here is the output
cat /etc/modprobe.d/*
zsh: no matches found: /etc/modprobe.d/*
here is the output
Looks promising. Just to make sure I’ve got it right, not you - me, please provide the output of:
ls /etc/modprobe.d/
nothing inside this folder. no stdout
Then I think rebooting is safe.
I know nothing about the card or the driver this post is about, but I remember you mentioned another mode, that the adapter is dual mode, or something. So if it still doesn’t work as expected after restarting, try the other mode. (Whatever that means.)
restarted still not working
Looks like the device has 2 modes.
megavolt said this dont know what he means by that
may i know how it is supposed to work if we remove the driver?
You didn’t remove the driver, I think. Well, in theory anyway. What I targeted there was an extra driver. I don’t know how to explain it.
Why I did that was because on the page I linked to above, it is noted that the driver is included in kernel version 5.15
. So by resetting everything to default, that one should have been in use, but it doesn’t look as if it is. To make sure, please provide the output of:
Here is the output
Kernel: 5.15.78-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=63feba22-4d83-490f-82a2-b00f60b30a40 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 wm: kwin_x11 dm: SDDM
Type: Desktop Mobo: N/A model: N/A serial: N/A BIOS: American Megatrends
v: 080015 date: 03/31/2017
RAM: total: 3.8 GiB used: 1.75 GiB (46.0%)
Array-1: capacity: 16 GiB note: est. slots: 4 EC: None
max-module-size: 4 GiB
Device-1: DIMM0 type: no module installed
Device-2: DIMM1 type: no module installed
Device-3: DIMM2 info: double-bank type: DDR2 detail: synchronous
size: 4 GiB speed: N/A volts: N/A width (bits): data: 64 total: 64
manufacturer: Samsung part-no: M378B5273CH0-CK0 serial: <filter>
Device-4: DIMM3 type: no module installed
Info: model: Intel Core2 Duo E7500 socket: 478 bits: 64 type: MCP
arch: Penryn level: v1 built: 2008 process: Intel 45nm family: 6
model-id: 0x17 (23) stepping: 0xA (10) microcode: 0xA0B
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2895 high: 2925 min/max: N/A base/boost: 2933/2933
volts: 1.3 V ext-clock: 267 MHz cores: 1: 2925 2: 2866 bogomips: 11704
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc
cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts est flexpriority fpu fxsr ht
lahf_lm lm mca mce mmx monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge
pni pse pse36 pti rep_good sep sse sse2 sse4_1 ssse3 syscall tm tm2
tpr_shadow tsc vme vmx vnmi vpid xsave xtpr
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT disabled
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel Mobile 4 Series Integrated Graphics driver: i915 v: kernel
arch: Gen-5 process: Intel 45nm built: 2008 ports: active: VGA-1
empty: SVIDEO-1 bus-ID: 00:02.0 chip-ID: 8086:2a42 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
s-diag: 485mm (19.11")
Monitor-1: VGA-1 model: LG (GoldStar) HD PLUS serial: <filter> built: 2015
res: 1600x900 hz: 60 dpi: 92 gamma: 1.2 size: 440x250mm (17.32x9.84")
diag: 506mm (19.9") ratio: 16:9 modes: max: 1600x900 min: 720x400
API: OpenGL v: 2.1 Mesa 22.2.3 renderer: Mesa Mobile Intel GM45 Express
(CTG) direct render: Yes
Device-1: Intel NM10/ICH7 Family High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:27d8 class-ID: 0403
Sound API: ALSA v: k5.15.78-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: no
Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e800 bus-ID: 02:00.0
chip-ID: 10ec:8136 class-ID: 0200
IF: ens33 state: down mac: <filter>
Device-2: Realtek RTL8188FTV 802.11b/g/n 1T1R 2.4G WLAN Adapter type: USB
driver: N/A bus-ID: 1-3:4 chip-ID: 0bda:f179 class-ID: 0000 serial: <filter>
IF-ID-1: enp0s29f7u6 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: OPPO SDM778G-IDP _SN:8F7AD3F2 type: USB driver: rndis_host
v: kernel bus-ID: 1-6:7 chip-ID: 22d9:276a class-ID: 0a00 serial: <filter>
Local Storage: total: 465.76 GiB used: 129.43 GiB (27.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD5000AAKX-08U6AA0 family: Blue size: 465.76 GiB block-size:
physical: 512 B logical: 512 B sata: 3.0 speed: <unknown> type: HDD
rpm: 7200 serial: <filter> rev: 1H19 temp: 32 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 3y 355d 3h cycles: 4706
ID-1: / raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
used: 129.43 GiB (28.3%) fs: ext4 block-size: 4096 B dev: /dev/sda1
maj-min: 8:1 label: N/A uuid: 63feba22-4d83-490f-82a2-b00f60b30a40
Hub-1: 1-0:1 info: Full speed or root hub ports: 8 rev: 2.0 speed: 480 Mb/s
Device-1: 1-3:4 info: Realtek RTL8188FTV 802.11b/g/n 1T1R 2.4G WLAN Adapter
type: WiFi driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-2: 1-6:7 info: OPPO SDM778G-IDP _SN:8F7AD3F2
type: Bluetooth,CDC-Data driver: rndis_host interfaces: 2 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 22d9:276a class-ID: 0a00
serial: <filter>
Hub-2: 2-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Device-1: 2-1:4 info: China Resource Semico USB Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 100mA chip-ID: 1a2c:6004 class-ID: 0301
Device-2: 2-2:3 info: Dell MS116 Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 413c:301a class-ID: 0301
Hub-3: 3-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-4: 4-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-5: 5-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
System Temperatures: cpu: 30.0 C mobo: N/A
Processes: 144 Uptime: 21m wakeups: 0 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 1173 libs: 355 tools: pamac Shell: Zsh (sudo) v: 5.9 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.23
Well driver is not loaded anyway… no idea why it is not loaded in 5.15
However… try again the driver but with headers…
pamac install linux515-headers linux510-headers
Keep sure you have installed headers for every kernel version you have installed.
