Network connection causes large boot time
Hi
I need help to fix large boot time
systemd-analyze
Startup finished in 2.186s (kernel) + 1min 36.933s (userspace) = 1min 39.120s
graphical.target reached after 1min 35.784s in userspace.
I think that the issue is related to this output
journalctl -b | grep wlan0.conf
oct. 29 17:48:51 family-pc systemd[1]: Expecting device /sys/subsystem/net/devices/wlan0.conf...
oct. 29 17:50:21 family-pc systemd[1]: sys-subsystem-net-devices-wlan0.conf.device: Job sys-subsystem-net-devices-wlan0.conf.device/start timed out.
oct. 29 17:50:21 family-pc systemd[1]: Timed out waiting for device /sys/subsystem/net/devices/wlan0.conf.
oct. 29 17:50:21 family-pc systemd[1]: Dependency failed for WPA supplicant daemon (for interface wlan0.conf).
oct. 29 17:50:21 family-pc systemd[1]: wpa_supplicant@wlan0.conf.service: Job wpa_supplicant@wlan0.conf.service/start failed with result 'dependency'.
oct. 29 17:50:21 family-pc systemd[1]: sys-subsystem-net-devices-wlan0.conf.device: Job sys-subsystem-net-devices-wlan0.conf.device/start failed with result 'timeout'.
there is no wlan0 device
  Kernel: 6.6.107-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=1325cf9e-d1ce-4793-982f-ab936c92fb48 rw quiet
    resume=UUID=bce1ed1a-aada-49c9-a865-88443882d3db
  Console: pty pts/0 DM: SDDM Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: BIOSTAR model: H61MGV3 v: 7.0 serial: N/A
    uuid: 03000200-0400-0500-0006-000700080009 BIOS: American Megatrends v: 4.6.5
    date: 03/20/2014
  Info: model: Intel Core i3-3220 socket: BGA1155 bits: 64 type: MT MCP
    arch: Ivy Bridge gen: core 3 level: v2 built: 2012-15 process: Intel 22nm
    family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1597 min/max: 1600/3300 base/boost: 3300/3800 scaling:
    driver: intel_cpufreq governor: schedutil volts: 3.3 V ext-clock: 100 MHz
    cores: 1: 1597 2: 1597 3: 1597 4: 1597 bogomips: 26350
  Flags-basic: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
    vulnerable
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics
    vendor: Biostar Microtech Intl Corp driver: i915 v: kernel arch: Gen-7
    process: Intel 22nm built: 2012-13 ports: active: VGA-1 empty: none
    bus-ID: 00:02.0 chip-ID: 8086:0152 class-ID: 0300
  Display: unspecified server: X.org v: 1.21.1.18 with: Xwayland v: 24.1.8
    driver: X: loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
    tty: 150x35
  Monitor-1: VGA-1 model: Samsung SA300/SA350 serial: <filter> built: 2011
    res: 1600x900 dpi: 92 gamma: 1.2 size: 443x249mm (17.44x9.8")
    diag: 508mm (20") ratio: 16:9 modes: max: 1600x900 min: 720x400
  API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
    device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus
    inactive: wayland,x11
  API: OpenGL v: 4.5 compat-v: 4.2 vendor: mesa v: 25.2.3-arch1.2
    note: console (EGL sourced) renderer: Mesa Intel HD Graphics 2500 (IVB GT1),
    llvmpipe (LLVM 20.1.8 256 bits)
  Info: Tools: api: eglinfo,glxinfo de: kscreen-console,kscreen-doctor
    x11: xprop,xrandr
    vendor: Biostar Microtech Intl Corp driver: snd_hda_intel v: kernel
    bus-ID: 00:1b.0 chip-ID: 8086:1c20 class-ID: 0403
  API: ALSA v: k6.6.107-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.8 status: off with: pipewire-media-session
    status: off tools: pw-cli
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: off with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
    vendor: Biostar Microtech Intl Corp driver: r8168 v: 8.055.00-NAPI
    modules: r8169 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
    bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Ralink RT2870/RT3070 Wireless Adapter driver: rt2800usb type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.1:3
    chip-ID: 148f:3070 class-ID: 0000 serial: <filter>
  IF: wlp0s29u1u1 state: up mac: <filter>
