold
[ 0.386957] pci 0000:00:08.0: [1022:1537] type 00 class 0x108000
[ 0.386969] pci 0000:00:08.0: reg 0x10: [mem 0xf0800000-0xf081ffff 64bit pref]
[ 0.386976] pci 0000:00:08.0: reg 0x18: [mem 0xfe600000-0xfe6fffff]
[ 0.386982] pci 0000:00:08.0: reg 0x1c: [mem 0xfea6f000-0xfea6ffff]
[ 0.386991] pci 0000:00:08.0: reg 0x24: [mem 0xfea6a000-0xfea6bfff]
[ 0.387082] pci 0000:00:10.0: [1022:7814] type 00 class 0x0c0330
[ 0.387103] pci 0000:00:10.0: reg 0x10: [mem 0xfea68000-0xfea69fff 64bit]
[ 0.387199] pci 0000:00:10.0: PME# supported from D0 D3hot D3cold
[ 0.387329] pci 0000:00:11.0: [1022:7801] type 00 class 0x010601
[ 0.387344] pci 0000:00:11.0: reg 0x10: [io 0xf140-0xf147]
[ 0.387352] pci 0000:00:11.0: reg 0x14: [io 0xf130-0xf133]
[ 0.387361] pci 0000:00:11.0: reg 0x18: [io 0xf120-0xf127]
[ 0.387369] pci 0000:00:11.0: reg 0x1c: [io 0xf110-0xf113]
[ 0.387378] pci 0000:00:11.0: reg 0x20: [io 0xf100-0xf10f]
[ 0.387386] pci 0000:00:11.0: reg 0x24: [mem 0xfea6e000-0xfea6e3ff]
[ 0.387428] pci 0000:00:11.0: PME# supported from D3hot
[ 0.388165] pci 0000:00:12.0: [1022:7808] type 00 class 0x0c0320
[ 0.388180] pci 0000:00:12.0: reg 0x10: [mem 0xfea6d000-0xfea6d0ff]
[ 0.388245] pci 0000:00:12.0: supports D1 D2
[ 0.388248] pci 0000:00:12.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.388355] pci 0000:00:13.0: [1022:7808] type 00 class 0x0c0320
[ 0.388370] pci 0000:00:13.0: reg 0x10: [mem 0xfea6c000-0xfea6c0ff]
[ 0.388435] pci 0000:00:13.0: supports D1 D2
[ 0.388437] pci 0000:00:13.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.388549] pci 0000:00:14.0: [1022:780b] type 00 class 0x0c0500
[ 0.388700] pci 0000:00:14.2: [1022:780d] type 00 class 0x040300
[ 0.388717] pci 0000:00:14.2: reg 0x10: [mem 0xfea60000-0xfea63fff 64bit]
[ 0.388773] pci 0000:00:14.2: PME# supported from D0 D3hot D3cold
[ 0.388872] pci 0000:00:14.3: [1022:780e] type 00 class 0x060100
[ 0.389030] pci 0000:00:18.0: [1022:1580] type 00 class 0x060000
[ 0.389094] pci 0000:00:18.1: [1022:1581] type 00 class 0x060000
[ 0.389155] pci 0000:00:18.2: [1022:1582] type 00 class 0x060000
[ 0.389216] pci 0000:00:18.3: [1022:1583] type 00 class 0x060000
[ 0.389280] pci 0000:00:18.4: [1022:1584] type 00 class 0x060000
[ 0.389350] pci 0000:00:18.5: [1022:1585] type 00 class 0x060000
[ 0.389542] pci 0000:01:00.0: [1002:6665] type 00 class 0x038000
[ 0.389562] pci 0000:01:00.0: reg 0x10: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.389576] pci 0000:01:00.0: reg 0x18: [mem 0xfe900000-0xfe93ffff 64bit]
[ 0.389585] pci 0000:01:00.0: reg 0x20: [io 0xe000-0xe0ff]
[ 0.389599] pci 0000:01:00.0: reg 0x30: [mem 0xfe940000-0xfe95ffff pref]
[ 0.389610] pci 0000:01:00.0: enabling Extended Tags
[ 0.389681] pci 0000:01:00.0: supports D1 D2
[ 0.389683] pci 0000:01:00.0: PME# supported from D1 D2 D3hot
[ 0.389730] pci 0000:01:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x4 link at 0000:00:02.1 (capable of 63.008 Gb/s with 8.0 GT/s PCIe x8 link)
[ 0.389857] pci 0000:00:02.1: PCI bridge to [bus 01]
[ 0.389863] pci 0000:00:02.1: bridge window [io 0xe000-0xefff]
[ 0.389868] pci 0000:00:02.1: bridge window [mem 0xfe900000-0xfe9fffff]
[ 0.389874] pci 0000:00:02.1: bridge window [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.389941] pci 0000:02:00.0: [10ec:b723] type 00 class 0x028000
[ 0.389962] pci 0000:02:00.0: reg 0x10: [io 0xd000-0xd0ff]
[ 0.389985] pci 0000:02:00.0: reg 0x18: [mem 0xfe800000-0xfe803fff 64bit]
[ 0.390100] pci 0000:02:00.0: supports D1 D2
[ 0.390102] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.390243] pci 0000:00:02.2: PCI bridge to [bus 02]
[ 0.390250] pci 0000:00:02.2: bridge window [io 0xd000-0xdfff]
[ 0.390254] pci 0000:00:02.2: bridge window [mem 0xfe800000-0xfe8fffff]
[ 0.390360] pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
[ 0.390384] pci 0000:03:00.0: reg 0x10: [io 0xc000-0xc0ff]
[ 0.390413] pci 0000:03:00.0: reg 0x18: [mem 0xfe704000-0xfe704fff 64bit]
[ 0.390433] pci 0000:03:00.0: reg 0x20: [mem 0xfe700000-0xfe703fff 64bit]
[ 0.390552] pci 0000:03:00.0: supports D1 D2
[ 0.390555] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.390789] pci 0000:00:02.3: PCI bridge to [bus 03]
[ 0.390795] pci 0000:00:02.3: bridge window [io 0xc000-0xcfff]
[ 0.390800] pci 0000:00:02.3: bridge window [mem 0xfe700000-0xfe7fffff]
[ 0.393259] ACPI: PCI: Interrupt link LNKA configured for IRQ 11
[ 0.393396] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[ 0.393561] ACPI: PCI: Interrupt link LNKC configured for IRQ 4
[ 0.393725] ACPI: PCI: Interrupt link LNKD configured for IRQ 11
[ 0.393859] ACPI: PCI: Interrupt link LNKE configured for IRQ 10
[ 0.394035] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.394151] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.394265] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.394873] ACPI: EC: interrupt unblocked
[ 0.394875] ACPI: EC: event unblocked
[ 0.394880] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.394882] ACPI: EC: GPE=0x3
[ 0.394885] ACPI: \_SB_.PCI0.SBRG.EC0_: Boot ECDT EC initialization complete
[ 0.394888] ACPI: \_SB_.PCI0.SBRG.EC0_: EC: Used to handle transactions and events
[ 0.395002] iommu: Default domain type: Translated
[ 0.395004] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.395344] SCSI subsystem initialized
[ 0.395366] libata version 3.00 loaded.
