Dear All,
I found that network Manager has a potential privacy issue.
With Open VPN active and running, it will run like a second parallel connection, not encrypted, when pingging Archlinux website.
This can be easily seen using a simple Wireshark capture.
I uploaded a video on YT, id is FbMuNnCkx2o
(sorry, links are disallow here)
Please report it in the appropriate place if you think this is a problem. In my opinion, it makes sense that the connectivity check bypasses the VPN, you can turn it off if you want.
Hi, yes, we can turn it off
But is it normal that it bypasses the user settings ? for me, it should not, or it should be explicitly announced and explained (which is not)
I am sorry, I am new here,.
Can you please advise if I should report as a pb or not ?
Thanks in advance !
