Network slow to startup on first boot or reboot
I have researched the topics on this forum for slow network startup and have tried some of the settings changes suggested but I am not getting anywhere.
I have a multiboot setup and one of the boot up options is plain Archlinux.
I don’t have the problem there.
It is just Manjaro.
It appears that when I first get logged in I can ping an ip address like 8.8.8.8
But pinging www.google.com just hangs and after about a minute or 2 it starts pinging.
Seems to be something with DNS but I don’t know enough about the settings to know what to change.
So I am sure this can be solved.
Just not sure what to try .
Here is some system info:
[demo@Manjaro ~]$ inxi -Fazy
  Kernel: 6.19.0-rc6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.19-x86_64
    root=UUID=45ca132d-4a37-4dc3-afa0-be2e80d6a4a2 rw quiet
    udev.log_priority=3 libata.noacpi=1 kvm.enable_virt_at_load=0
  Desktop: KDE Plasma v: 6.5.5 tk: Qt v: N/A info: frameworks v: 6.22.0
    wm: kwin_x11 with: plank tools: xscreensaver,xscreensaver-systemd vt: 2
    dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Convertible System: HP product: HP Spectre x360 Convertible 15-df1xxx
    v: N/A serial: <superuser required> Chassis: type: 31
  Mobo: HP model: 863F v: 54.24 serial: <superuser required>
    part-nu: 7UT64UA#ABA uuid: <superuser required> Firmware: UEFI vendor: AMI
    v: F.32 date: 12/08/2023
  ID-1: BAT0 charge: 89.2 Wh (100%) condition: 89.2/89.2 Wh (100%) volts: 12.95
    min: 11.55 model: HP Primary type: Li-ion serial: <filter> charging:
    status: full cycles: 62
  Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
    arch: Comet/Whiskey Lake note: check gen: core 10 level: v3 note: check
    built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
    stepping: 0xC (12) microcode: 0x100
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 4094 min/max: 400/4900 scaling: driver: intel_pstate
    governor: performance cores: 1: 4094 2: 4094 3: 4094 4: 4094 5: 4094 6: 4094
    7: 4094 8: 4094 bogomips: 36799
  Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  Type: indirect_target_selection mitigation: Aligned branch/return thunks
  Type: retbleed mitigation: Enhanced IBRS
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Hewlett-Packard
    ports: active: eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:9b41
    class-ID: 0300
  Device-2: Chicony HP Wide Vision FHD Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 04f2:b67b
  Display: x11 server: X.Org v: 21.1.21 with: Xwayland v: 24.1.9
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x2160 s-dpi: 300 s-size: 325x182mm (12.80x7.17")
    s-diag: 372mm (14.66")
  Monitor-1: eDP-1 model: AU Optronics 0x30eb built: 2017 res: N/A dpi: 284
    gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
    modes: 3840x2160
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.3-arch1.3
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
    device-ID: 8086:9b41 memory: 14.89 GiB unified: yes
  API: Vulkan v: 1.4.335 layers: 8 device: 0 type: integrated-gpu name: Intel
    UHD Graphics (CML GT2) driver: mesa intel v: 25.3.3-arch1.3
    device-ID: 8086:9b41 surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
    driver: sof-audio-pci-intel-cnl alternate: snd_soc_avs,
    snd_sof_pci_intel_cnl, snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:02c8
    class-ID: 0401
  API: ALSA v: k6.19.0-rc6-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
    status: active 2: wireplumber status: active tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
  IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
  Info: services: NetworkManager, systemd-networkd, systemd-timesyncd,
    wpa_supplicant
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 0bda:8771
  Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.1
    lmp-v: 10 status: discoverable: no pairing: no class-ID: 6c0000
  Local Storage: total: 931.51 GiB used: 312.88 GiB (33.6%)
    model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 41.9 C scheme: GPT
  ID-1: / raw-size: 163 GiB size: 160.13 GiB (98.24%) used: 69.33 GiB (43.3%)
    fs: ext4 dev: /dev/nvme0n1p11 maj-min: 259:11
  ID-2: /boot/efi raw-size: 499 MiB size: 498 MiB (99.80%)
    used: 207.3 MiB (41.6%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-3: /home raw-size: 314 GiB size: 308.01 GiB (98.09%)
    used: 243.36 GiB (79.0%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
  ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -1
    dev: /dev/nvme0n1p13 maj-min: 259:13
  System Temperatures: cpu: 51.0 C pch: 48.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Memory: total: 16 GiB note: est. available: 15.25 GiB used: 5.48 GiB (36.0%)
  Processes: 305 Power: uptime: 8m states: freeze,mem,disk suspend: s2idle
    image: 6.05 GiB services: org_kde_powerdevil,upowerd Init: systemd v: 258
  Packages: pm: pacman pkgs: 2045 libs: 431 tools: pamac,trizen,yay
    Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Bash v: 5.3.9
    running-in: alacritty inxi: 3.3.40
[demo@Manjaro ~]$ modinfo iwlwifi | grep parm
parm:           debug:debug output mask (uint)
parm:           swcrypto:using crypto in software (default 0 [hardware]) (int)
parm:           11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint)
parm:           amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 2K for AX210 devices, 4K for other devices 1:4K 2:8K 3:12K (16K buffers) 4: 2K (default 0) (int)
parm:           fw_restart:restart firmware in case of error (default true) (bool)
parm:           nvm_file:NVM file name (charp)
parm:           uapsd_disable:disable U-APSD functionality bitmap 1: BSS 2: P2P Client (default: 3) (uint)
parm:           enable_ini:0:disable, 1-15:FW_DBG_PRESET Values, 16:enabled without preset value defined,Debug INI TLV FW debug infrastructure (default: 16) (uint)
parm:           bt_coex_active:enable wifi/bt co-exist (default: enable) (bool)
parm:           led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int)
parm:           power_save:enable WiFi power management (default: disable) (bool)
parm:           power_level:default power save level (range from 1 - 5, default: 1) (int)
parm:           disable_11ac:Disable VHT capabilities (default: false) (bool)
parm:           remove_when_gone:Remove dev from PCIe bus if it is deemed inaccessible (default: false) (bool)
parm:           disable_11ax:Disable HE capabilities (default: false) (bool)
parm:           disable_11be:Disable EHT capabilities (default: false) (bool)
I’ve tried flushing the cache but that didn’t help
It may be an issue with your DNS - your provider gives you one, but you can choose your own
and it is easy to change in the NetworkManager GUI.
Search for (for example) cloudflare DNS
They are one of many, but this is one of the fastest ones.
And they have instructions on how to do it as well.
In the tab for IPv4 and IPv6 settings of the connection editor
choose Method “Automatic (DHCP) addresses only”
instead of the default “Automatic”
fill in the server IP below, commata in between when you put two in
done
Tried that . Rebooted . Didn’t work
I put in
8.8.8.8 and 1.1.1.1
It was my guess on what to try. I have no further guesses. :slightly_smiling_face:
You could try a stable kernel. It lists NetworkManager and systems-networkd. Maybe they conflict? Depending on how you set it up, systemd-resolved also might conflict.
You also set up tailscale, maybe it tries to connect?
Ok booted to 6.12 kernel and stopped tailscale service.
BAM network immediately.
I will look into this because I want to use tailscale.
Thanks for the pointer and help.
