Hi i installed manjaro few weeks ago and my system since then keep sending a pci port error, i tried updating my bios (fixed some other errors) but the pci one still going.
Some info of my system (Used [HowTo] get and post your System Info guide):
inxi -Fxz:
Kernel: 5.12.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: Xfce 4.16.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: TUF B360M-PLUS GAMING/BR v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 2811 date: 05/27/2020
Info: 6-Core model: Intel Core i5-9600KF bits: 64 type: MCP
arch: Kaby Lake note: check rev: D cache: L2: 9 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
bogomips: 44412
Speed: 800 MHz min/max: 800/4600 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 800 5: 800 6: 800
Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] driver: nvidia v: 460.80
bus-ID: 01:00.0
Display: x11 server: X,Org 1.20.11 driver: loaded: nvidia
resolution: 1920x1080~75Hz
OpenGL: renderer: GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA 460.80
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3
Device-2: NVIDIA TU106 High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 01:00.1
Sound Server-1: ALSA v: k5.12.2-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: no
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: efa0 bus-ID: 00:1f.6
Device-2: Realtek RTL8188EE Wireless Network Adapter driver: rtl8188ee
v: kernel port: 3000 bus-ID: 04:00.0
IF: wlp4s0 state: up mac: <filter>
Local Storage: total: 931.51 GiB used: 258.93 GiB (27.8%)
ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-75WN4A1
ID-1: / size: 892.26 GiB used: 258.93 GiB (29.0%) fs: ext4 dev: /dev/dm-0
mapped: luks-0f73e57b-b978-41d4-bc23-f53463ad9005
ID-2: /boot/efi size: 499 MiB used: 448 KiB (0.1%) fs: vfat dev: /dev/sda1
ID-1: swap-1 type: partition size: 3.91 GiB used: 0 KiB (0.0%)
dev: /dev/sda2
System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia temp: 47 C
Processes: 237 Uptime: 13m Memory: 15.56 GiB used: 2.5 GiB (16.1%)
Init: systemd Compilers: gcc: 10.2.0 Packages: 1213 Shell: Bash v: 5.1.8
inxi: 3.3.04
mhwd-kernel -li
Currently running: 5.12.2-1-MANJARO (linux512)
* linux414
* linux510
* linux512
mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2020.11.30 false PCI
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 1d57:ad17 Xenta Gaming Mouse
Bus 001 Device 002: ID 1a2c:2d23 China Resource Semico Co., Ltd Keyboard
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
lscpu
Arquitetura: x86_64
Modo(s) operacional da CPU: 32-bit, 64-bit
Ordem dos bytes: Little Endian
Tamanhos de endereço: 39 bits physical, 48 bits virtual
CPU(s): 6
Lista de CPU(s) on-line: 0-5
Thread(s) per nĂşcleo: 1
NĂşcleo(s) por soquete: 6
Soquete(s): 1
NĂł(s) de NUMA: 1
ID de fornecedor: GenuineIntel
FamĂlia da CPU: 6
Modelo: 158
Nome do modelo: Intel(R) Core(TM) i5-9600KF CPU @ 3.70GHz
Step: 13
CPU MHz: 3700.000
CPU MHz máx.: 4600,0000
CPU MHz mĂn.: 800,0000
BogoMIPS: 7402.02
cache de L1d: 192 KiB
cache de L1i: 192 KiB
cache de L2: 1,5 MiB
cache de L3: 9 MiB
CPU(s) de nĂł0 NUMA: 0-5
Vulnerability Itlb multihit: KVM: Mitigation: VMX unsupported
Vulnerability L1tf: Not affected
Vulnerability Mds: Not affected
Vulnerability Meltdown: Not affected
Vulnerability Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl and seccomp
Vulnerability Spectre v1: Mitigation; usercopy/swapgs barriers and __user pointer sanitization
Vulnerability Spectre v2: Mitigation; Enhanced IBRS, IBPB conditional, RSB filling
Vulnerability Srbds: Mitigation; TSX disabled
Vulnerability Tsx async abort: Mitigation; TSX disabled
Opções: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant
_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl est tm2 ssse3 sdbg fma cx16 xtpr pdcm
pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault invpcid_single ssbd ibrs ibpb stib
p ibrs_enhanced fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid mpx rdseed adx smap clflushopt intel_pt xsaveopt xsavec xgetbv1 xsaves dtherm ida arat p
ln pts hwp hwp_notify hwp_act_window hwp_epp md_clear flush_l1d arch_capabilities
dmesg
[ 0.000000] microcode: microcode updated early to revision 0xde, date = 2020-05-24
[ 0.000000] Linux version 5.12.2-1-MANJARO (builduser@LEGION) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Fri May 7 17:53:15 UTC 2021
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64 root=UUID=f8122e2b-5dc0-45ba-8e63-dc3143761763 rw quiet cryptdevice=UUID=0f73e57b-b978-41d4-bc23-f53463ad9005:luks-0f73e57b-b978-41d4-bc23-f53463ad9005 root=/dev/mapper/luks-0f73e57b-b978-41d4-bc23-f53463ad9005 apparmor=1 security=apparmor udev.log_priority=3 pcie_aspm=off
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
[ 0.000000] x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
[ 0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000000fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000001000-0x000000000008ffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000000090000-0x0000000000090fff] type 20
[ 0.000000] BIOS-e820: [mem 0x0000000000091000-0x000000000009efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000008d1a4fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000008d1a5000-0x000000008e9e7fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000008e9e8000-0x000000008ea65fff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x000000008ea66000-0x000000008eadbfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000008eadc000-0x000000008f44bfff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000008f44c000-0x000000008f50efff] type 20
[ 0.000000] BIOS-e820: [mem 0x000000008f50f000-0x000000008f50ffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000008f510000-0x000000008fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000046dffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.70 by American Megatrends
[ 0.000000] efi: ACPI 2.0=0x8ea02000 ACPI=0x8ea02000 SMBIOS=0x8f2a2000 SMBIOS 3.0=0x8f2a1000 MEMATTR=0x89065018 ESRT=0x8ac61d18
[ 0.000000] SMBIOS 3.2.1 present.
[ 0.000000] DMI: System manufacturer System Product Name/TUF B360M-PLUS GAMING/BR, BIOS 2811 05/27/2020
[ 0.000000] tsc: Detected 3700.000 MHz processor
[ 0.000000] tsc: Detected 3699.850 MHz TSC
[ 0.000005] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000008] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000013] last_pfn = 0x46e000 max_arch_pfn = 0x400000000
[ 0.000095] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000571] last_pfn = 0x8f510 max_arch_pfn = 0x400000000
[ 0.006459] esrt: Reserving ESRT space from 0x000000008ac61d18 to 0x000000008ac61d50.
[ 0.006462] e820: update [mem 0x8ac61000-0x8ac61fff] usable ==> reserved
[ 0.006473] check: Scanning 1 areas for low memory corruption
[ 0.006484] Using GB pages for direct mapping
[ 0.006892] Secure boot disabled
[ 0.006893] RAMDISK: [mem 0x3601d000-0x37005fff]
[ 0.006897] ACPI: Early table checksum verification disabled
[ 0.006899] ACPI: RSDP 0x000000008EA02000 000024 (v02 ALASKA)
[ 0.006902] ACPI: XSDT 0x000000008EA020A8 0000CC (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.006906] ACPI: FACP 0x000000008EA42428 000114 (v06 ALASKA A M I 01072009 AMI 00010013)
[ 0.006910] ACPI: DSDT 0x000000008EA02210 040218 (v02 ALASKA A M I 01072009 INTL 20160527)
[ 0.006913] ACPI: FACS 0x000000008EADB080 000040
[ 0.006915] ACPI: APIC 0x000000008EA42540 0000A0 (v04 ALASKA A M I 01072009 AMI 00010013)
[ 0.006917] ACPI: FPDT 0x000000008EA425E0 000044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.006919] ACPI: FIDT 0x000000008EA42628 00009C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.006921] ACPI: MCFG 0x000000008EA426C8 00003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.006924] ACPI: WSMT 0x000000008EA53128 000028 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.006926] ACPI: SSDT 0x000000008EA42760 001B1C (v02 CpuRef CpuSsdt 00003000 INTL 20160527)
[ 0.006928] ACPI: SSDT 0x000000008EA44280 003099 (v02 SaSsdt SaSsdt 00003000 INTL 20160527)
[ 0.006931] ACPI: SSDT 0x000000008EA47320 00232B (v02 PegSsd PegSsdt 00001000 INTL 20160527)
[ 0.006933] ACPI: HPET 0x000000008EA49650 000038 (v01 ALASKA A M I 00000002 01000013)
[ 0.006935] ACPI: SSDT 0x000000008EA49688 000FAE (v02 ALASKA Ther_Rvp 00001000 INTL 20160527)
[ 0.006937] ACPI: SSDT 0x000000008EA4A638 002FD0 (v02 INTEL xh_cfsd4 00000000 INTL 20160527)
[ 0.006940] ACPI: UEFI 0x000000008EA4D608 000042 (v01 ALASKA A M I 00000002 01000013)
[ 0.006942] ACPI: LPIT 0x000000008EA4D650 000094 (v01 ALASKA A M I 00000002 01000013)
[ 0.006944] ACPI: SSDT 0x000000008EA4D6E8 0027DE (v02 ALASKA PtidDevc 00001000 INTL 20160527)
[ 0.006946] ACPI: SSDT 0x000000008EA4FEC8 0014E2 (v02 ALASKA TbtTypeC 00000000 INTL 20160527)
[ 0.006949] ACPI: DBGP 0x000000008EA513B0 000034 (v01 ALASKA A M I 00000002 01000013)
[ 0.006951] ACPI: DBG2 0x000000008EA513E8 000054 (v00 ALASKA A M I 00000002 01000013)
[ 0.006953] ACPI: SSDT 0x000000008EA51440 001B67 (v02 ALASKA UsbCTabl 00001000 INTL 20160527)
[ 0.006955] ACPI: SSDT 0x000000008EA52FA8 000144 (v02 Intel ADebTabl 00001000 INTL 20160527)
[ 0.006958] ACPI: BGRT 0x000000008EA530F0 000038 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.006959] ACPI: Reserving FACP table memory at [mem 0x8ea42428-0x8ea4253b]
[ 0.006961] ACPI: Reserving DSDT table memory at [mem 0x8ea02210-0x8ea42427]
[ 0.006962] ACPI: Reserving FACS table memory at [mem 0x8eadb080-0x8eadb0bf]
[ 0.006962] ACPI: Reserving APIC table memory at [mem 0x8ea42540-0x8ea425df]
[ 0.006963] ACPI: Reserving FPDT table memory at [mem 0x8ea425e0-0x8ea42623]
[ 0.006964] ACPI: Reserving FIDT table memory at [mem 0x8ea42628-0x8ea426c3]
[ 0.006965] ACPI: Reserving MCFG table memory at [mem 0x8ea426c8-0x8ea42703]
[ 0.006965] ACPI: Reserving WSMT table memory at [mem 0x8ea53128-0x8ea5314f]
[ 0.006966] ACPI: Reserving SSDT table memory at [mem 0x8ea42760-0x8ea4427b]
[ 0.006967] ACPI: Reserving SSDT table memory at [mem 0x8ea44280-0x8ea47318]
[ 0.006968] ACPI: Reserving SSDT table memory at [mem 0x8ea47320-0x8ea4964a]
[ 0.006968] ACPI: Reserving HPET table memory at [mem 0x8ea49650-0x8ea49687]
[ 0.006969] ACPI: Reserving SSDT table memory at [mem 0x8ea49688-0x8ea4a635]
[ 0.006970] ACPI: Reserving SSDT table memory at [mem 0x8ea4a638-0x8ea4d607]
[ 0.006971] ACPI: Reserving UEFI table memory at [mem 0x8ea4d608-0x8ea4d649]
[ 0.006972] ACPI: Reserving LPIT table memory at [mem 0x8ea4d650-0x8ea4d6e3]
[ 0.006972] ACPI: Reserving SSDT table memory at [mem 0x8ea4d6e8-0x8ea4fec5]
[ 0.006973] ACPI: Reserving SSDT table memory at [mem 0x8ea4fec8-0x8ea513a9]
[ 0.006974] ACPI: Reserving DBGP table memory at [mem 0x8ea513b0-0x8ea513e3]
[ 0.006975] ACPI: Reserving DBG2 table memory at [mem 0x8ea513e8-0x8ea5143b]
[ 0.006976] ACPI: Reserving SSDT table memory at [mem 0x8ea51440-0x8ea52fa6]
[ 0.006976] ACPI: Reserving SSDT table memory at [mem 0x8ea52fa8-0x8ea530eb]
[ 0.006977] ACPI: Reserving BGRT table memory at [mem 0x8ea530f0-0x8ea53127]
[ 0.006987] ACPI: Local APIC address 0xfee00000
[ 0.007128] No NUMA configuration found
[ 0.007129] Faking a node at [mem 0x0000000000000000-0x000000046dffffff]
[ 0.007131] NODE_DATA(0) allocated [mem 0x46dffc000-0x46dffffff]
[ 0.007156] Zone ranges:
[ 0.007157] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.007158] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.007160] Normal [mem 0x0000000100000000-0x000000046dffffff]
[ 0.007161] Device empty
[ 0.007162] Movable zone start for each node
[ 0.007162] Early memory node ranges
[ 0.007163] node 0: [mem 0x0000000000001000-0x000000000008ffff]
[ 0.007164] node 0: [mem 0x0000000000091000-0x000000000009efff]
[ 0.007165] node 0: [mem 0x0000000000100000-0x000000008d1a4fff]
[ 0.007166] node 0: [mem 0x000000008f50f000-0x000000008f50ffff]
[ 0.007167] node 0: [mem 0x0000000100000000-0x000000046dffffff]
[ 0.007168] Initmem setup node 0 [mem 0x0000000000001000-0x000000046dffffff]
[ 0.007170] On node 0 totalpages: 4174147
[ 0.007171] DMA zone: 64 pages used for memmap
[ 0.007172] DMA zone: 23 pages reserved
[ 0.007172] DMA zone: 3997 pages, LIFO batch:0
[ 0.007394] DMA zone: 28771 pages in unavailable ranges
[ 0.007395] DMA32 zone: 8967 pages used for memmap
[ 0.007396] DMA32 zone: 573862 pages, LIFO batch:63
[ 0.011057] DMA32 zone: 11866 pages in unavailable ranges
[ 0.011057] Normal zone: 56192 pages used for memmap
[ 0.011058] Normal zone: 3596288 pages, LIFO batch:63
[ 0.036202] Normal zone: 8192 pages in unavailable ranges
[ 0.036488] ACPI: PM-Timer IO Port: 0x1808
[ 0.036489] ACPI: Local APIC address 0xfee00000
[ 0.036493] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.036494] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.036495] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.036495] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.036496] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[ 0.036497] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[ 0.036533] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ 0.036535] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.036537] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.036538] ACPI: IRQ0 used by override.
