Network and wifi are gone then restart kde
I installed KDE (I was leaving gnome) and everything was going well, I changed the DE, installed the new KDE programs, SSDM. until I restarted the notebook and the system stops recognizing my network, it is as if the driver disappeared, there is no Wi-fi connection option on my notebook, I tried via cable too and nothing. I’m on my cell phone now, what do I do?
inxi -Fazy
I tried to put the photo but I couldn’t:
“ sorry you cant embed media in this post”
Good, I dont want a photo :wink:
Please see this:
What should I do now?
Do these things …
heh. looks like the quote messed up the instruction.
paste code here
What code should I put here, sir?
Sorry I’m not an advanced user I don’t really know what to do, sorry
Sharing the complete output of inxi -Fazy is encouraged as is giving us some context about your system, and will not display private information. It was asked twice in this topic, “as is”, yet you decided to trim it down. With that decision you could have shared just
but then … is simple to get back just this reply
Please keep in mind the user is posting using his cellphone so the requested info is not that easy to provide by him/her…
Perhaps some instructions on how to save the info to a file then transfer it to his cellphone would help him/her to provide the info…
My first suggestion would be to use the Manjaro Log Helper (automated log generator GUI) and use the generated logfile as info after being transfered to the cellphone.
This computer that I have dual boot, each OS is on a different hd, in windows everything works normal, I don’t know if this information helps. I passed the result of the command to an external hd and here is all the output:
  Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: N/A
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
  root=UUID=22522a77-0c64-40db-a7c2-82deb48e2c6b rw quiet apparmor=1
  Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 info: latte-dock wm: kwin_x11
  dm: SDDM Distro: Manjaro Linux
  Type: Laptop System: Acer product: Aspire E5-573G v: V3.72 serial: <filter>
  Mobo: Acer model: ZORO_BH v: Type2 - A01 Board Version serial: <filter>
  UEFI [Legacy]: Insyde v: 1.37 date: 02/16/2016
  ID-1: BAT1 charge: 18.0 Wh condition: 18.0/37.0 Wh (49%) volts: 17.2/14.8
  model: SANYO AL15A32 type: Li-ion serial: <filter> status: Full
  Topology: Dual Core model: Intel Core i7-5500U bits: 64 type: MT MCP
  arch: Broadwell family: 6 model-id: 3D (61) stepping: 4 microcode: 2F
  L2 cache: 4096 KiB
  bogomips: 19207
  Speed: 1321 MHz min/max: 500/3000 MHz Core speeds (MHz): 1: 2394 2: 2400
  3: 2378 4: 2400
  Type: l1tf
  Device-1: Intel HD Graphics 5500 vendor: Acer Incorporated ALI driver: i915
  v: kernel bus ID: 00:02.0 chip ID: 8086:1616
  Device-2: NVIDIA GK208BM [GeForce 920M] driver: N/A
  alternate: nouveau, nvidia_drm, nvidia bus ID: 04:00.0 chip ID: 10de:1299
  Device-3: Sunplus Innovation HD WebCam type: USB driver: uvcvideo
  bus ID: 2-7:5 chip ID: 1bcf:2c81
  Display: x11 server: X.org 1.20.9 compositor: kwin_x11 driver: intel
  resolution: <xdpyinfo missing>
  OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 20.1.8
  direct render: Yes
  Device-1: Intel Broadwell-U Audio vendor: Acer Incorporated ALI
  driver: snd_hda_intel v: kernel bus ID: 00:03.0 chip ID: 8086:160c
  Device-2: Intel Wildcat Point-LP High Definition Audio
  vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
  bus ID: 00:1b.0 chip ID: 8086:9ca0
  Device-3: NVIDIA GK208 HDMI/DP Audio driver: snd_hda_intel v: kernel
  bus ID: 04:00.1 chip ID: 10de:0e0f
  Sound Server: ALSA v: k5.8.16-2-MANJARO
  vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 4000
  bus ID: 02:00.0 chip ID: 10ec:8168
  Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
  vendor: Lite-On driver: ath9k v: kernel port: 4000 bus ID: 03:00.0
  chip ID: 168c:0036
  IF: wlp3s0 state: down mac: <filter>
  Local Storage: total: 476.95 GiB used: 65.98 GiB (13.8%)
  ID-1: /dev/sda vendor: Lexar model: 256GB SSD size: 238.47 GiB block size:
  physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 117H
  scheme: MBR
  ID-2: /dev/sdb vendor: Lexar model: 256GB SSD size: 238.47 GiB block size:
  scheme: GPT
  ID-1: / raw size: 50.00 GiB size: 48.97 GiB (97.93%) used: 32.41 GiB (66.2%)
  fs: ext4 dev: /dev/sdb1
  ID-2: /home raw size: 188.47 GiB size: 184.52 GiB (97.90%)
  used: 33.56 GiB (18.2%) fs: ext4 dev: /dev/sdb2
  System Temperatures: cpu: 47.0 C mobo: N/A
  Processes: 244 Uptime: 1m Memory: 15.56 GiB used: 1.19 GiB (7.6%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages: 1627
  pacman: 1619 lib: 371 flatpak: 0 snap: 8 Shell: Bash v: 5.0.18
  running in: konsole inxi: 3.1.05
Please read the topics (and perhaps check what they say) that you get by clicking the link @bogdancovaciu gave above…
Ok, I will try to put it on the blacklist and see which one returns the internet
you know what, I give up. I’m going to reinstall the OS, I can’t do any of these things, everything is very complicated, thanks to those who helped me but I really give up
https://wiki.archlinux.org/index.php/Acer_Aspire_E5-573
Note the part of Kernel boot Parameters
Hey, I have had a similar problem. This happens when it is a dual boot(even if 2 separate drives) with windows being one of them. in the old archived forum, there was a topic on this.
It seems, when windows boots, it puts the Wifi Adapter into some special Hardware Flag (probably power saving or something similar), from which Linux is unable to activate/wake it up again. A hardware switch off and on solves the issue and then Linux is able to activate the wifi adapter again.
May be someone with advanced skills can figure out what is happening. I have multiple distros (like Suse, Endeavor, Manjaro), and all of them behave the same. Probably a kernel issue.
I thank everyone who answered and helped me here today, my solution in this case was to reinstall the operating system.
