Network Manager MegaThread
#1
There are recurring reports of issues involving Network Manager.
I want to get them fixed.
I’m starting this thread to collect information about hardware and software that works, compared to that which doesn’t, and to try and collect attempts to solve issues that may or may not work.
If you have issues, or no issues, with Network Manager please post details about your setup, hardware, drivers, AP, NM version, etc. This might help build up a better picture of where issues lie.
Or just make for a megathread…
Potentially useful reference:
https://bbs.archlinux.org/viewtopic.php?id=220101
No network connections found. Please Help
WiFi connection deactivated at startup
Wifi shutdown or restart
[Stable Update] 2018-01-05 - Kernels, KPTI, Plasma, Calamares, TLP
Cannot connect to wifi connection
[Testing Update] 2018-01-08 - GCC, Nvidia, AMD, Python, Haskell, Clean-Up
Wifi autoconnection
[Stable Update] 2017-12-31 - Kernels, Xorg-Server, Mesa, Compiz, Wine, Firefox
Wifi not working after reboot or lid close
[Stable Update] 2017-12-28 - Linux414, Calamares, Xorg-Server, Grub-Live-Theme
[Stable Update] 2018-01-07 - Browsers, Nvidia, PHP, Compiz, Adapta
Network issues on Manjaro KDE
[Testing Update] 2018-01-09 - Linux316, Nvidia, GCC, Octopi, Firefox
WiFi not working after update. Shows Ethernet Network (Intel Ethernet) Disconnected
[Testing Update] 2018-01-11 - Kernels, Systemd, Mesa, Intel Microcode
[Stable Update] 2018-01-12 - Kernels, Microcodes, Nvidia, Firefox, Boost, Cleanup
[Testing Update] 2018-01-13 - Architect, Snap, Mesa, Wine, KDE Apps
[Testing Update] 2018-01-15 - Vertex, Systemd, Haskell, Python, Linux v4.15
[Testing Update] 2018-01-18 - Kernels, Systemd, Pamac, KDE FW, Haskell, Python
[Stable Update] 2018-01-19 - Kernels, KDE Apps & Framework, Browsers, Virtualbox, Systemd, Mesa
Unstable internet over ethernet cable
Plasma doesn't automatically connect to the WiFi but it does if I select it manually
Wi-Fi 2.4GHz doesn't work after update while 5GHz still does
Dhcpcd 7.0.1-1
Wifi randomly breaks
#2
Could you please elaborate on the solution for the networkmanager issue?
You say downgrade should no longer be neccessary. And
This can be fixed by removing the existing connection settings, and then re-adding the connection.
Deleted all connections using nmcli con delete. Did not fix it for me on Manjaro Gnome/Kernel 4.14.8/networkmanager 1.10.2. Impossible to connect to my wifi.
Needed to downgrade to 1.8.4 again.
#3
4.14.9 is current. Have you updated?
Please provide some log output. Maybe start a new thread?
#4
It is still necessary regardless of the comment someone added to the wiki post stating it shouldn’t be. I can still recreate the issue here.
#5
I am very sorry, I am on kernel 4.15.r171224, don’t know where I read the 4.14.8 version number…
Here’s some log https://pastebin.com/rQQbUrkv
Obviously dhcp fails to acquire an IP which is not the case with networkmanager 1.8.4.
#6
2 posts were merged into an existing topic: [Stable Update] 2017-12-28 - Linux414, Calamares, Xorg-Server, Grub-Live-Theme
#7
I don’t understand why only some people have an issue with Network manager 1.10.2. It works perfectly on all of my systems.