[ 0.036539] ACPI: IRQ9 used by override.
[ 0.036541] Using ACPI (MADT) for SMP configuration information
[ 0.036541] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.036546] e820: update [mem 0x87d7d000-0x87e70fff] usable ==> reserved
[ 0.036553] TSC deadline timer available
[ 0.036554] smpboot: Allowing 6 CPUs, 0 hotplug CPUs
[ 0.036569] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.036571] PM: hibernation: Registered nosave memory: [mem 0x00090000-0x00090fff]
[ 0.036572] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
[ 0.036574] PM: hibernation: Registered nosave memory: [mem 0x87d7d000-0x87e70fff]
[ 0.036575] PM: hibernation: Registered nosave memory: [mem 0x8ac61000-0x8ac61fff]
[ 0.036576] PM: hibernation: Registered nosave memory: [mem 0x8d1a5000-0x8e9e7fff]
[ 0.036577] PM: hibernation: Registered nosave memory: [mem 0x8e9e8000-0x8ea65fff]
[ 0.036578] PM: hibernation: Registered nosave memory: [mem 0x8ea66000-0x8eadbfff]
[ 0.036578] PM: hibernation: Registered nosave memory: [mem 0x8eadc000-0x8f44bfff]
[ 0.036579] PM: hibernation: Registered nosave memory: [mem 0x8f44c000-0x8f50efff]
[ 0.036580] PM: hibernation: Registered nosave memory: [mem 0x8f510000-0x8fffffff]
[ 0.036581] PM: hibernation: Registered nosave memory: [mem 0x90000000-0xdfffffff]
[ 0.036581] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[ 0.036582] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
[ 0.036583] PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[ 0.036583] PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[ 0.036584] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.036584] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[ 0.036585] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
[ 0.036586] PM: hibernation: Registered nosave memory: [mem 0xfed04000-0xfedfffff]
[ 0.036586] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.036587] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[ 0.036587] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.036589] [mem 0x90000000-0xdfffffff] available for PCI devices
[ 0.036589] Booting paravirtualized kernel on bare hardware
[ 0.036591] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.040413] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:6 nr_node_ids:1
[ 0.040551] percpu: Embedded 56 pages/cpu s192512 r8192 d28672 u262144
[ 0.040556] pcpu-alloc: s192512 r8192 d28672 u262144 alloc=1*2097152
[ 0.040558] pcpu-alloc: [0] 0 1 2 3 4 5 - -
[ 0.040574] Built 1 zonelists, mobility grouping on. Total pages: 4108901
[ 0.040576] Policy zone: Normal
[ 0.040577] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64 root=UUID=f8122e2b-5dc0-45ba-8e63-dc3143761763 rw quiet cryptdevice=UUID=0f73e57b-b978-41d4-bc23-f53463ad9005:luks-0f73e57b-b978-41d4-bc23-f53463ad9005 root=/dev/mapper/luks-0f73e57b-b978-41d4-bc23-f53463ad9005 apparmor=1 security=apparmor udev.log_priority=3 pcie_aspm=off
[ 0.040648] PCIe ASPM is disabled
[ 0.041472] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.041913] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.042065] mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
[ 0.081425] Memory: 16216824K/16696588K available (14344K kernel code, 2065K rwdata, 4920K rodata, 1652K init, 4296K bss, 479504K reserved, 0K cma-reserved)
[ 0.081431] random: get_random_u64 called from __kmem_cache_create+0x22/0x530 with crng_init=0
[ 0.081521] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.081531] ftrace: allocating 42146 entries in 165 pages
[ 0.092385] ftrace: allocated 165 pages with 4 groups
[ 0.092458] rcu: Preemptible hierarchical RCU implementation.
[ 0.092459] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.092459] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=6.
[ 0.092460] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.092461] Trampoline variant of Tasks RCU enabled.
[ 0.092462] Rude variant of Tasks RCU enabled.
[ 0.092462] Tracing variant of Tasks RCU enabled.
[ 0.092462] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.092463] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.095142] NR_IRQS: 20736, nr_irqs: 1536, preallocated irqs: 16
[ 0.095557] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[ 0.095684] Console: colour dummy device 80x25
[ 0.095696] printk: console [tty0] enabled
[ 0.095709] ACPI: Core revision 20210105
[ 0.096031] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[ 0.096120] APIC: Switch to symmetric I/O mode setup
[ 0.097373] x2apic: IRQ remapping doesn't support X2APIC mode
[ 0.102219] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.116065] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x6aa99074b1c, max_idle_ns: 881590506587 ns
[ 0.116069] Calibrating delay loop (skipped), value calculated using timer frequency.. 7402.02 BogoMIPS (lpj=12332833)
[ 0.116071] pid_max: default: 32768 minimum: 301
[ 0.117511] efi: memattr: Entry attributes invalid: RO and XP bits both cleared
[ 0.117513] efi: memattr: ! 0x000000090000-0x000000090fff [Runtime Code|RUN| | | | | | | | | | | | | ]
[ 0.119158] LSM: Security Framework initializing
[ 0.119162] Yama: becoming mindful.
[ 0.119177] AppArmor: AppArmor initialized
[ 0.119211] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.119240] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.119428] x86/cpu: VMX (outside TXT) disabled by BIOS
[ 0.119429] x86/cpu: SGX disabled by BIOS
[ 0.119433] CPU0: Thermal monitoring enabled (TM1)
[ 0.119473] process: using mwait in idle threads
[ 0.119475] Last level iTLB entries: 4KB 128, 2MB 8, 4MB 8
[ 0.119476] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[ 0.119479] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.119481] Spectre V2 : Mitigation: Enhanced IBRS
[ 0.119481] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.119482] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.119484] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.119484] TAA: Mitigation: TSX disabled
[ 0.119486] SRBDS: Mitigation: TSX disabled
[ 0.119652] Freeing SMP alternatives memory: 36K
[ 0.120414] smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 1217
[ 0.120430] smpboot: CPU0: Intel(R) Core(TM) i5-9600KF CPU @ 3.70GHz (family: 0x6, model: 0x9e, stepping: 0xd)
[ 0.120531] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[ 0.120538] ... version: 4
[ 0.120539] ... bit width: 48
[ 0.120539] ... generic registers: 8
[ 0.120540] ... value mask: 0000ffffffffffff
[ 0.120540] ... max period: 00007fffffffffff
[ 0.120541] ... fixed-purpose events: 3
[ 0.120541] ... event mask: 00000007000000ff
[ 0.120609] rcu: Hierarchical SRCU implementation.
[ 0.121061] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.121099] smp: Bringing up secondary CPUs ...
[ 0.121165] x86: Booting SMP configuration:
[ 0.121166] .... node #0, CPUs: #1 #2 #3 #4 #5
[ 0.127593] smp: Brought up 1 node, 6 CPUs
[ 0.127593] smpboot: Max logical packages: 1
[ 0.127593] smpboot: Total of 6 processors activated (44415.12 BogoMIPS)
[ 0.129820] devtmpfs: initialized
[ 0.129820] x86/mm: Memory block size: 128MB
[ 0.130027] PM: Registering ACPI NVS region [mem 0x8ea66000-0x8eadbfff] (483328 bytes)
[ 0.130027] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.130027] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.130027] pinctrl core: initialized pinctrl subsystem
[ 0.130027] PM: RTC time: 22:04:46, date: 2021-05-26
[ 0.130027] NET: Registered protocol family 16
[ 0.130027] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.130027] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.130125] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.130130] audit: initializing netlink subsys (disabled)
[ 0.130135] audit: type=2000 audit(1622066686.033:1): state=initialized audit_enabled=0 res=1
[ 0.130135] thermal_sys: Registered thermal governor 'fair_share'
[ 0.130135] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.130135] thermal_sys: Registered thermal governor 'step_wise'
[ 0.130135] thermal_sys: Registered thermal governor 'user_space'
[ 0.130135] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.130135] cpuidle: using governor ladder
[ 0.130135] cpuidle: using governor menu
[ 0.130135] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.130135] ACPI: bus type PCI registered
[ 0.130135] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.130135] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.130135] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.130135] PCI: Using configuration type 1 for base access
[ 0.130354] Kprobes globally optimized
[ 0.130356] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.130356] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.130356] ACPI: Added _OSI(Module Device)
[ 0.130356] ACPI: Added _OSI(Processor Device)
[ 0.130356] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.130356] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.130356] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.130356] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.130356] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.195336] ACPI: 10 ACPI AML tables successfully acquired and loaded
[ 0.201145] ACPI: Dynamic OEM Table Load:
[ 0.201150] ACPI: SSDT 0xFFFF8C2D4090B500 0000F4 (v02 PmRef Cpu0Psd 00003000 INTL 20160527)
[ 0.201974] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[ 0.203394] ACPI: Dynamic OEM Table Load:
[ 0.203398] ACPI: SSDT 0xFFFF8C2D40EDB800 000400 (v02 PmRef Cpu0Cst 00003001 INTL 20160527)
[ 0.204315] ACPI: Dynamic OEM Table Load:
[ 0.204319] ACPI: SSDT 0xFFFF8C2D408EE800 0006EC (v02 PmRef Cpu0Ist 00003000 INTL 20160527)
[ 0.205323] ACPI: Dynamic OEM Table Load:
[ 0.205327] ACPI: SSDT 0xFFFF8C2D40E58E00 000133 (v02 PmRef Cpu0Hwp 00003000 INTL 20160527)
[ 0.206152] ACPI: Dynamic OEM Table Load:
[ 0.206156] ACPI: SSDT 0xFFFF8C2D408ED800 000724 (v02 PmRef HwpLvt 00003000 INTL 20160527)
[ 0.207205] ACPI: Dynamic OEM Table Load:
[ 0.207209] ACPI: SSDT 0xFFFF8C2D408EB000 0005FC (v02 PmRef ApIst 00003000 INTL 20160527)
[ 0.208172] ACPI: Dynamic OEM Table Load:
[ 0.208175] ACPI: SSDT 0xFFFF8C2D40EDA000 000317 (v02 PmRef ApHwp 00003000 INTL 20160527)
[ 0.209139] ACPI: Dynamic OEM Table Load:
[ 0.209144] ACPI: SSDT 0xFFFF8C2D40E95000 000AB0 (v02 PmRef ApPsd 00003000 INTL 20160527)
[ 0.210583] ACPI: Dynamic OEM Table Load:
[ 0.210587] ACPI: SSDT 0xFFFF8C2D40ED8400 00030A (v02 PmRef ApCst 00003000 INTL 20160527)
[ 0.214629] ACPI: Interpreter enabled
[ 0.214661] ACPI: (supports S0 S3 S4 S5)
[ 0.214662] ACPI: Using IOAPIC for interrupt routing
[ 0.214692] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.215744] ACPI: Enabled 8 GPEs in block 00 to 7F
[ 0.227402] ACPI: PM: Power Resource [USBC] (on)
[ 0.229835] ACPI: PM: Power Resource [V0PR] (on)
[ 0.230183] ACPI: PM: Power Resource [V1PR] (on)
[ 0.230524] ACPI: PM: Power Resource [V2PR] (on)
[ 0.235830] ACPI: PM: Power Resource [WRST] (on)
[ 0.238334] ACPI: PM: Power Resource [FN00] (off)
[ 0.238408] ACPI: PM: Power Resource [FN01] (off)
[ 0.238480] ACPI: PM: Power Resource [FN02] (off)
[ 0.238550] ACPI: PM: Power Resource [FN03] (off)
[ 0.238620] ACPI: PM: Power Resource [FN04] (off)
[ 0.239091] ACPI: PM: Power Resource [PIN] (off)
[ 0.239474] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[ 0.239480] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig Segments MSI EDR HPX-Type3]
[ 0.239567] acpi PNP0A08:00: _OSC: not requesting OS control; OS requires [ExtendedConfig ASPM ClockPM MSI]
[ 0.240357] PCI host bridge to bus 0000:00
[ 0.240358] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.240360] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.240361] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.240362] pci_bus 0000:00: root bus resource [mem 0x90000000-0xdfffffff window]
[ 0.240363] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[ 0.240364] pci_bus 0000:00: root bus resource [bus 00-fe]
[ 0.240380] pci 0000:00:00.0: [8086:3ec2] type 00 class 0x060000
[ 0.240527] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[ 0.240558] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.240943] pci 0000:00:14.0: [8086:a36d] type 00 class 0x0c0330
[ 0.240957] pci 0000:00:14.0: reg 0x10: [mem 0xa4320000-0xa432ffff 64bit]
[ 0.241008] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.241577] pci 0000:00:14.2: [8086:a36f] type 00 class 0x050000
[ 0.241592] pci 0000:00:14.2: reg 0x10: [mem 0xa4336000-0xa4337fff 64bit]
[ 0.241601] pci 0000:00:14.2: reg 0x18: [mem 0xa433c000-0xa433cfff 64bit]
[ 0.241744] pci 0000:00:16.0: [8086:a360] type 00 class 0x078000
[ 0.241761] pci 0000:00:16.0: reg 0x10: [mem 0xa433b000-0xa433bfff 64bit]
[ 0.241824] pci 0000:00:16.0: PME# supported from D3hot
[ 0.242077] pci 0000:00:17.0: [8086:a352] type 00 class 0x010601
[ 0.242087] pci 0000:00:17.0: reg 0x10: [mem 0xa4334000-0xa4335fff]
[ 0.242093] pci 0000:00:17.0: reg 0x14: [mem 0xa433a000-0xa433a0ff]
[ 0.242099] pci 0000:00:17.0: reg 0x18: [io 0x5050-0x5057]
[ 0.242105] pci 0000:00:17.0: reg 0x1c: [io 0x5040-0x5043]