[ 0.395366] ACPI: bus type USB registered
[ 0.395366] usbcore: registered new interface driver usbfs
[ 0.395366] usbcore: registered new interface driver hub
[ 0.395366] usbcore: registered new device driver usb
[ 0.395366] pps_core: LinuxPPS API ver. 1 registered
[ 0.395366] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.395366] PTP clock support registered
[ 0.395366] EDAC MC: Ver: 3.0.0
[ 0.395366] Registered efivars operations
[ 0.395366] NetLabel: Initializing
[ 0.395366] NetLabel: domain hash size = 128
[ 0.395366] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.395366] NetLabel: unlabeled traffic allowed by default
[ 0.395366] mctp: management component transport protocol core
[ 0.395366] NET: Registered PF_MCTP protocol family
[ 0.395366] PCI: Using ACPI for IRQ routing
[ 0.397831] PCI: pci_cache_line_size set to 64 bytes
[ 0.397890] e820: reserve RAM buffer [mem 0x8a5e1000-0x8bffffff]
[ 0.397894] e820: reserve RAM buffer [mem 0x8b7a5000-0x8bffffff]
[ 0.397896] e820: reserve RAM buffer [mem 0x8bdc7000-0x8bffffff]
[ 0.397898] e820: reserve RAM buffer [mem 0x8e027000-0x8fffffff]
[ 0.397901] e820: reserve RAM buffer [mem 0x8e067000-0x8fffffff]
[ 0.397903] e820: reserve RAM buffer [mem 0x8e999000-0x8fffffff]
[ 0.397905] e820: reserve RAM buffer [mem 0x8f000000-0x8fffffff]
[ 0.397907] e820: reserve RAM buffer [mem 0x22f000000-0x22fffffff]
[ 0.397930] pci 0000:00:01.0: vgaarb: setting as boot VGA device
[ 0.397930] pci 0000:00:01.0: vgaarb: bridge control possible
[ 0.397930] pci 0000:00:01.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.397930] vgaarb: loaded
[ 0.397930] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.397930] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 0.399554] clocksource: Switched to clocksource tsc-early
[ 0.416309] VFS: Disk quotas dquot_6.6.0
[ 0.416335] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.416493] pnp: PnP ACPI init
[ 0.416778] system 00:00: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.416927] system 00:01: [mem 0x90000000-0xcfffffff] has been reserved
[ 0.417963] system 00:05: [io 0x04d0-0x04d1] has been reserved
[ 0.417967] system 00:05: [io 0x040b] has been reserved
[ 0.417971] system 00:05: [io 0x04d6] has been reserved
[ 0.417974] system 00:05: [io 0x0c00-0x0c01] has been reserved
[ 0.417978] system 00:05: [io 0x0c14] has been reserved
[ 0.417981] system 00:05: [io 0x0c50-0x0c51] has been reserved
[ 0.417984] system 00:05: [io 0x0c52] has been reserved
[ 0.417987] system 00:05: [io 0x0c6c] has been reserved
[ 0.417990] system 00:05: [io 0x0c6f] has been reserved
[ 0.417994] system 00:05: [io 0x0cd0-0x0cd1] has been reserved
[ 0.417997] system 00:05: [io 0x0cd2-0x0cd3] has been reserved
[ 0.418000] system 00:05: [io 0x0cd4-0x0cd5] has been reserved
[ 0.418003] system 00:05: [io 0x0cd6-0x0cd7] has been reserved
[ 0.418006] system 00:05: [io 0x0cd8-0x0cdf] has been reserved
[ 0.418010] system 00:05: [io 0x0800-0x089f] has been reserved
[ 0.418013] system 00:05: [io 0x0900-0x090f] has been reserved
[ 0.418016] system 00:05: [io 0x0910-0x091f] has been reserved
[ 0.418019] system 00:05: [io 0xfe00-0xfefe] has been reserved
[ 0.418024] system 00:05: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.418029] system 00:05: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.418033] system 00:05: [mem 0xfed80000-0xfed8ffff] has been reserved
[ 0.418037] system 00:05: [mem 0xfed61000-0xfed70fff] has been reserved
[ 0.418041] system 00:05: [mem 0xfec10000-0xfec10fff] has been reserved
[ 0.418044] system 00:05: [mem 0xff000000-0xffffffff] has been reserved
[ 0.419976] pnp: PnP ACPI: found 6 devices
[ 0.427337] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.427445] NET: Registered PF_INET protocol family
[ 0.427754] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.429655] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.429757] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.429919] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.430337] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.430503] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.430698] MPTCP token hash table entries: 8192 (order: 5, 196608 bytes, linear)
[ 0.430784] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.430916] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.431024] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.431035] NET: Registered PF_XDP protocol family
[ 0.431064] pci 0000:00:02.1: PCI bridge to [bus 01]
[ 0.431072] pci 0000:00:02.1: bridge window [io 0xe000-0xefff]
[ 0.431079] pci 0000:00:02.1: bridge window [mem 0xfe900000-0xfe9fffff]
[ 0.431083] pci 0000:00:02.1: bridge window [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.431090] pci 0000:00:02.2: PCI bridge to [bus 02]
[ 0.431094] pci 0000:00:02.2: bridge window [io 0xd000-0xdfff]
[ 0.431098] pci 0000:00:02.2: bridge window [mem 0xfe800000-0xfe8fffff]
[ 0.431106] pci 0000:00:02.3: PCI bridge to [bus 03]
[ 0.431109] pci 0000:00:02.3: bridge window [io 0xc000-0xcfff]
[ 0.431114] pci 0000:00:02.3: bridge window [mem 0xfe700000-0xfe7fffff]
[ 0.431124] pci_bus 0000:00: resource 4 [io 0x0000-0x03af window]
[ 0.431128] pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7 window]
[ 0.431131] pci_bus 0000:00: resource 6 [io 0x03b0-0x03df window]
[ 0.431134] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window]
[ 0.431137] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000dffff window]
[ 0.431141] pci_bus 0000:00: resource 9 [mem 0xd0000000-0xfed3ffff window]
[ 0.431144] pci_bus 0000:00: resource 10 [mem 0xfed45000-0xffffffff window]
[ 0.431147] pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
[ 0.431150] pci_bus 0000:01: resource 1 [mem 0xfe900000-0xfe9fffff]
[ 0.431153] pci_bus 0000:01: resource 2 [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.431157] pci_bus 0000:02: resource 0 [io 0xd000-0xdfff]
[ 0.431159] pci_bus 0000:02: resource 1 [mem 0xfe800000-0xfe8fffff]
[ 0.431164] pci_bus 0000:03: resource 0 [io 0xc000-0xcfff]
[ 0.431167] pci_bus 0000:03: resource 1 [mem 0xfe700000-0xfe7fffff]
[ 0.431386] pci 0000:00:01.1: D0 power state depends on 0000:00:01.0
[ 0.447825] pci 0000:00:12.0: quirk_usb_early_handoff+0x0/0x750 took 15703 usecs
[ 0.447852] pci 0000:00:12.0: PME# does not work under D3, disabling it
[ 0.465443] pci 0000:00:13.0: quirk_usb_early_handoff+0x0/0x750 took 17164 usecs
[ 0.465461] pci 0000:00:13.0: PME# does not work under D3, disabling it
[ 0.465505] PCI: CLS 0 bytes, default 64
[ 0.465525] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.465526] software IO TLB: mapped [mem 0x0000000084b1a000-0x0000000088b1a000] (64MB)
[ 0.465592] LVT offset 0 assigned for vector 0x400
[ 0.465672] Trying to unpack rootfs image as initramfs...
