Network is unreachable
I don’t know if I’m the only one, but in the last few days I’ve been seeing the following message more and more often:
  • 500 Can't connect to aur.archlinux.org:443 (Network is unreachable)
  • Unable to GET https://aur.archlinux.org/rpc?
  • Unable to get info for AUR packages...
A few minutes later it works (or not)
:footprints:
I know that this is not Manjaro’s responsibility. But maybe it will reassure others who have the same problem. After all, it’s enough to repeat the process later.
Probably DNS.
You can check if any global outages were happening at the same time that might have contributed.
I will try to include it in the hosts-file :wink:
Have you checked the docs?
Which is why this website exists… :point_down:
Is It Down?
:wink:
