Hello, I’m having issues with using my Wifi adapter on Manjaro. It works fine when I plug it into a USB 2 port, but does not work when I plug it into USB 3. Anytime I plug it in it will start to connect to Wifi, but immediately disconnect once it does. The adapter works completely fine on USB 3 on Windows so I know the adapter or port itself isn’t broken. Is there any way to fix this? (Tried also updating BIOs albeit to no result.)
Output of inxi -Fazy
Kernel: 5.7.17-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
root=UUID=32719104-3641-4b1d-ad76-94db0d43c947 rw quiet apparmor=1
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop Mobo: ASRock model: 970M Pro3 serial: <filter>
UEFI [Legacy]: American Megatrends v: P1.60 date: 06/17/2016
Topology: 6-Core model: AMD FX-6300 bits: 64 type: MCP arch: Bulldozer
family: 15 (21) model-id: 2 stepping: N/A microcode: 6000852
L2 cache: 2048 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 41927
Speed: 1548 MHz min/max: 1400/3500 MHz boost: enabled Core speeds (MHz):
1: 1452 2: 1457 3: 3791 4: 3792 5: 3791 6: 3791
disabled, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel bus ID: 01:00.0 chip ID: 1002:67df
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: amdgpu
FAILED: ati unloaded: modesetting,radeon alternate: fbdev,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 676x380mm (26.6x15.0")
s-diag: 775mm (30.5")
Monitor-1: DisplayPort-0 res: 2560x1440 hz: 60 dpi: 105
size: 621x341mm (24.4x13.4") diag: 708mm (27.9")
OpenGL: renderer: Radeon RX 580 Series (POLARIS10 DRM 3.37.0
5.7.17-2-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.6 direct render: Yes
Device-1: AMD SBx00 Azalia vendor: ASRock driver: snd_hda_intel v: kernel
bus ID: 00:14.2 chip ID: 1002:4383
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 1002:aaf0
Sound Server: ALSA v: k5.7.17-2-MANJARO
vendor: ASRock driver: r8169 v: kernel port: d000 bus ID: 05:00.0
chip ID: 10ec:8168
IF: enp5s0 state: down mac: <filter>
Device-2: NetGear A6210 type: USB driver: mt76x2u bus ID: 4-2:8
chip ID: 0846:9053 serial: <filter>
IF: wlp0s19f2u2 state: up mac: <filter>
Local Storage: total: 931.51 GiB used: 47.75 GiB (5.1%)
ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-08WN4A0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: 1A02 scheme: GPT
ID-1: / raw size: 188.48 GiB size: 184.52 GiB (97.90%)
used: 47.73 GiB (25.9%) fs: ext4 dev: /dev/sda5
System Temperatures: cpu: 42.0 C mobo: N/A gpu: amdgpu temp: 43 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 764
Processes: 218 Uptime: 1h 47m Memory: 15.61 GiB used: 2.85 GiB (18.2%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1295 lib: 328
flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
Output of sudo dmesg | grep usb
[ 0.480554] usbcore: registered new interface driver usbfs
[ 0.480554] usbcore: registered new interface driver hub
[ 0.480554] usbcore: registered new device driver usb
[ 0.530023] pci 0000:00:12.0: quirk_usb_early_handoff+0x0/0x6d5 took 18659 usecs
[ 0.546682] pci 0000:00:13.0: quirk_usb_early_handoff+0x0/0x6d5 took 16075 usecs
[ 0.563352] pci 0000:00:14.5: quirk_usb_early_handoff+0x0/0x6d5 took 16103 usecs
[ 0.580011] pci 0000:00:16.0: quirk_usb_early_handoff+0x0/0x6d5 took 16258 usecs
[ 0.726709] usbcore: registered new interface driver usbserial_generic
[ 0.726714] usbserial: USB Serial support registered for generic
[ 1.430043] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.07
[ 1.430045] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.430046] usb usb1: Product: EHCI Host Controller
[ 1.430047] usb usb1: Manufacturer: Linux 5.7.17-2-MANJARO ehci_hcd
[ 1.430048] usb usb1: SerialNumber: 0000:00:12.2
[ 1.430723] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.07
[ 1.430724] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.430725] usb usb2: Product: xHCI Host Controller