[ 0.465751] perf: AMD IBS detected (0x000000ff)
[ 0.466894] Initialise system trusted keyrings
[ 0.466911] Key type blacklist registered
[ 0.467081] workingset: timestamp_bits=41 max_order=21 bucket_order=0
[ 0.469203] zbud: loaded
[ 0.487483] Key type asymmetric registered
[ 0.487494] Asymmetric key parser 'x509' registered
[ 0.646566] Freeing initrd memory: 8720K
[ 0.651551] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[ 0.651599] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 0.651666] io scheduler mq-deadline registered
[ 0.651668] io scheduler kyber registered
[ 0.651722] io scheduler bfq registered
[ 0.652920] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.653187] ACPI: AC: AC Adapter [AC0] (on-line)
[ 0.653267] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.653300] ACPI: button: Power Button [PWRB]
[ 0.653351] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
[ 0.653380] ACPI: button: Lid Switch [LID]
[ 0.653427] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
[ 0.653610] ACPI: button: Sleep Button [SLPB]
[ 0.653678] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 0.653726] ACPI: button: Power Button [PWRF]
[ 0.653788] ACPI: \_PR_.P000: Found 2 idle states
[ 0.653929] ACPI: \_PR_.P001: Found 2 idle states
[ 0.654051] ACPI: \_PR_.P002: Found 2 idle states
[ 0.654160] ACPI: \_PR_.P003: Found 2 idle states
[ 0.656089] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.656092] ACPI: thermal: Thermal Zone [THRM] (60 C)
[ 0.656400] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.659994] Non-volatile memory driver v1.3
[ 0.659997] Linux agpgart interface v0.103
[ 0.660000] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[ 0.660079] ACPI: bus type drm_connector registered
[ 0.661024] ahci 0000:00:11.0: version 3.0
[ 0.661295] ahci 0000:00:11.0: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[ 0.661302] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio slum part
[ 0.664121] scsi host0: ahci
[ 0.664379] scsi host1: ahci
[ 0.664444] ata1: SATA max UDMA/133 abar m1024@0xfea6e000 port 0xfea6e100 irq 30
[ 0.664449] ata2: SATA max UDMA/133 abar m1024@0xfea6e000 port 0xfea6e180 irq 30
[ 0.664576] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.664581] ehci-pci: EHCI PCI platform driver
[ 0.664743] ehci-pci 0000:00:12.0: EHCI Host Controller
[ 0.664753] ehci-pci 0000:00:12.0: new USB bus registered, assigned bus number 1
[ 0.664760] ehci-pci 0000:00:12.0: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 0.664769] ehci-pci 0000:00:12.0: debug port 2
[ 0.664825] ehci-pci 0000:00:12.0: irq 18, io mem 0xfea6d000
[ 0.677979] ehci-pci 0000:00:12.0: USB 2.0 started, EHCI 1.00
[ 0.678302] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.18
[ 0.678308] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.678311] usb usb1: Product: EHCI Host Controller
[ 0.678314] usb usb1: Manufacturer: Linux 5.18.5-1-MANJARO ehci_hcd
[ 0.678317] usb usb1: SerialNumber: 0000:00:12.0
[ 0.678583] hub 1-0:1.0: USB hub found
[ 0.678605] hub 1-0:1.0: 2 ports detected
[ 0.679290] ehci-pci 0000:00:13.0: EHCI Host Controller
[ 0.679300] ehci-pci 0000:00:13.0: new USB bus registered, assigned bus number 2
[ 0.679306] ehci-pci 0000:00:13.0: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 0.679315] ehci-pci 0000:00:13.0: debug port 2
[ 0.679366] ehci-pci 0000:00:13.0: irq 18, io mem 0xfea6c000
[ 0.691125] ehci-pci 0000:00:13.0: USB 2.0 started, EHCI 1.00
[ 0.691348] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.18
[ 0.691353] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.691356] usb usb2: Product: EHCI Host Controller
[ 0.691359] usb usb2: Manufacturer: Linux 5.18.5-1-MANJARO ehci_hcd
[ 0.691362] usb usb2: SerialNumber: 0000:00:13.0
[ 0.692249] hub 2-0:1.0: USB hub found
[ 0.692271] hub 2-0:1.0: 2 ports detected
[ 0.692980] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.692987] ohci-pci: OHCI PCI platform driver
[ 0.693005] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.693081] usbcore: registered new interface driver usbserial_generic
[ 0.693090] usbserial: USB Serial support registered for generic
[ 0.693308] rtc_cmos 00:02: RTC can wake from S4
[ 0.693531] ACPI: battery: Slot [BAT0] (battery present)
[ 0.693553] rtc_cmos 00:02: registered as rtc0
[ 0.693575] rtc_cmos 00:02: setting system clock to 2022-06-17T04:58:20 UTC (1655441900)
[ 0.693606] rtc_cmos 00:02: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 0.693760] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.693929] efifb: probing for efifb
[ 0.693951] efifb: showing boot graphics
[ 0.695162] efifb: framebuffer at 0xd0000000, using 4224k, total 4224k
[ 0.695165] efifb: mode is 1366x768x32, linelength=5632, pages=1
[ 0.695168] efifb: scrolling: redraw
[ 0.695168] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.695257] fbcon: Deferring console take-over
[ 0.695259] fb0: EFI VGA frame buffer device
[ 0.695300] hid: raw HID events driver (C) Jiri Kosina
[ 0.695452] drop_monitor: Initializing network drop monitor service
[ 0.720685] Initializing XFRM netlink socket
[ 0.720900] NET: Registered PF_INET6 protocol family
[ 0.726393] Segment Routing with IPv6
[ 0.726400] RPL Segment Routing with IPv6
[ 0.726426] In-situ OAM (IOAM) with IPv6
[ 0.726473] NET: Registered PF_PACKET protocol family
[ 0.726539] x86/pm: family 0x16 cpu detected, MSR saving is needed during suspending.
[ 0.726917] microcode: CPU0: patch_level=0x07030105
[ 0.726924] microcode: CPU1: patch_level=0x07030105
[ 0.726937] microcode: CPU2: patch_level=0x07030105
[ 0.726962] microcode: CPU3: patch_level=0x07030105
[ 0.726969] microcode: Microcode Update Driver: v2.2.
[ 0.726979] IPI shorthand broadcast: enabled
[ 0.726996] sched_clock: Marking stable (726173861, 616484)->(745907794, -19117449)
[ 0.727268] registered taskstats version 1
[ 0.727430] Loading compiled-in X.509 certificates
[ 0.733962] Loaded X.509 cert 'Build time autogenerated kernel key: 3d10200799e3b89234ccc9c84cea80e53bc231fc'
[ 0.736353] zswap: loaded using pool zstd/z3fold
[ 0.736775] Key type ._fscrypt registered
[ 0.736778] Key type .fscrypt registered
[ 0.736779] Key type fscrypt-provisioning registered
[ 0.739600] PM: Magic number: 10:142:970
[ 0.739959] RAS: Correctable Errors collector initialized.
