My pc is dual booting windows 10 and manjaro, ever since I installed manjaro, my network partly works and doesn’t work, If I open Google, it loads but only certain websites are working, I ran into the same problem on Windows, when I set a static IP, but my network is dynamic as far as I know, Also my network works perfectly fine on windows no lag or anything, also my networks works fully if I tether the Pc, my desktop doesn’t have wifi btw.
Kernel: 5.15.25-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=e830da85-8f33-443e-af61-bc21fb8de2a8 rw quiet splash apparmor=1
Desktop: GNOME 41.4 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Desktop System: Hewlett-Packard product: HP Compaq 8200 Elite SFF PC
v: N/A serial: <superuser required> Chassis: type: 6
Mobo: Hewlett-Packard model: 1495 serial: <superuser required>
UEFI: Hewlett-Packard v: J01 v02.15 date: 11/10/2011
RAM: total: 7.66 GiB used: 3.46 GiB (45.2%)
RAM Report:
Info: model: Intel Core i5-2400 bits: 64 type: MCP arch: Sandy Bridge
family: 6 model-id: 0x2A (42) stepping: 7 microcode: 0x2F
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 1681 high: 1900 min/max: 1600/3400 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1596 2: 1900 3: 1596
4: 1633 bogomips: 24755
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good
sep smx ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology
xtpr
Type: l1tf
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Hewlett-Packard driver: i915 v: kernel ports: active: VGA-1
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:0102 class-ID: 0300
Device-2: Generalplus GENERAL WEBCAM type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-1.4:3 chip-ID: 1b3f:2247
class-ID: 0102
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.0
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: VGA-1 model: HP ZR2240w serial: <filter> built: 2011
res: 1920x1080 dpi: 103 gamma: 1.2 size: 475x267mm (18.7x10.5")
diag: 545mm (21.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
OpenGL: renderer: Mesa DRI Intel HD Graphics 2000 (SNB GT1)
v: 3.3 Mesa 21.3.7 compat-v: 3.0 direct render: Yes
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
class-ID: 0102
Sound Server-1: ALSA v: k5.15.25-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.47 running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Hewlett-Packard
driver: e1000e v: kernel port: f060 bus-ID: 00:19.0 chip-ID: 8086:1502
class-ID: 0200
Local Storage: total: 931.51 GiB used: 35.34 GiB (3.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HUA721010KLA330
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: A94A scheme: GPT
ID-1: / raw-size: 252.7 GiB size: 247.67 GiB (98.01%)
used: 35.31 GiB (14.3%) fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: e830da85-8f33-443e-af61-bc21fb8de2a8
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 27.6 MiB (10.8%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: SYSTEM
uuid: 0A1B-0E17
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 676.97 GiB fs: ntfs label: hard drive
uuid: B44451A144516760
ID-3: /dev/sda4 maj-min: 8:4 size: 608 MiB fs: ntfs label: N/A
uuid: 561036A410368ACF
ID-4: /dev/sda5 maj-min: 8:5 size: 1000 MiB fs: ntfs label: WinRE_DRV
uuid: 44C41F38C41F2C24
Hub-1: 1-0:1 info: Full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.4:3 info: Generalplus GENERAL WEBCAM type: Video,Audio
power: 100mA chip-ID: 1b3f:2247 class-ID: 0102
Hub-3: 2-0:1 info: Full speed or root hub ports: 3 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.7:4 info: BY Tech Usb Gaming Keyboard type: Keyboard,HID
power: 500mA chip-ID: 258a:0016 class-ID: 0300
Device-2: 2-1.8:5 info: Sunplus Innovation Gaming mouse [Philips SPK9304]
type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 1.5 Mb/s power: 98mA chip-ID: 1bcf:08a0 class-ID: 0301
System Temperatures: cpu: 36.0 C mobo: N/A
Processes: 232 Uptime: 1d 1h 55m wakeups: 17 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1328
pacman: 1297 lib: 377 flatpak: 12 snap: 19 Shell: Zsh v: 5.8.1
running-in: terminator inxi: 3.3.13
Your inxi is incomplete.
Apart from this, if it works in Windows, make sure to shutdown it completely and not that “fastboot” feature.
how do I complete my inxi?
oh I just updated the whole thing
I turned off fast boot on windows but still there is only limited internet access on manjaro
Hanzel
March 13, 2022, 8:58pm
#7
Some hardware is initialized and not properly shut down by windows to help windows booting faster this can be the cause of this problem. See this article how to turn that feature off.
