this happens for downloading every appearance settings like Application style, Icons, Cursors, Splash screen, Plasma style etc.
It worked before reinstalling Manjaro, and I didn’t change my network.
Thank you.
Thank you.
Can’t replicate - works here.
You did update your system after reinstalling Manjaro?
btw:
no screenshots please!
Send them to a sharing site
like https://0x0.st
and post the link instead
yes, I did update everything.
any information that I can/should provide?
update: btw, I’ve reinstalled two days ago. It wasn’t working from the start, I thought it was a temporary thing. Everything else working fine tho.
I would not know where to start. Sorry!
All I can say: works here on a fully updated and almost stock Plasma installation running in a VM.
I just checked with various icon sets and cursor themes.
no worries, Thank you for your fast responses.
If it is fixed I’ll update my post/comment.
You are welcome.
just an example what I meant re uploading screenshots to a sharing site and providing the link:
here I fetched the Windows 10 icon pack
This does periodically happen, and it was already happening in the days of Plasma 5 as well.
It is not clear whether it’s a bug in the application for installing new components from store.kde.org, or whether it’s a server error at store.kde.org’s end itself. I am under the impression that it may be the latter.
Done! I’ll keep that in mind in my future posts. Thank you
Just to be sure, you meant posting link like this ^ (i.e. in blockquote), and not as plain text (which shows the actual image), right?
Yes, that did happen to me in plasma 5 as well, but it used to get fixed after a while or another try.
This time, it’s happening continuously for two days. So I thought there might be something wrong from my end.
Guess I’ll just wait.
thank you for your response.
Yes, correct - just like you did when you edited your post.
Or otherwise formatted - just not as plain text.
Although even that works - the image would appear as if you posted it here directly.
Thanks!