[ 0.774216] ata2: SATA link down (SStatus 0 SControl 300)
[ 0.927677] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 0.940886] usb 2-1: new high-speed USB device number 2 using ehci-pci
[ 0.943965] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 0.994412] ata1.00: ATA-8: TOSHIBA MQ01ABD100, AX0R5J, max UDMA/100
[ 0.994740] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 0.996455] ata1.00: configured for UDMA/100
[ 0.996713] scsi 0:0:0:0: Direct-Access ATA TOSHIBA MQ01ABD1 5J PQ: 0 ANSI: 5
[ 0.997182] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 0.997187] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 0.997212] sd 0:0:0:0: [sda] Write Protect is off
[ 0.997217] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 0.997262] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.074573] usb 1-1: New USB device found, idVendor=0438, idProduct=7900, bcdDevice= 0.18
[ 1.074584] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.074856] hub 1-1:1.0: USB hub found
[ 1.074937] hub 1-1:1.0: 4 ports detected
[ 1.087864] usb 2-1: New USB device found, idVendor=0438, idProduct=7900, bcdDevice= 0.18
[ 1.087875] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.088147] hub 2-1:1.0: USB hub found
[ 1.088228] hub 2-1:1.0: 2 ports detected
[ 1.117717] sda: sda1 sda2 sda3 sda4
[ 1.131563] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.135572] Freeing unused decrypted memory: 2036K
[ 1.136340] Freeing unused kernel image (initmem) memory: 1856K
[ 1.136354] Write protecting the kernel read-only data: 28672k
[ 1.137426] Freeing unused kernel image (text/rodata gap) memory: 2040K
[ 1.137971] Freeing unused kernel image (rodata/data gap) memory: 1220K
[ 1.199583] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.199593] rodata_test: all tests were successful
[ 1.199603] Run /init as init process
[ 1.199606] with arguments:
[ 1.199608] /init
[ 1.199609] with environment:
[ 1.199611] HOME=/
[ 1.199612] TERM=linux
[ 1.199614] BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
[ 1.374008] usb 1-1.3: new full-speed USB device number 3 using ehci-pci
[ 1.421313] i8042: PNP: PS/2 Controller [PNP030b:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[ 1.424147] i8042: Detected active multiplexing controller, rev 1.1
[ 1.425186] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.425272] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 1.425322] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 1.425369] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 1.425415] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 1.433261] xhci_hcd 0000:00:10.0: xHCI Host Controller
[ 1.433280] xhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 3
[ 1.433459] xhci_hcd 0000:00:10.0: hcc params 0x014040c3 hci version 0x100 quirks 0x0000000000000410
[ 1.433887] xhci_hcd 0000:00:10.0: xHCI Host Controller
[ 1.433894] xhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 4
[ 1.433901] xhci_hcd 0000:00:10.0: Host supports USB 3.0 SuperSpeed
[ 1.436930] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.18
[ 1.436938] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.436942] usb usb3: Product: xHCI Host Controller
[ 1.436945] usb usb3: Manufacturer: Linux 5.18.5-1-MANJARO xhci-hcd
[ 1.436948] usb usb3: SerialNumber: 0000:00:10.0
[ 1.437181] hub 3-0:1.0: USB hub found
[ 1.437201] hub 3-0:1.0: 2 ports detected
[ 1.437447] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.437503] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.18
[ 1.437508] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.437511] usb usb4: Product: xHCI Host Controller
[ 1.437514] usb usb4: Manufacturer: Linux 5.18.5-1-MANJARO xhci-hcd
[ 1.437516] usb usb4: SerialNumber: 0000:00:10.0
[ 1.437864] hub 4-0:1.0: USB hub found
[ 1.437880] hub 4-0:1.0: 2 ports detected
[ 1.493274] usb 1-1.3: New USB device found, idVendor=0bda, idProduct=b721, bcdDevice= 2.00
[ 1.493285] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.493289] usb 1-1.3: Product: Bluetooth Radio
[ 1.493293] usb 1-1.3: Manufacturer: Realtek
[ 1.493296] usb 1-1.3: SerialNumber: 00e04c000001
[ 1.493994] tsc: Refined TSC clocksource calibration: 2195.881 MHz
[ 1.494001] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x1fa6ffc1640, max_idle_ns: 440795239502 ns
[ 1.494138] clocksource: Switched to clocksource tsc
[ 1.528978] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 1.570662] usb 1-1.4: new high-speed USB device number 4 using ehci-pci
[ 1.687365] usb 3-1: new low-speed USB device number 2 using xhci_hcd
[ 1.710428] usb 1-1.4: New USB device found, idVendor=04f2, idProduct=b52b, bcdDevice=95.52
[ 1.710440] usb 1-1.4: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 1.710444] usb 1-1.4: Product: USB2.0 VGA UVC WebCam
[ 1.710447] usb 1-1.4: Manufacturer: Chicony Electronics Co.,Ltd.
[ 1.710449] usb 1-1.4: SerialNumber: 0x0001
[ 1.859065] usb 3-1: New USB device found, idVendor=18f8, idProduct=0f97, bcdDevice= 1.00
[ 1.859076] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.859080] usb 3-1: Product: USB OPTICAL MOUSE
[ 1.889482] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:10.0/usb3/3-1/3-1:1.0/0003:18F8:0F97.0001/input/input9
[ 1.889644] hid-generic 0003:18F8:0F97.0001: input,hidraw0: USB HID v1.10 Mouse [USB OPTICAL MOUSE ] on usb-0000:00:10.0-1/input0
[ 1.908753] input: USB OPTICAL MOUSE Keyboard as /devices/pci0000:00/0000:00:10.0/usb3/3-1/3-1:1.1/0003:18F8:0F97.0002/input/input10
[ 1.964317] hid-generic 0003:18F8:0F97.0002: input,hiddev96,hidraw1: USB HID v1.10 Keyboard [USB OPTICAL MOUSE ] on usb-0000:00:10.0-1/input1
[ 1.964392] usbcore: registered new interface driver usbhid
[ 1.964395] usbhid: USB HID core driver
[ 2.416179] fbcon: Taking over console
[ 2.416475] Console: switching to colour frame buffer device 170x48
[ 36.072548] EXT4-fs (sda3): mounted filesystem with ordered data mode. Quota mode: none.
[ 41.313472] systemd[1]: systemd 251.2-3-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 41.313486] systemd[1]: Detected architecture x86-64.
[ 41.464710] systemd[1]: Hostname set to <simon-x555yi>.
[ 43.523309] systemd[1]: Queued start job for default target Graphical Interface.
[ 43.525358] systemd[1]: Created slice Slice /system/getty.
[ 43.526011] systemd[1]: Created slice Slice /system/modprobe.
[ 43.526531] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 43.526931] systemd[1]: Created slice User and Session Slice.
[ 43.527050] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 43.527150] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 43.527463] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 43.527543] systemd[1]: Reached target Local Encrypted Volumes.