The network interface does not seem to have any ip4 connectivity, that might explain some sites working and others not. I’m not sure how to help you with that.
Hanzel
March 13, 2022, 9:04pm
#8
Your log might have some clues about the connection the command below will show the networkmanagers log and indicate what is going on:
journalctl --boot |grep NetworkManager
~ journalctl --boot |grep NetworkManager ✔
Mar 13 16:44:26 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204266.7727] NetworkManager (version 1.34.0-1) is starting... (for the first time)
Mar 13 16:44:26 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204266.8712] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
Mar 13 16:44:27 suriya-hpcompaq8200elitesffpc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 13 16:44:27 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204267.5850] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Mar 13 16:44:28 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204268.0507] manager[0x55ec667ac000]: monitoring kernel firmware directory '/lib/firmware'.
Mar 13 16:44:28 suriya-hpcompaq8200elitesffpc dbus-daemon[667]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.5' (uid=0 pid=668 comm="/usr/bin/NetworkManager --no-daemon ")
Mar 13 16:44:28 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204268.3166] hostname: hostname: using hostnamed
Mar 13 16:44:28 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204268.3166] hostname: hostname changed from (none) to "suriya-hpcompaq8200elitesffpc"
Mar 13 16:44:28 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204268.3573] dns-mgr[0x55ec66791250]: init: dns=default,systemd-resolved rc-manager=symlink
Mar 13 16:44:28 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204268.3576] manager[0x55ec667ac000]: rfkill: Wi-Fi hardware radio set enabled
Mar 13 16:44:28 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204268.3576] manager[0x55ec667ac000]: rfkill: WWAN hardware radio set enabled
Mar 13 16:44:30 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204270.1018] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.34.0-1/libnm-device-plugin-bluetooth.so)
Mar 13 16:44:30 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204270.1599] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.34.0-1/libnm-device-plugin-wwan.so)
Mar 13 16:44:30 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204270.2885] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.34.0-1/libnm-device-plugin-ovs.so)
Mar 13 16:44:30 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204270.3590] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.34.0-1/libnm-device-plugin-adsl.so)
Mar 13 16:44:30 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204270.7180] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.34.0-1/libnm-device-plugin-team.so)
Mar 13 16:44:30 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204270.9015] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.34.0-1/libnm-device-plugin-wifi.so)
Mar 13 16:44:30 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204270.9019] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
Mar 13 16:44:30 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204270.9020] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
Mar 13 16:44:30 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204270.9020] manager: Networking is enabled by state file
Mar 13 16:44:30 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204270.9666] dhcp-init: Using DHCP client 'internal'
Mar 13 16:44:30 suriya-hpcompaq8200elitesffpc dbus-daemon[667]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.5' (uid=0 pid=668 comm="/usr/bin/NetworkManager --no-daemon ")
Mar 13 16:44:31 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204271.0115] settings: Loaded settings plugin: keyfile (internal)
Mar 13 16:44:31 suriya-hpcompaq8200elitesffpc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 13 16:44:31 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204271.6273] device (lo): carrier: link connected
Mar 13 16:44:31 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204271.6277] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
Mar 13 16:44:31 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204271.6723] manager: (eno1): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
Mar 13 16:44:31 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204271.6733] device (eno1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 13 16:44:32 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204272.0529] ovsdb: disconnected from ovsdb
Mar 13 16:44:33 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204273.0327] modem-manager: ModemManager not available
Mar 13 16:44:33 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204273.1385] modem-manager: ModemManager now available
Mar 13 16:44:34 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204274.5080] device (eno1): carrier: link connected
Mar 13 16:44:34 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204274.5083] device (eno1): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
Mar 13 16:44:34 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204274.5093] policy: auto-activating connection 'Profile 1' (06b41dc8-97a9-43f0-9812-e0d95607aee8)
Mar 13 16:44:34 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204274.5100] device (eno1): Activation: starting connection 'Profile 1' (06b41dc8-97a9-43f0-9812-e0d95607aee8)
Mar 13 16:44:34 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204274.5101] device (eno1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 13 16:44:34 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204274.5105] manager: NetworkManager state is now CONNECTING
Mar 13 16:44:34 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204274.5107] device (eno1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 13 16:44:34 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204274.5116] device (eno1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mar 13 16:44:34 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204274.5121] dhcp4 (eno1): activation: beginning transaction (timeout in 45 seconds)
Mar 13 16:44:36 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204276.2178] dhcp6 (eno1): activation: beginning transaction (timeout in 45 seconds)
Mar 13 16:44:36 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204276.2256] dhcp6 (eno1): state changed unknown -> bound, address=2607:9880:2058:151::7e12
Mar 13 16:44:36 suriya-hpcompaq8200elitesffpc dbus-daemon[667]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.5' (uid=0 pid=668 comm="/usr/bin/NetworkManager --no-daemon ")
Mar 13 16:44:38 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204278.0387] device (eno1): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Mar 13 16:44:38 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204278.0944] device (eno1): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Mar 13 16:44:38 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204278.0947] device (eno1): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Mar 13 16:44:38 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204278.0952] manager: NetworkManager state is now CONNECTED_LOCAL
Mar 13 16:44:38 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204278.0957] manager: NetworkManager state is now CONNECTED_SITE
Mar 13 16:44:38 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204278.0958] policy: set 'Profile 1' (eno1) as default for IPv6 routing and DNS
Mar 13 16:44:38 suriya-hpcompaq8200elitesffpc dbus-daemon[667]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.5' (uid=0 pid=668 comm="/usr/bin/NetworkManager --no-daemon ")
Mar 13 16:44:38 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204278.2593] device (eno1): Activation: successful, device activated.