pamac build 8188eu-dkms-git
It should now compile the driver against every kernel.
Now check what modules (drivers) has been loaded:
lsmod
You said:
But was there any output? Normally you get the path printed where the driver is located. If not then the driver is already loaded.
If you installed the dkms then the module is called 8188eu
, so:
sudo modprobe -v 8188eu
I don’t know if it has anything to do with the dual mode or not, but this device:
seems to be the troubling one. And it doesn’t look like the drivers we’ve been trying to use the whole time. So we have to install it. First make sure the headers for your kernel(S) are installed:
pamac install $(pamac list --installed --quiet | grep "^linux" | grep "^linux[0-9]*[-rt]*$" | awk '{print $1"-headers"}' ORS=' ')
I think you’ve done this one before.
Then install the driver for it, from the AUR:
pamac build 8188fu-supremegamers-dkms-git
Followed by a reboot and seeing if it works.
I might be dumb here, but
isn’t the same as
And neither was I unable to find anywhere that states the driver is the same. So, my advice is to use the correct one, and not 8188eu
since that’s obviously not working.
Hi megavolt
this is path for modprobe
~ sudo modprobe -v 8188eu ✔
insmod /lib/modules/5.15.78-1-MANJARO/kernel/net/wireless/cfg80211.ko.xz
insmod /lib/modules/5.15.78-1-MANJARO/updates/dkms/8188eu.ko.xz
and this is output for lsmod
lsmod ✔ 3m 13s
Module Size Used by
snd_usb_audio 389120 0
snd_usbmidi_lib 45056 1 snd_usb_audio
snd_rawmidi 53248 1 snd_usbmidi_lib
snd_seq_device 16384 1 snd_rawmidi
mc 73728 1 snd_usb_audio
qrtr 24576 4
ns 36864 1 qrtr
rfkill 32768 3
snd_hda_codec_realtek 167936 1
snd_hda_codec_generic 98304 1 snd_hda_codec_realtek
ledtrig_audio 16384 1 snd_hda_codec_generic
snd_hda_intel 61440 3
snd_intel_dspcfg 32768 1 snd_hda_intel
rndis_host 24576 0
snd_intel_sdw_acpi 20480 1 snd_intel_dspcfg
mousedev 24576 0
snd_hda_codec 184320 3 snd_hda_codec_generic,snd_hda_intel,snd_hda_codec_realtek
iTCO_wdt 16384 0
cdc_ether 24576 1 rndis_host
usbnet 61440 2 rndis_host,cdc_ether
i915 3276800 87
mii 16384 1 usbnet
coretemp 20480 0
intel_pmc_bxt 16384 1 iTCO_wdt
snd_hda_core 118784 4 snd_hda_codec_generic,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
joydev 28672 0
at24 28672 0
snd_hwdep 20480 2 snd_usb_audio,snd_hda_codec
iTCO_vendor_support 16384 1 iTCO_wdt
kvm_intel 364544 0
gpio_ich 16384 0
snd_pcm 163840 4 snd_hda_intel,snd_usb_audio,snd_hda_codec,snd_hda_core
r8169 110592 0
lpc_ich 28672 0
snd_timer 49152 1 snd_pcm
snd 126976 17 snd_hda_codec_generic,snd_seq_device,snd_hwdep,snd_hda_intel,snd_usb_audio,snd_usbmidi_lib,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_pcm,snd_rawmidi
ppdev 24576 0
kvm 1110016 1 kvm_intel
realtek 36864 1
mdio_devres 16384 1 r8169
pcspkr 16384 0
rng_core 16384 0
irqbypass 16384 1 kvm
video 65536 1 i915
i2c_i801 45056 0
libphy 163840 3 r8169,mdio_devres,realtek
soundcore 16384 1 snd
ttm 86016 1 i915
intel_agp 24576 0
intel_gtt 28672 2 intel_agp,i915
i2c_smbus 20480 1 i2c_i801
parport_pc 69632 0
mac_hid 16384 0
parport 81920 2 parport_pc,ppdev
squashfs 77824 2
loop 40960 4