  Local Storage: total: 931.51 GiB used: 127.23 GiB (13.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-00WN4A0
    family: Blue (CMR) size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B sata: 3.1 speed: 3.0 Gb/s tech: HDD rpm: 7200
    serial: <filter> fw-rev: 1A01 temp: 36 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 1y 342d 14h cycles: 1608
  ID-1: / raw-size: 50.78 GiB size: 49.68 GiB (97.84%) used: 39.03 GiB (78.6%)
    fs: ext4 block-size: 4096 B dev: /dev/sda5 maj-min: 8:5
  ID-2: /home raw-size: 210.11 GiB size: 205.76 GiB (97.93%)
    used: 88.2 GiB (42.9%) fs: ext4 block-size: 4096 B dev: /dev/sda7
    maj-min: 8:7
  ID-1: swap-1 type: partition size: 10.74 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda6 maj-min: 8:6
  System Temperatures: cpu: 30.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Memory: total: 4 GiB available: 3.73 GiB used: 648.7 MiB (17.0%) igpu: 64 MiB
  Processes: 137 Power: uptime: 21m states: freeze,standby,mem,disk
    suspend: s2idle avail: shallow wakeups: 0 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 1.48 GiB Init: systemd v: 257
  Packages: 1758 pm: dpkg pkgs: 0 tools: apt,apt-get pm: pacman pkgs: 1751
    libs: 476 tools: octopi,pamac,yay pm: flatpak pkgs: 7 Compilers:
    clang: 20.1.8 gcc: 15.2.1 Shell: Bash (su) v: 5.3.3
    running-in: pty pts/0 (SSH) inxi: 3.3.39
That seems awfully over-specific.
Rather, examine the whole log - all entries - around that time frame - not just the lines where this file name is mentioned in.
Don’t filter for lines with this pattern only …
Might provide better context.
Your Wlan device doesn’t have this name - it is called
wlp0s29u1u1
as per your inxi output
So: where would that insistence to start a non existent device
wlan0
come from?
systemd-analyze blame
could shed some more light as well
thanks for the replying . Should I post all the journalctl -b output ?
sorry for my english
You should look at it - around that time frame where the issue seems to occur.
And if you can’t make sense of it - you may post it.
But not all of it - just the relevant time frame.
Post here
or to some file sharing web site -
they will give you a link to what you uploaded
which you can post here.
I feel lost. I don’t know where to start!!!
As of now, you don’t even know that what you think the problem is with your long boot time
is actually the real problem.
That the culprit is this wlan0.conf is, so far, just an assumption.
I don’t know either.
I would start by examining the whole log:
journalctl -b
and then search within that for any errors - or for your wlan0.conf
to find the time where this occurs - and see the context, the messages around that, before and after.
You can search by putting in a slash (/), followed by the search term.
… that is how you can search the contents of the log that is currently being listed.
You appear to be using Plasma - there may be some GUI tools to examine the logs
instead of this terminal approach.
I don’t know - I’m nor familiar enough with Plasma to give advice where to find these tools.
If it is any consolation:
I, too, have only a spinning disk in my machine.
And the cold boot time is … not very fast.
A minute and a half is normal - and then another minute or so to go from login to a functional browser (it needs to start, then ask for the password to unlock the encrypted passwords store …)
It takes time to ā€œscrapeā€ all that from a spinning disk. :smiling_face_with_sunglasses:
Spinning disks are reliable - but slow.
and your systen has got only 4 GB of RAM
for a system running Plasma that is very scarce.
I have twice that (8 GB) - and that is already precious little -
and I use half of that (4 GB) to run virtual machines.
… the VM’s start up way faster than the host system does … - the virtual disks are smaller and more contiguous …
Not so much (disk head) searching/moving required.
With a spinning disk, it is very much a mechanical system.
Reliable - but it takes time.