[ 43.527576] systemd[1]: Reached target Login Prompts.
[ 43.527611] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 43.527658] systemd[1]: Reached target Path Units.
[ 43.527698] systemd[1]: Reached target Remote File Systems.
[ 43.527728] systemd[1]: Reached target Slice Units.
[ 43.527776] systemd[1]: Reached target Local Verity Protected Volumes.
[ 43.527917] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 43.544935] systemd[1]: Listening on LVM2 poll daemon socket.
[ 43.561911] systemd[1]: Listening on Process Core Dump Socket.
[ 43.562231] systemd[1]: Listening on Journal Audit Socket.
[ 43.562440] systemd[1]: Listening on Journal Socket (/dev/log).
[ 43.562659] systemd[1]: Listening on Journal Socket.
[ 43.589122] systemd[1]: Listening on udev Control Socket.
[ 43.589393] systemd[1]: Listening on udev Kernel Socket.
[ 43.591205] systemd[1]: Mounting Huge Pages File System...
[ 43.592863] systemd[1]: Mounting POSIX Message Queue File System...
[ 43.594580] systemd[1]: Mounting Kernel Debug File System...
[ 43.596223] systemd[1]: Mounting Kernel Trace File System...
[ 43.598351] systemd[1]: Starting Create List of Static Device Nodes...
[ 43.600221] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 43.602527] systemd[1]: Starting Load Kernel Module configfs...
[ 43.605039] systemd[1]: Starting Load Kernel Module drm...
[ 43.607160] systemd[1]: Starting Load Kernel Module fuse...
[ 43.607406] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
[ 43.748295] fuse: init (API version 7.36)
[ 43.774753] systemd[1]: Starting Load Kernel Modules...
[ 43.776395] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 43.776559] systemd[1]: Repartition Root Disk was skipped because all trigger condition checks failed.
[ 43.778337] systemd[1]: Starting Coldplug All udev Devices...
[ 43.781499] systemd[1]: Mounted Huge Pages File System.
[ 43.781693] systemd[1]: Mounted POSIX Message Queue File System.
[ 43.781845] systemd[1]: Mounted Kernel Debug File System.
[ 43.781985] systemd[1]: Mounted Kernel Trace File System.
[ 43.782326] systemd[1]: Finished Create List of Static Device Nodes.
[ 43.782925] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 43.783150] systemd[1]: Finished Load Kernel Module configfs.
[ 43.783584] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 43.783792] systemd[1]: Finished Load Kernel Module drm.
[ 43.784237] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 43.784464] systemd[1]: Finished Load Kernel Module fuse.
[ 43.786556] systemd[1]: Mounting FUSE Control File System...
[ 43.788361] systemd[1]: Mounting Kernel Configuration File System...
[ 43.791751] systemd[1]: Mounted Kernel Configuration File System.
[ 43.807961] EXT4-fs (sda3): re-mounted. Quota mode: none.
[ 43.809704] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 43.809946] systemd[1]: First Boot Wizard was skipped because of a failed condition check (ConditionFirstBoot=yes).
[ 43.854489] systemd[1]: Rebuild Hardware Database was skipped because all trigger condition checks failed.
[ 43.856178] systemd[1]: Starting Load/Save Random Seed...
[ 43.857992] systemd[1]: Starting Create System Users...
[ 43.861420] systemd[1]: Mounted FUSE Control File System.
[ 43.938785] systemd[1]: Finished Load Kernel Modules.
[ 43.940554] systemd[1]: Starting Apply Kernel Variables...
[ 44.352027] systemd[1]: Finished Load/Save Random Seed.
[ 44.352305] systemd[1]: First Boot Complete was skipped because of a failed condition check (ConditionFirstBoot=yes).
[ 44.543789] systemd[1]: Finished Coldplug All udev Devices.
[ 44.594520] systemd[1]: Finished Apply Kernel Variables.
[ 44.927891] systemd[1]: Finished Create System Users.
[ 44.929866] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 45.619346] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 45.619553] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of a failed condition check (ConditionKernelVersion=<5.6).
[ 45.622253] systemd[1]: Starting Journal Service...
[ 45.624956] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 45.672943] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 45.673144] systemd[1]: Reached target Preparation for Local File Systems.
[ 45.673206] systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of a failed condition check (ConditionPathExists=/var/lib/machines.raw).
[ 45.826623] systemd[1]: Started Journal Service.
[ 45.826800] audit: type=1130 audit(1655441945.627:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 45.865634] systemd-journald[238]: Received client request to flush runtime journal.
[ 45.982283] systemd-journald[238]: File /var/log/journal/0484a992e03a41888032c25fc0707575/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 47.313300] audit: type=1130 audit(1655441947.117:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 47.673995] acpi_cpufreq: overriding BIOS provided _PSD data
[ 47.687540] ACPI: video: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 47.688247] acpi device:02: registered as cooling_device4
[ 47.688346] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/LNXVIDEO:00/input/input12
[ 47.688663] ACPI: video: Video Device [VGA1] (multi-head: yes rom: no post: no)
[ 47.703924] ACPI BIOS Error (bug): Could not resolve symbol [^^^PB2.VGA.AFN7], AE_NOT_FOUND (20211217/psargs-330)
[ 47.703972] ACPI Error: Aborting method \_SB.PCI0.VGA.LCDD._BCM due to previous error (AE_NOT_FOUND) (20211217/psparse-529)
[ 47.703993] ACPI: \_SB_.PCI0.VGA_.LCDD: _BCM evaluation failed
[ 47.704302] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input13
[ 47.785101] ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\SBSM) (20211217/utaddress-204)
[ 47.785120] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 47.785565] input: Asus Wireless Radio Control as /devices/LNXSYSTM:00/LNXSYBUS:00/ATK4002:00/input/input14
[ 47.797780] ccp 0000:00:08.0: 4 command queues available
[ 47.804205] ccp 0000:00:08.0: ccp enabled
[ 47.922622] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[ 47.922827] sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
[ 47.922965] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[ 48.070106] input: PC Speaker as /devices/platform/pcspkr/input/input15
[ 48.166398] cryptd: max_cpu_qlen set to 1000
[ 48.441129] r8169 0000:03:00.0 eth0: RTL8168gu/8111gu, 2c:4d:54:26:97:2a, XID 509, IRQ 39
[ 48.441143] r8169 0000:03:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 48.450509] AVX version of gcm_enc/dec engaged.
[ 48.450551] AES CTR mode by8 optimization enabled
[ 48.493825] Bluetooth: Core ver 2.22
[ 48.493880] NET: Registered PF_BLUETOOTH protocol family
[ 48.493882] Bluetooth: HCI device and connection manager initialized
[ 48.493892] Bluetooth: HCI socket layer initialized
[ 48.493896] Bluetooth: L2CAP socket layer initialized
[ 48.493904] Bluetooth: SCO socket layer initialized
[ 48.682143] [drm] radeon kernel modesetting enabled.