crypto_user 24576 0
fuse 176128 1
ip_tables 36864 0
x_tables 57344 1 ip_tables
ext4 1015808 1
crc32c_generic 16384 2
crc16 16384 1 ext4
mbcache 16384 1 ext4
jbd2 192512 1 ext4
ata_generic 16384 0
pata_acpi 16384 0
usbhid 77824 0
ata_piix 40960 1
and again
output was
Install DKMS modules [2/3]
==> dkms install --no-depmod 8188eu/5.2.2.4.r821.f4af533 -k 5.15.78-1-MANJARO
/usr/lib/modules/5.15.78-1-MANJARO/build/scripts/sign-file: error while loading shared libraries: libcrypto.so.1.1: cannot open shared object file: No such file or directory
==> dkms install --no-depmod 8188eu/5.2.2.4.r821.f4af533 -k 5.15.76-2-rt53-MANJARO
Error! Bad return status for module build on kernel: 5.15.76-2-rt53-MANJARO (x86_64)
Consult /var/lib/dkms/8188eu/5.2.2.4.r821.f4af533/build/make.log for more information.
==> WARNING: `dkms install --no-depmod 8188eu/5.2.2.4.r821.f4af533 -k 5.15.76-2-rt53-MANJARO' exited 10
==> depmod 5.15.78-1-MANJARO
==> ERROR: Missing 5.10.154-1-MANJARO kernel modules tree for module 8188eu/5.2.2.4.r821.f4af533.
Refreshing PackageKit... [3/3]
Something’s wonky here. Please provide the output of:
and
ls /boot
and
pamac list --installed | grep --ignore-case 'headers'
these are the outputs which you required.
pamac list --installed --quiet | grep "^linux" | grep "^linux[0-9]*[-rt]*$" ✔ 3m 48s
linux515
linux515-rt
ls /boot ✔ 4s
grub initramfs-5.15-rt-x86_64.img initramfs-5.15-x86_64.img linux-515-rt-x86_64.kver memtest86+ vmlinuz-5.15-x86_64
initramfs-5.15-rt-x86_64-fallback.img initramfs-5.15-x86_64-fallback.img intel-ucode.img linux515-x86_64.kver vmlinuz-5.15-rt-x86_64
pamac list --installed | grep --ignore-case 'headers' INT ✘
linux-api-headers 5.18.15-1 core 5.4 MB
linux510-headers 5.10.154-1 core 132.5 MB
linux515-headers 5.15.78-1 core 143.2 MB
linux515-rt-headers 5.15.76_rt53-2 community 135.9 MB
vulkan-headers 1:1.3.227-1 extra 18.6 MB
This
…might be the cause of this. Since you don’t have kernel version 5.10
installed. So let’s remove it, first:
pamac remove linux510-headers
Followed by trying to install the driver again:
pamac remove linux510-headers ✔ 4s
Preparing...
Checking dependencies...
Warning: dkms optionally requires linux-headers: build modules against the Arch kernel
To remove (1):
Total removed size: 132.5 MB
Apply transaction ? [y/N] y
Running pre-transaction hooks...
Remove DKMS modules [1/1]
Removing linux510-headers (5.10.154-1)... [1/1]
Arming ConditionNeedsUpdate... [1/3]
Updating module dependencies... [2/3]
pamac build 8188fu-supremegamers-dkms-git ✔ 13s
Preparing...
Cloning 8188fu-supremegamers-dkms-git build files...
Generating 8188fu-supremegamers-dkms-git information...
Checking 8188fu-supremegamers-dkms-git dependencies...
Warning: 8188fu-supremegamers-dkms-git-r126.f56edce-1 is up to date -- reinstalling
Resolving dependencies...
Checking inter-conflicts...
To build (1):
8188fu-supremegamers-dkms-git r126.f56edce-1 AUR
Edit build files : [e]
Apply transaction ? [e/y/N] y
Building 8188fu-supremegamers-dkms-git...
==> Making package: 8188fu-supremegamers-dkms-git r126.f56edce-1 (Wed 30 Nov 2022 09:17:00 PM IST)
==> Retrieving sources...
