Network Manager not working after disabling powersave
Hello!
So my internet was working too slow on manjaro (i have dualbooted it with windows) but it works fine and fast on windows, so i was searching for its solution and then i found this command on a post on this forum:
echo "wifi.powersave = 2" | sudo tee /etc/NetworkManager/conf.d/wifi-powersave.conf
then entered my password and rebooted, after the reboot my NetworkManager never started again, i tried the same command with value 0 and 3 to get it back working but i failed to do so.
This is the output when i run
sudo systemctl restart NetworkManager
output:
Job for NetworkManager.service failed because the control process exited with error code. See "systemctl status NetworkManager.service" and "journal ctl -xeu NetworlManager.service" for details
and these are the output of the above commands
× NetworkManager.service - Network Manager
Loaded: loaded (/usr/lib/systemd/system/NetworkManager service; enabled; preset: disabled)
Active: failed (Result: exit-code) since Wed 2024-05-22 20:05:21 IST; 4min 28s ago
Docs: man: NetworkManager(8)
Process: 1754 ExecStart=/usr/bin/NetworkManager --no-daemon (code=exited, status=1/FAILURE)
Main PID: 1754 (code=exited, status=1/FAILURE)
CPU: 43ms
May 22 20:05:21 manjaro systemd[1]: NetworkManager service: Scheduled restart job, restart counter is at 5.
May 22 20:05:21 manjaro systemd[1]: NetworkManager service: Start request repeated too quickly.
May 22 20:05:21 manjaro systemd[1]: NetworkManager service: Failed with result 'exit-code'.
May 22 20:05:21 manjaro systemd[1]: Failed to start Network Manager.
and
journalctl -xeu NetworkManager.service
An ExecStart= process belonging to unit NetworkManager.service has exited.
The process' exit code is 'exited' and its exit status is 1.
May 22 20:05:21 manjaro systemd[1]: NetworkManager.service: Failed with result 'exit-code'.
Subject: Unit failed
Defined-By: systemd
Support: https://forum.manjaro.org/c/support
 The unit NetworkManager service has entered the 'failed' state with result 'exit-code'.
Subject: A start job for unit NetworkManager.service has failed
Defined-By: systemd
A start job for unit NetworkManager.service has finished with a failure.
 The job identifier is 2870 and the job result is failed.
May 22 20:05:21 manjaro systemd[1]: NetworkManager.service: Scheduled restart job, restart counter is at 5.
Subject: Automatic restarting of a unit has been scheduled
Defined-By: systemd
 Automatic restarting of the unit NetworkManager service has been scheduled, as the result for the configured Restart= setting for the unit.
May 22 20:05:21 manjaro systemd[1]: NetworkManager.service: Start request repeated too quickly.
Defined-By: systemd
Defined-By: systemd
A start job for unit NetworkManager.service had finished with a failure
The job identifier is 2963 and the job result is failed
How do i fix this issue ? also, if i have posted this far, why internet is so slow on manjaro though ? :[
also, i forgot to mention that the wifi icon isn’t in the bar anymore…if this helps. I am new so forgive me for my mistakes and incompatibility
As the problems started with the wifi-powersave.conf file change, can you paste here the contents of this file?