[ 48.682184] vga_switcheroo: detected switching method \_SB_.PCI0.VGA_.ATPX handle
[ 48.683115] ATPX version 1, functions 0x00000003
[ 48.683302] radeon 0000:00:01.0: CIK support disabled by module param
[ 48.683382] radeon 0000:01:00.0: SI support disabled by module param
[ 48.728344] psmouse serio4: elantech: assuming hardware version 4 (with firmware version 0x381f00)
[ 48.743461] psmouse serio4: elantech: Synaptics capabilities query result 0x10, 0x14, 0x0e.
[ 48.757545] psmouse serio4: elantech: Elan sample query result 00, 23, 64
[ 48.826705] input: ETPS/2 Elantech Touchpad as /devices/platform/i8042/serio4/input/input19
[ 48.959687] snd_hda_intel 0000:00:01.1: Force to non-snoop mode
[ 48.965815] asus_wmi: ASUS WMI generic driver loaded
[ 49.014340] r8169 0000:03:00.0 enp3s0: renamed from eth0
[ 49.052759] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/sound/card0/input20
[ 49.067699] mousedev: PS/2 mouse device common for all mice
[ 49.088050] asus_wmi: Initialization: 0x1
[ 49.088182] asus_wmi: BIOS WMI version: 7.9
[ 49.088318] asus_wmi: SFUN value: 0xa0077
[ 49.088324] asus-nb-wmi asus-nb-wmi: Detected ATK, not ASUSWMI, use DSTS
[ 49.088329] asus-nb-wmi asus-nb-wmi: Detected ATK, enable event queue
[ 49.095367] snd_hda_codec_conexant hdaudioC1D0: CX20751/2: BIOS auto-probing.
[ 49.095773] snd_hda_codec_conexant hdaudioC1D0: autoconfig for CX20751/2: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[ 49.095782] snd_hda_codec_conexant hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 49.095787] snd_hda_codec_conexant hdaudioC1D0: hp_outs=1 (0x16/0x0/0x0/0x0/0x0)
[ 49.095791] snd_hda_codec_conexant hdaudioC1D0: mono: mono_out=0x0
[ 49.095794] snd_hda_codec_conexant hdaudioC1D0: inputs:
[ 49.095797] snd_hda_codec_conexant hdaudioC1D0: Internal Mic=0x1a
[ 49.095801] snd_hda_codec_conexant hdaudioC1D0: Mic=0x19
[ 49.099822] input: HD-Audio Generic Mic as /devices/pci0000:00/0000:00:14.2/sound/card1/input21
[ 49.099954] input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:14.2/sound/card1/input22
[ 49.137521] input: Asus WMI hotkeys as /devices/platform/asus-nb-wmi/input/input23
[ 49.215193] SVM: TSC scaling supported
[ 49.215202] kvm: Nested Virtualization enabled
[ 49.215204] SVM: kvm: Nested Paging enabled
[ 49.215212] SVM: LBR virtualization supported
[ 49.218834] Bluetooth: hci0: RTL: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[ 49.219828] Bluetooth: hci0: RTL: rom_version status=0 version=1
[ 49.219837] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_fw.bin
[ 49.221105] usbcore: registered new interface driver btusb
[ 49.275834] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 49.287793] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 49.316612] MCE: In-kernel MCE decoding enabled.
[ 49.386077] mc: Linux media interface: v0.10
[ 49.556041] videodev: Linux video capture interface: v2.00
[ 49.623042] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_config.bin
[ 49.623123] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[ 49.623139] Bluetooth: hci0: RTL: cfg_sz -2, total sz 22496
[ 49.933076] usb 1-1.4: Found UVC 1.00 device USB2.0 VGA UVC WebCam (04f2:b52b)
[ 49.939705] input: USB2.0 VGA UVC WebCam: USB2.0 V as /devices/pci0000:00/0000:00:12.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input24
[ 49.939919] usbcore: registered new interface driver uvcvideo
[ 49.988333] audit: type=1130 audit(1655441949.790:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 50.065711] [drm] amdgpu kernel modesetting enabled.
[ 50.065755] amdgpu: vga_switcheroo: detected switching method \_SB_.PCI0.VGA_.ATPX handle
[ 50.066726] ATPX version 1, functions 0x00000003
[ 50.089698] amdgpu: CRAT table not found
[ 50.089723] amdgpu: Virtual CRAT table created for CPU
[ 50.089744] amdgpu: Topology: Add CPU node
[ 50.089840] checking generic (d0000000 420000) vs hw (d0000000 10000000)
[ 50.089845] checking generic (d0000000 420000) vs hw (d0000000 10000000)
[ 50.089847] fb0: switching to amdgpu from EFI VGA
[ 50.090070] Console: switching to colour dummy device 80x25
[ 50.090155] amdgpu 0000:00:01.0: vgaarb: deactivate vga console
[ 50.090420] [drm] initializing kernel modesetting (MULLINS 0x1002:0x9851 0x1043:0x1B9D 0x45).
[ 50.090429] amdgpu 0000:00:01.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
[ 50.090513] [drm] register mmio base: 0xFEA00000
[ 50.090516] [drm] register mmio size: 262144
[ 50.090638] [drm] add ip block number 0 <cik_common>
[ 50.090642] [drm] add ip block number 1 <gmc_v7_0>
[ 50.090644] [drm] add ip block number 2 <cik_ih>
[ 50.090646] [drm] add ip block number 3 <gfx_v7_0>
[ 50.090648] [drm] add ip block number 4 <cik_sdma>
[ 50.090650] [drm] add ip block number 5 <kv_dpm>
[ 50.090652] [drm] add ip block number 6 <dm>
[ 50.090654] [drm] add ip block number 7 <uvd_v4_2>
[ 50.090656] [drm] add ip block number 8 <vce_v2_0>
[ 50.090661] kfd kfd: amdgpu: MULLINS not supported in kfd
[ 50.124915] [drm] BIOS signature incorrect 0 0
[ 50.124995] amdgpu 0000:00:01.0: amdgpu: Fetched VBIOS from ROM BAR
[ 50.125001] amdgpu: ATOM BIOS: 113-C69300-101
[ 50.125078] [drm] vm size is 64 GB, 2 levels, block size is 10-bit, fragment size is 9-bit
[ 50.125087] amdgpu 0000:00:01.0: amdgpu: VRAM: 1024M 0x000000F400000000 - 0x000000F43FFFFFFF (1024M used)
[ 50.125092] amdgpu 0000:00:01.0: amdgpu: GART: 1024M 0x000000FF00000000 - 0x000000FF3FFFFFFF
[ 50.125101] [drm] Detected VRAM RAM=1024M, BAR=1024M
[ 50.125103] [drm] RAM width 64bits UNKNOWN
[ 50.125206] [drm] amdgpu: 1024M of VRAM memory ready
[ 50.125209] [drm] amdgpu: 3072M of GTT memory ready.
[ 50.125239] [drm] GART: num cpu pages 262144, num gpu pages 262144
[ 50.125275] [drm] PCIE GART of 1024M enabled (table at 0x000000F400401000).
