Well i turned it off with
sudo ethtool -s [devicename] wol d
already. Beforehand i checked with ethtool [devicename] and it was set to g. However, i’m pretty sure that this wasn’t the case up to this point. The laptop is always connected to LAN, well, it doesn’t have a LAN port so I have a USB to LAN adapter. This alone should have prevented the laptop from sleep, or am I missing anything?
❯ inxi -zv8
Kernel: 7.2.0--1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-7.2-x86_64
root=UUID=6af1ea40-9cc2-4608-8968-470bd70db7b6 rw quiet splash
resume=UUID=bcbc0542-a627-41cb-8aa2-73334358faed udev.log_priority=3
Desktop: KDE Plasma v: 6.7.4 tk: Qt v: N/A info: frameworks v: 6.29.0
wm: kwin_wayland with: krunner vt: 1 dm: SDDM Distro: Manjaro
base: Arch Linux
Type: Laptop System: HP product: HP EliteBook 840 14 inch G10 Notebook PC
v: SBKPFV3 serial: <superuser required> Chassis: type: 10
Mobo: HP model: 8B41 v: KBC Version 51.45.00 serial: <superuser required>
uuid: <superuser required> Firmware: UEFI vendor: HP v: 70 Ver. 01.11.00
date: 11/06/2025
ID-1: BAT0 charge: 40.8 Wh (100%) condition: 40.8/51.3 Wh (79.5%)
volts: 12.36 min: 11.58 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> charging: status: full cycles: 21
System RAM: total: 32 GiB available: 30.97 GiB used: 5.46 GiB (17.6%)
Device-1: Bottom-Slot 1(left) type: DDR5 detail: synchronous size: 16 GiB
speed: spec: 5600 MT/s actual: 5200 MT/s volts: curr: 1 width (bits):
data: 64 total: 64 manufacturer: Samsung part-no: M425R2GA3BB0-CWMOD
serial: <filter>
Device-2: Bottom-Slot 2(right) type: DDR5 detail: synchronous size: 16 GiB
serial: <filter>
Info: model: 13th Gen Intel Core i7-1360P bits: 64 type: MST AMCP
arch: Raptor Lake level: v3 note: check built: 2022+ process: Intel 7 (10nm)
family: 6 model-id: 0xBA (186) stepping: 2 microcode: 0x6134
Topology: cpus: 1x dies: 1 clusters: 6 cores: 12 threads: 16 mt: 4 tpc: 2
st: 8 smt: enabled cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32
KiB, 8x64 KiB L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 400 min/max: 400/5000:3700 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400 15: 400 16: 400
bogomips: 83558
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
xtopology xtpr
conditional; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel alternate: xe arch: Xe process: Intel 7 (10nm)
built: 2022+ ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:a7a0 class-ID: 0300
Device-2: Luxvisions Innotech HP 5MP Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 30c9:0096
Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
alternate: fbdev,vesa dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: AU Optronics 0x6da8 built: 2022 res:
mode: 2560x1600 hz: 120 scale: 105% (1.05) to: 2438x1524 dpi: 216 gamma: 1.2
chroma: red: x: 0.678 y: 0.318 green: x: 0.267 y: 0.698 blue: x: 0.153
y: 0.047 white: x: 0.314 y: 0.329 size: 301x188mm (11.85x7.4")
diag: 355mm (14") ratio: 16:10 modes: 2560x1600
EDID-Warnings: 1: parse_edid: unknown flag 2 2: parse_edid: unknown tag
112
drv: iris x11: drv: iris
API: OpenGL v: 4.6 vendor: intel mesa v: 26.1.8-arch1.1 glx-v: 1.4
direct-render: yes renderer: Mesa Intel Iris Xe Graphics (RPL-P)
device-ID: 8086:a7a0 memory: 30.25 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.357 layers: 2 device: 0 type: integrated-gpu name: Intel
Iris Xe Graphics (RPL-P) driver: mesa intel v: 26.1.8-arch1.1
device-ID: 8086:a7a0 surfaces: N/A
Device-1: Intel Raptor Lake-P/U/H cAVS vendor: Hewlett-Packard
driver: sof-audio-pci-intel-tgl alternate: snd_soc_avs,
snd_sof_pci_intel_tgl, snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:51ca
class-ID: 0401
API: ALSA v: k7.2.0--1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.8 status: active with: 1: pipewire-pulse
Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f1 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
Device-2: Realtek USB 10/100/1G/2.5G LAN driver: r8152 type: USB rev: 3.2
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1:2 chip-ID: 0bda:8156
class-ID: 0000 serial: <filter>
IF: enp0s20f0u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: wwan0 state: down mac: N/A
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0033
class-ID: e001
Local Storage: total: 953.87 GiB used: 46.62 GiB (4.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN810 SDCPNRY-1T00-1006 size: 953.87 GiB block-size: physical: 512 B
fw-rev: HPS2 temp: 27.9 C scheme: GPT
ID-1: / raw-size: 110 GiB size: 107.72 GiB (97.92%) used: 28.19 GiB (26.2%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 6af1ea40-9cc2-4608-8968-470bd70db7b6
used: 328 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: D652-A9B7
ID-3: /home raw-size: 835 GiB size: 820.82 GiB (98.30%)
used: 18.43 GiB (2.2%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
label: N/A uuid: d9ebda44-b9de-4add-b4df-428536493ce4
ID-1: swap-1 type: partition size: 8.37 GiB used: 0 KiB (0.0%)
priority: -1 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: bcbc0542-a627-41cb-8aa2-73334358faed
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 3 rev: 3.1
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-1:2 info: Luxvisions Innotech HP 5MP Camera type: video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 30c9:0096 class-ID: fe01
serial: <filter>
Device-2: 3-7:3 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 06cb:00f0 class-ID: ff00 serial: <filter>
Device-3: 3-10:4 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0033 class-ID: e001
Device-1: 4-1:2 info: Realtek USB 10/100/1G/2.5G LAN type: Network
driver: r8152 interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
mode: 3.2 gen-1x1 power: 256mA chip-ID: 0bda:8156 class-ID: 0000
serial: <filter>
System Temperatures: cpu: 32.2 C mobo: N/A
Fan Speeds (rpm): cpu: 963
Packages: 1705 pm: pacman pkgs: 1698 libs: 354 tools: pamac pm: flatpak
pkgs: 7
1: https://mirror.futureweb.be/manjaro/unstable/$repo/$arch
2: https://ftp.gwdg.de/pub/linux/manjaro/unstable/$repo/$arch
3: https://manjaro.ipacct.com/manjaro/unstable/$repo/$arch
4: https://mirror.it4i.cz/manjaro/unstable/$repo/$arch
5: https://mirror.xenyth.net/manjaro/unstable/$repo/$arch
6: https://opencolo.mm.fcix.net/manjaro/unstable/$repo/$arch
7: https://mirrors.sonic.net/manjaro/unstable/$repo/$arch
8: https://muug.ca/mirror/manjaro/unstable/$repo/$arch
Processes:
CPU top: 5 of 433
1: cpu: 12.3% command: konsole pid: 19669 mem: 114.2 MiB (0.3%)
2: cpu: 6.3% command: zsh pid: 19677 mem: 10.8 MiB (0.0%)
3: cpu: 2.1% command: brave pid: 19360 mem: 213.6 MiB (0.6%)
4: cpu: 1.8% command: kwin_wayland pid: 1363 mem: 344.7 MiB (1.0%)
5: cpu: 0.9% command: plasmashell pid: 1517 mem: 443.7 MiB (1.3%)
Memory top: 5 of 433
1: mem: 670.1 MiB (2.1%) command: firefox pid: 1848 cpu: 0.3%
2: mem: 480.9 MiB (1.5%) command: brave pid: 17899 cpu: 0.1%
3: mem: 443.7 MiB (1.3%) command: plasmashell pid: 1517 cpu: 0.9%
4: mem: 393.5 MiB (1.2%) command: firefox pid: 2530 cpu: 0.0%
5: mem: 344.7 MiB (1.0%) command: kwin_wayland pid: 1363 cpu: 1.8%
Processes: 433 Power: uptime: 21h 42m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 12 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 12.31 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 261 default: graphical
tool: systemctl
Compilers: clang: 22.1.8 gcc: 16.2.1 Shell: Zsh v: 5.9.2
running-in: konsole inxi: 3.3.41
So far, I assume it could have been some driver or firmware update. The kernel version didn’t make a difference - I tried with 7.1.8 and 6.18. I need to check whether there is an option in the BIOS, and I’ll have a look at the pacman logs. Unfortunately I can’t recall the exact time.
