Just installed latest Manjaro via a USB stick on a brand new machine. All went smoothly with possible partitioning setup which I have not yet addressed. This is my third installation of Manjaro on various machines and I’ve been running it as my main desktop for a couple of years or so.
I spent some time setting up the desktop etc, connected via Remmina to a newly installed vino, and proceded to install and remove various apps. I always remove bluetooth, hexchat and pidgin. I’ve never had a need for them. This time I also removed bluez. After a while I rebooted the machine.
All seemed well until I tried to connect with Remmina, when it became obvious there was no connection to the new machine. There was no interface at all, not even a dhcp one. Just a blank panel through which I tried to add a new connection; and failed.
I’m guesing that the removal of bluez may be the cause, although for every warning it gave only “optional”.
a) Is this a reasonable diagnosis; b) if so, how can I get it back without an internet connection; c) if so, could bluez come with a better warning.
I don’t say that this was the wrong way. Personally, I remove packages only using pacman, i.e.
sudo pacman -R {package}
or
sudo pacman -Rs {package}
to remove dependent and orphaned packages.
pamac works a bit different and you could end up easily in a recursive removal of packages that depend on the package which you want to remove, depending on your settings. Always check the list of packages to be removed before execution.
There were about half a dozen notifications all saying bluez was OPTIONALLY used by this/that. What I want to know is: is bluez NECESSARY for the internet connection and/or could it be the reason for the connection going missing.
And if so, what do I need to copy from the installation usb to make it right; or should I just cut my losses and reinstall from scratch?
It seems two network interfaces are detected, although both are down. Which one is that did work during installation but it doesn’t work now: the wired or the wireless one?
The day after the last reply here I reinstalled Manjaro on the new machine. Again I removed hexchat, pidgin and bluetooth but this time I left bluez installed. So far all is well.
I have long believed that bluetooth should be completely seperated from all other libs and, for preference, not installed in the first place. For those who do use bluetooth (about 40% internationally but what percentage of Manjaro?), a simple question during installation should suffice. Just a thought.