[ 1.430726] usb usb2: Manufacturer: Linux 5.7.17-2-MANJARO xhci-hcd
[ 1.430727] usb usb2: SerialNumber: 0000:02:00.0
[ 1.431038] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.431070] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.07
[ 1.431071] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.431072] usb usb3: Product: xHCI Host Controller
[ 1.431073] usb usb3: Manufacturer: Linux 5.7.17-2-MANJARO xhci-hcd
[ 1.431074] usb usb3: SerialNumber: 0000:02:00.0
[ 1.446653] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.07
[ 1.446654] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.446655] usb usb4: Product: EHCI Host Controller
[ 1.446656] usb usb4: Manufacturer: Linux 5.7.17-2-MANJARO ehci_hcd
[ 1.446657] usb usb4: SerialNumber: 0000:00:13.2
[ 1.459976] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.07
[ 1.459978] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.459979] usb usb5: Product: EHCI Host Controller
[ 1.459980] usb usb5: Manufacturer: Linux 5.7.17-2-MANJARO ehci_hcd
[ 1.459981] usb usb5: SerialNumber: 0000:00:16.2
[ 1.520678] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.07
[ 1.520680] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.520681] usb usb6: Product: OHCI PCI host controller
[ 1.520682] usb usb6: Manufacturer: Linux 5.7.17-2-MANJARO ohci_hcd
[ 1.520683] usb usb6: SerialNumber: 0000:00:12.0
[ 1.580690] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.07
[ 1.580692] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.580694] usb usb7: Product: OHCI PCI host controller
[ 1.580695] usb usb7: Manufacturer: Linux 5.7.17-2-MANJARO ohci_hcd
[ 1.580696] usb usb7: SerialNumber: 0000:00:13.0
[ 1.657364] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.07
[ 1.657366] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.657367] usb usb8: Product: OHCI PCI host controller
[ 1.657368] usb usb8: Manufacturer: Linux 5.7.17-2-MANJARO ohci_hcd
[ 1.657369] usb usb8: SerialNumber: 0000:00:14.5
[ 1.720672] usb usb9: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.07
[ 1.720674] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.720675] usb usb9: Product: OHCI PCI host controller
[ 1.720676] usb usb9: Manufacturer: Linux 5.7.17-2-MANJARO ohci_hcd
[ 1.720677] usb usb9: SerialNumber: 0000:00:16.0
[ 1.779959] usb 3-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 1.797050] usb 3-1: New USB device found, idVendor=0846, idProduct=9053, bcdDevice= 1.00
[ 1.797052] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.797053] usb 3-1: Product: A6210
[ 1.797054] usb 3-1: Manufacturer: NETGEAR
[ 1.797055] usb 3-1: SerialNumber: 100
[ 2.059920] usb 7-3: new full-speed USB device number 2 using ohci-pci
[ 2.076594] usb 9-1: new full-speed USB device number 2 using ohci-pci
[ 2.243629] usb 7-3: New USB device found, idVendor=258a, idProduct=0036, bcdDevice= 1.00
[ 2.243631] usb 7-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.243632] usb 7-3: Product: Wired Gaming Mouse
[ 2.243633] usb 7-3: Manufacturer: SINOWEALTH
[ 2.260883] usbcore: registered new interface driver usbhid
[ 2.260884] usbhid: USB HID core driver
[ 2.262613] input: SINOWEALTH Wired Gaming Mouse as /devices/pci0000:00/0000:00:13.0/usb7/7-3/7-3:1.0/0003:258A:0036.0001/input/input2
[ 2.262658] hid-generic 0003:258A:0036.0001: input,hidraw0: USB HID v1.11 Mouse [SINOWEALTH Wired Gaming Mouse] on usb-0000:00:13.0-3/input0
[ 2.262943] input: SINOWEALTH Wired Gaming Mouse Keyboard as /devices/pci0000:00/0000:00:13.0/usb7/7-3/7-3:1.1/0003:258A:0036.0002/input/input3
[ 2.268635] usb 9-1: New USB device found, idVendor=1532, idProduct=0203, bcdDevice= 2.00
[ 2.268637] usb 9-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.268638] usb 9-1: Product: Razer BlackWidow Chroma
[ 2.268639] usb 9-1: Manufacturer: Razer
[ 2.274924] input: Razer Razer BlackWidow Chroma as /devices/pci0000:00/0000:00:16.0/usb9/9-1/9-1:1.0/0003:1532:0203.0003/input/input6