Hi @kola,
Simply try removing that file and see if that helps:
sudo rm /etc/NetworkManager/conf.d/wifi-powersave.conf
Edit:
Could be drivers. Please provide the output of:
inxi --admin --verbosity=8 --width
it is just a single line
“wifi.powersave = 0”
Should be two…
[connection]
wifi.powersave = 2
yup, worked just fine. Thank you
on it
 inxi --admin --verbosity=8 --width         ✔
  Host: manjaro Kernel: 6.6.30-2-MANJARO arch: x86_64 bits: 64 compiler: gcc
    v: 13.2.1 clocksource: tsc avail: hpet,acpi_pm
    root=UUID=79b15d75-4d5b-4c66-b539-7b3f139ae945 rw plymouth.enable=0
    disablehooks=plymouth quiet splash udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.1.0
  Type: Laptop System: HP product: HP Pavilion Laptop 13-an0xxx
    v: Type1ProductConfigId serial: <superuser required> Chassis: type: 10
  Mobo: HP model: 84C5 v: 15.32 serial: <superuser required>
    part-nu: 5SE72PA#ACJ uuid: <superuser required> UEFI: Insyde v: F.09
    date: 11/26/2019
  ID-1: BAT0 charge: 6.8 Wh (33.7%) condition: 20.2/20.2 Wh (100.0%) volts: 8.5
    min: 7.6 model: HP Primary type: Li-ion serial: N/A status: charging
  System RAM: total: 8 GiB available: 7.65 GiB used: 1.99 GiB (26.0%)
  Array-1: capacity: 16 GiB slots: 1 modules: 1 EC: None
  Device-1: Bottom - on board type: DDR4 detail: synchronous size: 8 GiB
    speed: 2400 MT/s volts: curr: 1 min: 2 max: 2 width (bits): data: 64
    total: 64 manufacturer: Samsung part-no: K4AAG165WB-MCRC serial: N/A
  Info: model: Intel Core i5-8265U bits: 64 type: MT MCP arch: Whiskey Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x8E (142) stepping: 0xB (11) microcode: 0xF4
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 750 high: 800 min/max: 400/3900 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 400
    5: 800 6: 800 7: 800 8: 800 bogomips: 28808
    dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht hwp
    hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid lahf_lm
    lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
    pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts
    rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
    sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer vme
    x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: itlb_multihit status: KVM: VMX unsupported
  Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Hewlett-Packard
    ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:3ea0
    class-ID: 0300
  Device-2: Chicony HP Wide Vision HD Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 04f2:b627
    class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 23.2.6
    compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
    device: 1 drv: swrast surfaceless: drv: iris wayland: drv: iris x11:
    drv: iris inactive: gbm
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.6-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (WHL GT2)
    device-ID: 8086:3ea0 memory: 7.47 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: Intel
    UHD Graphics 620 (WHL GT2) driver: mesa intel v: 24.0.6-manjaro1.1
    device-ID: 8086:3ea0 surfaces: xcb,xlib,wayland
  Device-1: Intel Cannon Point-LP High Definition Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
  API: ALSA v: k6.6.30-2-MANJARO status: kernel-api with: aoss
  Server-1: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
  IF: wlo1 state: up mac: 98:3b:8f:af:89:62
  IP v4: 192.168.1.2/24 type: dynamic noprefixroute scope: global
    broadcast: 192.168.1.255
  IP v6: 2401:4900:1c37:aedb:a053:3268:d880:1f35/64
  IP v6: fe80::5a86:4fd1:a766:5595/64 type: noprefixroute scope: link
  WAN IP: 122.167.214.192
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4
  Local Storage: total: 238.47 GiB used: 25.01 GiB (10.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
    lanes: 2 tech: SSD serial: X85PCAIDP12P fw-rev: ADHA0101 temp: 58.9 C
    scheme: GPT
  ID-1: / raw-size: 78.12 GiB size: 76.35 GiB (97.73%) used: 24.93 GiB (32.6%)
    fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
    uuid: 79b15d75-4d5b-4c66-b539-7b3f139ae945
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
    used: 81.7 MiB (31.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: CACF-9EFB
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 147.22 GiB fs: ntfs
    label: Windows uuid: 9E3A94763A944D61
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 11.89 GiB fs: ntfs label: N/A
    uuid: AA00758700755AF1
  ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 980 MiB fs: ntfs
    label: Windows RE tools uuid: 94AE0C42AE0C1F7C
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-1:2 info: USB OPTICAL MOUSE type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 100mA chip-ID: 275d:0ba6 class-ID: 0301
  Device-2: 1-3:3 info: Chicony HP Wide Vision HD Camera type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 04f2:b627 class-ID: 0e02
  Device-3: 1-10:4 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
  System Temperatures: cpu: 56.0 C pch: 51.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1486 libs: 402 tools: pamac,yay
    1: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    2: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
    3: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    4: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    5: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
    6: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    7: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    8: https://mirrors.netix.net/manjaro/stable/$repo/$arch
    9: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    10: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    11: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    12: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    13: https://manjaro.kurdy.org/stable/$repo/$arch
    14: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    15: https://mirror.init7.net/manjaro/stable/$repo/$arch
    16: https://repos.silknet.com/manjaro/stable/$repo/$arch
    17: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    18: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    19: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    20: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    21: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    22: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    23: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    24: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    25: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    26: https://mirror.erickochen.nl/manjaro/stable/$repo/$arch
