Hey All,
I just installed Manjaro yesterday. I am loving the system. I had a lot of problems setting stuff up, but figured out almost everything. My only remaining problem is my network. When I reboot my computer it connects to the Wifi network right away, however, my connection upload and download B/s fluctuate between 0 and 1000. They mostly just stay at 0 B/s. I am currently on Linux515, I downgraded to linux510 to see if that helped. It didn’t.
I followed a NetworkManager guide: (I added spaces because I can’t provide links apparently)
linuxhint. com / arch_linux_network_manager
I followed this guys suggestions:
https:// archived.forum.manjaro. org/t/solved-internet-connectivity-issues/70146/2
None of that worked. So I am curious if anyone has any thoughts while I try to troubleshoot this. I want to use Manjaro, but if I can’t solve this network problem then I can’t use it.
It is definitely a Manjaro problem as when I switch to my Windows 10 partition the wifi is fine and also my MacBook sitting right next to my computer has perfectly fine internet and they are both connected to the same wifi network.
Here is system info:
inxi -Nxxxa
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Ralink MT7610U (Archer T2U 2.4G+5G WLAN Adapter type: USB
driver: mt76x0u bus-ID: 1-9:5 chip-ID: 148f:761a class-ID: 0000 serial: 1.0
inxi -Fazy ✔ 31s
Kernel: 5.15.28-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=883544ae-4caa-4007-bd04-ab6172e8d40c rw nvidia-drm.modeset=1
quiet apparmor=1 security=apparmor udev.log_priority=3
Desktop: KDE Plasma 5.24.3 tk: Qt 5.15.3 wm: kwin_wayland vt: 2 dm: SDDM
Type: Desktop System: MSI product: MS-7A71 v: 1.0
serial: <superuser required>
Mobo: MSI model: Z270-A PRO (MS-7A71) v: 1.0 serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: 1.30 date: 06/28/2017
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
status: Discharging
Info: model: Intel Core i5-7600K bits: 64 type: MCP arch: Kaby Lake
family: 6 model-id: 0x9E (158) stepping: 9 microcode: 0xEC
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 1397 high: 1900 min/max: 800/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 1900 2: 1792 3: 1098
4: 800 bogomips: 30409
Type: l1tf
STIBP: disabled, RSB filling
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Gigabyte driver: nvidia
v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: DVI-D-1,HDMI-A-1 empty: DP-1 bus-ID: 01:00.0
chip-ID: 10de:1c82 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.0
compositor: kwin_wayland driver: X: loaded: nvidia gpu: nvidia
d-rect: 3840x1080 display-ID: 0
Monitor-1: DVI-D-1 pos: primary,left res: 1920x1080 size: N/A
Monitor-2: HDMI-A-1 pos: right res: 1920x1080 size: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 510.54 direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
serial: <filter>
IF: wlp0s20f0u9 state: up mac: <filter>
Local Storage: total: 1.82 TiB used: 58.43 GiB (3.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HDS722020ALA330
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: B37B scheme: GPT
ID-1: / raw-size: 91.7 GiB size: 89.7 GiB (97.82%) used: 23.33 GiB (26.0%)
fs: ext4 dev: /dev/sda6 maj-min: 8:6
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 243 Uptime: 5m wakeups: 2 Memory: 15.59 GiB
used: 2.24 GiB (14.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1226 lib: 327 flatpak: 0
Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.13
I have also installed rtl88xxau-aircrack-dkms-git using pamac
as a driver for the Archer T2U. (saw it on another forum post I don’t have the link though)
Though I don’t know if it is working or not as when I do lsmod
I do not see 8821au. if I do grep 88
then I get an intel_uncore which isn’t important for this. I am not that experienced with AUR so I might have not installed it correctly even though there were no errors when installing and also I downloaded the headers for it.