[ 0.242111] pci 0000:00:17.0: reg 0x20: [io 0x5020-0x503f]
[ 0.242116] pci 0000:00:17.0: reg 0x24: [mem 0xa4339000-0xa43397ff]
[ 0.242148] pci 0000:00:17.0: PME# supported from D3hot
[ 0.242343] pci 0000:00:1b.0: [8086:a32c] type 01 class 0x060400
[ 0.242411] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.242747] pci 0000:00:1c.0: [8086:a33c] type 01 class 0x060400
[ 0.242806] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.243118] pci 0000:00:1c.5: [8086:a33d] type 01 class 0x060400
[ 0.243186] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[ 0.243208] pci 0000:00:1c.5: PTM enabled (root), 4ns granularity
[ 0.243503] pci 0000:00:1d.0: [8086:a330] type 01 class 0x060400
[ 0.243571] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.243904] pci 0000:00:1f.0: [8086:a308] type 00 class 0x060100
[ 0.244211] pci 0000:00:1f.3: [8086:a348] type 00 class 0x040300
[ 0.244240] pci 0000:00:1f.3: reg 0x10: [mem 0xa4330000-0xa4333fff 64bit]
[ 0.244276] pci 0000:00:1f.3: reg 0x20: [mem 0xa4100000-0xa41fffff 64bit]
[ 0.244349] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ 0.245422] pci 0000:00:1f.4: [8086:a323] type 00 class 0x0c0500
[ 0.245444] pci 0000:00:1f.4: reg 0x10: [mem 0xa4338000-0xa43380ff 64bit]
[ 0.245470] pci 0000:00:1f.4: reg 0x20: [io 0xefa0-0xefbf]
[ 0.245638] pci 0000:00:1f.5: [8086:a324] type 00 class 0x0c8000
[ 0.245651] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[ 0.245788] pci 0000:00:1f.6: [8086:15bc] type 00 class 0x020000
[ 0.245815] pci 0000:00:1f.6: reg 0x10: [mem 0xa4300000-0xa431ffff]
[ 0.245955] pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold
[ 0.246089] pci 0000:01:00.0: [10de:1f08] type 00 class 0x030000
[ 0.246099] pci 0000:01:00.0: reg 0x10: [mem 0xa3000000-0xa3ffffff]
[ 0.246107] pci 0000:01:00.0: reg 0x14: [mem 0x90000000-0x9fffffff 64bit pref]
[ 0.246115] pci 0000:01:00.0: reg 0x1c: [mem 0xa0000000-0xa1ffffff 64bit pref]
[ 0.246121] pci 0000:01:00.0: reg 0x24: [io 0x4000-0x407f]
[ 0.246126] pci 0000:01:00.0: reg 0x30: [mem 0xa4000000-0xa407ffff pref]
[ 0.246142] pci 0000:01:00.0: BAR 1: assigned to efifb
[ 0.246173] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 0.246217] pci 0000:01:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x16 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[ 0.246255] pci 0000:01:00.1: [10de:10f9] type 00 class 0x040300
[ 0.246264] pci 0000:01:00.1: reg 0x10: [mem 0xa4080000-0xa4083fff]
[ 0.246351] pci 0000:01:00.2: [10de:1ada] type 00 class 0x0c0330
[ 0.246363] pci 0000:01:00.2: reg 0x10: [mem 0xa2000000-0xa203ffff 64bit pref]
[ 0.246376] pci 0000:01:00.2: reg 0x1c: [mem 0xa2040000-0xa204ffff 64bit pref]
[ 0.246418] pci 0000:01:00.2: PME# supported from D0 D3hot D3cold
[ 0.246455] pci 0000:01:00.3: [10de:1adb] type 00 class 0x0c8000
[ 0.246463] pci 0000:01:00.3: reg 0x10: [mem 0xa4084000-0xa4084fff]
[ 0.246516] pci 0000:01:00.3: PME# supported from D0 D3hot D3cold
[ 0.246547] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.246549] pci 0000:00:01.0: bridge window [io 0x4000-0x4fff]
[ 0.246551] pci 0000:00:01.0: bridge window [mem 0xa3000000-0xa40fffff]
[ 0.246553] pci 0000:00:01.0: bridge window [mem 0x90000000-0xa20fffff 64bit pref]
[ 0.246621] acpiphp: Slot [1] registered
[ 0.246630] pci 0000:00:1b.0: PCI bridge to [bus 02]
[ 0.246690] acpiphp: Slot [1-1] registered
[ 0.246693] pci 0000:00:1c.0: PCI bridge to [bus 03]
[ 0.246773] pci 0000:04:00.0: [10ec:8179] type 00 class 0x028000
[ 0.246790] pci 0000:04:00.0: reg 0x10: [io 0x3000-0x30ff]
[ 0.246812] pci 0000:04:00.0: reg 0x18: [mem 0xa4200000-0xa4203fff 64bit]
[ 0.246914] pci 0000:04:00.0: supports D1 D2
[ 0.246915] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.247001] pci 0000:00:1c.5: PCI bridge to [bus 04]
[ 0.247007] pci 0000:00:1c.5: bridge window [io 0x3000-0x3fff]
[ 0.247009] pci 0000:00:1c.5: bridge window [mem 0xa4200000-0xa42fffff]
[ 0.247070] acpiphp: Slot [1-2] registered
[ 0.247080] pci 0000:00:1d.0: PCI bridge to [bus 05]
[ 0.248298] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.248375] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *1
[ 0.248449] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.248523] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.248597] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.248670] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.248744] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.248817] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 11 12 14 15) *0
[ 0.253481] iommu: Default domain type: Translated
[ 0.253490] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[ 0.253490] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.253490] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.253490] vgaarb: loaded
[ 0.253490] SCSI subsystem initialized
[ 0.253490] libata version 3.00 loaded.
[ 0.253490] ACPI: bus type USB registered
[ 0.253490] usbcore: registered new interface driver usbfs
[ 0.253490] usbcore: registered new interface driver hub
[ 0.253490] usbcore: registered new device driver usb
[ 0.253490] pps_core: LinuxPPS API ver. 1 registered
[ 0.253490] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.253490] PTP clock support registered
[ 0.253490] EDAC MC: Ver: 3.0.0
[ 0.253490] Registered efivars operations
[ 0.253490] NetLabel: Initializing
[ 0.253490] NetLabel: domain hash size = 128
[ 0.253490] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.253490] NetLabel: unlabeled traffic allowed by default
[ 0.253490] PCI: Using ACPI for IRQ routing
[ 0.296451] PCI: pci_cache_line_size set to 64 bytes
[ 0.296524] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[ 0.296525] e820: reserve RAM buffer [mem 0x87d7d000-0x87ffffff]
[ 0.296526] e820: reserve RAM buffer [mem 0x8ac61000-0x8bffffff]
[ 0.296527] e820: reserve RAM buffer [mem 0x8d1a5000-0x8fffffff]
[ 0.296528] e820: reserve RAM buffer [mem 0x8f510000-0x8fffffff]
[ 0.296529] e820: reserve RAM buffer [mem 0x46e000000-0x46fffffff]
[ 0.296616] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.296621] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[ 0.299401] clocksource: Switched to clocksource tsc-early
[ 0.304200] VFS: Disk quotas dquot_6.6.0
[ 0.304210] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.304272] AppArmor: AppArmor Filesystem Enabled
[ 0.304303] pnp: PnP ACPI init
[ 0.304380] system 00:00: [mem 0x40000000-0x403fffff] could not be reserved
[ 0.304385] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.304545] system 00:01: [io 0x0290-0x029f] has been reserved
[ 0.304548] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.304979] pnp 00:02: [dma 0 disabled]
[ 0.305005] pnp 00:02: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.305092] system 00:03: [io 0x0680-0x069f] has been reserved
[ 0.305095] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.305191] system 00:04: [io 0x1854-0x1857] has been reserved
[ 0.305193] system 00:04: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.305345] system 00:05: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.305347] system 00:05: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.305349] system 00:05: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.305350] system 00:05: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.305351] system 00:05: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.305353] system 00:05: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.305354] system 00:05: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.305355] system 00:05: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.305357] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.305555] system 00:06: [io 0x1800-0x18fe] could not be reserved
[ 0.305557] system 00:06: [mem 0xfd000000-0xfd69ffff] has been reserved
[ 0.305559] system 00:06: [mem 0xfd6c0000-0xfd6cffff] has been reserved
[ 0.305560] system 00:06: [mem 0xfd6f0000-0xfdffffff] has been reserved
[ 0.305561] system 00:06: [mem 0xfe000000-0xfe01ffff] could not be reserved
[ 0.305562] system 00:06: [mem 0xfe200000-0xfe7fffff] has been reserved
[ 0.305564] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[ 0.305566] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.305832] system 00:07: [io 0x2000-0x20fe] has been reserved
[ 0.305835] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.306961] system 00:08: [mem 0xfd6e0000-0xfd6effff] has been reserved
[ 0.306963] system 00:08: [mem 0xfd6d0000-0xfd6dffff] has been reserved
[ 0.306964] system 00:08: [mem 0xfd6b0000-0xfd6bffff] has been reserved
[ 0.306965] system 00:08: [mem 0xfd6a0000-0xfd6affff] has been reserved
[ 0.306968] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.307799] pnp: PnP ACPI: found 9 devices
[ 0.312966] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.313001] NET: Registered protocol family 2
[ 0.313083] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.313141] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.313264] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.313320] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.313372] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[ 0.313466] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.313500] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.313540] NET: Registered protocol family 1
[ 0.313543] NET: Registered protocol family 44
[ 0.313547] pci 0000:00:1b.0: bridge window [io 0x1000-0x0fff] to [bus 02] add_size 1000
[ 0.313549] pci 0000:00:1b.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02] add_size 200000 add_align 100000
[ 0.313551] pci 0000:00:1b.0: bridge window [mem 0x00100000-0x000fffff] to [bus 02] add_size 200000 add_align 100000
[ 0.313553] pci 0000:00:1d.0: bridge window [io 0x1000-0x0fff] to [bus 05] add_size 1000
[ 0.313555] pci 0000:00:1d.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 05] add_size 200000 add_align 100000
[ 0.313556] pci 0000:00:1d.0: bridge window [mem 0x00100000-0x000fffff] to [bus 05] add_size 200000 add_align 100000
[ 0.313561] pci 0000:00:1b.0: BAR 14: assigned [mem 0xa2100000-0xa22fffff]
[ 0.313564] pci 0000:00:1b.0: BAR 15: assigned [mem 0xa2300000-0xa24fffff 64bit pref]
[ 0.313565] pci 0000:00:1d.0: BAR 14: assigned [mem 0xa2500000-0xa26fffff]
[ 0.313568] pci 0000:00:1d.0: BAR 15: assigned [mem 0xa2700000-0xa28fffff 64bit pref]
[ 0.313569] pci 0000:00:1b.0: BAR 13: assigned [io 0x6000-0x6fff]
[ 0.313570] pci 0000:00:1d.0: BAR 13: assigned [io 0x7000-0x7fff]
[ 0.313573] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.313574] pci 0000:00:01.0: bridge window [io 0x4000-0x4fff]
[ 0.313576] pci 0000:00:01.0: bridge window [mem 0xa3000000-0xa40fffff]
[ 0.313578] pci 0000:00:01.0: bridge window [mem 0x90000000-0xa20fffff 64bit pref]
[ 0.313580] pci 0000:00:1b.0: PCI bridge to [bus 02]
[ 0.313587] pci 0000:00:1b.0: bridge window [io 0x6000-0x6fff]
[ 0.313590] pci 0000:00:1b.0: bridge window [mem 0xa2100000-0xa22fffff]
[ 0.313592] pci 0000:00:1b.0: bridge window [mem 0xa2300000-0xa24fffff 64bit pref]
[ 0.313596] pci 0000:00:1c.0: PCI bridge to [bus 03]
[ 0.313602] pci 0000:00:1c.5: PCI bridge to [bus 04]
[ 0.313604] pci 0000:00:1c.5: bridge window [io 0x3000-0x3fff]
[ 0.313606] pci 0000:00:1c.5: bridge window [mem 0xa4200000-0xa42fffff]
[ 0.313611] pci 0000:00:1d.0: PCI bridge to [bus 05]
[ 0.313614] pci 0000:00:1d.0: bridge window [io 0x7000-0x7fff]
[ 0.313617] pci 0000:00:1d.0: bridge window [mem 0xa2500000-0xa26fffff]
[ 0.313619] pci 0000:00:1d.0: bridge window [mem 0xa2700000-0xa28fffff 64bit pref]
[ 0.313623] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.313624] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.313625] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.313626] pci_bus 0000:00: resource 7 [mem 0x90000000-0xdfffffff window]
[ 0.313627] pci_bus 0000:00: resource 8 [mem 0xfc800000-0xfe7fffff window]
[ 0.313628] pci_bus 0000:01: resource 0 [io 0x4000-0x4fff]
[ 0.313629] pci_bus 0000:01: resource 1 [mem 0xa3000000-0xa40fffff]
[ 0.313630] pci_bus 0000:01: resource 2 [mem 0x90000000-0xa20fffff 64bit pref]
[ 0.313631] pci_bus 0000:02: resource 0 [io 0x6000-0x6fff]
[ 0.313632] pci_bus 0000:02: resource 1 [mem 0xa2100000-0xa22fffff]
[ 0.313632] pci_bus 0000:02: resource 2 [mem 0xa2300000-0xa24fffff 64bit pref]
[ 0.313633] pci_bus 0000:04: resource 0 [io 0x3000-0x3fff]
[ 0.313634] pci_bus 0000:04: resource 1 [mem 0xa4200000-0xa42fffff]
[ 0.313635] pci_bus 0000:05: resource 0 [io 0x7000-0x7fff]
[ 0.313636] pci_bus 0000:05: resource 1 [mem 0xa2500000-0xa26fffff]
[ 0.313637] pci_bus 0000:05: resource 2 [mem 0xa2700000-0xa28fffff 64bit pref]
[ 0.313941] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.313958] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 0.313997] pci 0000:01:00.2: D0 power state depends on 0000:01:00.0
[ 0.314174] pci 0000:01:00.3: D0 power state depends on 0000:01:00.0
[ 0.314207] PCI: CLS 64 bytes, default 64
[ 0.314233] Trying to unpack rootfs image as initramfs...