    27: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    28: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    29: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    30: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    31: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    32: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    33: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    34: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    35: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    36: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    37: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    38: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    39: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    40: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    41: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    42: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    43: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    44: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    45: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    46: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    47: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    48: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    49: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    50: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    51: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    52: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    53: http://manjaro.grena.ge/stable/$repo/$arch
    54: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    55: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    56: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    57: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    58: http://manjaro.mirrors.theom.nz/manjaro/stable/$repo/$arch
    59: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    60: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    61: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    62: https://mirror.23m.com/manjaro/stable/$repo/$arch
    63: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    64: https://linorg.usp.br/manjaro/stable/$repo/$arch
    65: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    66: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    67: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    68: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
    69: https://mirrors2.manjaro.org/stable/$repo/$arch
    70: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    71: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
    72: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    73: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    74: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    75: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    76: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    77: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    78: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    79: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
    80: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
    81: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    82: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    83: https://manjaro.ynh.ovh/stable/$repo/$arch
    84: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    85: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    86: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    87: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
    88: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    89: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    90: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    91: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    92: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    93: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    94: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    95: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    96: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    97: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
    98: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    99: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    100: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    101: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    102: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    103: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    104: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    105: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    106: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    107: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    108: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    109: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    110: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    111: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    112: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    113: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
    114: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    115: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    116: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    117: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    118: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
    119: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    120: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 246
  1: cpu: 30.9% command: brave pid: 1298 mem: 245.3 MiB (3.1%)
  2: cpu: 15.5% command: kwin_wayland pid: 653 mem: 195.1 MiB (2.4%)
  3: cpu: 15.3% command: plasmashell pid: 777 mem: 269.2 MiB (3.4%)
  4: cpu: 13.1% command: brave pid: 1229 mem: 163.7 MiB (2.0%)
  5: cpu: 12.5% command: brave pid: 1173 mem: 370.2 MiB (4.7%)
  Memory top: 5 of 246
  1: mem: 370.2 MiB (4.7%) command: brave pid: 1173 cpu: 12.5%
  2: mem: 269.2 MiB (3.4%) command: plasmashell pid: 777 cpu: 15.3%
  3: mem: 245.3 MiB (3.1%) command: brave pid: 1298 cpu: 30.9%
  4: mem: 195.1 MiB (2.4%) command: kwin_wayland pid: 653 cpu: 15.5%
  5: mem: 163.7 MiB (2.0%) command: brave pid: 1229 cpu: 13.1%
  Processes: 246 Power: uptime: 2m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 3.05 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.26 running-in: konsole inxi: 3.3.34
I honestly have no idea. What I can suggest is trying a different kernel. Perhaps 6.1, the current SLTS. To install it, run:
sudo mhwd-kernel --install linux61
Reboot into it:
All available kernels installed on your system will be presented upon booting up. GNU GRUB is visible with a couple of options. Choose “Advanced Options for Manjaro Linux” by using the arrow keys on your keyboard and then ↵ Enter.
On the next screen (as illustrated) are backup copies of each kernel version installed (which will also be automatically removed if or when a kernel version is deleted). To select a kernel, simply use the arrow keys to highlight the desired version, and then press ↵ Enter.
And see if it helps. If it does, violet!
Remember to remove your current one if you’ll be sticking to 6.1. Too do so, from 6.1, run:
sudo mhwd-kernel --remove linux61
For more:
Seeing ad you’re new, let me just tell you: keep your system up-to-date. Don’t neglect maintenance. See:
Take a look here:
there is no “iwlwifi.conf” file in that folder in my computer…
EDIT: and suddenly the i get a repetitive alert of " no internet connection" . It wasn’t like this before
EDIT 2: so changing to kernel 6.1 was a huge help, thank you both of you
Yes, but you can create it and try to set some of the optiones described in the thread and see the impact in performance or reliability.
so i did it and ther performance has definitely improved, i will inform again if this issue persists. Thank you again