[ 50.279617] [drm] Internal thermal controller without fan control
[ 50.279630] [drm] amdgpu: dpm initialized
[ 50.282879] rtl8723be 0000:02:00.0: enabling device (0000 -> 0003)
[ 50.294821] [drm] Found UVD firmware Version: 1.64 Family ID: 9
[ 50.297364] rtl8723be: Using firmware rtlwifi/rtl8723befw_36.bin
[ 50.307609] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
[ 50.308729] rtlwifi: rtlwifi: wireless switch is on
[ 50.317655] [drm] Found VCE firmware Version: 50.10 Binary ID: 2
[ 50.328871] [drm] Display Core initialized with v3.2.177!
[ 50.329707] rtl8723be 0000:02:00.0 wlp2s0: renamed from wlan0
[ 50.347761] snd_hda_intel 0000:00:01.1: bound 0000:00:01.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
[ 50.424127] Adding 5119996k swap on /dev/sda4. Priority:-2 extents:1 across:5119996k FS
[ 50.444687] Bluetooth: hci0: RTL: fw version 0x0e2f9f73
[ 50.444940] [drm] UVD initialized successfully.
[ 50.555954] [drm] VCE initialized successfully.
[ 50.556681] amdgpu 0000:00:01.0: amdgpu: SE 1, SH per SE 1, CU per SH 2, active_cu_number 2
[ 50.557927] [drm] Initialized amdgpu 3.46.0 20150101 for 0000:00:01.0 on minor 0
[ 50.562287] fbcon: amdgpudrmfb (fb0) is primary device
[ 51.329700] Console: switching to colour frame buffer device 170x48
[ 51.352033] amdgpu 0000:00:01.0: [drm] fb0: amdgpudrmfb frame buffer device
[ 51.364635] amdgpu 0000:01:00.0: enabling device (0000 -> 0003)
[ 51.364866] [drm] initializing kernel modesetting (HAINAN 0x1002:0x6665 0x1043:0x226D 0x83).
[ 51.364879] amdgpu 0000:01:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
[ 51.365023] [drm] register mmio base: 0xFE900000
[ 51.365029] [drm] register mmio size: 262144
[ 51.365218] [drm] add ip block number 0 <si_common>
[ 51.365224] [drm] add ip block number 1 <gmc_v6_0>
[ 51.365227] [drm] add ip block number 2 <si_ih>
[ 51.365230] [drm] add ip block number 3 <gfx_v6_0>
[ 51.365233] [drm] add ip block number 4 <si_dma>
[ 51.365236] [drm] add ip block number 5 <si_dpm>
[ 51.365245] kfd kfd: amdgpu: HAINAN not supported in kfd
[ 51.503405] amdgpu 0000:01:00.0: amdgpu: Fetched VBIOS from ATRM
[ 51.503419] amdgpu: ATOM BIOS: BR45747.001
[ 51.503446] amdgpu 0000:01:00.0: amdgpu: PCIE atomic ops is not supported
[ 51.503453] [drm] GPU posting now...
[ 51.513908] [drm] vm size is 64 GB, 2 levels, block size is 10-bit, fragment size is 9-bit
[ 51.520751] amdgpu 0000:01:00.0: amdgpu: VRAM: 2048M 0x000000F400000000 - 0x000000F47FFFFFFF (2048M used)
[ 51.520765] amdgpu 0000:01:00.0: amdgpu: GART: 256M 0x000000FF00000000 - 0x000000FF0FFFFFFF
[ 51.520787] [drm] Detected VRAM RAM=2048M, BAR=256M
[ 51.520790] [drm] RAM width 64bits DDR3
[ 51.520823] [drm] amdgpu: 2048M of VRAM memory ready
[ 51.520827] [drm] amdgpu: 3072M of GTT memory ready.
[ 51.520872] [drm] GART: num cpu pages 65536, num gpu pages 65536
[ 51.521370] amdgpu 0000:01:00.0: amdgpu: PCIE GART of 256M enabled (table at 0x000000F400000000).
[ 51.830409] [drm] Internal thermal controller without fan control
[ 51.830447] [drm] amdgpu: dpm initialized
[ 52.140243] amdgpu 0000:01:00.0: amdgpu: SE 1, SH per SE 1, CU per SH 5, active_cu_number 5
[ 52.462094] audit: type=1130 audit(1655441952.263:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-1328\x2d15F3 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 52.724694] amdgpu 0000:01:00.0: amdgpu: Using ATPX for runtime pm
[ 52.724928] [drm] Initialized amdgpu 3.46.0 20150101 for 0000:01:00.0 on minor 1
[ 52.945601] audit: type=1130 audit(1655441952.747:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@backlight:acpi_video0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 53.002554] audit: type=1130 audit(1655441952.803:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@backlight:amdgpu_bl0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 55.286563] audit: type=1130 audit(1655441955.087:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 55.292690] audit: type=1130 audit(1655441955.093:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ldconfig comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 55.376622] audit: type=1131 audit(1655441955.180:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 55.614588] audit: type=1130 audit(1655441955.417:11): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 55.698213] audit: type=1127 audit(1655441955.503:12): pid=390 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[ 55.744902] audit: type=1130 audit(1655441955.547:13): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-catalog-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 55.762377] audit: type=1130 audit(1655441955.563:14): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 57.992173] kauditd_printk_skb: 7 callbacks suppressed
[ 57.992184] audit: type=1130 audit(1655441957.793:22): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 57.997174] audit: type=1130 audit(1655441957.797:23): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 57.997550] audit: type=1130 audit(1655441957.800:24): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 57.997893] audit: type=1130 audit(1655441957.800:25): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 58.178677] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 58.178688] Bluetooth: BNEP filters: protocol multicast
[ 58.178697] Bluetooth: BNEP socket layer initialized
[ 58.254216] audit: type=1334 audit(1655441958.057:26): prog-id=16 op=LOAD
[ 58.254441] audit: type=1334 audit(1655441958.057:27): prog-id=17 op=LOAD
[ 58.254505] audit: type=1334 audit(1655441958.057:28): prog-id=18 op=LOAD
[ 58.304059] NET: Registered PF_ALG protocol family
[ 58.424948] audit: type=1130 audit(1655441958.227:29): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 60.995295] audit: type=1130 audit(1655441960.793:30): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 61.046128] audit: type=1130 audit(1655441960.847:31): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 63.002594] kauditd_printk_skb: 1 callbacks suppressed
[ 63.002604] audit: type=1130 audit(1655441962.803:33): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-swap comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 63.177693] audit: type=1130 audit(1655441962.980:34): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 63.240874] Generic FE-GE Realtek PHY r8169-0-300:00: attached PHY driver (mii_bus:phy_addr=r8169-0-300:00, irq=MAC)
[ 63.397550] r8169 0000:03:00.0 enp3s0: Link is Down
[ 63.810543] audit: type=1130 audit(1655441963.610:35): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 64.958970] audit: type=1130 audit(1655441964.760:36): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 65.330737] NET: Registered PF_QIPCRTR protocol family
[ 65.335300] audit: type=1130 audit(1655441965.137:37): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 65.855881] amdgpu 0000:01:00.0: amdgpu: PCIE GART of 256M enabled (table at 0x000000F400000000).