I wonder if this is a regression/incompatiblity with the randomised MAC address…
Dez 28 20:31:09  NetworkManager[417]: <info>  [1514489469.8854] device (wlp2s0): set-hw-addr: set MAC address to 6A:EA:B8:27:29:B3 (scanning)
Dez 28 20:31:10  NetworkManager[417]: <info>  [1514489470.9035] device (wlp2s0): set-hw-addr: reset MAC address to 7C:11:CB:CC:BB:AA (preserve)
Dez 28 20:31:59  NetworkManager[417]: <info>  [1514489519.8843] device (wlp2s0): set-hw-addr: set MAC address to DE:4D:63:CC:BB:AA (scanning)
Dez 28 20:32:01  NetworkManager[417]: <info>  [1514489521.4784] device (wlp2s0): set-hw-addr: reset MAC address to 7C:11:CB:CC:BB:AA (preserve)
Dez 28 20:32:47  NetworkManager[417]: <info>  [1514489567.8751] device (wlp2s0): set-hw-addr: set MAC address to 56:8D:05:CC:BB:AA (scanning)
To find out, play with the setting here:
On testing these on my AP, all of them eventually work fine but can increase connection time (multiple de-auths); Stable requires much more connection time (many de-auths). Hence this may need to be tweaked to suit your own AP.
People might also read this:
https://wiki.archlinux.org/index.php/MAC_address_spoofing#Connection_to_DHCPv4_network_fails
#8
This is a plausible cause. However, disabling MAC randomization didn’t solve it for me.
I set
[connection-mac-randomization]
wifi.cloned-mac-address=stable
in /etc/NetworkManager/NetworkManager.conf.
Also followed this https://wiki.archlinux.org/index.php/Dhcpcd#Client_ID to no avail.
Btw, I am using a Linksys LRT224 as router and DHCP and one single Ubiquiti UAP-AC-LR Wifi access point. The issue consistently occurs on different client machines (two laptops, one PC), so I suppose it seems not to be related to certain client hardware.
#9
@mleman @jonathon
I actually have a workaround for this issue in Plasma.
Open the Configuration-Page for the Network Connections, choose your Wifi-Connection and go to the Wifi-Security Page. Then choose to safe the password for everyone. This will disable the password encryption, but the connection will be enabled after a reboot.
Here a pic of the config page:
I hope this helps.
NetworkManager and OpenVPN issues
#10
According to man NetworkManager.conf,
It’s also probably worth trying with
[device]
wifi.scan-rand-mac-address=no
in /etc/NetworkManager/conf.d/disable-random-mac.conf as per
#11
After reverting my change and trying this, it is not working.
Here is the output from NetworkManager:
Dez 28 22:22:59 Linux-Schleppi NetworkManager[405]: <info>  [1514496179.5237] device (wlp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Dez 28 22:22:59 Linux-Schleppi NetworkManager[405]: <info>  [1514496179.5240] device (wlp2s0): Activation: (wifi) access point 'BMW3ER 5 Ghz' has security, but secrets are required.
Dez 28 22:22:59 Linux-Schleppi NetworkManager[405]: <info>  [1514496179.5240] device (wlp2s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Dez 28 22:22:59 Linux-Schleppi NetworkManager[405]: <warn>  [1514496179.5255] device (wlp2s0): No agents were available for this request.
Dez 28 22:22:59 Linux-Schleppi NetworkManager[405]: <info>  [1514496179.5255] device (wlp2s0): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed')
Dez 28 22:22:59 Linux-Schleppi NetworkManager[405]: <info>  [1514496179.5258] manager: NetworkManager state is now DISCONNECTED
Dez 28 22:22:59 Linux-Schleppi NetworkManager[405]: <warn>  [1514496179.5261] device (wlp2s0): Activation: failed for connection 'BMW3ER 5 Ghz'
Dez 28 22:22:59 Linux-Schleppi NetworkManager[405]: <info>  [1514496179.5314] device (wlp2s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Dez 28 22:23:00 Linux-Schleppi NetworkManager[405]: <info>  [1514496180.2824] audit: op="radio-control" arg="wireless-enabled:1" pid=1026 uid=1000 result="success"
Dez 28 22:23:00 Linux-Schleppi NetworkManager[405]: <info>  [1514496180.2848] audit: op="radio-control" arg="wwan-enabled:1" pid=1026 uid=1000 result="success"
And yes, the password is saved and correct. Everything works, if I manually connect to my wifi-network.
