Network Manager reconnects every 2 seconds
Hi,
I have this problem that every 10 minutes or so the network manager reconnects to the wifi every two seconds or so. So it rapidly disconnects and connects again. I looked into journalctl and the thing that happens before every disconnect is the following line:
bgscan simple: Failed to enable signal strength monitoring
I tried searching for it on the web, but couldn’t find any useful information.
Here’s a longer journalctl snippet
Dec 17 16:23:45 triton-moon wpa_supplicant[794]: bgscan simple: Failed to enable signal strength monitoring
Dec 17 16:23:45 triton-moon NetworkManager[642]: <info>  [1608218625.8156] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Dec 17 16:23:47 triton-moon wpa_supplicant[794]: wlp4s0: CTRL-EVENT-DISCONNECTED bssid=98:9b:cb:61:92:f2 reason=0
Dec 17 16:23:47 triton-moon wpa_supplicant[794]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Dec 17 16:23:47 triton-moon NetworkManager[642]: <info>  [1608218627.5853] device (wlp4s0): supplicant interface state: completed -> disconnected
Dec 17 16:23:47 triton-moon NetworkManager[642]: <info>  [1608218627.6847] device (wlp4s0): supplicant interface state: disconnected -> scanning
Dec 17 16:23:49 triton-moon wpa_supplicant[794]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
Dec 17 16:23:49 triton-moon wpa_supplicant[794]: wlp4s0: Trying to associate with 98:9b:cb:61:92:f2 (SSID='Interwebz Slow' freq=2412 MHz)
Dec 17 16:23:49 triton-moon NetworkManager[642]: <info>  [1608218629.3215] device (wlp4s0): supplicant interface state: scanning -> associating
Dec 17 16:23:49 triton-moon wpa_supplicant[794]: wlp4s0: Associated with 98:9b:cb:61:92:f2
Dec 17 16:23:49 triton-moon wpa_supplicant[794]: wlp4s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Dec 17 16:23:49 triton-moon wpa_supplicant[794]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Dec 17 16:23:49 triton-moon NetworkManager[642]: <info>  [1608218629.4577] device (wlp4s0): supplicant interface state: associating -> associated
Dec 17 16:23:49 triton-moon NetworkManager[642]: <info>  [1608218629.4647] device (wlp4s0): supplicant interface state: associated -> 4way_handshake
Dec 17 16:23:49 triton-moon wpa_supplicant[794]: wlp4s0: WPA: Key negotiation completed with 98:9b:cb:61:92:f2 [PTK=CCMP GTK=CCMP]
Dec 17 16:23:49 triton-moon wpa_supplicant[794]: wlp4s0: CTRL-EVENT-CONNECTED - Connection to 98:9b:cb:61:92:f2 completed [id=0 id_str=]
This section repeats itself for a few minutes.
I’m currently on kernel linux57. I can’t upgrade, because I believe the Nvidia Kernel Module is still missing.
Does anybody have a idea for how to fix this? Thanks.
Cheers,
Triton
I dont think so.
You are on EOL with outdated packages … you need to fix this.
Okay, I upgraded my Kernel to linux 59, but the error persists. At first everything seemed to work, but the next day the network errors started again. Everything works fine on my phone, so it isn’t our internet or wifi connection.