An SSD doesn’t have this limitation.
there is an error at time 17:50:21 related to sys-subsystem-net-devices-wlan0.conf.device time out but I can’ figure out what trigged the wlan0.conf.device
oct. 29 17:49:03 family-pc NetworkManager[542]: <info>  [1761756543.5932] device (wlp0s29u1u1): state change: ip-config -> ip-check (reason 'none', managed-type: 'ful>
oct. 29 17:49:03 family-pc NetworkManager[542]: <info>  [1761756543.5955] device (wlp0s29u1u1): state change: ip-check -> secondaries (reason 'none', managed-type: 'f>
oct. 29 17:49:03 family-pc NetworkManager[542]: <info>  [1761756543.5958] device (wlp0s29u1u1): state change: secondaries -> activated (reason 'none', managed-type: '>
oct. 29 17:49:03 family-pc NetworkManager[542]: <info>  [1761756543.5963] manager: NetworkManager state is now CONNECTED_SITE
oct. 29 17:49:03 family-pc NetworkManager[542]: <info>  [1761756543.5971] device (wlp0s29u1u1): Activation: successful, device activated.
oct. 29 17:49:04 family-pc NetworkManager[542]: <info>  [1761756544.1357] manager: NetworkManager state is now CONNECTED_GLOBAL
oct. 29 17:49:04 family-pc NetworkManager[542]: <info>  [1761756544.7734] manager: startup complete
oct. 29 17:49:06 family-pc NetworkManager[542]: <info>  [1761756546.9667] dhcp6 (wlp0s29u1u1): activation: beginning transaction (timeout in 45 seconds)
oct. 29 17:49:06 family-pc avahi-daemon[544]: Leaving mDNS multicast group on interface wlp0s29u1u1.IPv6 with address fe80::19c0:9faa:b6e3:f79.
oct. 29 17:49:06 family-pc avahi-daemon[544]: Joining mDNS multicast group on interface wlp0s29u1u1.IPv6 with address fd80::6695:8d03:c8f:aba6.
oct. 29 17:49:06 family-pc NetworkManager[542]: <info>  [1761756546.9680] policy: set 'Reseau300' (wlp0s29u1u1) as default for IPv6 routing and DNS
oct. 29 17:49:06 family-pc avahi-daemon[544]: Registering new address record for fd80::6695:8d03:c8f:aba6 on wlp0s29u1u1.*.
oct. 29 17:49:06 family-pc avahi-daemon[544]: Withdrawing address record for fe80::19c0:9faa:b6e3:f79 on wlp0s29u1u1.
oct. 29 17:49:07 family-pc NetworkManager[542]: <info>  [1761756547.0398] dhcp6 (wlp0s29u1u1): state changed new lease
oct. 29 17:49:08 family-pc systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
oct. 29 17:49:26 family-pc systemd-timesyncd[307]: Contacted time server 162.159.200.123:123 (2.manjaro.pool.ntp.org).
oct. 29 17:49:26 family-pc systemd-timesyncd[307]: Initial clock synchronization to Wed 2025-10-29 17:49:26.324941 CET.
oct. 29 17:49:27 family-pc systemd[1]: systemd-hostnamed.service: Deactivated successfully.
oct. 29 17:50:21 family-pc kernel: fbcon: Taking over console
oct. 29 17:50:21 family-pc systemd[1]: Reached target Network.
oct. 29 17:50:21 family-pc systemd[1]: Starting CUPS Scheduler...
oct. 29 17:50:21 family-pc systemd[1]: Starting OpenSSH Daemon...
oct. 29 17:50:21 family-pc systemd[1]: Starting Permit User Sessions...
oct. 29 17:50:21 family-pc kernel: Console: switching to colour frame buffer device 200x56
oct. 29 17:50:21 family-pc systemd[1]: systemd-vconsole-setup.service: Deactivated successfully.
oct. 29 17:50:21 family-pc systemd[1]: Stopped Virtual Console Setup.
oct. 29 17:50:21 family-pc systemd[1]: Stopping Virtual Console Setup...
oct. 29 17:50:21 family-pc systemd[1]: Starting Virtual Console Setup...
oct. 29 17:50:21 family-pc systemd[1]: Finished Virtual Console Setup.
oct. 29 17:50:21 family-pc systemd[1]: Finished Permit User Sessions.
oct. 29 17:50:21 family-pc systemd[1]: Started Command Scheduler.
oct. 29 17:50:21 family-pc systemd[1]: Started Simple Desktop Display Manager.
oct. 29 17:50:21 family-pc sshd[652]: Server listening on 0.0.0.0 port 22.
your actual network device was mentioned and activated
the other one (wherever it came from ) didn’t induce significant slow down
I can’t either.