[ 2.316689] hid-generic 0003:258A:0036.0002: input,hiddev0,hidraw1: USB HID v1.11 Keyboard [SINOWEALTH Wired Gaming Mouse] on usb-0000:00:13.0-3/input1
[ 2.373319] hid-generic 0003:1532:0203.0003: input,hidraw2: USB HID v1.11 Keyboard [Razer Razer BlackWidow Chroma] on usb-0000:00:16.0-1/input0
[ 2.374639] input: Glorious Model O as /devices/pci0000:00/0000:00:13.0/usb7/7-3/7-3:1.0/0003:258A:0036.0001/input/input7
[ 2.374675] glorious 0003:258A:0036.0001: input,hidraw0: USB HID v1.11 Mouse [Glorious Model O] on usb-0000:00:13.0-3/input0
[ 2.376179] input: Razer Razer BlackWidow Chroma Keyboard as /devices/pci0000:00/0000:00:16.0/usb9/9-1/9-1:1.1/0003:1532:0203.0004/input/input8
[ 2.417053] input: Glorious Model O Keyboard as /devices/pci0000:00/0000:00:13.0/usb7/7-3/7-3:1.1/0003:258A:0036.0002/input/input12
[ 2.473306] input: Razer Razer BlackWidow Chroma Consumer Control as /devices/pci0000:00/0000:00:16.0/usb9/9-1/9-1:1.1/0003:1532:0203.0004/input/input9
[ 2.529965] input: Razer Razer BlackWidow Chroma System Control as /devices/pci0000:00/0000:00:16.0/usb9/9-1/9-1:1.1/0003:1532:0203.0004/input/input10
[ 2.529967] input: Glorious Model O Consumer Control as /devices/pci0000:00/0000:00:13.0/usb7/7-3/7-3:1.1/0003:258A:0036.0002/input/input13
[ 2.529998] input: Razer Razer BlackWidow Chroma as /devices/pci0000:00/0000:00:16.0/usb9/9-1/9-1:1.1/0003:1532:0203.0004/input/input11
[ 2.530037] hid-generic 0003:1532:0203.0004: input,hidraw1: USB HID v1.11 Keyboard [Razer Razer BlackWidow Chroma] on usb-0000:00:16.0-1/input1
[ 2.530071] glorious 0003:258A:0036.0002: input,hiddev0,hidraw3: USB HID v1.11 Keyboard [Glorious Model O] on usb-0000:00:13.0-3/input1
[ 2.532926] input: Razer Razer BlackWidow Chroma as /devices/pci0000:00/0000:00:16.0/usb9/9-1/9-1:1.2/0003:1532:0203.0005/input/input15
[ 2.532972] hid-generic 0003:1532:0203.0005: input,hidraw4: USB HID v1.11 Mouse [Razer Razer BlackWidow Chroma] on usb-0000:00:16.0-1/input2
[ 15.284900] input: Razer Razer BlackWidow Chroma as /devices/pci0000:00/0000:00:16.0/usb9/9-1/9-1:1.0/0003:1532:0203.0003/input/input28
[ 15.340293] razerkbd 0003:1532:0203.0003: input,hidraw2: USB HID v1.11 Keyboard [Razer Razer BlackWidow Chroma] on usb-0000:00:16.0-1/input0
[ 15.570552] input: Razer Razer BlackWidow Chroma as /devices/pci0000:00/0000:00:16.0/usb9/9-1/9-1:1.1/0003:1532:0203.0004/input/input29
[ 15.626884] razerkbd 0003:1532:0203.0004: input,hidraw1: USB HID v1.11 Keyboard [Razer Razer BlackWidow Chroma] on usb-0000:00:16.0-1/input1
[ 15.673369] input: Razer Razer BlackWidow Chroma as /devices/pci0000:00/0000:00:16.0/usb9/9-1/9-1:1.2/0003:1532:0203.0005/input/input30
[ 15.673689] razerkbd 0003:1532:0203.0005: input,hidraw4: USB HID v1.11 Mouse [Razer Razer BlackWidow Chroma] on usb-0000:00:16.0-1/input2
[ 15.756964] usb 3-1: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 208.013382] usb 3-1: USB disconnect, device number 2
[ 208.793253] usb 4-2: new high-speed USB device number 3 using ehci-pci
[ 208.941695] usb 4-2: New USB device found, idVendor=0846, idProduct=9053, bcdDevice= 1.00
[ 208.941702] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 208.941707] usb 4-2: Product: A6210
[ 208.941711] usb 4-2: Manufacturer: NETGEAR
[ 208.941715] usb 4-2: SerialNumber: 100
[ 209.073334] usb 4-2: reset high-speed USB device number 3 using ehci-pci
[ 219.192381] usbcore: registered new interface driver mt76x2u
[ 591.512469] usb 4-2: USB disconnect, device number 3
[ 593.670621] usb 3-1: new SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 593.688294] usb 3-1: New USB device found, idVendor=0846, idProduct=9053, bcdDevice= 1.00
[ 593.688300] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 593.688303] usb 3-1: Product: A6210
[ 593.688306] usb 3-1: Manufacturer: NETGEAR
[ 593.688309] usb 3-1: SerialNumber: 100
[ 593.810814] usb 3-1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 613.937173] usb 3-1: USB disconnect, device number 3
