Hello. Lately I have been having problems with my Ethernet connection not working while it states it’s connected (both from Network Manager and physically) and there are no connection problems (the limited connectivity problem for example).
I did a little searching and I found out that both systemd-networkd.service+socket and NetworkManager are running and while I disabled the systemd-networkd.service+socket as a test, it keeps restarting on every reboot.
When I boot my pc, I don’t have Internet and if I stop the aforementioned services, it comes back online. I feel like I am not solving this properly, but even if I am and the services shouldn’t have started, can you please tell me how to really disable them? Or provide me with the proper solution.
I don’t have a strange network configuration, only a connection with only IPv4 for the VPN, and a normal one. All configured from the NetworkManager GUI. The VPN is not automatic. I switch it on later and is not part of the problem. I just mentioned my whole network config and my needs.
❯ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.15.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=a1ea04ed-0556-4d2e-839f-dcb62a64ef9e rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.3 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Mobo: ASUSTeK model: TUF GAMING B550-PLUS v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 1804
date: 02/02/2021
RAM: total: 31.32 GiB used: 7.59 GiB (24.2%)
RAM Report:
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3488 high: 4081 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3768 2: 2051
3: 3723 4: 2797 5: 4081 6: 3576 7: 3538 8: 3491 9: 3759 10: 3370 11: 4080
12: 3624 bogomips: 86270
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Gigabyte
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 06:00.0 chip-ID: 10de:1c03 class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 93 s-size: 1049x292mm (41.30x11.50")
s-diag: 1089mm (42.87")
Monitor-1: DP-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 93
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
Monitor-2: HDMI-0 pos: right res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2
v: 4.6.0 NVIDIA 510.54 direct render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: Gigabyte
bus-ID: 06:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-2: Texas Instruments PCM2902 Audio Codec type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:2 chip-ID: 08bb:2902
class-ID: 0300
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: br-eb2ff28aca9a state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> scope: link
IF-ID-2: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-3: vethb4ade6e state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-4: vethb86f044 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Local Storage: total: 1.36 TiB used: 511.53 GiB (36.6%)
model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3750525AS
size: 698.64 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: JC45 scheme: MBR
ID-1: / raw-size: 60 GiB size: 58.81 GiB (98.01%) used: 38.99 GiB (66.3%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: a1ea04ed-0556-4d2e-839f-dcb62a64ef9e
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 4606-82DD
ID-3: /data/hdd raw-size: 698.63 GiB size: 698.63 GiB (100.00%)
used: 442.37 GiB (63.3%) fs: ntfs dev: /dev/sdb1 maj-min: 8:17 label: DATA
uuid: E4C26CDEC26CB708
ID-4: /home raw-size: 120 GiB size: 117.62 GiB (98.01%)
used: 30.17 GiB (25.7%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
label: N/A uuid: 2dbcc15d-ced7-428c-8a34-2086c49c000e
Kernel: swappiness: 10 (default 60) cache-pressure: 50 (default 100)
ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/nvme0n1p4 maj-min: 259:4 size: 285.26 GiB fs: ntfs label: N/A
uuid: 7EAC9D5C09AEE14F
ID-2: /dev/sda1 maj-min: 8:1 size: 450 MiB fs: ntfs label: Recovery
uuid: 4C54FE1154FDFD90
ID-3: /dev/sda2 maj-min: 8:2 size: 99 MiB fs: vfat label: N/A
uuid: 2AFE-7779
ID-4: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-5: /dev/sda4 maj-min: 8:4 size: 232.33 GiB fs: ntfs label: N/A
uuid: 04E200CFE200C6C0
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-1:2 info: Kingston HyperX Alloy FPS Mechanical Gaming Keyboard
type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 0951:16b7 class-ID: 0301
Device-2: 1-6:3 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:1939 class-ID: 0300 serial: <filter>
Hub-2: 1-7:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: Texas Instruments PCM2902 Audio Codec
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 08bb:2902 class-ID: 0300
Device-2: 3-2:3 info: Itron iONE Strix Claw Gaming Mouse
type: Mouse,Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 195d:1016 class-ID: 0300
Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 58 C
Processes: 395 Uptime: 31m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1680 pacman: 1669 lib: 357
flatpak: 4 snap: 7 Shell: Zsh v: 5.8.1 running-in: kitty inxi: 3.3.14```