#12
Tried disabling wifi.scan-rand-mac-address in addition to wifi.cloned-mac-address=permanent. Does not help either.
Also, on Manjaro Gnome there is no option to store the connection password for every user (or I did not find it) but I noticed that the key is stored in plaintext in /etc/NetworkManager/system-connections/WIFI anyway.
#13
What are your directory permissions on
$ ls -l /etc/NetworkManager
total 4
drwxr-xr-x 1 root root   0 Nov 10 21:16 conf.d
drwxr-xr-x 1 root root  68 Nov 25 07:59 dispatcher.d
drwxr-xr-x 1 root root   0 Nov 10 21:16 dnsmasq.d
drwxr-xr-x 1 root root   0 Nov 10 21:16 dnsmasq-shared.d
-rw-r--r-- 1 root root  88 Dec 12 08:04 NetworkManager.conf
drwx------ 1 root root  28 Dec 28 21:30 system-connections
drwxr-xr-x 1 root root 180 Dec  7 19:37 VPN
Note that /etc/NetworkManager/system-connections should be readwrite only for root.
#14
They are exactly the same as yours. I am aware that only root may see the Wifi key in system-connections. Just saying it is not encrypted. However, I did not want to point this out as an issue.
#15
OK, no worries - just ruling that out as a potential factor.
#16
Mine are like these:
drwxr-xr-x 2 root root 4096 28. Dez 22:21 conf.d
drwxr-xr-x 5 root root 4096 29. Mai 2016  dispatcher.d
drwxr-xr-x 2 root root 4096 11. Mai 2016  dnsmasq.d
drwxr-xr-x 2 root root 4096 22. Feb 2017  dnsmasq-shared.d
-rw-r--r-- 1 root root  110 28. Dez 21:21 NetworkManager.conf
drwxr-xr-x 2 root root 4096 28. Dez 22:28 system-connections
Are these okay?
#17
Do this:
sudo chmod -R a-rwx,u+rwX /etc/NetworkManager/system-connections
and see if it helps. I wonder whether Network Manager won’t save the secret if the files are globally-accessible.
#18
Still need to disable the encryption of the passphrases to be able to automatically connect to my wifi.
#19
it may help people willing to compromise security by saving the password stored unencrypted in an easy to access file but it’s not a workaround I’m willing to use personally. therefore the rollback is still my preferred option
#20
spoofing isn’t turned on for my notebook, according to the journal it is set to preserve but the settings look a bit different in KDE even with 1.10.2 installed and running.
I found this though from when I use 10.1.2 and think it is more relevant to this issue, since I don’t get the expected wallet password prompt on screen.
