Hey, I’m having a problem with my dorm network WiFi.
When I connect to it, after logging into the network with my Username and Password, It requires me to login frequently with random intervals between each login; sometimes 10mins, sometimes 5mins, etc. which is abnormal.
The normal behavior is logging in just once a day.
This is what other people here do and even I myself have this kind of behavior on my Windows and Android devices (logging in just once a day).
What I tried and didn’t help thus far:
- Forgetting the network and Connecting to it again
- Trying another account.
- Resetting the network settings to its default.
- Trying another Wifi card.
- Connect + Login and then using the same network on the latest version of Live on-bootable-usb Manjaro.
- Calling IT support of my university. They say, It’s just you that having this problem, nobody else reported such a thing.
- Restarting NetworkManager daemon using
sudo systemctl stop NetworkManager
and thensudo systemctl start NetworkManager
What I’m guessing is, Whatever the problem is, it’s something OS related.
Thanks, regards.