[ 0.451440] Freeing initrd memory: 16292K
[ 0.451450] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.451451] software IO TLB: mapped [mem 0x0000000083d7d000-0x0000000087d7d000] (64MB)
[ 0.451535] platform rtc_cmos: registered platform RTC device (no PNP device found)
[ 0.451808] check: Scanning for low memory corruption every 60 seconds
[ 0.451998] Initialise system trusted keyrings
[ 0.452004] Key type blacklist registered
[ 0.452030] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[ 0.452723] zbud: loaded
[ 0.458973] Key type asymmetric registered
[ 0.458974] Asymmetric key parser 'x509' registered
[ 0.458977] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.458995] io scheduler mq-deadline registered
[ 0.458995] io scheduler kyber registered
[ 0.459008] io scheduler bfq registered
[ 0.459493] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.459507] efifb: probing for efifb
[ 0.459522] efifb: Ignoring BGRT: unexpected or invalid BMP data
[ 0.459522] efifb: framebuffer at 0x90000000, using 3072k, total 3072k
[ 0.459523] efifb: mode is 1024x768x32, linelength=4096, pages=1
[ 0.459524] efifb: scrolling: redraw
[ 0.459525] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.459551] fbcon: Deferring console take-over
[ 0.459552] fb0: EFI VGA frame buffer device
[ 0.459888] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[ 0.459903] ACPI: button: Sleep Button [SLPB]
[ 0.459920] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 0.459931] ACPI: button: Power Button [PWRB]
[ 0.459947] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.466195] ACPI: button: Power Button [PWRF]
[ 0.466450] smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 1217
[ 0.467430] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.467431] ACPI: thermal: Thermal Zone [TZ00] (28 C)
[ 0.467577] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.468016] 00:02: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 0.470315] Non-volatile memory driver v1.3
[ 0.470317] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 0.470317] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[ 0.470887] ahci 0000:00:17.0: version 3.0
[ 0.482877] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 6 ports 6 Gbps 0x3f impl SATA mode
[ 0.482880] ahci 0000:00:17.0: flags: 64bit ncq sntf led clo only pio slum part ems deso sadm sds apst
[ 0.533364] scsi host0: ahci
[ 0.533632] scsi host1: ahci
[ 0.533860] scsi host2: ahci
[ 0.534073] scsi host3: ahci
[ 0.534177] scsi host4: ahci
[ 0.534287] scsi host5: ahci
[ 0.534308] ata1: SATA max UDMA/133 abar m2048@0xa4339000 port 0xa4339100 irq 125
[ 0.534310] ata2: SATA max UDMA/133 abar m2048@0xa4339000 port 0xa4339180 irq 125
[ 0.534312] ata3: SATA max UDMA/133 abar m2048@0xa4339000 port 0xa4339200 irq 125
[ 0.534313] ata4: SATA max UDMA/133 abar m2048@0xa4339000 port 0xa4339280 irq 125
[ 0.534314] ata5: SATA max UDMA/133 abar m2048@0xa4339000 port 0xa4339300 irq 125
[ 0.534316] ata6: SATA max UDMA/133 abar m2048@0xa4339000 port 0xa4339380 irq 125
[ 0.534336] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.534341] ehci-pci: EHCI PCI platform driver
[ 0.534346] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.534347] ohci-pci: OHCI PCI platform driver
[ 0.534351] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.534374] usbcore: registered new interface driver usbserial_generic
[ 0.534376] usbserial: USB Serial support registered for generic
[ 0.534521] rtc_cmos rtc_cmos: RTC can wake from S4
[ 0.535278] rtc_cmos rtc_cmos: registered as rtc0
[ 0.535473] rtc_cmos rtc_cmos: setting system clock to 2021-05-26T22:04:47 UTC (1622066687)
[ 0.535480] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 0.535655] intel_pstate: Intel P-state driver initializing
[ 0.536075] intel_pstate: Disabling energy efficiency optimization
[ 0.536076] intel_pstate: HWP enabled
[ 0.536151] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.536295] hid: raw HID events driver (C) Jiri Kosina
[ 0.536362] ashmem: initialized
[ 0.536390] intel_pmc_core INT33A1:00: initialized
[ 0.536429] drop_monitor: Initializing network drop monitor service
[ 0.536464] Initializing XFRM netlink socket
[ 0.536512] NET: Registered protocol family 10
[ 0.539357] Segment Routing with IPv6
[ 0.539358] RPL Segment Routing with IPv6
[ 0.539372] NET: Registered protocol family 17
[ 0.539710] microcode: sig=0x906ed, pf=0x2, revision=0xde
[ 0.539803] microcode: Microcode Update Driver: v2.2.
[ 0.539806] IPI shorthand broadcast: enabled
[ 0.539812] sched_clock: Marking stable (539085530, 560222)->(541759471, -2113719)
[ 0.539897] registered taskstats version 1
[ 0.539903] Loading compiled-in X.509 certificates
[ 0.541510] Loaded X.509 cert 'Build time autogenerated kernel key: c56976e24ecbf1aba19ca4c05d427aeac28025ca'
[ 0.542246] zswap: loaded using pool zstd/z3fold
[ 0.542476] Key type ._fscrypt registered
[ 0.542477] Key type .fscrypt registered
[ 0.542477] Key type fscrypt-provisioning registered
[ 0.542501] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.544008] PM: Magic number: 5:795:98
[ 0.544197] RAS: Correctable Errors collector initialized.
[ 0.849498] ata6: SATA link down (SStatus 4 SControl 300)
[ 0.849539] ata3: SATA link down (SStatus 4 SControl 300)
[ 0.849582] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 0.849620] ata4: SATA link down (SStatus 4 SControl 300)
[ 0.849652] ata1: SATA link down (SStatus 4 SControl 300)
[ 0.850465] ata5.00: ATA-10: WDC WD10EZEX-75WN4A1, 13057113, max UDMA/133
[ 0.850475] ata5.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 0.851443] ata5.00: configured for UDMA/133
[ 0.852769] ata2: SATA link down (SStatus 4 SControl 300)
[ 0.853135] scsi 4:0:0:0: Direct-Access ATA WDC WD10EZEX-75W 7113 PQ: 0 ANSI: 5
[ 0.853491] sd 4:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 0.853500] sd 4:0:0:0: [sda] 4096-byte physical blocks
[ 0.853517] sd 4:0:0:0: [sda] Write Protect is off
[ 0.853522] sd 4:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 0.853545] sd 4:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.911747] sda: sda1 sda2 sda3
[ 0.926252] sd 4:0:0:0: [sda] Attached SCSI disk
[ 0.928763] Freeing unused decrypted memory: 2036K
[ 0.929442] Freeing unused kernel image (initmem) memory: 1652K
[ 0.929448] Write protecting the kernel read-only data: 22528k
[ 0.930755] Freeing unused kernel image (text/rodata gap) memory: 2036K
[ 0.931363] Freeing unused kernel image (rodata/data gap) memory: 1224K
[ 0.968905] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.968909] rodata_test: all tests were successful
[ 0.968931] Run /init as init process
[ 0.968933] with arguments:
[ 0.968935] /init
[ 0.968936] with environment:
[ 0.968937] HOME=/
[ 0.968938] TERM=linux
[ 0.968939] BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
[ 0.968941] cryptdevice=UUID=0f73e57b-b978-41d4-bc23-f53463ad9005:luks-0f73e57b-b978-41d4-bc23-f53463ad9005
[ 1.073257] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.073262] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 1.074336] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
[ 1.074461] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.12
[ 1.074463] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.074464] usb usb1: Product: xHCI Host Controller
[ 1.074465] usb usb1: Manufacturer: Linux 5.12.2-1-MANJARO xhci-hcd
[ 1.074466] usb usb1: SerialNumber: 0000:00:14.0
[ 1.074530] hub 1-0:1.0: USB hub found
[ 1.074544] hub 1-0:1.0: 16 ports detected
[ 1.075847] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.075850] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 1.075852] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.075871] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.12
[ 1.075872] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.075873] usb usb2: Product: xHCI Host Controller
[ 1.075874] usb usb2: Manufacturer: Linux 5.12.2-1-MANJARO xhci-hcd
[ 1.075875] usb usb2: SerialNumber: 0000:00:14.0
[ 1.075931] hub 2-0:1.0: USB hub found
[ 1.075938] hub 2-0:1.0: 6 ports detected
[ 1.076500] usb: port power management may be unreliable
[ 1.076648] cryptd: max_cpu_qlen set to 1000
[ 1.076772] xhci_hcd 0000:01:00.2: xHCI Host Controller
[ 1.076775] xhci_hcd 0000:01:00.2: new USB bus registered, assigned bus number 3
[ 1.077365] xhci_hcd 0000:01:00.2: hcc params 0x0180ff05 hci version 0x110 quirks 0x0000000000000010
[ 1.077442] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.12
[ 1.077443] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.077444] usb usb3: Product: xHCI Host Controller
[ 1.077445] usb usb3: Manufacturer: Linux 5.12.2-1-MANJARO xhci-hcd
[ 1.077446] usb usb3: SerialNumber: 0000:01:00.2
[ 1.077485] hub 3-0:1.0: USB hub found
[ 1.077489] hub 3-0:1.0: 2 ports detected
[ 1.077557] xhci_hcd 0000:01:00.2: xHCI Host Controller
[ 1.077558] xhci_hcd 0000:01:00.2: new USB bus registered, assigned bus number 4
[ 1.077560] xhci_hcd 0000:01:00.2: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.077576] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.077584] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.12
[ 1.077586] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.077586] usb usb4: Product: xHCI Host Controller
[ 1.077587] usb usb4: Manufacturer: Linux 5.12.2-1-MANJARO xhci-hcd
[ 1.077588] usb usb4: SerialNumber: 0000:01:00.2
[ 1.077622] hub 4-0:1.0: USB hub found
[ 1.077628] hub 4-0:1.0: 4 ports detected
[ 1.079106] AVX2 version of gcm_enc/dec engaged.
[ 1.079123] AES CTR mode by8 optimization enabled
[ 1.322920] device-mapper: uevent: version 1.0.3
[ 1.323062] device-mapper: ioctl: 4.44.0-ioctl (2021-02-01) initialised: dm-devel@redhat.com
[ 1.325957] Key type encrypted registered
[ 1.399448] usb 1-7: new low-speed USB device number 2 using xhci_hcd
[ 1.452815] tsc: Refined TSC clocksource calibration: 3696.000 MHz
[ 1.452831] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x6a8d280fdb9, max_idle_ns: 881591151302 ns
[ 1.452893] clocksource: Switched to clocksource tsc
[ 1.544626] usb 1-7: New USB device found, idVendor=1a2c, idProduct=2d23, bcdDevice= 1.10
[ 1.544628] usb 1-7: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.544629] usb 1-7: Product: USB Keyboard
[ 1.544630] usb 1-7: Manufacturer: USB
[ 1.549344] input: USB USB Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:1A2C:2D23.0001/input/input3
[ 1.602913] hid-generic 0003:1A2C:2D23.0001: input,hidraw0: USB HID v1.10 Keyboard [USB USB Keyboard] on usb-0000:00:14.0-7/input0
[ 1.605017] input: USB USB Keyboard Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.1/0003:1A2C:2D23.0002/input/input4
[ 1.659537] input: USB USB Keyboard System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.1/0003:1A2C:2D23.0002/input/input5
[ 1.659714] hid-generic 0003:1A2C:2D23.0002: input,hidraw1: USB HID v1.10 Device [USB USB Keyboard] on usb-0000:00:14.0-7/input1
[ 1.659727] usbcore: registered new interface driver usbhid
[ 1.659728] usbhid: USB HID core driver
[ 1.666119] usb 1-8: new full-speed USB device number 3 using xhci_hcd
[ 1.807818] usb 1-8: New USB device found, idVendor=1d57, idProduct=ad17, bcdDevice= 1.05
[ 1.807820] usb 1-8: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 1.807821] usb 1-8: Product: Gaming Mouse
[ 1.807822] usb 1-8: Manufacturer: LXD
[ 1.809505] input: LXD Gaming Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/0003:1D57:AD17.0003/input/input6
[ 1.809710] hid-generic 0003:1D57:AD17.0003: input,hidraw2: USB HID v1.10 Mouse [LXD Gaming Mouse] on usb-0000:00:14.0-8/input0
[ 5.403902] random: cryptsetup: uninitialized urandom read (2 bytes read)
[ 5.586053] fbcon: Taking over console
[ 5.586364] Console: switching to colour frame buffer device 128x48
[ 5.749470] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 5.975750] random: fast init done
[ 6.514849] systemd[1]: systemd 247.7-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 6.529606] systemd[1]: Detected architecture x86-64.
[ 6.580727] systemd[1]: Set hostname to <netvorsystem>.
[ 7.220675] random: crng init done
[ 8.557674] systemd[1]: Queued start job for default target Graphical Interface.
[ 8.578078] systemd[1]: Created slice system-getty.slice.
[ 8.578585] systemd[1]: Created slice system-modprobe.slice.
[ 8.579053] systemd[1]: Created slice Cryptsetup Units Slice.
[ 8.579639] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 8.580031] systemd[1]: Created slice User and Session Slice.
[ 8.580109] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 8.580168] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 8.580336] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 8.580402] systemd[1]: Reached target Login Prompts.
[ 8.580438] systemd[1]: Reached target Remote File Systems.
[ 8.580450] systemd[1]: Reached target Slices.
[ 8.580543] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 8.580849] systemd[1]: Listening on LVM2 poll daemon socket.
[ 8.582219] systemd[1]: Listening on Process Core Dump Socket.
[ 8.582393] systemd[1]: Listening on Journal Audit Socket.
[ 8.582505] systemd[1]: Listening on Journal Socket (/dev/log).
[ 8.582626] systemd[1]: Listening on Journal Socket.
[ 8.607877] systemd[1]: Listening on udev Control Socket.
[ 8.607974] systemd[1]: Listening on udev Kernel Socket.
[ 8.608788] systemd[1]: Mounting Huge Pages File System...
[ 8.609647] systemd[1]: Mounting POSIX Message Queue File System...
[ 8.610525] systemd[1]: Mounting Kernel Debug File System...
[ 8.611430] systemd[1]: Mounting Kernel Trace File System...
[ 8.612507] systemd[1]: Starting Load AppArmor profiles...
[ 8.613209] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 8.613571] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 8.613984] systemd[1]: Starting Load Kernel Module configfs...
[ 8.614391] systemd[1]: Starting Load Kernel Module drm...
[ 8.614778] systemd[1]: Starting Load Kernel Module fuse...
[ 8.642414] systemd[1]: Starting Set Up Additional Binary Formats...
[ 8.642567] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 8.668237] systemd[1]: Starting Load Kernel Modules...
[ 8.670293] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 8.670448] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[ 8.672077] systemd[1]: Starting Coldplug All udev Devices...
[ 8.672941] systemd[1]: Mounted Huge Pages File System.
[ 8.672981] systemd[1]: Mounted POSIX Message Queue File System.
[ 8.673013] systemd[1]: Mounted Kernel Debug File System.
[ 8.673042] systemd[1]: Mounted Kernel Trace File System.
[ 8.673221] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 8.673376] systemd[1]: modprobe@configfs.service: Succeeded.
[ 8.673515] systemd[1]: Finished Load Kernel Module configfs.
[ 8.673563] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 283 (systemd-binfmt)
[ 8.673931] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[ 8.674368] systemd[1]: Mounting Kernel Configuration File System...
[ 8.675029] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[ 8.683947] systemd[1]: modprobe@drm.service: Succeeded.
[ 8.684115] systemd[1]: Finished Load Kernel Module drm.
[ 8.684182] systemd[1]: Mounted Kernel Configuration File System.
[ 8.703494] systemd[1]: Finished Set Up Additional Binary Formats.
[ 8.703756] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
[ 8.706274] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 8.706570] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[ 8.707463] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 8.709284] systemd[1]: Starting Load/Save Random Seed...
[ 8.711395] systemd[1]: Starting Create System Users...
[ 8.868185] systemd[1]: Finished Coldplug All udev Devices.