|28/12/2017 23:18|kdeconnectd|kdeconnect.core: Sending onNetworkChange to  1  LinkProviders|
|28/12/2017 23:18|kdeconnectd|kdeconnect.core: Broadcasting identity packet|
|28/12/2017 23:18|dbus-daemon|[session uid=1000 pid=788] Successfully activated service 'org.freedesktop.Notifications'|
|28/12/2017 23:18|plasmashell|libkcups: Create-Printer-Subscriptions last error: 0 successful-ok|
|28/12/2017 23:18|plasmashell|libkcups: Cancel-Subscription last error: 0 successful-ok|
|28/12/2017 23:18|plasmashell|libkcups: Get-Jobs last error: 0 successful-ok|
|28/12/2017 23:18|plasmashell|Plasma Shell startup completed|
|28/12/2017 23:18|kwin_x11|QXcbConnection: XCB error: 3 (BadWindow), sequence: 4045, resource id: 2097183, major code: 18 (ChangeProperty), minor code: 0|
|28/12/2017 23:18|plasmashell|libkcups: 0|
|28/12/2017 23:18|plasmashell|Both point size and pixel size set. Using pixel size.|
|28/12/2017 23:18|org_kde_powerdevil|powerdevil: Screen brightness value:  2441|
|28/12/2017 23:18|org_kde_powerdevil|powerdevil: Screen brightness value max:  4882|
|28/12/2017 23:18|plasmashell|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "AllDevices"|
|28/12/2017 23:18|plasmashell|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "Capabilities"|
|28/12/2017 23:18|plasmashell|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "ConnectivityCheckAvailable"|
|28/12/2017 23:18|plasmashell|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "ConnectivityCheckEnabled"|
|28/12/2017 23:18|plasmashell|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "Devices"|
|28/12/2017 23:18|plasmashell|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "GlobalDnsConfiguration"|
|28/12/2017 23:18|plasmashell|networkmanager-qt: virtual void NetworkManager::DevicePrivate::propertyChanged(const QString&, const QVariant&) Unhandled property "LldpNeighbors"|
|28/12/2017 23:18|plasmashell|networkmanager-qt: virtual void NetworkManager::DevicePrivate::propertyChanged(const QString&, const QVariant&) Unhandled property "Real"|
|28/12/2017 23:18|kdeinit5|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "AllDevices"|
|28/12/2017 23:18|kdeinit5|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "Capabilities"|
|28/12/2017 23:18|kdeinit5|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "ConnectivityCheckAvailable"|
|28/12/2017 23:18|kdeinit5|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "ConnectivityCheckEnabled"|
|28/12/2017 23:18|kdeinit5|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "Devices"|
|28/12/2017 23:18|kdeinit5|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "GlobalDnsConfiguration"|
|28/12/2017 23:18|kdeinit5|networkmanager-qt: virtual void NetworkManager::DevicePrivate::propertyChanged(const QString&, const QVariant&) Unhandled property "LldpNeighbors"|
|28/12/2017 23:18|kdeinit5|networkmanager-qt: virtual void NetworkManager::DevicePrivate::propertyChanged(const QString&, const QVariant&) Unhandled property "Real"|
|28/12/2017 23:18|plasmashell|trying to show an empty dialog|
|28/12/2017 23:18|plasmashell|Currrent active notifications: QHash()|
|28/12/2017 23:18|plasmashell|Guessing partOf as: 0|
|28/12/2017 23:18|plasmashell| New Notification:  "Touchpad" "Touchpad was disabled because a mouse was plugged in" -1 & Part of: 0|
|28/12/2017 23:18|plasmashell|Currrent active notifications: QHash(("notification 1", "TouchpadTouchpad"))|
|28/12/2017 23:18|plasmashell| New Notification:  "Yakuake" "<html>Application successfully started.<br/>Press <b>F12</b> to use it ...</html>" -1 & Part of: 0|
