I’ve noticed some weird since the last update. NetworkManager is reporting a constant switch in policy between the WIFI and Wired connections:
Jul 27 19:36:23 pavla NetworkManager[815]: <info> [1627407383.9187] policy: set 'Wired connection 1' (enp59s0u1) as default for IPv6 routing and DNS
Jul 27 19:36:24 pavla NetworkManager[815]: <info> [1627407384.7372] policy: set 'wifi-redacted' (wlp2s0) as default for IPv6 routing and DNS
Jul 27 19:36:24 pavla NetworkManager[815]: <info> [1627407384.7377] policy: set 'Wired connection 1' (enp59s0u1) as default for IPv6 routing and DNS
Jul 27 19:36:26 pavla NetworkManager[815]: <info> [1627407386.9899] policy: set 'wifi-redacted' (wlp2s0) as default for IPv6 routing and DNS
Jul 27 19:36:26 pavla NetworkManager[815]: <info> [1627407386.9905] policy: set 'Wired connection 1' (enp59s0u1) as default for IPv6 routing and DNS
Jul 27 19:36:27 pavla NetworkManager[815]: <info> [1627407387.8093] policy: set 'wifi-redacted' (wlp2s0) as default for IPv6 routing and DNS
Jul 27 19:36:27 pavla NetworkManager[815]: <info> [1627407387.8100] policy: set 'Wired connection 1' (enp59s0u1) as default for IPv6 routing and DNS
Jul 27 19:36:29 pavla NetworkManager[815]: <info> [1627407389.8571] policy: set 'wifi-redacted' (wlp2s0) as default for IPv6 routing and DNS
Jul 27 19:36:29 pavla NetworkManager[815]: <info> [1627407389.8575] policy: set 'Wired connection 1' (enp59s0u1) as default for IPv6 routing and DNS
I always have my laptop’s wifi turned on, because I move between places very often. At home, I connect using an Ethernet cable to my router (via USB-C adapter).
Since the update when I connect the cable (after being connected via wifi) NetworkManager
starts that continuous switch. Even after turning the wifi off, it keeps telling:
Jul 27 19:38:26 pavla NetworkManager[815]: <info> [1627407506.8570] policy: set 'Wired connection 1' (enp59s0u1) as default for IPv6 routing and DNS
Jul 27 19:38:27 pavla NetworkManager[815]: <info> [1627407507.7893] policy: set 'Wired connection 1' (enp59s0u1) as default for IPv6 routing and DNS
Jul 27 19:38:29 pavla NetworkManager[815]: <info> [1627407509.8592] policy: set 'Wired connection 1' (enp59s0u1) as default for IPv6 routing and DNS
Jul 27 19:38:30 pavla NetworkManager[815]: <info> [1627407510.7886] policy: set 'Wired connection 1' (enp59s0u1) as default for IPv6 routing and DNS
I need to unplug my laptop from the Ethernet cable and plug it back, for it to stop doing that.
Is this normal/expected or a bug?