[ 8.873891] vboxdrv: loading out-of-tree module taints kernel.
[ 8.873997] vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
[ 8.876080] vboxdrv: Found 6 processor cores
[ 8.895285] fuse: init (API version 7.33)
[ 8.895744] systemd[1]: modprobe@fuse.service: Succeeded.
[ 8.895897] systemd[1]: Finished Load Kernel Module fuse.
[ 8.896385] systemd[1]: Mounting FUSE Control File System...
[ 8.899726] vboxdrv: TSC mode is Invariant, tentative frequency 3695999706 Hz
[ 8.899727] vboxdrv: Successfully loaded version 6.1.22 (interface 0x00300000)
[ 8.956629] VBoxNetAdp: Successfully started.
[ 8.965071] systemd[1]: Mounted FUSE Control File System.
[ 8.985453] VBoxNetFlt: Successfully started.
[ 9.576707] audit: type=1400 audit(1622066696.537:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=300 comm="apparmor_parser"
[ 9.582767] audit: type=1400 audit(1622066696.544:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=303 comm="apparmor_parser"
[ 9.583339] audit: type=1400 audit(1622066696.544:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=303 comm="apparmor_parser"
[ 9.624480] audit: type=1400 audit(1622066696.584:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="php-fpm" pid=305 comm="apparmor_parser"
[ 9.635224] audit: type=1400 audit(1622066696.594:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-script-login" pid=306 comm="apparmor_parser"
[ 9.652723] audit: type=1400 audit(1622066696.610:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="torbrowser_tor" pid=307 comm="apparmor_parser"
[ 9.661486] audit: type=1400 audit(1622066696.620:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session" pid=302 comm="apparmor_parser"
[ 9.662279] audit: type=1400 audit(1622066696.620:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session//chromium" pid=302 comm="apparmor_parser"
[ 9.721348] audit: type=1400 audit(1622066696.680:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="torbrowser_firefox" pid=304 comm="apparmor_parser"
[ 10.133837] audit: type=1400 audit(1622066697.094:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=301 comm="apparmor_parser"
[ 10.135207] systemd[1]: Finished Load AppArmor profiles.
[ 10.135688] systemd[1]: Starting Load AppArmor profiles managed internally by snapd...
[ 10.659058] systemd[1]: Finished Load AppArmor profiles managed internally by snapd.
[ 10.866207] nvidia: module license 'NVIDIA' taints kernel.
[ 10.866210] Disabling lock debugging due to kernel taint
[ 10.882581] nvidia-nvlink: Nvlink Core is being initialized, major device number 237
[ 10.883026] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ 10.923930] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 460.80 Fri May 7 06:55:54 UTC 2021
[ 11.277503] Linux agpgart interface v0.103
[ 11.541329] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 460.80 Fri May 7 06:48:29 UTC 2021
[ 11.550027] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 11.550033] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
[ 11.756671] systemd[1]: Finished Load Kernel Modules.
[ 11.758599] systemd[1]: Starting Apply Kernel Variables...
[ 12.142147] systemd[1]: Finished Apply Kernel Variables.
[ 12.238684] systemd[1]: Starting CLI Netfilter Manager...
[ 12.258468] systemd[1]: Finished Load/Save Random Seed.
[ 12.258773] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[ 12.392049] systemd[1]: Finished Create System Users.
[ 12.393978] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 12.703627] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 12.706062] systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
[ 12.708525] systemd[1]: Starting Journal Service...
[ 12.709326] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 12.786709] systemd[1]: Started Journal Service.
[ 12.848186] systemd-journald[346]: Received client request to flush runtime journal.
[ 13.997275] input: PC Speaker as /devices/platform/pcspkr/input/input7
[ 14.031416] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 14.031466] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 14.318923] EDAC ie31200: No ECC support
[ 14.318952] EDAC ie31200: No ECC support
[ 14.321698] e1000e: Intel(R) PRO/1000 Network Driver
[ 14.321699] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 14.321844] e1000e 0000:00:1f.6: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 14.436800] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[ 14.436852] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 14.437885] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[ 14.438625] i2c i2c-0: 1/4 memory slots populated (from DMI)
[ 14.439908] i2c i2c-0: Successfully instantiated SPD at 0x53
[ 14.560434] e1000e 0000:00:1f.6 0000:00:1f.6 (uninitialized): registered PHC clock
[ 14.599641] nvidia-gpu 0000:01:00.3: enabling device (0000 -> 0002)
[ 14.627610] e1000e 0000:00:1f.6 eth0: (PCI Express:2.5GT/s:Width x1) a8:5e:45:1e:35:51
[ 14.627616] e1000e 0000:00:1f.6 eth0: Intel(R) PRO/1000 Network Connection
[ 14.627685] e1000e 0000:00:1f.6 eth0: MAC: 13, PHY: 12, PBA No: FFFFFF-0FF
[ 14.776183] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[ 14.776408] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[ 14.776445] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 14.776453] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 14.877885] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input8
[ 14.877918] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input9
[ 14.877938] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input10
[ 14.877958] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input11
[ 14.877985] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input12
[ 14.878076] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input13
[ 14.944688] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC887-VD: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[ 14.944691] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 14.944692] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 14.944693] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 14.944694] snd_hda_codec_realtek hdaudioC0D0: dig-out=0x11/0x0
[ 14.944695] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 14.944695] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 14.944696] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 14.944697] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 14.963479] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
[ 14.963501] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
[ 14.963522] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1f.3/sound/card0/input16
[ 14.963546] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1f.3/sound/card0/input17
[ 14.963566] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input18
[ 14.979572] Adding 4095996k swap on /dev/sda2. Priority:-2 extents:1 across:4095996k FS
[ 15.016743] ee1004 0-0053: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 15.027484] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 655360 ms ovfl timer
[ 15.027490] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 15.027492] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 15.027494] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 15.032673] iTCO_vendor_support: vendor-support=0
[ 15.094243] e1000e 0000:00:1f.6 eno1: renamed from eth0
[ 15.094494] asus_wmi: ASUS WMI generic driver loaded
[ 15.103689] asus_wmi: Initialization: 0x0
[ 15.103712] asus_wmi: BIOS WMI version: 0.9
[ 15.103811] asus_wmi: SFUN value: 0x0
[ 15.103812] eeepc-wmi eeepc-wmi: Detected ASUSWMI, use DCTS
[ 15.104120] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input19
[ 15.110860] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 15.123095] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 15.143032] iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[ 15.143265] iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 15.489398] kauditd_printk_skb: 51 callbacks suppressed
[ 15.489421] audit: type=1130 audit(1622066702.447:35): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 15.546183] rtl8188ee 0000:04:00.0: enabling device (0000 -> 0003)
[ 15.547836] intel_rapl_common: Found RAPL domain package
[ 15.547841] intel_rapl_common: Found RAPL domain core
[ 15.547846] intel_rapl_common: Found RAPL domain dram
[ 15.553986] rtl8188ee: rtl8188ee: FW Power Save off (module option)
[ 15.553997] rtl8188ee: Using firmware rtlwifi/rtl8188efw.bin
[ 15.556721] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
[ 15.557182] rtlwifi: rtlwifi: wireless switch is on
[ 15.679875] rtl8188ee 0000:04:00.0 wlp4s0: renamed from wlan0
[ 15.874394] audit: type=1130 audit(1622066702.834:36): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-cryptsetup@luks\x2d0f73e57b\x2db978\x2d41d4\x2dbc23\x2df53463ad9005 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 16.149985] loop: module loaded
[ 16.152363] loop0: detected capacity change from 0 to 720744
[ 16.166313] loop1: detected capacity change from 0 to 65712
[ 16.186251] loop2: detected capacity change from 0 to 133320
[ 16.213161] loop3: detected capacity change from 0 to 113504
[ 16.213369] loop4: detected capacity change from 0 to 126424
[ 16.214320] nvidia-gpu 0000:01:00.3: i2c timeout error e0000000
[ 16.214333] ucsi_ccg 1-0008: i2c_transfer failed -110
[ 16.214341] ucsi_ccg 1-0008: ucsi_ccg_init failed - -110
[ 16.214355] ucsi_ccg: probe of 1-0008 failed with error -110
[ 16.291225] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 16.380138] audit: type=1130 audit(1622066703.340:37): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-C328\x2d13BB comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 16.948054] audit: type=1130 audit(1622066703.910:38): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 18.698947] mousedev: PS/2 mouse device common for all mice
[ 20.642839] audit: type=1130 audit(1622066707.604:39): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ldconfig comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 21.955096] audit: type=1131 audit(1622066708.914:40): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 26.367799] audit: type=1130 audit(1622066713.327:41): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 26.680412] audit: type=1130 audit(1622066713.640:42): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 26.729496] audit: type=1127 audit(1622066713.690:43): pid=681 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[ 26.888040] audit: type=1130 audit(1622066713.847:44): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 26.999642] audit: type=1130 audit(1622066713.960:45): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-catalog-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.025082] audit: type=1130 audit(1622066713.984:46): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-done comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.065614] audit: type=1130 audit(1622066714.024:47): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.068406] audit: type=1130 audit(1622066714.027:48): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.071158] audit: type=1334 audit(1622066714.030:49): prog-id=7 op=LOAD
[ 27.071231] audit: type=1334 audit(1622066714.030:50): prog-id=8 op=LOAD
[ 31.414035] kauditd_printk_skb: 13 callbacks suppressed
[ 31.414037] audit: type=1130 audit(1622066718.374:64): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=accounts-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 31.918523] audit: type=1130 audit(1622066718.877:65): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 32.220537] loop5: detected capacity change from 0 to 8
[ 32.226217] audit: type=1130 audit(1622066719.187:66): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 33.880653] audit: type=1130 audit(1622066720.840:67): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 38.069787] audit: type=1130 audit(1622066725.030:68): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 38.418671] audit: type=1103 audit(1622066725.377:69): pid=926 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 38.500197] audit: type=1130 audit(1622066725.460:70): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 38.525085] audit: type=1101 audit(1622066725.484:71): pid=930 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 38.525089] audit: type=1103 audit(1622066725.484:72): pid=930 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 38.525162] audit: type=1006 audit(1622066725.484:73): pid=930 uid=0 subj==unconfined old-auid=4294967295 auid=969 tty=(none) old-ses=4294967295 ses=1 res=1
[ 38.525166] audit: type=1300 audit(1622066725.484:73): arch=c000003e syscall=1 success=yes exit=3 a0=9 a1=7ffff24a76e0 a2=3 a3=3c9 items=0 ppid=1 pid=930 auid=969 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd" subj==unconfined key=(null)
[ 38.525168] audit: type=1327 audit(1622066725.484:73): proctitle="(systemd)"
[ 38.527125] audit: type=1105 audit(1622066725.487:74): pid=930 uid=0 auid=969 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 38.531613] audit: type=1334 audit(1622066725.490:75): prog-id=11 op=LOAD
[ 54.717288] kauditd_printk_skb: 6 callbacks suppressed
[ 54.717290] audit: type=1100 audit(1622066741.677:80): pid=970 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="netvor" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 54.718223] audit: type=1101 audit(1622066741.677:81): pid=970 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="netvor" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 54.974555] audit: type=1106 audit(1622066741.934:82): pid=926 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 54.974691] audit: type=1104 audit(1622066741.934:83): pid=926 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 54.980650] audit: type=1103 audit(1622066741.940:84): pid=970 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="netvor" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 54.980827] audit: type=1006 audit(1622066741.940:85): pid=970 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ 54.980840] audit: type=1300 audit(1622066741.940:85): arch=c000003e syscall=1 success=yes exit=4 a0=9 a1=7ffe330927f0 a2=4 a3=3e8 items=0 ppid=724 pid=970 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="lightdm" exe="/usr/bin/lightdm" subj==unconfined key=(null)
[ 54.980848] audit: type=1327 audit(1622066741.940:85): proctitle=6C69676874646D002D2D73657373696F6E2D6368696C64003132003139
[ 54.995091] audit: type=1130 audit(1622066741.954:86): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 54.998606] audit: type=1101 audit(1622066741.957:87): pid=980 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="netvor" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 57.004334] wlp4s0: authenticate with 74:3c:18:83:25:19
[ 57.023253] wlp4s0: send auth to 74:3c:18:83:25:19 (try 1/3)
[ 57.039204] wlp4s0: authenticated