Mar 13 16:44:38 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204278.2602] manager: startup complete
Mar 13 16:44:38 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204278.9330] manager: NetworkManager state is now CONNECTED_GLOBAL
Mar 13 16:44:41 suriya-hpcompaq8200elitesffpc systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Mar 13 16:44:41 suriya-hpcompaq8200elitesffpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 13 16:44:41 suriya-hpcompaq8200elitesffpc kernel: audit: type=1131 audit(1647204281.545:110): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 13 16:44:45 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647204285.4720] agent-manager: agent[8ea4be1b5ca5c292,:1.20/org.gnome.Shell.NetworkAgent/120]: agent registered
Mar 13 17:06:46 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205606.0206] agent-manager: agent[26c3a6c2e5e87191,:1.66/org.gnome.Shell.NetworkAgent/1000]: agent registered
Mar 13 17:06:58 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <warn> [1647205618.1657] dhcp4 (eno1): request timed out
Mar 13 17:06:58 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205618.1657] dhcp4 (eno1): state changed unknown -> timeout
Mar 13 17:08:00 suriya-hpcompaq8200elitesffpc audit[668]: USYS_CONFIG pid=668 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-update uuid=06b41dc8-97a9-43f0-9812-e0d95607aee8 name=50726F66696C652031 args=connection.timestamp,ipv4.addresses,ipv4.method pid=1739 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mar 13 17:08:00 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205680.9401] audit: op="connection-update" uuid="06b41dc8-97a9-43f0-9812-e0d95607aee8" name="Profile 1" args="connection.timestamp,ipv4.addresses,ipv4.method" pid=1739 uid=1000 result="success"
Mar 13 17:08:00 suriya-hpcompaq8200elitesffpc kernel: audit: type=1111 audit(1647205680.937:166): pid=668 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-update uuid=06b41dc8-97a9-43f0-9812-e0d95607aee8 name=50726F66696C652031 args=connection.timestamp,ipv4.addresses,ipv4.method pid=1739 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mar 13 17:08:02 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205682.8638] device (eno1): state change: activated -> deactivating (reason 'user-requested', sys-iface-state: 'managed')
Mar 13 17:08:02 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205682.8640] manager: NetworkManager state is now DISCONNECTING
Mar 13 17:08:02 suriya-hpcompaq8200elitesffpc audit[668]: USYS_CONFIG pid=668 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=device-disconnect interface="eno1" ifindex=2 pid=1739 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mar 13 17:08:02 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205682.8646] audit: op="device-disconnect" interface="eno1" ifindex=2 pid=1739 uid=1000 result="success"
Mar 13 17:08:02 suriya-hpcompaq8200elitesffpc dbus-daemon[667]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.5' (uid=0 pid=668 comm="/usr/bin/NetworkManager --no-daemon ")
Mar 13 17:08:02 suriya-hpcompaq8200elitesffpc kernel: audit: type=1111 audit(1647205682.864:167): pid=668 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=device-disconnect interface="eno1" ifindex=2 pid=1739 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mar 13 17:08:02 suriya-hpcompaq8200elitesffpc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 13 17:08:02 suriya-hpcompaq8200elitesffpc kernel: audit: type=1130 audit(1647205682.874:168): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 13 17:08:03 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205683.5634] device (eno1): state change: deactivating -> disconnected (reason 'user-requested', sys-iface-state: 'managed')
Mar 13 17:08:03 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205683.5846] dhcp4 (eno1): canceled DHCP transaction
Mar 13 17:08:03 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205683.5847] dhcp4 (eno1): state changed timeout -> terminated
Mar 13 17:08:03 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205683.5850] dhcp6 (eno1): canceled DHCP transaction
Mar 13 17:08:03 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205683.5850] dhcp6 (eno1): state changed bound -> terminated
Mar 13 17:08:03 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205683.8910] manager: NetworkManager state is now DISCONNECTED