[ 65.894049] r8169 0000:03:00.0 enp3s0: Link is Up - 100Mbps/Full - flow control off
[ 65.894081] IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
[ 73.245770] audit: type=1131 audit(1655441973.047:38): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 73.688798] audit: type=1130 audit(1655441973.490:39): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 78.730149] audit: type=1100 audit(1655441978.533:40): pid=541 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 78.730234] audit: type=1101 audit(1655441978.533:41): pid=541 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 78.754041] audit: type=1103 audit(1655441978.557:42): pid=541 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 78.847534] audit: type=1130 audit(1655441978.650:43): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@966 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 78.945034] audit: type=1101 audit(1655441978.747:44): pid=543 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 78.945130] audit: type=1103 audit(1655441978.747:45): pid=543 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 78.945254] audit: type=1006 audit(1655441978.747:46): pid=543 uid=0 old-auid=4294967295 auid=966 tty=(none) old-ses=4294967295 ses=1 res=1
[ 78.945270] audit: type=1300 audit(1655441978.747:46): arch=c000003e syscall=1 success=yes exit=3 a0=9 a1=7fff67449180 a2=3 a3=7fff67448e95 items=0 ppid=1 pid=543 auid=966 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd" key=(null)
[ 78.945279] audit: type=1327 audit(1655441978.747:46): proctitle="(systemd)"
[ 78.999701] audit: type=1105 audit(1655441978.803:47): pid=543 uid=0 auid=966 ses=1 msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 90.716866] kauditd_printk_skb: 3 callbacks suppressed
[ 90.716876] audit: type=1130 audit(1655441990.517:51): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 90.827019] audit: type=1334 audit(1655441990.627:52): prog-id=19 op=LOAD
[ 90.827124] audit: type=1334 audit(1655441990.627:53): prog-id=20 op=LOAD
[ 91.254389] audit: type=1131 audit(1655441991.057:54): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 91.349772] audit: type=1130 audit(1655441991.150:55): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 91.350724] audit: type=1334 audit(1655441991.153:56): prog-id=0 op=UNLOAD
[ 91.350733] audit: type=1334 audit(1655441991.153:57): prog-id=0 op=UNLOAD
[ 91.350739] audit: type=1334 audit(1655441991.153:58): prog-id=0 op=UNLOAD
[ 107.375182] audit: type=1100 audit(1655442007.177:59): pid=590 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="simon" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 107.375774] audit: type=1101 audit(1655442007.177:60): pid=590 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="simon" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 107.376546] audit: type=1103 audit(1655442007.177:61): pid=590 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="simon" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 107.376735] audit: type=1006 audit(1655442007.177:62): pid=590 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ 107.376778] audit: type=1300 audit(1655442007.177:62): arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7ffe92405580 a2=4 a3=7ffe92405294 items=0 ppid=444 pid=590 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" key=(null)
[ 107.376788] audit: type=1327 audit(1655442007.177:62): proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746835616438626538372D366332372D343939662D386630352D396431366431633465363165002D2D69640031002D2D7374617274002F7573722F62696E2F7374617274706C61736D612D783131002D2D
[ 107.411850] audit: type=1130 audit(1655442007.213:63): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 107.423740] audit: type=1101 audit(1655442007.223:64): pid=592 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="simon" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 107.423828] audit: type=1103 audit(1655442007.223:65): pid=592 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="simon" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 107.423922] audit: type=1006 audit(1655442007.223:66): pid=592 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[ 108.143104] systemd-journald[238]: File /var/log/journal/0484a992e03a41888032c25fc0707575/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[ 118.897628] kauditd_printk_skb: 7 callbacks suppressed
[ 118.897636] audit: type=1131 audit(1655442018.700:72): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@966 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 118.914859] audit: type=1131 audit(1655442018.717:73): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@966 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 126.788668] audit: type=1130 audit(1655442026.590:74): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 129.912923] Bluetooth: RFCOMM TTY layer initialized
[ 129.912943] Bluetooth: RFCOMM socket layer initialized
[ 129.912950] Bluetooth: RFCOMM ver 1.11
[ 139.741091] amdgpu 0000:01:00.0: amdgpu: PCIE GART of 256M enabled (table at 0x000000F400000000).
[ 140.709655] audit: type=1111 audit(1655442040.510:75): pid=409 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics interface="enp3s0" ifindex=2 args=500 pid=848 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 140.735359] audit: type=1111 audit(1655442040.537:76): pid=409 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics interface="wlp2s0" ifindex=3 args=500 pid=848 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 140.742354] audit: type=1334 audit(1655442040.543:77): prog-id=21 op=LOAD
[ 140.742574] audit: type=1334 audit(1655442040.543:78): prog-id=22 op=LOAD
[ 140.742631] audit: type=1334 audit(1655442040.543:79): prog-id=23 op=LOAD
[ 140.845051] audit: type=1130 audit(1655442040.647:80): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 140.910754] audit: type=1111 audit(1655442040.713:81): pid=409 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics interface="wlp2s0" ifindex=3 args=500 pid=848 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 170.885002] audit: type=1131 audit(1655442070.687:82): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 170.977614] audit: type=1334 audit(1655442070.783:83): prog-id=0 op=UNLOAD
[ 170.977628] audit: type=1334 audit(1655442070.783:84): prog-id=0 op=UNLOAD
[ 170.977634] audit: type=1334 audit(1655442070.783:85): prog-id=0 op=UNLOAD
[ 227.997281] audit: type=1100 audit(1655442127.797:86): pid=1161 uid=1000 auid=1000 ses=3 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="simon" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 227.997582] audit: type=1101 audit(1655442127.800:87): pid=1161 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="simon" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 227.998884] audit: type=1110 audit(1655442127.800:88): pid=1161 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 228.001543] audit: type=1105 audit(1655442127.803:89): pid=1161 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 232.456002] audit: type=1106 audit(1655442132.257:90): pid=1161 uid=1000 auid=1000 ses=3 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 232.456021] audit: type=1104 audit(1655442132.257:91): pid=1161 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 688.917545] amdgpu 0000:01:00.0: amdgpu: PCIE GART of 256M enabled (table at 0x000000F400000000).
[ 732.828028] amdgpu 0000:01:00.0: amdgpu: PCIE GART of 256M enabled (table at 0x000000F400000000).
[ 862.804524] audit: type=1100 audit(1655442762.607:92): pid=2429 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="simon" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 862.805090] audit: type=1101 audit(1655442762.607:93): pid=2429 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="simon" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 862.807331] audit: type=1110 audit(1655442762.610:94): pid=2429 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 862.811747] audit: type=1105 audit(1655442762.613:95): pid=2429 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
journalctl --boot=0 --priority=3 --no-pager
июн 17 11:59:15 simon-x555yi kernel: ACPI BIOS Error (bug): Could not resolve symbol [^^^PB2.VGA.AFN7], AE_NOT_FOUND (20211217/psargs-330)
июн 17 11:59:15 simon-x555yi kernel: ACPI Error: Aborting method \_SB.PCI0.VGA.LCDD._BCM due to previous error (AE_NOT_FOUND) (20211217/psparse-529)
июн 17 11:59:15 simon-x555yi kernel: kfd kfd: amdgpu: MULLINS not supported in kfd
июн 17 11:59:15 simon-x555yi kernel: kfd kfd: amdgpu: HAINAN not supported in kfd
июн 17 11:59:39 simon-x555yi systemd[543]: Failed to start Update XDG user dir configuration.