But before you embark on a journey to find the cause:
is this the cause that causes your slow boot?
My answer:
no, it isn’t.
You use an HDD - as I do.
A spinning disk.
They are slow.
A minute or two until you get to the desktop … is normal.
as I said earlier
May be I’m wrong but I thing the issue is related to the waiting time for the mentioned device
`oct. 29 17:50:21 family-pc systemd[1]: Timed out waiting for device /sys/subsystem/net/devices/wlan0.conf.`
as there is a jump in the time from 17:49:27 to 17:50:21
You are not wrong.
But your conclusion, that that is the reason for your long boot time.
is still wrong - at least: inconclusive
Where is the useless wlan0.conf come from?
I don’t know.
It’s still not the reason for your slow boot …
maybe you are - maybe you are not
I don’t think you are.
But I don’t know for sure.
What’s in this file, if it exists?:
cat /sys/subsystem/net/devices/wlan0.conf
No such file or directory
There is some configuration you have which wants to start a device which you don’t even have - or which you do not have anymore.
I do not know how to find it.
Somewhere in /etc probably …
I searched for the message
sys subsystem net devices timeout
and read through some of the results.
here are a few that could be relevant - I can’t help further
[SOLVED] Timed out waiting for device sys-subsystem-net-devices- / Newbie Corner / Arch Linux Forums
netctl - ArchWiki
(this one should not be active, I think - NetworkManager is the default in Manjaro)
[SOLVED] a start job is running for sys-subsystem-net-devices.. / Newbie Corner / Arch Linux Forums
Solved: systemd boot waits 90 seconds on net-devices-eth0
@hafid
If you are unfamiliar with using the command-line to produce logs, manjaro-log-helper (a GUI application) may be helpful.
sudo pacman -S manjaro-log-helper
There is also this tutorial with focus on the more traditional methods for generating logs via a terminal:
I am guessing that you have an invalid configuration pointing to a non-existing network interface.
This could be caused by following a guide from somewhere on the interweb which assumes the wifi network device is wlan0 - which it rarely is - except maybe for a raspberry pi.
Probably! I don’t remember! may be a long time ago and just now I figure out that there is a boot time issue. I want to cancel the faulty configuration but I don’t know how.
I’d have advised to use mc or some other file managers search function …
Did you think of that?
It may be clumsy, but these commands should find something:
Search the entire /etc directory recursively for a file with that string (wlan0 or wlan0.conf) in it:
sudo grep -rnwl /etc/ -e wlan0
See what comes up.
Search for a file named wlan0.conf anywhwere in the /etc directory:
sudo find /etc -type f -name "wlan0.conf"
Search other directories instead of /etc
for example where all the default systemd service files are
sudo grep -rnwl /usr/lib/systemd/ -e wlan0
sudo find /usr/lib/systemd -type f -name "wlan0.conf"
You could try to search for a file with wlan0 as part of the filename
find /etc -name '*wlan0*'
Or for a file containing a reference to wlan0
grep -rl /etc 'wlan0'
Don’t be rash with the rm command - inspect the file - it could be innocent..
Note: expect permission errors if a file or folder is only accessible to a specific user or group.
I found the file /etc/systemd/system/multi-user.target.wants/wpa_supplicant@wlan0.conf.service
I have disabled the systemd service and reboot
systemd-analyze
Startup finished in 2.567s (kernel) + 16.490s (userspace) = 19.057s
graphical.target reached after 14.812s in userspace.
which is much much better! So thanks to everyone for the valuable help
