NetworkManager failing to connect after seeing printer setup network
Hello,
I keep having this issue with NetworkManager on Manjaro KDE. I have a HP Deskjet printer, which upon restart opens a setup WiFi Network, whose name is something like: “setup=xx> DeskJet 2700 Series”.
I discovered this problem when I had to do some configuration on the printer, normally that network is not on and the printer is connected to my home network.
The issue is that after discovering the setup network, NetworkManager is not capable to connect to my home network until I restart the NetworkManager service through systemctl.
This is my system info:
  Kernel: 5.10.59-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=00a9e317-ba7b-47ba-b833-d95a652fc1ac rw quiet
  cryptdevice=UUID=afd10076-88aa-49ad-9a95-fe0b596324b8:luks-afd10076-88aa-49ad-9a95-fe0b596324b8
  root=/dev/mapper/luks-afd10076-88aa-49ad-9a95-fe0b596324b8 apparmor=1
  security=apparmor
  resume=/dev/mapper/luks-84eeaf18-1a2f-4578-93e8-bb21c6a37787
  udev.log_priority=3
  Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: LENOVO product: 81F5 v: Lenovo ideapad 330S-15IKB
  serial: <filter> Chassis: type: 10 v: Lenovo ideapad 330S-15IKB
  serial: <filter>
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <filter>
  UEFI: LENOVO v: 7SCN36WW date: 10/09/2019
  ID-1: BAT0 charge: 15.8 Wh (56.6%) condition: 27.9/30.0 Wh (92.9%)
  volts: 8.0 min: 7.4 model: LENOVO BASE-BAT type: Li-poly serial: <filter>
  status: Charging
  RAM: total: 7.68 GiB used: 3.42 GiB (44.5%)
  Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
  arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
  microcode: EA cache: L2: 8 MiB bogomips: 32012
  Speed: 600 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 600 2: 600 3: 600
  4: 600 5: 600 6: 600 7: 600 8: 600
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
  avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
  mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
  rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
  xsaves xtopology xtpr
  Type: l1tf
  Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
  bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
  Device-2: Syntek Integrated Camera type: USB driver: uvcvideo bus-ID: 1-7:3
  chip-ID: 174f:2426 class-ID: 0e02 serial: <filter>
  loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
  screens: 1
  Screen-1: 0 s-res: 1280x720 s-dpi: 96 s-size: 338x190mm (13.3x7.5")
  s-diag: 388mm (15.3")
  Monitor-1: eDP1 res: 1280x720 dpi: 96 size: 340x190mm (13.4x7.5")
  diag: 389mm (15.3")
  OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.6
  direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
  chip-ID: 8086:9d71 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.59-1-MANJARO running: yes
  Sound Server-3: JACK v: 1.9.19 running: no
  Sound Server-4: PulseAudio v: 15.0 running: yes
  Sound Server-5: PipeWire v: 0.3.33 running: yes
  Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
  vendor: Lenovo driver: ath10k_pci v: kernel port: 3040 bus-ID: 01:00.0
  chip-ID: 168c:0042 class-ID: 0280
  Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-4:2
  chip-ID: 0cf3:e500 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 7 state: up address: see --recommends
  Device-1: luks-afd10076-88aa-49ad-9a95-fe0b596324b8 maj-min: 254:0
  type: LUKS dm: dm-0 size: 922.41 GiB
  Components:
  p-1: sda2 maj-min: 8:2 size: 922.42 GiB
  Device-2: luks-84eeaf18-1a2f-4578-93e8-bb21c6a37787 maj-min: 254:1
  type: LUKS dm: dm-1 size: 8.8 GiB
  Components:
  p-1: sda3 maj-min: 8:3 size: 8.8 GiB
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
  v: 3.0 port: 3060 bus-ID: 00:17.0 chip-ID: 8086.282a rev: 21 class-ID: 0104
  Local Storage: total: 931.51 GiB used: 100.71 GiB (10.8%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
  type: SSD serial: <filter> rev: 1B6Q scheme: GPT
  ID-1: / raw-size: 922.41 GiB size: 906.86 GiB (98.31%)
  used: 100.71 GiB (11.1%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
  mapped: luks-afd10076-88aa-49ad-9a95-fe0b596324b8 label: N/A
  uuid: 00a9e317-ba7b-47ba-b833-d95a652fc1ac
  used: 440 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
  uuid: 8947-776F
  dev: /dev/dm-1 maj-min: 254:1
  mapped: luks-84eeaf18-1a2f-4578-93e8-bb21c6a37787 label: N/A
  uuid: c03cf2b0-c90b-4974-8e99-e68670da6f0b
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
  Device-1: 1-1:5 info: Logitech M105 Optical Mouse type: Mouse
  driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
  power: 100mA chip-ID: 046d:c077 class-ID: 0301
  Device-2: 1-4:2 info: Qualcomm Atheros type: Bluetooth driver: btusb
  interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e500
  class-ID: e001
  Device-3: 1-7:3 info: Syntek Integrated Camera type: Video driver: uvcvideo
  interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 174f:2426
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 39.0 C mobo: 0.0 C
  Processes: 280 Uptime: 7h 28m wakeups: 6 Init: systemd v: 248
  tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1487 lib: 365
  flatpak: 0 Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.06
Here are the dmesg logs I get when the laptop tries to connect to the network:
[  +4,902077] wlp1s0: authenticate with d8:b6:b7:01:11:ef
[  +0,037410] wlp1s0: send auth to d8:b6:b7:01:11:ef (try 1/3)
[  +0,001937] wlp1s0: authenticated
[  +0,002593] wlp1s0: associate with d8:b6:b7:01:11:ef (try 1/3)
[  +0,003708] wlp1s0: RX AssocResp from d8:b6:b7:01:11:ef (capab=0x411 status=0 aid=2)
[  +0,002844] wlp1s0: associated
[  +7,920592] wlp1s0: deauthenticated from d8:b6:b7:01:11:ef (Reason: 15=4WAY_HANDSHAKE_TIMEOUT)
[ +14,845599] wlp1s0: authenticate with d8:b6:b7:01:11:ef
[  +0,036917] wlp1s0: send auth to d8:b6:b7:01:11:ef (try 1/3)
[  +0,001898] wlp1s0: authenticated
[  +0,006012] wlp1s0: associate with d8:b6:b7:01:11:ef (try 1/3)
[  +0,003809] wlp1s0: RX AssocResp from d8:b6:b7:01:11:ef (capab=0x411 status=0 aid=2)
[  +0,003535] wlp1s0: associated
[  +7,922231] wlp1s0: deauthenticated from d8:b6:b7:01:11:ef (Reason: 15=4WAY_HANDSHAKE_TIMEOUT)
[ago25 17:20] wlp1s0: authenticate with d8:b6:b7:01:11:ef
[  +0,037186] wlp1s0: send auth to d8:b6:b7:01:11:ef (try 1/3)
[  +0,002028] wlp1s0: authenticated
[  +0,002318] wlp1s0: associate with d8:b6:b7:01:11:ef (try 1/3)
[  +0,003724] wlp1s0: RX AssocResp from d8:b6:b7:01:11:ef (capab=0x411 status=0 aid=2)
[  +0,003313] wlp1s0: associated
[  +7,922960] wlp1s0: deauthenticated from d8:b6:b7:01:11:ef (Reason: 15=4WAY_HANDSHAKE_TIMEOUT)
[ +14,856139] wlp1s0: authenticate with d8:b6:b7:01:11:ef
[  +0,037430] wlp1s0: send auth to d8:b6:b7:01:11:ef (try 1/3)
[  +0,001987] wlp1s0: authenticated
[  +0,002045] wlp1s0: associate with d8:b6:b7:01:11:ef (try 1/3)
[  +0,003955] wlp1s0: RX AssocResp from d8:b6:b7:01:11:ef (capab=0x411 status=0 aid=2)
[  +0,003053] wlp1s0: associated
[  +1,654437] wlp1s0: deauthenticating from d8:b6:b7:01:11:ef by local choice (Reason: 3=DEAUTH_LEAVING)
Has anyone experienced this? I’m pretty confident it has something to do with my printer since I reproduced the same situation some times with the same result.
Thanks in advance
I had the same in the past too and the problem went away once the HP printer was configured correctly and was not broadcasting its setup network any more but connected to the home WiFi network on a reserved IP address.
This only happened when I was closer to the printer than to the router while the printer network was not fully configured yet and the network was saved into my network list. Deleting the printer WiFi from my laptop’s network list made the problem go away too.
Nowadays it has an Ethernet cable and its WiFi is turned off because it’s too far away from the router so the speed got too low so I can’t help you more than share the above experience…
:crossed_fingers:
Interesting. In my case I didn’t had the setup network saved, and I was much closer to the router than to the printer. The only explanation I can think off is that maybe both networks were using the same frequency bands and somehow that caused the authentication to fail, but I tried the same with my phone and a windows laptop and they had no problem.
Should I maybe report this to NetworkManager? If this happens with the printer maybe the same problem can appear with other device networks.
So did you either:
  • finish setting up the WiFi network of the printer so it’s a client instead of a server?
    XOR
  • turn its WiFi off if you connect to it through USB/Ethernet cable to print?
:thinking:
Oh yes sorry. I did the first. When it is connected to the home network it also provides another wifi network itself called “DIRECT-XX-HP Deskjet 2700 Series” for configuration purposes, but that one gives me zero problems. That’s why I first thought maybe it had something to do with the name of the network, which contained ‘=’ and ‘>’, but that seems dumb.