|28/12/2017 23:18|kdeinit5|kf5.kio.trash: listdir:  QUrl("trash:/")|
|28/12/2017 23:18|plasmashell|Empty filename passed to function|
|28/12/2017 23:18|kernel|logitech-hidpp-device 0003:046D:1028.0004: HID++ 1.0 device connected.|
|28/12/2017 23:18|upower.service|treating change event as add on /sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.2/0003:046D:C52B.0003/0003:046D:1028.0004/power_supply/hidpp_battery_0|
|28/12/2017 23:18|baloo_file|org.kde.baloo: "/org/freedesktop/UPower/devices/mouse_hidpp_battery_0"|
|28/12/2017 23:18|org_kde_powerdevil|powerdevil: Battery with UDI "/org/freedesktop/UPower/devices/mouse_hidpp_battery_0" was detected|
|28/12/2017 23:18|baloo_file|QObject::connect: invalid null parameter|
|28/12/2017 23:18|kdeinit5|QObject::connect: invalid null parameter|
|28/12/2017 23:18|kcmshell5|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "AllDevices"|
|28/12/2017 23:18|kcmshell5|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "Capabilities"|
|28/12/2017 23:18|kcmshell5|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "ConnectivityCheckAvailable"|
|28/12/2017 23:18|kcmshell5|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "ConnectivityCheckEnabled"|
|28/12/2017 23:18|kcmshell5|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "Devices"|
|28/12/2017 23:18|kcmshell5|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "GlobalDnsConfiguration"|
|28/12/2017 23:18|kcmshell5|networkmanager-qt: virtual void NetworkManager::DevicePrivate::propertyChanged(const QString&, const QVariant&) Unhandled property "LldpNeighbors"|
|28/12/2017 23:18|kcmshell5|networkmanager-qt: virtual void NetworkManager::DevicePrivate::propertyChanged(const QString&, const QVariant&) Unhandled property "Real"|
|28/12/2017 23:18|kdeinit5|plasma-nm: virtual NMVariantMapMap SecretAgent::GetSecrets(const NMVariantMapMap&, const QDBusObjectPath&, const QString&, const QStringList&, uint)|
|28/12/2017 23:18|kdeinit5|plasma-nm: Path: "/org/freedesktop/NetworkManager/Settings/1"|
|28/12/2017 23:18|kdeinit5|plasma-nm: Setting name: "802-11-wireless-security"|
|28/12/2017 23:18|kdeinit5|plasma-nm: Hints: ()|
|28/12/2017 23:18|kdeinit5|plasma-nm: Flags: 4|
|28/12/2017 23:18|kdeinit5|plasma-nm: bool SecretAgent::processGetSecrets(SecretsRequest&) const Waiting for the wallet to open|
|28/12/2017 23:18|kwalletd5|Application ' "kded5" ' using kwallet without parent window!|
|28/12/2017 23:19|kcmshell5|Error loading text-to-speech plug-in "speechd"|
|28/12/2017 23:19|plasmashell|Currrent active notifications: QHash()|
|28/12/2017 23:19|plasmashell|Guessing partOf as: 0|
|28/12/2017 23:19|plasmashell| New Notification:  "Failed to get secrets for A063500143599" "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken." -1 & Part of: 0|
as compared to 10.1.0 output:
|28/12/2017 23:46|kdeconnectd|kdeconnect.core: Sending onNetworkChange to  1  LinkProviders|
|28/12/2017 23:46|kdeconnectd|kdeconnect.core: Broadcasting identity packet|
|28/12/2017 23:46|dbus-daemon|[session uid=1000 pid=852] Successfully activated service 'org.freedesktop.Notifications'|
|28/12/2017 23:46|plasmashell|libkcups: Create-Printer-Subscriptions last error: 0 successful-ok|
|28/12/2017 23:46|plasmashell|libkcups: Cancel-Subscription last error: 0 successful-ok|
|28/12/2017 23:46|plasmashell|libkcups: Get-Jobs last error: 0 successful-ok|
|28/12/2017 23:46|plasmashell|file:///usr/lib/qt/qml/QtQuick/Controls/ScrollView.qml:365: TypeError: Cannot read property 'padding' of null|
|28/12/2017 23:46|plasmashell|file:///usr/lib/qt/qml/QtQuick/Controls/ScrollView.qml:364: TypeError: Cannot read property 'padding' of null|