[ 57.042814] wlp4s0: associate with 74:3c:18:83:25:19 (try 1/3)
[ 57.051627] wlp4s0: RX AssocResp from 74:3c:18:83:25:19 (capab=0x411 status=0 aid=2)
[ 57.052003] wlp4s0: associated
[ 57.143012] wlp4s0: Limiting TX power to 26 (26 - 0) dBm as advertised by 74:3c:18:83:25:19
[ 57.163129] IPv6: ADDRCONF(NETDEV_CHANGE): wlp4s0: link becomes ready
[ 62.623095] kauditd_printk_skb: 17 callbacks suppressed
[ 62.623113] audit: type=1334 audit(1622066749.584:101): prog-id=13 op=LOAD
[ 62.623232] audit: type=1334 audit(1622066749.584:102): prog-id=14 op=LOAD
[ 63.962018] audit: type=1130 audit(1622066750.920:103): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=colord comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 64.407126] audit: type=1130 audit(1622066751.367:104): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 65.266697] audit: type=1131 audit(1622066752.227:105): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 65.286300] audit: type=1131 audit(1622066752.247:106): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 67.273384] audit: type=1130 audit(1622066754.234:107): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 68.006933] audit: type=1131 audit(1622066754.967:108): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 68.613673] audit: type=1130 audit(1622066755.574:109): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 98.622525] audit: type=1131 audit(1622066785.580:110): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 182.170648] [UFW BLOCK] IN=wlp4s0 OUT= MAC=01:00:5e:00:00:01:74:3c:18:83:25:10:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 235.282489] audit: type=1111 audit(1622066922.240:111): pid=687 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-add-activate uuid=be6cdc55-ed23-464f-b194-dde4677b8377 name=504154524943494120494249 pid=1163 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 235.304973] audit: type=1130 audit(1622066922.264:112): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 235.614074] wlp4s0: deauthenticating from 74:3c:18:83:25:19 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 240.775519] audit: type=1334 audit(1622066927.734:113): prog-id=15 op=LOAD
[ 240.775665] audit: type=1334 audit(1622066927.734:114): prog-id=16 op=LOAD
[ 240.812419] audit: type=1130 audit(1622066927.770:115): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 246.009820] audit: type=1131 audit(1622066932.970:116): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 248.315882] audit: type=1111 audit(1622066935.274:117): pid=687 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-activate uuid=896d0133-ba74-484d-bc31-76d5b817b682 name=343534204F4920464942524120322E3420472031 pid=1163 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 248.338287] audit: type=1130 audit(1622066935.297:118): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 252.857058] wlp4s0: authenticate with 74:3c:18:83:25:19
[ 252.876561] wlp4s0: send auth to 74:3c:18:83:25:19 (try 1/3)
[ 252.878784] wlp4s0: authenticated
[ 252.882731] wlp4s0: associate with 74:3c:18:83:25:19 (try 1/3)
[ 252.886068] wlp4s0: RX AssocResp from 74:3c:18:83:25:19 (capab=0x411 status=0 aid=2)
[ 252.886485] wlp4s0: associated
[ 252.952961] wlp4s0: Limiting TX power to 26 (26 - 0) dBm as advertised by 74:3c:18:83:25:19
[ 252.966495] IPv6: ADDRCONF(NETDEV_CHANGE): wlp4s0: link becomes ready
[ 259.009267] audit: type=1131 audit(1622066945.967:119): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 261.744277] audit: type=1130 audit(1622066948.704:120): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 265.877782] audit: type=1111 audit(1622066952.837:121): pid=687 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-activate uuid=896d0133-ba74-484d-bc31-76d5b817b682 name=343534204F4920464942524120322E3420472031 pid=1163 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 265.958443] wlp4s0: deauthenticating from 74:3c:18:83:25:19 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 270.877111] audit: type=1131 audit(1622066957.837:122): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 270.918934] wlp4s0: authenticate with 74:3c:18:83:25:19
[ 270.966127] audit: type=1334 audit(1622066957.927:123): prog-id=16 op=UNLOAD
[ 270.966146] audit: type=1334 audit(1622066957.927:124): prog-id=15 op=UNLOAD
[ 271.412469] wlp4s0: send auth to 74:3c:18:83:25:19 (try 1/3)
[ 271.414111] wlp4s0: authenticated
[ 271.419406] wlp4s0: associate with 74:3c:18:83:25:19 (try 1/3)
[ 271.422673] wlp4s0: RX AssocResp from 74:3c:18:83:25:19 (capab=0x411 status=0 aid=2)
[ 271.422893] wlp4s0: associated
[ 271.482800] wlp4s0: Limiting TX power to 26 (26 - 0) dBm as advertised by 74:3c:18:83:25:19
[ 271.482842] IPv6: ADDRCONF(NETDEV_CHANGE): wlp4s0: link becomes ready
[ 272.006261] audit: type=1131 audit(1622066958.967:125): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 277.510320] audit: type=1130 audit(1622066964.470:126): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 281.894527] audit: type=1334 audit(1622066968.854:127): prog-id=17 op=LOAD
[ 281.894576] audit: type=1334 audit(1622066968.854:128): prog-id=18 op=LOAD
[ 281.929448] audit: type=1130 audit(1622066968.890:129): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 288.006939] audit: type=1131 audit(1622066974.967:130): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 289.755372] audit: type=1111 audit(1622066976.714:131): pid=687 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-update uuid=896d0133-ba74-484d-bc31-76d5b817b682 name=343534204F4920464942524120322E3420472031 args=connection.timestamp,ipv4.dns pid=2479 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 297.956353] audit: type=1111 audit(1622066984.917:132): pid=687 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=device-disconnect interface="wlp4s0" ifindex=3 pid=1163 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 297.979702] audit: type=1130 audit(1622066984.940:133): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 298.074402] wlp4s0: deauthenticating from 74:3c:18:83:25:19 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 298.226341] [UFW BLOCK] IN=wlp4s0 OUT= MAC= SRC=0000:0000:0000:0000:0000:0000:0000:0000 DST=ff02:0000:0000:0000:0000:0000:0000:00fb LEN=72 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=ICMPv6 TYPE=131 CODE=0
[ 305.788825] audit: type=1111 audit(1622066992.747:134): pid=687 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-activate uuid=896d0133-ba74-484d-bc31-76d5b817b682 name=343534204F4920464942524120322E3420472031 pid=1163 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 307.304582] wlp4s0: authenticate with 74:3c:18:83:25:19
[ 307.324158] wlp4s0: send auth to 74:3c:18:83:25:19 (try 1/3)
[ 307.325773] wlp4s0: authenticated
[ 307.329388] wlp4s0: associate with 74:3c:18:83:25:19 (try 1/3)
[ 307.332724] wlp4s0: RX AssocResp from 74:3c:18:83:25:19 (capab=0x411 status=0 aid=2)
[ 307.333542] wlp4s0: associated
[ 307.396388] IPv6: ADDRCONF(NETDEV_CHANGE): wlp4s0: link becomes ready
[ 307.411581] wlp4s0: Limiting TX power to 26 (26 - 0) dBm as advertised by 74:3c:18:83:25:19
[ 308.005415] audit: type=1131 audit(1622066994.964:135): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 309.233884] audit: type=1130 audit(1622066996.194:136): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 311.980574] audit: type=1131 audit(1622066998.940:137): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 312.096069] audit: type=1334 audit(1622066999.057:138): prog-id=18 op=UNLOAD
[ 312.096073] audit: type=1334 audit(1622066999.057:139): prog-id=17 op=UNLOAD
[ 319.010606] audit: type=1131 audit(1622067005.970:140): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 432.551984] [UFW BLOCK] IN=wlp4s0 OUT= MAC=01:00:5e:00:00:01:74:3c:18:83:25:10:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 540.418540] [UFW BLOCK] IN=wlp4s0 OUT= MAC=d0:37:45:45:db:99:74:3c:18:83:25:10:08:00 SRC=162.159.138.232 DST=192.168.1.71 LEN=79 TOS=0x00 PREC=0x00 TTL=57 ID=23205 DF PROTO=TCP SPT=443 DPT=34596 WINDOW=96 RES=0x00 ACK PSH URGP=0
[ 540.419049] [UFW BLOCK] IN=wlp4s0 OUT= MAC=d0:37:45:45:db:99:74:3c:18:83:25:10:08:00 SRC=162.159.138.232 DST=192.168.1.71 LEN=64 TOS=0x00 PREC=0x00 TTL=57 ID=23206 DF PROTO=TCP SPT=443 DPT=34596 WINDOW=96 RES=0x00 ACK PSH URGP=0
[ 557.896461] [UFW BLOCK] IN=wlp4s0 OUT= MAC=01:00:5e:00:00:01:74:3c:18:83:25:10:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 682.933543] [UFW BLOCK] IN=wlp4s0 OUT= MAC=01:00:5e:00:00:01:74:3c:18:83:25:10:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 794.761935] [UFW BLOCK] IN=wlp4s0 OUT= MAC=01:00:5e:00:00:fb:74:3c:18:83:25:10:08:00 SRC=192.168.1.254 DST=224.0.0.251 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 795.379161] [UFW BLOCK] IN=wlp4s0 OUT= MAC=01:00:5e:00:00:fb:74:3c:18:83:25:10:08:00 SRC=192.168.1.254 DST=224.0.0.251 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 808.277778] [UFW BLOCK] IN=wlp4s0 OUT= MAC=01:00:5e:00:00:01:74:3c:18:83:25:10:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 924.119377] audit: type=1130 audit(1622067611.080:141): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 924.119392] audit: type=1131 audit(1622067611.080:142): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 933.316865] [UFW BLOCK] IN=wlp4s0 OUT= MAC=01:00:5e:00:00:01:74:3c:18:83:25:10:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 1058.351891] [UFW BLOCK] IN=wlp4s0 OUT= MAC=01:00:5e:00:00:01:74:3c:18:83:25:10:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 1183.698329] [UFW BLOCK] IN=wlp4s0 OUT= MAC=01:00:5e:00:00:01:74:3c:18:83:25:10:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 1308.733576] [UFW BLOCK] IN=wlp4s0 OUT= MAC=01:00:5e:00:00:01:74:3c:18:83:25:10:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 1434.083204] [UFW BLOCK] IN=wlp4s0 OUT= MAC=01:00:5e:00:00:01:74:3c:18:83:25:10:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 1559.116613] [UFW BLOCK] IN=wlp4s0 OUT= MAC=01:00:5e:00:00:01:74:3c:18:83:25:10:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 1665.084390] audit: type=1100 audit(1622068352.044:143): pid=4182 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="netvor" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1665.085203] audit: type=1101 audit(1622068352.044:144): pid=4182 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="netvor" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1665.085315] audit: type=1110 audit(1622068352.044:145): pid=4182 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1665.085623] audit: type=1105 audit(1622068352.044:146): pid=4182 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINT
loop0 squashfs 4.0 0 100% /var/lib/snapd/snap/rpcs3-emu/349
loop1 squashfs 4.0 0 100% /var/lib/snapd/snap/snapd/11841
loop2 squashfs 4.0 0 100% /var/lib/snapd/snap/gtk-common-themes/1515
loop3 squashfs 4.0 0 100% /var/lib/snapd/snap/core18/2066
loop4 squashfs 4.0 0 100% /var/lib/snapd/snap/core20/1026
sda
├─sda1 vfat FAT32 EFI C328-13BB 498,5M 0% /boot/efi
├─sda2 swap 1 Swap cc8f0f21-897b-4b92-97e1-532c81ec52be [SWAP]
└─sda3 crypto_LUKS 1 0f73e57b-b978-41d4-bc23-f53463ad9005
└─luks-0f73e57b-b978-41d4-bc23-f53463ad9005 ext4 1.0 f8122e2b-5dc0-45ba-8e63-dc3143761763 587,9G 29% /
journalctl -f
-- Journal begins at Tue 2021-05-18 12:30:21 -03. --
mai 26 19:40:10 netvorsystem dbus-daemon[686]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.3' (uid=0 pid=687 comm="/usr/bin/NetworkManager --no-daemon ")
mai 26 19:40:10 netvorsystem systemd[1]: Starting Network Manager Script Dispatcher Service...
mai 26 19:40:10 netvorsystem dbus-daemon[686]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
mai 26 19:40:10 netvorsystem systemd[1]: Started Network Manager Script Dispatcher Service.
mai 26 19:40:10 netvorsystem audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 26 19:40:10 netvorsystem kernel: audit: type=1130 audit(1622068810.497:151): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 26 19:40:20 netvorsystem systemd[1]: NetworkManager-dispatcher.service: Succeeded.
mai 26 19:40:20 netvorsystem audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 26 19:40:20 netvorsystem kernel: audit: type=1131 audit(1622068820.974:152): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 26 19:41:12 netvorsystem kernel: [UFW BLOCK] IN=wlp4s0 OUT= MAC=01:00:5e:00:00:01:74:3c:18:83:25:10:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
mai 26 19:42:54 netvorsystem dbus-daemon[686]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service' requested by ':1.92' (uid=1000 pid=4404 comm="/opt/discord/Discord ")
mai 26 19:42:54 netvorsystem systemd[1]: Condition check resulted in Bluetooth service being skipped.
mai 26 19:43:17 netvorsystem kernel: [UFW BLOCK] IN=wlp4s0 OUT= MAC=01:00:5e:00:00:01:74:3c:18:83:25:10:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
mai 26 19:43:19 netvorsystem dbus-daemon[686]: [system] Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
cat /var/log/Xorg.0.log
[ 31.124]
X.Org X Server 1.20.11
[ 31.124] Build Operating System: Linux Manjaro Linux
[ 31.124] Current Operating System: Linux netvorsystem 5.12.2-1-MANJARO #1 SMP PREEMPT Fri May 7 17:53:15 UTC 2021 x86_64
[ 31.124] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64 root=UUID=f8122e2b-5dc0-45ba-8e63-dc3143761763 rw quiet cryptdevice=UUID=0f73e57b-b978-41d4-bc23-f53463ad9005:luks-0f73e57b-b978-41d4-bc23-f53463ad9005 root=/dev/mapper/luks-0f73e57b-b978-41d4-bc23-f53463ad9005 apparmor=1 security=apparmor udev.log_priority=3 pcie_aspm=off
[ 31.124] Build Date: 13 April 2021 04:11:08PM
[ 31.124]
[ 31.124] Current version of pixman: 0.40.0
[ 31.124] Before reporting problems, check http://wiki.x.org
[ 31.124] Markers: (--) probed, (**) from config file, (==) default setting,
[ 31.124] (==) Log file: "/var/log/Xorg.0.log", Time: Wed May 26 19:05:18 2021
[ 31.169] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 31.169] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 31.264] (==) ServerLayout "layout"
[ 31.264] (**) |-->Screen "Screen0" (0)
[ 31.264] (**) | |-->Monitor "Monitor0"
[ 31.264] (**) | |-->Device "Device0"
[ 31.264] (==) Automatically adding devices
[ 31.264] (==) Automatically enabling devices
[ 31.264] (==) Automatically adding GPU devices
[ 31.264] (==) Automatically binding GPU devices
[ 31.264] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 31.342] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 31.342] Entry deleted from font path.
[ 31.342] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 31.342] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 31.342] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 31.342] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 31.342] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 31.342] (**) Extension "COMPOSITE" is enabled
[ 31.342] (II) The server relies on udev to provide the list of input devices.
