All,
I recently started having this issue after installing Docker for testing. I’ve since removed Docker and it’s dependencies, but it still continues. Tried to move to a different kernel and update, and still no change in behavior. My wired network adapter will function normally until a point in time where it will go through the following output in dmesg and be offline. Cannot disconnect and reconnect cable, forcing an ip link set down/up does nothing. Only a reboot. Below is the output from dmesg when this happens:
[172392.702635] tg3 0000:01:00.0 enp1s0: 0x00007aa0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
[172392.702638] tg3 0000:01:00.0 enp1s0: 0x00007ab0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
[172392.702641] tg3 0000:01:00.0 enp1s0: 0x00007ac0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
[172392.702645] tg3 0000:01:00.0 enp1s0: 0x00007ad0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
[172392.702648] tg3 0000:01:00.0 enp1s0: 0x00007ae0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
[172392.702652] tg3 0000:01:00.0 enp1s0: 0x00007af0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
[172392.702655] tg3 0000:01:00.0 enp1s0: 0x00007b00: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
[172392.702659] tg3 0000:01:00.0 enp1s0: 0x00007b10: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
[172392.702662] tg3 0000:01:00.0 enp1s0: 0x00007b20: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
[172392.702666] tg3 0000:01:00.0 enp1s0: 0x00007b30: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
[172392.702670] tg3 0000:01:00.0 enp1s0: 0x00007b40: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
[172392.702673] tg3 0000:01:00.0 enp1s0: 0x00007b50: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
[172392.702677] tg3 0000:01:00.0 enp1s0: 0x00007b60: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
[172392.702680] tg3 0000:01:00.0 enp1s0: 0x00007b70: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
[172392.702683] tg3 0000:01:00.0 enp1s0: 0x00007b80: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
[172392.702687] tg3 0000:01:00.0 enp1s0: 0x00007b90: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
[172392.702691] tg3 0000:01:00.0 enp1s0: 0x00007ba0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
[172392.702694] tg3 0000:01:00.0 enp1s0: 0x00007bb0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
[172392.702698] tg3 0000:01:00.0 enp1s0: 0x00007bc0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
[172392.702701] tg3 0000:01:00.0 enp1s0: 0x00007bd0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
[172392.702705] tg3 0000:01:00.0 enp1s0: 0x00007be0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
[172392.702708] tg3 0000:01:00.0 enp1s0: 0x00007bf0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
[172392.702715] tg3 0000:01:00.0 enp1s0: 0: Host status block [00000001:000000fc:(0000:0139:0000):(0139:00d6)]
[172392.702719] tg3 0000:01:00.0 enp1s0: 0: NAPI info [000000fc:000000fc:(00c3:00d6:01ff):0139:(0001:0000:0000:0000)]
[172392.741923] audit: type=1111 audit(1601211971.881:158): pid=569 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-update uuid=ad0879de-f969-3ab6-9c28-b17dc1292c6c name=576972656420636F6E6E656374696F6E2031 result=fail exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=failed'
[172392.806499] tg3 0000:01:00.0: tg3_stop_block timed out, ofs=2c00 enable_bit=2
[172392.910236] tg3 0000:01:00.0: tg3_stop_block timed out, ofs=2000 enable_bit=2
[172393.013987] tg3 0000:01:00.0: tg3_stop_block timed out, ofs=2400 enable_bit=2
[172393.117793] tg3 0000:01:00.0: tg3_stop_block timed out, ofs=2800 enable_bit=2
[172393.221478] tg3 0000:01:00.0: tg3_stop_block timed out, ofs=3000 enable_bit=2
[172393.325158] tg3 0000:01:00.0: tg3_stop_block timed out, ofs=1400 enable_bit=2
[172393.428787] tg3 0000:01:00.0: tg3_stop_block timed out, ofs=1800 enable_bit=2
[172393.532442] tg3 0000:01:00.0: tg3_stop_block timed out, ofs=c00 enable_bit=2
[172393.636101] tg3 0000:01:00.0: tg3_stop_block timed out, ofs=4800 enable_bit=2
[172393.739728] tg3 0000:01:00.0: tg3_stop_block timed out, ofs=1000 enable_bit=2
[172393.843381] tg3 0000:01:00.0: tg3_stop_block timed out, ofs=1c00 enable_bit=2
[172393.947088] tg3 0000:01:00.0: tg3_abort_hw timed out, TX_MODE_ENABLE will not clear MAC_TX_MODE=ffffffff
[172394.050747] tg3 0000:01:00.0: tg3_stop_block timed out, ofs=3c00 enable_bit=2
[172394.154425] tg3 0000:01:00.0: tg3_stop_block timed out, ofs=4c00 enable_bit=2
[172395.720295] tg3 0000:01:00.0 enp1s0: No firmware running
[172396.963903] tg3 0000:01:00.0: tg3_abort_hw timed out, TX_MODE_ENABLE will not clear MAC_TX_MODE=ffffffff
[172412.723486] tg3 0000:01:00.0 enp1s0: Link is down
[172418.839213] audit: type=1130 audit(1601211997.964:159): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[172429.183698] audit: type=1131 audit(1601212008.306:160): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