|28/12/2017 23:46|plasmashell|file:///usr/lib/qt/qml/QtQuick/Controls/ScrollView.qml:363: TypeError: Cannot read property 'padding' of null|
|28/12/2017 23:46|plasmashell|file:///usr/lib/qt/qml/QtQuick/Controls/ScrollView.qml:362: TypeError: Cannot read property 'padding' of null|
|28/12/2017 23:46|plasmashell|Plasma Shell startup completed|
|28/12/2017 23:46|kwin_x11|QXcbConnection: XCB error: 3 (BadWindow), sequence: 4164, resource id: 2097183, major code: 18 (ChangeProperty), minor code: 0|
|28/12/2017 23:46|plasmashell|libkcups: 0|
|28/12/2017 23:46|plasmashell|Both point size and pixel size set. Using pixel size.|
|28/12/2017 23:46|org_kde_powerdevil|powerdevil: Screen brightness value:  2441|
|28/12/2017 23:46|org_kde_powerdevil|powerdevil: Screen brightness value max:  4882|
|28/12/2017 23:46|plasmashell|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "AllDevices"|
|28/12/2017 23:46|plasmashell|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "Capabilities"|
|28/12/2017 23:46|plasmashell|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "ConnectivityCheckAvailable"|
|28/12/2017 23:46|plasmashell|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "ConnectivityCheckEnabled"|
|28/12/2017 23:46|plasmashell|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "Devices"|
|28/12/2017 23:46|plasmashell|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "GlobalDnsConfiguration"|
|28/12/2017 23:46|plasmashell|networkmanager-qt: virtual void NetworkManager::DevicePrivate::propertyChanged(const QString&, const QVariant&) Unhandled property "LldpNeighbors"|
|28/12/2017 23:46|plasmashell|networkmanager-qt: virtual void NetworkManager::DevicePrivate::propertyChanged(const QString&, const QVariant&) Unhandled property "Real"|
|28/12/2017 23:46|kdeinit5|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "AllDevices"|
|28/12/2017 23:46|kdeinit5|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "Capabilities"|
|28/12/2017 23:46|kdeinit5|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "ConnectivityCheckAvailable"|
|28/12/2017 23:46|kdeinit5|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "ConnectivityCheckEnabled"|
|28/12/2017 23:46|kdeinit5|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "Devices"|
|28/12/2017 23:46|kdeinit5|networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "GlobalDnsConfiguration"|
|28/12/2017 23:46|NetworkManager|<info>  [1514504776.1473] policy: auto-activating connection 'A063500143599'|
|28/12/2017 23:46|NetworkManager|<info>  [1514504776.1492] device (wlp1s0): Activation: starting connection 'A063500143599' (3c4eded6-3299-4d4c-808d-de346af7f008)|
|28/12/2017 23:46|NetworkManager|<info>  [1514504776.1495] device (wlp1s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')|
|28/12/2017 23:46|NetworkManager|<info>  [1514504776.1500] manager: NetworkManager state is now CONNECTING|
|28/12/2017 23:46|NetworkManager|<info>  [1514504776.1630] device (wlp1s0): set-hw-addr: reset MAC address to 00:C2:C6:84:8F:14 (preserve)|
|28/12/2017 23:46|kernel|iwlwifi 0000:01:00.0: Radio type=0x2-0x0-0x0|
|28/12/2017 23:46|plasmashell|trying to show an empty dialog|
|28/12/2017 23:46|plasmashell|Currrent active notifications: QHash()|
|28/12/2017 23:46|plasmashell|Guessing partOf as: 0|
|28/12/2017 23:46|plasmashell| New Notification:  "Yakuake" "<html>Application successfully started.<br/>Press <b>F12</b> to use it ...</html>" -1 & Part of: 0|
|28/12/2017 23:46|plasmashell|Currrent active notifications: QHash(("notification 1", "YakuakeYakuake"))|