[ 31.342] (II) Module ABI versions:
[ 31.342] X.Org ANSI C Emulation: 0.4
[ 31.342] X.Org Video Driver: 24.1
[ 31.342] X.Org XInput driver : 24.1
[ 31.342] X.Org Server Extension : 10.0
[ 31.343] (++) using VT number 7
[ 31.343] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 31.343] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 31.343] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 31.343] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 31.344] (--) PCI:*(1@0:0:0) 10de:1f08:10de:12fd rev 161, Mem @ 0xa3000000/16777216, 0x90000000/268435456, 0xa0000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x????????/131072
[ 31.344] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 31.344] (II) LoadModule: "glx"
[ 31.663] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 32.050] (II) Module glx: vendor="X.Org Foundation"
[ 32.050] compiled for 1.20.11, module version = 1.0.0
[ 32.050] ABI class: X.Org Server Extension, version 10.0
[ 32.050] (II) LoadModule: "nvidia"
[ 32.073] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 32.201] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 32.201] compiled for 1.6.99.901, module version = 1.0.0
[ 32.201] Module class: X.Org Video Driver
[ 32.234] (II) NVIDIA dlloader X Driver 460.80 Fri May 7 06:53:15 UTC 2021
[ 32.234] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 32.273] (II) Loading sub module "fb"
[ 32.273] (II) LoadModule: "fb"
[ 32.273] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 32.306] (II) Module fb: vendor="X.Org Foundation"
[ 32.306] compiled for 1.20.11, module version = 1.0.0
[ 32.306] ABI class: X.Org ANSI C Emulation, version 0.4
[ 32.306] (II) Loading sub module "wfb"
[ 32.306] (II) LoadModule: "wfb"
[ 32.306] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 32.325] (II) Module wfb: vendor="X.Org Foundation"
[ 32.325] compiled for 1.20.11, module version = 1.0.0
[ 32.325] ABI class: X.Org ANSI C Emulation, version 0.4
[ 32.325] (II) Loading sub module "ramdac"
[ 32.325] (II) LoadModule: "ramdac"
[ 32.325] (II) Module "ramdac" already built-in
[ 32.417] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 32.417] (==) NVIDIA(0): RGB weight 888
[ 32.417] (==) NVIDIA(0): Default visual is TrueColor
[ 32.417] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 32.417] (**) Option "AllowNVIDIAGpuScreens"
[ 32.430] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 32.430] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 32.430] (**) NVIDIA(0): Enabling 2D acceleration
[ 32.430] (II) Loading sub module "glxserver_nvidia"
[ 32.430] (II) LoadModule: "glxserver_nvidia"
[ 32.431] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 33.658] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 33.658] compiled for 1.6.99.901, module version = 1.0.0
[ 33.658] Module class: X.Org Server Extension
[ 33.658] (II) NVIDIA GLX Module 460.80 Fri May 7 06:50:15 UTC 2021
[ 33.818] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 34.488] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 34.488] (--) NVIDIA(0): DFP-0
[ 34.488] (--) NVIDIA(0): DFP-1 (boot)
[ 34.488] (--) NVIDIA(0): DFP-2
[ 34.488] (--) NVIDIA(0): DFP-3
[ 34.489] (II) NVIDIA(0): NVIDIA GPU GeForce RTX 2060 (TU106-A) at PCI:1:0:0 (GPU-0)
[ 34.489] (--) NVIDIA(0): Memory: 6291456 kBytes
[ 34.489] (--) NVIDIA(0): VideoBIOS: 90.06.3f.00.73
[ 34.489] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 34.489] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 34.489] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 34.489] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 34.518] (--) NVIDIA(GPU-0): Samsung S24D332 (DFP-1): connected
[ 34.518] (--) NVIDIA(GPU-0): Samsung S24D332 (DFP-1): Internal TMDS
[ 34.518] (--) NVIDIA(GPU-0): Samsung S24D332 (DFP-1): 600.0 MHz maximum pixel clock
[ 34.518] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 34.518] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 34.518] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[ 34.518] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 34.518] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 34.518] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 34.565] (==) NVIDIA(0):
[ 34.565] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 34.565] (==) NVIDIA(0): will be used as the requested mode.
[ 34.567] (II) NVIDIA(0): Validated MetaModes:
[ 34.567] (II) NVIDIA(0): "DFP-1:nvidia-auto-select"
[ 34.567] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[ 34.611] (--) NVIDIA(0): DPI set to (92, 91); computed from "UseEdidDpi" X config
[ 34.611] (--) NVIDIA(0): option
[ 34.611] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[ 34.611] (II) NVIDIA: access.
[ 34.613] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 34.613] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 34.613] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 34.613] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 34.613] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 34.613] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 34.613] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 34.613] (II) NVIDIA(0): Config Options in the README.
[ 36.488] (II) NVIDIA(0): Setting mode "DFP-1:nvidia-auto-select"
[ 37.036] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 37.037] (==) NVIDIA(0): Backing store enabled
[ 37.037] (==) NVIDIA(0): Silken mouse disabled
[ 37.037] (**) NVIDIA(0): DPMS enabled
[ 37.053] (WW) NVIDIA(0): Option "NoLogo" is not used
[ 37.053] (II) Loading sub module "dri2"
[ 37.053] (II) LoadModule: "dri2"
[ 37.053] (II) Module "dri2" already built-in
[ 37.053] (II) NVIDIA(0): [DRI2] Setup complete
[ 37.053] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 37.056] (II) Initializing extension Generic Event Extension
[ 37.057] (II) Initializing extension SHAPE
[ 37.057] (II) Initializing extension MIT-SHM
[ 37.057] (II) Initializing extension XInputExtension
[ 37.057] (II) Initializing extension XTEST
[ 37.057] (II) Initializing extension BIG-REQUESTS
[ 37.057] (II) Initializing extension SYNC
[ 37.057] (II) Initializing extension XKEYBOARD
[ 37.057] (II) Initializing extension XC-MISC
[ 37.057] (II) Initializing extension SECURITY
[ 37.057] (II) Initializing extension XFIXES
[ 37.057] (II) Initializing extension RENDER
[ 37.057] (II) Initializing extension RANDR
[ 37.057] (II) Initializing extension COMPOSITE
[ 37.057] (II) Initializing extension DAMAGE
[ 37.057] (II) Initializing extension MIT-SCREEN-SAVER
[ 37.058] (II) Initializing extension DOUBLE-BUFFER
[ 37.058] (II) Initializing extension RECORD
[ 37.058] (II) Initializing extension DPMS
[ 37.058] (II) Initializing extension Present
[ 37.058] (II) Initializing extension DRI3
[ 37.058] (II) Initializing extension X-Resource
[ 37.058] (II) Initializing extension XVideo
[ 37.058] (II) Initializing extension XVideo-MotionCompensation
[ 37.058] (II) Initializing extension GLX
[ 37.058] (II) Indirect GLX disabled.
[ 37.058] (II) GLX: Another vendor is already registered for screen 0
[ 37.058] (II) Initializing extension XFree86-VidModeExtension
[ 37.058] (II) Initializing extension XFree86-DGA
[ 37.058] (II) Initializing extension XFree86-DRI
[ 37.058] (II) Initializing extension DRI2
[ 37.058] (II) Initializing extension NV-GLX
[ 37.058] (II) Initializing extension NV-CONTROL
[ 37.058] (II) Initializing extension XINERAMA
[ 37.594] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 37.594] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 37.594] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 37.594] (**) Power Button: Applying InputClass "system-keyboard"
[ 37.594] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 37.594] (II) LoadModule: "libinput"
[ 37.638] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 37.670] (II) Module libinput: vendor="X.Org Foundation"
[ 37.670] compiled for 1.20.11, module version = 1.0.1
[ 37.670] Module class: X.Org XInput Driver
[ 37.670] ABI class: X.Org XInput driver, version 24.1
[ 37.670] (II) Using input driver 'libinput' for 'Power Button'
[ 37.670] (**) Power Button: always reports core events
[ 37.670] (**) Option "Device" "/dev/input/event2"
[ 37.670] (**) Option "_source" "server/udev"
[ 37.686] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 37.686] (II) event2 - Power Button: device is a keyboard
[ 37.686] (II) event2 - Power Button: device removed
[ 37.702] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 37.702] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 37.702] (**) Option "xkb_layout" "br"
[ 37.702] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 37.714] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 37.715] (II) event2 - Power Button: device is a keyboard
[ 37.715] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 37.715] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 37.715] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 37.715] (**) Power Button: Applying InputClass "system-keyboard"
[ 37.715] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 37.715] (II) Using input driver 'libinput' for 'Power Button'
[ 37.715] (**) Power Button: always reports core events
[ 37.715] (**) Option "Device" "/dev/input/event1"
[ 37.715] (**) Option "_source" "server/udev"
[ 37.715] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 37.716] (II) event1 - Power Button: device is a keyboard
[ 37.716] (II) event1 - Power Button: device removed
[ 37.750] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 37.750] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 37.750] (**) Option "xkb_layout" "br"
[ 37.750] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 37.750] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 37.750] (II) event1 - Power Button: device is a keyboard
[ 37.751] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[ 37.751] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 37.751] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 37.751] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 37.751] (**) Sleep Button: Applying InputClass "Keyboard Defaults"
[ 37.751] (II) Using input driver 'libinput' for 'Sleep Button'
[ 37.751] (**) Sleep Button: always reports core events
[ 37.751] (**) Option "Device" "/dev/input/event0"
[ 37.751] (**) Option "_source" "server/udev"
[ 37.751] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 37.751] (II) event0 - Sleep Button: device is a keyboard
[ 37.752] (II) event0 - Sleep Button: device removed
[ 37.795] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[ 37.795] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[ 37.795] (**) Option "xkb_layout" "br"
[ 37.795] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 37.797] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 37.797] (II) event0 - Sleep Button: device is a keyboard
[ 37.799] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event10)
[ 37.799] (II) No input driver specified, ignoring this device.
[ 37.799] (II) This device may have been added with another device file.
[ 37.800] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event11)
[ 37.800] (II) No input driver specified, ignoring this device.
[ 37.800] (II) This device may have been added with another device file.
[ 37.801] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event12)
[ 37.801] (II) No input driver specified, ignoring this device.
[ 37.801] (II) This device may have been added with another device file.
[ 37.802] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event13)
[ 37.802] (II) No input driver specified, ignoring this device.
[ 37.802] (II) This device may have been added with another device file.
[ 37.803] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event8)
[ 37.803] (II) No input driver specified, ignoring this device.
[ 37.803] (II) This device may have been added with another device file.
[ 37.804] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event9)
[ 37.804] (II) No input driver specified, ignoring this device.
[ 37.804] (II) This device may have been added with another device file.
[ 37.806] (II) config/udev: Adding input device USB USB Keyboard (/dev/input/event3)
[ 37.806] (**) USB USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 37.806] (**) USB USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 37.806] (**) USB USB Keyboard: Applying InputClass "system-keyboard"
[ 37.806] (**) USB USB Keyboard: Applying InputClass "Keyboard Defaults"
[ 37.806] (II) Using input driver 'libinput' for 'USB USB Keyboard'
[ 37.806] (**) USB USB Keyboard: always reports core events
[ 37.806] (**) Option "Device" "/dev/input/event3"
[ 37.806] (**) Option "_source" "server/udev"
[ 37.809] (II) event3 - USB USB Keyboard: is tagged by udev as: Keyboard
[ 37.809] (II) event3 - USB USB Keyboard: device is a keyboard
[ 37.810] (II) event3 - USB USB Keyboard: device removed
[ 37.852] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:1A2C:2D23.0001/input/input3/event3"
[ 37.852] (II) XINPUT: Adding extended input device "USB USB Keyboard" (type: KEYBOARD, id 9)
[ 37.852] (**) Option "xkb_layout" "br"
[ 37.852] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 37.856] (II) event3 - USB USB Keyboard: is tagged by udev as: Keyboard
[ 37.856] (II) event3 - USB USB Keyboard: device is a keyboard
[ 37.858] (II) config/udev: Adding input device USB USB Keyboard Consumer Control (/dev/input/event4)
[ 37.858] (**) USB USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 37.858] (**) USB USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 37.858] (**) USB USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 37.858] (**) USB USB Keyboard Consumer Control: Applying InputClass "Keyboard Defaults"
[ 37.858] (II) Using input driver 'libinput' for 'USB USB Keyboard Consumer Control'
[ 37.858] (**) USB USB Keyboard Consumer Control: always reports core events
[ 37.858] (**) Option "Device" "/dev/input/event4"
[ 37.858] (**) Option "_source" "server/udev"
[ 37.861] (II) event4 - USB USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 37.862] (II) event4 - USB USB Keyboard Consumer Control: device is a keyboard
[ 37.862] (II) event4 - USB USB Keyboard Consumer Control: device removed
[ 37.892] (II) libinput: USB USB Keyboard Consumer Control: needs a virtual subdevice
[ 37.892] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.1/0003:1A2C:2D23.0002/input/input4/event4"
[ 37.892] (II) XINPUT: Adding extended input device "USB USB Keyboard Consumer Control" (type: MOUSE, id 10)
[ 37.892] (**) Option "AccelerationScheme" "none"
[ 37.892] (**) USB USB Keyboard Consumer Control: (accel) selected scheme none/0
[ 37.892] (**) USB USB Keyboard Consumer Control: (accel) acceleration factor: 2.000
[ 37.892] (**) USB USB Keyboard Consumer Control: (accel) acceleration threshold: 4
[ 37.895] (II) event4 - USB USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 37.896] (II) event4 - USB USB Keyboard Consumer Control: device is a keyboard
[ 37.898] (II) config/udev: Adding input device USB USB Keyboard System Control (/dev/input/event5)
[ 37.898] (**) USB USB Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[ 37.898] (**) USB USB Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[ 37.898] (**) USB USB Keyboard System Control: Applying InputClass "system-keyboard"
[ 37.898] (**) USB USB Keyboard System Control: Applying InputClass "Keyboard Defaults"
[ 37.898] (II) Using input driver 'libinput' for 'USB USB Keyboard System Control'
[ 37.898] (**) USB USB Keyboard System Control: always reports core events
[ 37.898] (**) Option "Device" "/dev/input/event5"
[ 37.898] (**) Option "_source" "server/udev"
[ 37.901] (II) event5 - USB USB Keyboard System Control: is tagged by udev as: Keyboard
[ 37.901] (II) event5 - USB USB Keyboard System Control: device is a keyboard
[ 37.902] (II) event5 - USB USB Keyboard System Control: device removed
[ 37.932] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.1/0003:1A2C:2D23.0002/input/input5/event5"
[ 37.932] (II) XINPUT: Adding extended input device "USB USB Keyboard System Control" (type: KEYBOARD, id 11)
[ 37.932] (**) Option "xkb_layout" "br"
[ 37.932] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 37.936] (II) event5 - USB USB Keyboard System Control: is tagged by udev as: Keyboard
[ 37.936] (II) event5 - USB USB Keyboard System Control: device is a keyboard
[ 37.938] (II) config/udev: Adding input device LXD Gaming Mouse (/dev/input/event6)
[ 37.938] (**) LXD Gaming Mouse: Applying InputClass "evdev pointer catchall"
[ 37.938] (**) LXD Gaming Mouse: Applying InputClass "libinput pointer catchall"
[ 37.938] (II) Using input driver 'libinput' for 'LXD Gaming Mouse'
[ 37.938] (**) LXD Gaming Mouse: always reports core events
[ 37.938] (**) Option "Device" "/dev/input/event6"
[ 37.938] (**) Option "_source" "server/udev"
[ 37.998] (II) event6 - LXD Gaming Mouse: is tagged by udev as: Mouse
[ 37.998] (II) event6 - LXD Gaming Mouse: device set to 1000 DPI
[ 37.998] (II) event6 - LXD Gaming Mouse: device is a pointer
[ 37.999] (II) event6 - LXD Gaming Mouse: device removed
[ 38.065] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/0003:1D57:AD17.0003/input/input6/event6"
[ 38.065] (II) XINPUT: Adding extended input device "LXD Gaming Mouse" (type: MOUSE, id 12)
[ 38.066] (**) Option "AccelerationScheme" "none"
[ 38.066] (**) LXD Gaming Mouse: (accel) selected scheme none/0
[ 38.066] (**) LXD Gaming Mouse: (accel) acceleration factor: 2.000
[ 38.066] (**) LXD Gaming Mouse: (accel) acceleration threshold: 4
[ 38.124] (II) event6 - LXD Gaming Mouse: is tagged by udev as: Mouse
[ 38.125] (II) event6 - LXD Gaming Mouse: device set to 1000 DPI
[ 38.125] (II) event6 - LXD Gaming Mouse: device is a pointer
[ 38.127] (II) config/udev: Adding input device LXD Gaming Mouse (/dev/input/mouse0)
[ 38.127] (II) No input driver specified, ignoring this device.