[ 615.773556] usb 4-2: new high-speed USB device number 4 using ehci-pci
[ 615.921546] usb 4-2: New USB device found, idVendor=0846, idProduct=9053, bcdDevice= 1.00
[ 615.921552] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 615.921556] usb 4-2: Product: A6210
[ 615.921559] usb 4-2: Manufacturer: NETGEAR
[ 615.921562] usb 4-2: SerialNumber: 100
[ 616.050236] usb 4-2: reset high-speed USB device number 4 using ehci-pci
[ 798.406962] usb 4-2: USB disconnect, device number 4
[ 800.283213] usb 3-1: new SuperSpeed Gen 1 USB device number 4 using xhci_hcd
[ 800.300927] usb 3-1: New USB device found, idVendor=0846, idProduct=9053, bcdDevice= 1.00
[ 800.300933] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 800.300936] usb 3-1: Product: A6210
[ 800.300939] usb 3-1: Manufacturer: NETGEAR
[ 800.300942] usb 3-1: SerialNumber: 100
[ 800.423401] usb 3-1: reset SuperSpeed Gen 1 USB device number 4 using xhci_hcd
[ 924.276835] usb 3-1: USB disconnect, device number 4
[ 925.711150] usb 4-2: new high-speed USB device number 5 using ehci-pci
[ 925.859232] usb 4-2: New USB device found, idVendor=0846, idProduct=9053, bcdDevice= 1.00
[ 925.859238] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 925.859242] usb 4-2: Product: A6210
[ 925.859245] usb 4-2: Manufacturer: NETGEAR
[ 925.859247] usb 4-2: SerialNumber: 100
[ 925.987826] usb 4-2: reset high-speed USB device number 5 using ehci-pci
[ 5385.624394] usb 4-2: USB disconnect, device number 5
[ 5386.971461] usb 3-1: new SuperSpeed Gen 1 USB device number 5 using xhci_hcd
[ 5386.989126] usb 3-1: New USB device found, idVendor=0846, idProduct=9053, bcdDevice= 1.00
[ 5386.989132] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5386.989135] usb 3-1: Product: A6210
[ 5386.989138] usb 3-1: Manufacturer: NETGEAR
[ 5386.989141] usb 3-1: SerialNumber: 100
[ 5387.111642] usb 3-1: reset SuperSpeed Gen 1 USB device number 5 using xhci_hcd
[ 5525.875060] usb 3-1: USB disconnect, device number 5
[ 5574.144732] usb 4-2: new high-speed USB device number 6 using ehci-pci
[ 5574.299407] usb 4-2: New USB device found, idVendor=0846, idProduct=9053, bcdDevice= 1.00
[ 5574.299413] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5574.299417] usb 4-2: Product: A6210
[ 5574.299420] usb 4-2: Manufacturer: NETGEAR
[ 5574.299423] usb 4-2: SerialNumber: 100
[ 5574.428075] usb 4-2: reset high-speed USB device number 6 using ehci-pci
[ 5692.486180] usb 4-2: USB disconnect, device number 6
[ 5747.208040] usb 4-2: new high-speed USB device number 7 using ehci-pci
[ 5747.355971] usb 4-2: New USB device found, idVendor=0846, idProduct=9053, bcdDevice= 1.00
[ 5747.355978] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5747.355981] usb 4-2: Product: A6210
[ 5747.355984] usb 4-2: Manufacturer: NETGEAR
[ 5747.355987] usb 4-2: SerialNumber: 100
[ 5747.484732] usb 4-2: reset high-speed USB device number 7 using ehci-pci
[ 5852.737577] usb 4-2: USB disconnect, device number 7
[ 5901.064731] usb 4-2: new high-speed USB device number 8 using ehci-pci
[ 5901.216175] usb 4-2: New USB device found, idVendor=0846, idProduct=9053, bcdDevice= 1.00
[ 5901.216181] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5901.216185] usb 4-2: Product: A6210
[ 5901.216188] usb 4-2: Manufacturer: NETGEAR
[ 5901.216191] usb 4-2: SerialNumber: 100
[ 5901.344740] usb 4-2: reset high-speed USB device number 8 using ehci-pci
[ 6719.223370] usb 4-2: USB disconnect, device number 8
Output of lsusb
when plugged into 3.0
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 009 Device 002: ID 1532:0203 Razer USA, Ltd BlackWidow Chroma
Bus 009 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 002: ID 258a:0036 SINOWEALTH Wired Gaming Mouse
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Output of lsusb when plugged into 2.0
Bus 004 Device 010: ID 0846:9053 NetGear, Inc. A6210