|28/12/2017 23:46|plasmashell| New Notification:  "Touchpad" "Touchpad was disabled because a mouse was plugged in" -1 & Part of: 0|
|28/12/2017 23:46|kernel|IPv6: ADDRCONF(NETDEV_UP): wlp1s0: link is not ready|
|28/12/2017 23:46|NetworkManager|<info>  [1514504776.5143] device (wlp1s0): supplicant interface state: inactive -> disabled|
|28/12/2017 23:46|NetworkManager|<info>  [1514504776.5162] device (wlp1s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')|
|28/12/2017 23:46|NetworkManager|<info>  [1514504776.5167] device (wlp1s0): Activation: (wifi) access point 'A063500143599' has security, but secrets are required.|
|28/12/2017 23:46|NetworkManager|<info>  [1514504776.5167] device (wlp1s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')|
|28/12/2017 23:46|kdeinit5|networkmanager-qt: virtual void NetworkManager::DevicePrivate::propertyChanged(const QString&, const QVariant&) Unhandled property "LldpNeighbors"|
|28/12/2017 23:46|kdeinit5|networkmanager-qt: virtual void NetworkManager::DevicePrivate::propertyChanged(const QString&, const QVariant&) Unhandled property "Real"|
|28/12/2017 23:46|plasmashell|networkmanager-qt: virtual void NetworkManager::ActiveConnectionPrivate::propertyChanged(const QString&, const QVariant&) Unhandled property "StateFlags"|
|28/12/2017 23:46|kdeinit5|kf5.kio.trash: listdir:  QUrl("trash:/")|
|28/12/2017 23:46|NetworkManager|<info>  [1514504776.5496] device (wlp1s0): supplicant interface state: disabled -> inactive|
|28/12/2017 23:46|kdeinit5|networkmanager-qt: virtual void NetworkManager::ActiveConnectionPrivate::propertyChanged(const QString&, const QVariant&) Unhandled property "StateFlags"|
|28/12/2017 23:46|kdeinit5|plasma-nm: Unhandled active connection state change:  1|
|28/12/2017 23:46|kdeinit5|plasma-nm: virtual NMVariantMapMap SecretAgent::GetSecrets(const NMVariantMapMap&, const QDBusObjectPath&, const QString&, const QStringList&, uint)|
|28/12/2017 23:46|kdeinit5|plasma-nm: Path: "/org/freedesktop/NetworkManager/Settings/2"|
|28/12/2017 23:46|kdeinit5|plasma-nm: Setting name: "802-11-wireless-security"|
|28/12/2017 23:46|kdeinit5|plasma-nm: Hints: ()|
|28/12/2017 23:46|kdeinit5|plasma-nm: Flags: 1|
|28/12/2017 23:46|kdeinit5|plasma-nm: bool SecretAgent::processGetSecrets(SecretsRequest&) const Waiting for the wallet to open|
|28/12/2017 23:46|plasmashell|Empty filename passed to function|
|28/12/2017 23:46|kwalletd5|Application ' "kded5" ' using kwallet without parent window!|
|28/12/2017 23:46|NetworkManager|<info>  [1514504787.1582] device (wlp1s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')|
|28/12/2017 23:46|NetworkManager|<info>  [1514504787.1587] device (wlp1s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')|
|28/12/2017 23:46|NetworkManager|<info>  [1514504787.1606] device (wlp1s0): Activation: (wifi) connection 'A063500143599' has security, and secrets exist.  No new secrets needed.|
|28/12/2017 23:46|NetworkManager|<info>  [1514504787.1606] Config: added 'ssid' value 'A063500143599'|
|28/12/2017 23:46|NetworkManager|<info>  [1514504787.1606] Config: added 'scan_ssid' value '1'|
|28/12/2017 23:46|NetworkManager|<info>  [1514504787.1607] Config: added 'bgscan' value 'simple:30:-80:86400'|
|28/12/2017 23:46|NetworkManager|<info>  [1514504787.1607] Config: added 'key_mgmt' value 'WPA-PSK'|
|28/12/2017 23:46|NetworkManager|<info>  [1514504787.1607] Config: added 'psk' value '<hidden>'|
|28/12/2017 23:46|NetworkManager|<info>  [1514504787.1833] device (wlp1s0): supplicant interface state: inactive -> scanning|
|28/12/2017 23:46|kernel|wlp1s0: authenticate with _router MAC obscured_|
