I have a problem with the Internet on Manjaro Kernel 5.10.2. The first attempts were on 6.9.0-1 but it looked the same. The problem is that I connect to the Internet via WiFi without a proxy or VPN. Everything works fine until I start downloading something using the terminal, e.g. git clone or sudo pacman -S xxx, and especially when I use rdesktop. Then the internet stops working, but the WIFI connection is still active. For example, they enter the Brave browser and when refreshing the page, nothing happens, the page does not load. Iâm new and I have freshly installed manjaro
journalctl --follow
maj 18 23:44:49 idotk NetworkManager[524]: <info> [1716068689.0871] manager: NetworkManager state is now CONNECTED_SITE
maj 18 23:44:49 idotk NetworkManager[524]: <info> [1716068689.0877] device (wlp2s0): Activation: successful, device activated.
maj 18 23:44:49 idotk NetworkManager[524]: <info> [1716068689.2497] manager: NetworkManager state is now CONNECTED_GLOBAL
maj 18 23:44:49 idotk wpa_supplicant[693]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
maj 18 23:44:56 idotk systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
maj 18 23:46:15 idotk wpa_supplicant[693]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-47 noise=-99 txrate=6000
maj 18 23:46:32 idotk systemd[1]: Starting Time & Date Service...
maj 18 23:46:32 idotk systemd[1]: Started Time & Date Service.
maj 18 23:47:02 idotk systemd[1]: systemd-timedated.service: Deactivated successfully.
maj 18 23:48:06 idotk systemd[733]: tumblerd.service: Consumed 4.183s CPU time.
maj 18 23:52:02 idotk wpa_supplicant[693]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
maj 18 23:52:03 idotk wpa_supplicant[693]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
11: PCI 200.0: 0282 WLAN controller
[Created at pci.386]
Unique ID: qru8.uBUKI35slGC
Parent ID: VRCs.vK7L+QX+LN4
SysFS ID: /devices/pci0000:00/0000:00:01.3/0000:02:00.0
SysFS BusID: 0000:02:00.0
Hardware Class: network
Model: "Lenovo Qualcomm Atheros QCA9377 Wireless Network Adapter"
Vendor: pci 0x168c "Qualcomm Atheros"
Device: pci 0x0042 "QCA9377 802.11ac Wireless Network Adapter"
SubVendor: pci 0x17aa "Lenovo"
SubDevice: pci 0x0901 "Qualcomm Atheros QCA9377 Wireless Network Adapter"
Revision: 0x31
Driver: "ath10k_pci"
Driver Modules: "ath10k_pci"
Device File: wlp2s0
Features: WLAN
Memory Range: 0xc0200000-0xc03fffff (rw,non-prefetchable)
IRQ: 54 (30718 events)
HW Address: 3c:91:80:74:f7:93
Permanent HW Address: 3c:91:80:74:f7:93
Link detected: yes
WLAN channels: 1 2 3 4 5 6 7 8 9 10 11 12 13 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140
WLAN frequencies: 2.412 2.417 2.422 2.427 2.432 2.437 2.442 2.447 2.452 2.457 2.462 2.467 2.472 5.18 5.2 5.22 5.24 5.26 5.28 5.3 5.32 5.5 5.52 5.54 5.56 5.58 5.6 5.62 5.64 5.66 5.68 5.7
WLAN encryption modes: WEP40 WEP104 TKIP CCMP
WLAN authentication modes: open sharedkey wpa-psk wpa-eap
Module Alias: "pci:v0000168Cd00000042sv000017AAsd00000901bc02sc80i00"
Driver Info #0:
Driver Status: ath10k_pci is active
Driver Activation Cmd: "modprobe ath10k_pci"
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #23 (PCI bridge)