-> Updating 8188fu git repo...
-> Found blacklist-r8188fu.conf
-> Found dkms.conf
8188fu ... Skipped
blacklist-r8188fu.conf ... Passed
dkms.conf ... Passed
==> Extracting sources...
-> Creating working copy of 8188fu git repo...
Cloning into '8188fu'...
done.
==> Starting prepare()...
==> Starting pkgver()...
==> Entering fakeroot environment...
==> Starting package()...
==> Tidying install...
-> Removing libtool files...
-> Purging unwanted files...
-> Removing static library files...
-> Stripping unneeded symbols from binaries and libraries...
-> Compressing man and info pages...
==> Checking for packaging issues...
==> Creating package "8188fu-supremegamers-dkms-git"...
-> Generating .PKGINFO file...
-> Generating .BUILDINFO file...
-> Adding install file...
-> Generating .MTREE file...
-> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: 8188fu-supremegamers-dkms-git r126.f56edce-1 (Wed 30 Nov 2022 09:17:23 PM IST)
==> Cleaning up...
Checking keyring... [1/1]
Checking integrity... [1/1]
Loading packages files... [1/1]
Checking file conflicts... [1/1]
Checking available disk space... [1/1]
Creating Timeshift snapshot before upgrade... [1/2]
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
Remove upgraded DKMS modules [2/2]
==> dkms remove 8188fu/r126.f56edce
Error! The module/version combo: 8188fu-r126.f56edce is not located in the DKMS tree.
Error while configuring 8188fu-supremegamers-dkms-git
Error: 8188fu-supremegamers-dkms-git: command failed to execute correctly
Configuring 8188fu-supremegamers-dkms-git... [1/1]
Sign command: /usr/lib/modules/5.15.78-1-MANJARO/build/scripts/sign-file
Signing key: /var/lib/dkms/mok.key
Public certificate (MOK): /var/lib/dkms/mok.pub
Creating symlink /var/lib/dkms/8188fu/r126.f56edce/source -> /usr/src/8188fu-r126.f56edce
Building module:
Cleaning build area...
'make' all KVER=5.15.78-1-MANJARO.......................(bad exit status: 2)
Error! Bad return status for module build on kernel: 5.15.78-1-MANJARO (x86_64)
Consult /var/lib/dkms/8188fu/r126.f56edce/build/make.log for more information.
==> dkms install --no-depmod 8188fu/r126.f56edce -k 5.15.78-1-MANJARO
==> WARNING: `dkms install --no-depmod 8188fu/r126.f56edce -k 5.15.78-1-MANJARO' exited 10
==> dkms install --no-depmod 8188fu/r126.f56edce -k 5.15.76-2-rt53-MANJARO
==> WARNING: `dkms install --no-depmod 8188fu/r126.f56edce -k 5.15.76-2-rt53-MANJARO' exited 10
these are outputs
And, is it working? If you haven’t rebooted yet, please do so and, after boot, please provide
…again.
I have to go now, but if you still have issues, someone else will be able to help, as well.
here is the output after i restarted
udev.log_priority=3
RAM: total: 3.8 GiB used: 1.48 GiB (38.9%)
Speed (MHz): avg: 2285 high: 2925 min/max: N/A base/boost: 2933/2933
volts: 1.3 V ext-clock: 267 MHz cores: 1: 1646 2: 2925 bogomips: 11704
SMT disabled
driver: N/A bus-ID: 1-5:4 chip-ID: 0bda:f179 class-ID: 0000 serial: <filter>
v: kernel bus-ID: 1-6:6 chip-ID: 22d9:276a class-ID: 0a00 serial: <filter>
Local Storage: total: 465.76 GiB used: 129.32 GiB (27.8%)
rpm: 7200 serial: <filter> rev: 1H19 temp: 33 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 3y 355d 4h cycles: 4706
used: 129.32 GiB (28.3%) fs: ext4 block-size: 4096 B dev: /dev/sda1
Device-1: 1-5:4 info: Realtek RTL8188FTV 802.11b/g/n 1T1R 2.4G WLAN Adapter
Device-2: 1-6:6 info: OPPO SDM778G-IDP _SN:8F7AD3F2
serial: <filter>
Device-1: 2-1:2 info: China Resource Semico USB Keyboard
System Temperatures: cpu: 31.0 C mobo: N/A
Processes: 152 Uptime: 5m wakeups: 0 Init: systemd v: 251 default: graphical
how do i check if its working? when i remove my mobiles usb tethering in network it shows no available connection. i cannot see any wifi option in setting as well
You are missing libcrypto.so.1.1
which is in the openssl-1.1
package
after installing openssl-1.1
package still didnt work
It should not give the same error while building at least, maybe post the output of that build process again to see the diff/new errors that might have happened.