[ 38.127] (II) This device may have been added with another device file.
[ 38.128] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event14)
[ 38.128] (II) No input driver specified, ignoring this device.
[ 38.128] (II) This device may have been added with another device file.
[ 38.129] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event15)
[ 38.129] (II) No input driver specified, ignoring this device.
[ 38.129] (II) This device may have been added with another device file.
[ 38.130] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event16)
[ 38.130] (II) No input driver specified, ignoring this device.
[ 38.130] (II) This device may have been added with another device file.
[ 38.131] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event17)
[ 38.131] (II) No input driver specified, ignoring this device.
[ 38.131] (II) This device may have been added with another device file.
[ 38.131] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event18)
[ 38.132] (II) No input driver specified, ignoring this device.
[ 38.132] (II) This device may have been added with another device file.
[ 38.132] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event19)
[ 38.133] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 38.133] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 38.133] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[ 38.133] (**) Eee PC WMI hotkeys: Applying InputClass "Keyboard Defaults"
[ 38.133] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[ 38.133] (**) Eee PC WMI hotkeys: always reports core events
[ 38.133] (**) Option "Device" "/dev/input/event19"
[ 38.133] (**) Option "_source" "server/udev"
[ 38.134] (II) event19 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[ 38.134] (II) event19 - Eee PC WMI hotkeys: device is a keyboard
[ 38.135] (II) event19 - Eee PC WMI hotkeys: device removed
[ 38.212] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input19/event19"
[ 38.212] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 13)
[ 38.212] (**) Option "xkb_layout" "br"
[ 38.212] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 38.214] (II) event19 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[ 38.214] (II) event19 - Eee PC WMI hotkeys: device is a keyboard
[ 38.216] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[ 38.216] (II) No input driver specified, ignoring this device.
[ 38.216] (II) This device may have been added with another device file.
[ 38.230] (**) USB USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 38.230] (**) USB USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 38.230] (**) USB USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 38.230] (**) USB USB Keyboard Consumer Control: Applying InputClass "Keyboard Defaults"
[ 38.230] (II) Using input driver 'libinput' for 'USB USB Keyboard Consumer Control'
[ 38.230] (**) USB USB Keyboard Consumer Control: always reports core events
[ 38.230] (**) Option "Device" "/dev/input/event4"
[ 38.230] (**) Option "_source" "_driver/libinput"
[ 38.230] (II) libinput: USB USB Keyboard Consumer Control: is a virtual subdevice
[ 38.230] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.1/0003:1A2C:2D23.0002/input/input4/event4"
[ 38.230] (II) XINPUT: Adding extended input device "USB USB Keyboard Consumer Control" (type: KEYBOARD, id 14)
[ 38.230] (**) Option "xkb_layout" "br"
[ 38.230] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 58.671] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 58.671] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 58.671] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 58.701] (--) NVIDIA(GPU-0): Samsung S24D332 (DFP-1): connected
[ 58.701] (--) NVIDIA(GPU-0): Samsung S24D332 (DFP-1): Internal TMDS
[ 58.701] (--) NVIDIA(GPU-0): Samsung S24D332 (DFP-1): 600.0 MHz maximum pixel clock
[ 58.701] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 58.701] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 58.701] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[ 58.701] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 58.701] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 58.701] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 64.674] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 64.674] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 64.674] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 64.704] (--) NVIDIA(GPU-0): Samsung S24D332 (DFP-1): connected
[ 64.704] (--) NVIDIA(GPU-0): Samsung S24D332 (DFP-1): Internal TMDS
[ 64.704] (--) NVIDIA(GPU-0): Samsung S24D332 (DFP-1): 600.0 MHz maximum pixel clock
[ 64.704] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 64.704] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 64.704] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[ 64.704] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 64.704] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 64.705] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 65.546] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 65.546] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 65.546] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 65.579] (--) NVIDIA(GPU-0): Samsung S24D332 (DFP-1): connected
[ 65.579] (--) NVIDIA(GPU-0): Samsung S24D332 (DFP-1): Internal TMDS
[ 65.579] (--) NVIDIA(GPU-0): Samsung S24D332 (DFP-1): 600.0 MHz maximum pixel clock
[ 65.579] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 65.579] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 65.579] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[ 65.579] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 65.579] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 65.579] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 80.515] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 80.515] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 80.515] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 80.546] (--) NVIDIA(GPU-0): Samsung S24D332 (DFP-1): connected
[ 80.546] (--) NVIDIA(GPU-0): Samsung S24D332 (DFP-1): Internal TMDS
[ 80.546] (--) NVIDIA(GPU-0): Samsung S24D332 (DFP-1): 600.0 MHz maximum pixel clock
[ 80.546] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 80.546] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 80.546] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[ 80.547] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 80.547] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 80.547] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 105.552] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 105.552] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 105.552] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 105.585] (--) NVIDIA(GPU-0): Samsung S24D332 (DFP-1): connected
[ 105.586] (--) NVIDIA(GPU-0): Samsung S24D332 (DFP-1): Internal TMDS
[ 105.586] (--) NVIDIA(GPU-0): Samsung S24D332 (DFP-1): 600.0 MHz maximum pixel clock
[ 105.586] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 105.586] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 105.586] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[ 105.586] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 105.586] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 105.586] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 196.335] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 196.335] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 196.335] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 196.365] (--) NVIDIA(GPU-0): Samsung S24D332 (DFP-1): connected
[ 196.365] (--) NVIDIA(GPU-0): Samsung S24D332 (DFP-1): Internal TMDS
[ 196.365] (--) NVIDIA(GPU-0): Samsung S24D332 (DFP-1): 600.0 MHz maximum pixel clock
[ 196.365] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 196.365] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 196.365] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[ 196.365] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 196.365] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 196.365] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 206.380] (EE) client bug: timer event6 debounce: scheduled expiry is in the past (-6ms), your system is too slow
[ 206.381] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-19ms), your system is too slow
[ 229.324] (EE) event6 - LXD Gaming Mouse: client bug: event processing lagging behind by 15ms, your system is too slow
[ 229.324] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-3ms), your system is too slow
[ 556.188] (EE) event6 - LXD Gaming Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[ 641.364] (EE) event6 - LXD Gaming Mouse: client bug: event processing lagging behind by 14ms, your system is too slow
[ 782.544] (EE) event6 - LXD Gaming Mouse: client bug: event processing lagging behind by 14ms, your system is too slow
[ 793.661] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 793.661] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 793.661] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 793.690] (--) NVIDIA(GPU-0): Samsung S24D332 (DFP-1): connected
[ 793.690] (--) NVIDIA(GPU-0): Samsung S24D332 (DFP-1): Internal TMDS
[ 793.691] (--) NVIDIA(GPU-0): Samsung S24D332 (DFP-1): 600.0 MHz maximum pixel clock
[ 793.691] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 793.691] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 793.691] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[ 793.691] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 793.691] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 793.691] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 977.154] (EE) event6 - LXD Gaming Mouse: client bug: event processing lagging behind by 13ms, your system is too slow
[ 977.154] (EE) event6 - LXD Gaming Mouse: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 1644.200] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-5ms), your system is too slow
[ 1679.058] (II) event6 - LXD Gaming Mouse: Enabling spurious button debouncing, see https://wayland.freedesktop.org/libinput/doc/1.17.2/button-debouncing.html for details
ip addr
rfkill list
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eno1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether a8:5e:45:1e:35:51 brd ff:ff:ff:ff:ff:ff
altname enp0s31f6
3: wlp4s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether d0:37:45:45:db:99 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.71/24 brd 192.168.1.255 scope global dynamic noprefixroute wlp4s0
valid_lft 3465sec preferred_lft 3465sec
inet6 2804:d45:a1c0:f600:59a:21bc:532:9bec/64 scope global dynamic noprefixroute
valid_lft 3468sec preferred_lft 3468sec
inet6 fe80::b9e0:36ae:1dfc:77cf/64 scope link noprefixroute
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
lspci -v
altname enp0s31f6
Soft blocked: no
Hard blocked: no
[netvor@netvorsystem ~]$ xinput
bash: xinput: comando nĂŁo encontrado
[netvor@netvorsystem ~]$ lspci -v
00:00.0 Host bridge: Intel Corporation 8th Gen Core Processor Host Bridge/DRAM Registers (rev 0d)
DeviceName: Onboard - Other
Subsystem: ASUSTeK Computer Inc. PRIME H310M-D
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
Kernel driver in use: skl_uncore
Kernel modules: ie31200_edac
00:01.0 PCI bridge: Intel Corporation 6th-9th Gen Core Processor PCIe Controller (x16) (rev 0d) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 120
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00004000-00004fff [size=4K]
Memory behind bridge: a3000000-a40fffff [size=17M]
Prefetchable memory behind bridge: 0000000090000000-00000000a20fffff [size=289M]
Kernel driver in use: pcieport
00:14.0 USB controller: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller (rev 10) (prog-if 30 [XHCI])
Subsystem: ASUSTeK Computer Inc. Device 8694
Flags: bus master, medium devsel, latency 0, IRQ 126
Memory at a4320000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:14.2 RAM memory: Intel Corporation Cannon Lake PCH Shared SRAM (rev 10)
Flags: fast devsel
Memory at a4336000 (64-bit, non-prefetchable) [disabled] [size=8K]
Memory at a433c000 (64-bit, non-prefetchable) [disabled] [size=4K]
00:16.0 Communication controller: Intel Corporation Cannon Lake PCH HECI Controller (rev 10)
Flags: bus master, fast devsel, latency 0, IRQ 129
Memory at a433b000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: mei_me
Kernel modules: mei_me
00:17.0 SATA controller: Intel Corporation Cannon Lake PCH SATA AHCI Controller (rev 10) (prog-if 01 [AHCI 1.0])
DeviceName: Onboard - SATA
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 125
Memory at a4334000 (32-bit, non-prefetchable) [size=8K]
Memory at a433a000 (32-bit, non-prefetchable) [size=256]
I/O ports at 5050 [size=8]
I/O ports at 5040 [size=4]
I/O ports at 5020 [size=32]
Memory at a4339000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
00:1b.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #21 (rev f0) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 121
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00006000-00006fff [size=4K]
Memory behind bridge: a2100000-a22fffff [size=2M]
Prefetchable memory behind bridge: 00000000a2300000-00000000a24fffff [size=2M]
00:1c.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #5 (rev f0) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 122
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: [disabled]
Memory behind bridge: [disabled]
Prefetchable memory behind bridge: [disabled]
00:1c.5 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #6 (rev f0) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 123
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
I/O behind bridge: 00003000-00003fff [size=4K]
Memory behind bridge: a4200000-a42fffff [size=1M]
00:1d.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #9 (rev f0) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 124
Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
I/O behind bridge: 00007000-00007fff [size=4K]
Memory behind bridge: a2500000-a26fffff [size=2M]
Prefetchable memory behind bridge: 00000000a2700000-00000000a28fffff [size=2M]
00:1f.0 ISA bridge: Intel Corporation Device a308 (rev 10)
00:1f.3 Audio device: Intel Corporation Cannon Lake PCH cAVS (rev 10)
DeviceName: Onboard - Sound
Subsystem: ASUSTeK Computer Inc. Device 86c7
Flags: bus master, fast devsel, latency 32, IRQ 131
Memory at a4330000 (64-bit, non-prefetchable) [size=16K]
Memory at a4100000 (64-bit, non-prefetchable) [size=1M]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_soc_skl, snd_sof_pci_intel_cnl
00:1f.4 SMBus: Intel Corporation Cannon Lake PCH SMBus Controller (rev 10)
Flags: medium devsel, IRQ 16
Memory at a4338000 (64-bit, non-prefetchable) [size=256]
I/O ports at efa0 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
00:1f.5 Serial bus controller [0c80]: Intel Corporation Cannon Lake PCH SPI Controller (rev 10)
Flags: fast devsel
Memory at fe010000 (32-bit, non-prefetchable) [size=4K]
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (7) I219-V (rev 10)
DeviceName: Onboard - Ethernet
Subsystem: ASUSTeK Computer Inc. Device 8672
Flags: bus master, fast devsel, latency 0, IRQ 128
Memory at a4300000 (32-bit, non-prefetchable) [size=128K]
Kernel driver in use: e1000e
Kernel modules: e1000e
01:00.0 VGA compatible controller: NVIDIA Corporation TU106 [GeForce RTX 2060 Rev. A] (rev a1) (prog-if 00 [VGA controller])
Subsystem: NVIDIA Corporation Device 12fd
Flags: bus master, fast devsel, latency 0, IRQ 133
Memory at a3000000 (32-bit, non-prefetchable) [size=16M]
Memory at 90000000 (64-bit, prefetchable) [size=256M]
Memory at a0000000 (64-bit, prefetchable) [size=32M]
I/O ports at 4000 [size=128]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
01:00.1 Audio device: NVIDIA Corporation TU106 High Definition Audio Controller (rev a1)
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at a4080000 (32-bit, non-prefetchable) [size=16K]
01:00.2 USB controller: NVIDIA Corporation TU106 USB 3.1 Host Controller (rev a1) (prog-if 30 [XHCI])
Flags: bus master, fast devsel, latency 0, IRQ 127
Memory at a2000000 (64-bit, prefetchable) [size=256K]
Memory at a2040000 (64-bit, prefetchable) [size=64K]
01:00.3 Serial bus controller [0c80]: NVIDIA Corporation TU106 USB Type-C UCSI Controller (rev a1)
Flags: bus master, fast devsel, latency 0, IRQ 130
Memory at a4084000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: nvidia-gpu
Kernel modules: i2c_nvidia_gpu
04:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8188EE Wireless Network Adapter (rev 01)
Subsystem: Realtek Semiconductor Co., Ltd. Device 8197
Flags: bus master, fast devsel, latency 0, IRQ 132
I/O ports at 3000 [size=256]
Memory at a4200000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: rtl8188ee
Kernel modules: rtl8188ee
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC887-VD Analog [ALC887-VD Analog]
Subdevices: 0/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 1: ALC887-VD Digital [ALC887-VD Digital]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 11: HDMI 5 [HDMI 5]
Subdevices: 1/1
uname -a
Linux netvorsystem 5.12.2-1-MANJARO #1 SMP PREEMPT Fri May 7 17:53:15 UTC 2021 x86_64 GNU/Linux
that’s all i could collect and post (the text limit didn’t let post more info), i’m new to linux so if i did something wrong sorry for that and i am always open to learn more. i hope that someone can help me and that the info that i posted is good enough.