Mar 13 17:08:04 suriya-hpcompaq8200elitesffpc audit[668]: USYS_CONFIG pid=668 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-activate uuid=06b41dc8-97a9-43f0-9812-e0d95607aee8 name=50726F66696C652031 pid=1739 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mar 13 17:08:04 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205684.8437] device (eno1): Activation: starting connection 'Profile 1' (06b41dc8-97a9-43f0-9812-e0d95607aee8)
Mar 13 17:08:04 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205684.8438] audit: op="connection-activate" uuid="06b41dc8-97a9-43f0-9812-e0d95607aee8" name="Profile 1" pid=1739 uid=1000 result="success"
Mar 13 17:08:04 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205684.8439] device (eno1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 13 17:08:04 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205684.8441] manager: NetworkManager state is now CONNECTING
Mar 13 17:08:04 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205684.8442] device (eno1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 13 17:08:04 suriya-hpcompaq8200elitesffpc kernel: audit: type=1111 audit(1647205684.840:173): pid=668 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-activate uuid=06b41dc8-97a9-43f0-9812-e0d95607aee8 name=50726F66696C652031 pid=1739 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mar 13 17:08:04 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205684.8449] device (eno1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mar 13 17:08:04 suriya-hpcompaq8200elitesffpc audit[668]: SYSCALL arch=c000003e syscall=321 success=yes exit=23 a0=5 a1=7ffc24206320 a2=78 a3=7ffc24206320 items=0 ppid=1 pid=668 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" subj==unconfined key=(null)
Mar 13 17:08:04 suriya-hpcompaq8200elitesffpc kernel: audit: type=1300 audit(1647205684.844:174): arch=c000003e syscall=321 success=yes exit=23 a0=5 a1=7ffc24206320 a2=78 a3=7ffc24206320 items=0 ppid=1 pid=668 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" subj==unconfined key=(null)
Mar 13 17:08:04 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205684.8475] device (eno1): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Mar 13 17:08:04 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205684.8571] device (eno1): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Mar 13 17:08:04 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205684.8573] device (eno1): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Mar 13 17:08:04 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205684.8576] manager: NetworkManager state is now CONNECTED_LOCAL
Mar 13 17:08:04 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205684.8579] device (eno1): Activation: successful, device activated.
Mar 13 17:08:06 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205686.3457] dhcp6 (eno1): activation: beginning transaction (timeout in 45 seconds)
Mar 13 17:08:06 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205686.3469] manager: NetworkManager state is now CONNECTED_SITE
Mar 13 17:08:06 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205686.3470] policy: set 'Profile 1' (eno1) as default for IPv6 routing and DNS
Mar 13 17:08:07 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205687.0299] dhcp6 (eno1): state changed unknown -> bound, address=2607:9880:2058:151::7e12
Mar 13 17:08:11 suriya-hpcompaq8200elitesffpc NetworkManager[668]: <info> [1647205691.1238] manager: NetworkManager state is now CONNECTED_GLOBAL
Mar 13 17:08:12 suriya-hpcompaq8200elitesffpc systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Mar 13 17:08:12 suriya-hpcompaq8200elitesffpc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 13 17:08:12 suriya-hpcompaq8200elitesffpc kernel: audit: type=1131 audit(1647205692.877:183): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Hanzel
March 13, 2022, 9:18pm
#10
Does rebooting your network device change anything? The machine seems to want to get an IP4 address but it times out. (i’m going on the assumption that you need IP4 to connect.)
I figured it out, I just set my ipv4 to manual and set up a manual connection, thanks for all the help!
I used this link
[type or paste code here](https://linuxconfig.org/how-to-setup-a-static-ip-address-on-manjaro-linux)
to configure a manual connection
system
closed
March 16, 2022, 11:26am
#13
